path: root/drivers/i2c
2012-03-22Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm main changes from Dave Airlie: "This is the main drm pull request, I'm probably going to send two more smaller ones, will explain below. This contains a patch that is also in the fbdev tree, but it should be the same patch, it added an API for hot unplugging framebuffer devices, and I need that API for a new driver. It also contains some changes to the i2c tree which Jean has acked, and one change to moorestown platform stuff in x86. Highlights: - new drivers: UDL driver for USB displaylink devices, kms only, should support correct hotplug operations. - core: i2c speedups + better hotplug support, EDID overriding via firmware interface - allows user to load a firmware for a broken monitor/kvm from userspace, it even has documentation for it. - exynos: new HDMI audio + hdmi 1.4 + virtual output driver - gma500: code cleanup - radeon: cleanups, CS optimisations, streamout support and pageflip fix - nouveau: NVD9 displayport support + more reclocking work - i915: re-enabling GMBUS, finish gpu patch (might help hibernation who knows), missed irq fixes, stencil tiling fixes, interlaced support, aliasesd PPGTT support for SNB/IVB, swizzling for SNB/IVB, semaphore fixes As well as the usual bunch of cleanups and fixes all over the place. I've got two things I'd like to merge a bit later: a) AMD support for all their new radeonhd 7000 series GPU and APUs. AMD dropped this a bit late due to insane internal review processes, (please AMD just follow Intel and let open source guys ship stuff early) however I don't want to penalise people who own this hardware (since its been on sale for 3-4 months and GPU hw doesn't exactly have a lifetime in years) and consign them to using closed drivers for longer than necessary. The changes are well contained and just plug into the driver new gpu functionality so they should be fairly regression proof. I just want to give them a bit of a run on the hw AMD kindly sent me. b) drm prime/dma-buf interface code. This is just infrastructure code to expose the dma-buf stuff to drm drivers and to userspace. I'm not planning on pushing any driver support in this cycle (except maybe exynos), but I'd like to get the infrastructure code in so for the next cycle I can start getting the driver support into the individual drivers. We have started driver support for i915, nouveau and udl along with I think exynos and omap in staging. However this code relies on the dma-buf tree being pulled into your tree first since it needs the latest interfaces from that tree. I'll push to get that tree sent asap. (oh and any warnings you see in i915 are gcc's fault from what anyone can see)." Fix up trivial conflicts in arch/x86/platform/mrst/mrst.c due to the new msic_thermal_platform_data() thermal function being added next to the tc35876x_platform_data() i2c device function.. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (326 commits) drm/i915: use DDC_ADDR instead of hard-coding it drm/radeon: use DDC_ADDR instead of hard-coding it drm: remove unneeded redefinition of DDC_ADDR drm/exynos: added virtual display driver. drm: allow loading an EDID as firmware to override broken monitor drm/exynos: enable hdmi audio feature drm/exynos: add default pixel format for plane drm/exynos: cleanup exynos_hdmi.h drm/exynos: add is_local member in exynos_drm_subdrv struct drm/exynos: add subdrv open/close functions drm/exynos: remove module of exynos drm subdrv drm/exynos: release pending pageflip events when closed drm/exynos: added new funtion to get/put dma address. drm/exynos: update gem and buffer framework. drm/exynos: added mode_fixup feature and code clean. drm/exynos: add HDMI version 1.4 support drm/exynos: remove exynos_mixer.h gma500: Fix mmap frambuffer drm/radeon: Drop radeon_gem_object_(un)pin. drm/radeon: Restrict offset for legacy display engine. ...
2012-03-20Merge tag 'drm-intel-next-2012-03-01' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next * tag 'drm-intel-next-2012-03-01' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: Only clear the GPU domains upon a successful finish drm/i915: reenable gmbus on gen3+ again drm/i915: i2c: unconditionally set up gpio fallback drm/i915: merge gmbus and gpio i2c adpater into one drm/i915: merge struct intel_gpio into struct intel_gmbus i2c: export bit-banging algo functions drm/nouveau: do a better job at hiding the NIH i2c bit-banging algo drm/i915: add dev_priv to intel_gmbus drm/i915: Fix single msg gmbus_xfers writes drm/i915: error_buffer->ring should be signed drm/i915: Silence the error message from i915_wait_request() drm/i915: use the new hdmi_force_audio enum more drm/i915: No need to search again after retiring requests drm/i915: Only bump refcnt on objects scheduled for eviction drm/i915/bios: Downgrade the "signature missing" DRM_ERROR to debug drm/i915: Ignore LVDS on hp t5745 and hp st5747 thin client drm/i915: Fixes distorted external screen image on HP 2730p
2012-03-15i2c-algo-bit: Fix spurious SCL timeouts under heavy loadVille Syrjala
When the system is under heavy load, there can be a significant delay between the getscl() and time_after() calls inside sclhi(). That delay may cause the time_after() check to trigger after SCL has gone high, causing sclhi() to return -ETIMEDOUT. To fix the problem, double check that SCL is still low after the timeout has been reached, before deciding to return -ETIMEDOUT. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: stable@vger.kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-03-15i2c-core: Comment says "transmitted" but means "received"Wolfram Sang
Fix that. Also convert this and the related comment to proper commenting style. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-02-29i2c: export bit-banging algo functionsDaniel Vetter
i915 has a hw i2c controller (gmbus) but for a bunch of stupid reasons we need to be able to fall back to the bit-banging algo on gpio pins. The current code sets up a 2nd i2c controller for the same i2c bus using the bit-banging algo. This has a bunch of issues, the major one being that userspace can directly access this fallback i2c adaptor behind the drivers back. But we need to frob a few registers before and after using fallback gpio bit-banging, so this horribly fails. The new plan is to only set up one i2c adaptor and transparently fall back to bit-banging by directly calling the xfer function of the bit- banging algo in the i2c core. To make that possible, export the 2 i2c algo functions. v2: As suggested by Jean Delvare, simply export the i2c_bit_algo vtable instead of the individual functions. Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-24i2c: mxs: only flag completion when queue is completely doneWolfram Sang
The hardware generates an interrupt for every completed command in the queue while the code assumed that it will only generate one interrupt when the queue is empty. So, explicitly check if the queue is really empty. This patch fixed problems which occurred due to high traffic on the bus. While we are here, move the completion-initialization after the parameter error checking. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Lothar Waßmann <LW@KARO-electronics.de> Cc: stable@kernel.org
2012-02-13Merge branch 'fixes' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra into fixes * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra: ARM: tegra: paz00: fix wrong UART port on mini-pcie plug ARM: tegra: paz00: fix wrong SD1 power gpio i2c: tegra: Add devexit_p() for remove ARM: tegra: dma: fix buildbreak for !CONFIG_TEGRA_SYSTEM_DMA
2012-02-06i2c: tegra: Add devexit_p() for removeShubhrajyoti Datta
It was originally missed in the __devinit/__devexit annotations. Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-20i2c: OMAP: Fix OMAP1 build errorCousson, Benoit
CONFIG_OF is not defined for OMAP1 yet and thus the omap1_defconfig build generate an error for 3.3-rc1. drivers/i2c/busses/i2c-omap.c: In function 'omap_i2c_probe': drivers/i2c/busses/i2c-omap.c:1021:26: error: 'omap_i2c_of_match' undeclared (first use in this function) drivers/i2c/busses/i2c-omap.c:1021:26: note: each undeclared identifier is reported only once for each function it appears in Wrap omap_i2c_of_match with of_match_ptr() to prevent compilation error in case of OMAP1 build. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-17Merge branches 'for-33/i2c/eg20t' and 'for-33/i2c/omap' into for-linus/i2c-33Ben Dooks
2012-01-17i2c-eg20t: Change-company-name-OKI-SEMICONDUCTOR to LAPIS SemiconductorTomoya MORINAGA
On October 1 in 2011, OKI SEMICONDUCTOR Co., Ltd. changed the company name in to LAPIS Semiconductor Co., Ltd. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2012-01-17i2c-eg20t: Support new device LAPIS Semiconductor ML7831 IOHTomoya MORINAGA
ML7831 is companion chip for Intel Atom E6xx series. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2012-01-17i2c-eg20t: modified the setting of transfer rate.Toshiharu Okada
This patch modified the setting value of I2C Bus Transfer Rate Setting Counter regisrer. Signed-off-by: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2012-01-17i2c-eg20t: use i2c_add_numbered_adapter to get a fixed bus numberFeng Tang
For EG20T and ML7213 IOH, the i2c controller numbers are fixed, using fixed bus number will make it much easier for platform code to use i2c_register_board_info() to register i2c devices. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2012-01-17i2c: OMAP: Add DT support for i2c controllerBenoit Cousson
Add initial DT support to retrieve the frequency using a DT attribute instead of the pdata pointer if of_node exist. Add documentation for omap i2c controller binding. Based on original patches from Manju and Grant. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Ben Dooks <ben-linux@fluff.org> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-01-17I2C: OMAP: NACK without STPJan Weitzel
On OMAP4 OMAP_I2C_STAT_NACK is causing a timeout on the next access. The isr cleans all flags in OMAP_I2C_CON_REG by setting OMAP_I2C_CON_STP OMAP_I2C_CON_STP is also set in omap_i2c_xfer_msg on the last message. According to the TI TSR the sequence for OMAP_I2C_STAT_NACK and OMAP_I2C_STAT_AL are nearly the same. Removing the OMAP_I2C_CON_STP part in the isr fix the problem. Tested on OMAP4430 and OMAP3530 (here NACK was not a problem) Fixes also booting on 2430sdp. Signed-off-by: Jan Weitzel <j.weitzel@phytec.de> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-01-17I2C: OMAP: correct SYSC register offset for OMAP4Alexander Aring
Correct OMAP_I2C_SYSC_REG offset in omap4 register map. Offset 0x20 is reserved and OMAP_I2C_SYSC_REG has 0x10 as offset. Signed-off-by: Alexander Aring <a.aring@phytec.de> [khilman@ti.com: minor changelog edits] Cc: stable@vger.kernel.org Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-01-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (119 commits) MIPS: Delete unused function add_temporary_entry. MIPS: Set default pci cache line size. MIPS: Flush huge TLB MIPS: Octeon: Remove SYS_SUPPORTS_HIGHMEM. MIPS: Octeon: Add support for OCTEON II PCIe MIPS: Octeon: Update PCI Latency timer and enable more error reporting. MIPS: Alchemy: Update cpu-feature-overrides MIPS: Alchemy: db1200: Improve PB1200 detection. MIPS: Alchemy: merge Au1000 and Au1300-style IRQ controller code. MIPS: Alchemy: chain IRQ controllers to MIPS IRQ controller MIPS: Alchemy: irq: register pm at irq init time MIPS: Alchemy: Touchscreen support on DB1100 MIPS: Alchemy: Hook up IrDA on DB1000/DB1100 net/irda: convert au1k_ir to platform driver. MIPS: Alchemy: remove unused board headers MTD: nand: make au1550nd.c a platform_driver MIPS: Netlogic: Mark Netlogic chips as SMT capable MIPS: Netlogic: Add support for XLP 3XX cores MIPS: Netlogic: Merge some of XLR/XLP wakup code MIPS: Netlogic: Add default XLP config. ... Fix up trivial conflicts in arch/mips/kernel/{perf_event_mipsxx.c, traps.c} and drivers/tty/serial/Makefile
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12i2c/gpio-i2cmux: Convert to use module_platform_driver()Axel Lin
Convert gpio-i2cmux to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c/busses: Use module_platform_driver()Axel Lin
Convert the drivers in drivers/i2c/busses/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Barry Song <21cnbao@gmail.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c-dev: Use memdup_userThomas Meyer
Use memdup_user rather than duplicating its implementation. This is a little bit restricted to reduce false positives. The semantic patch that makes this output is available in scripts/coccinelle/api/memdup_user.cocci. More information about semantic patching is available at http://coccinelle.lip6.fr/ Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c: Convert to DEFINE_PCI_DEVICE_TABLEAxel Lin
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Use DEFINE_PCI_DEVICE_TABLE ensures we make the pci_device_id table const and marked as __devinitconst. This also fixes some warnings from checkpatch: e.g. WARNING: Use DEFINE_PCI_DEVICE_TABLE for struct pci_device_id #1096: FILE: i2c/busses/i2c-intel-mid.c:1096: +static struct pci_device_id intel_mid_i2c_ids[] = { Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Acked-by: Dirk Brandewie <dirk.brandewie@gmail.com> Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c-ali1535: enable SPARC supportcorentin.labbe
The i2c-ali1535 driver doesn't work on SPARC, because it assumes that ioport address are 16-bit wide (address stored in an unsigned short). But on SPARC arch, ioports are mapped in memory and so must be stored in an unsigned long. Use pci_resource_start for getting IOMEM base address, then read the SMBBA of the i2c bus and use these together for I/O access. I would like to thank Jean DELVARE for reviewing my patch. Signed-off-by: LABBE Corentin <corentin.labbe@geomatys.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c: Fix error value returned by several bus driversJean Delvare
When adding checks for ACPI resource conflicts to many bus drivers, not enough attention was paid to the error paths, and for several drivers this causes 0 to be returned on error in some cases. Fix this by properly returning a non-zero value on every error. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
2012-01-10Merge branch 'unicore32' of git://github.com/gxt/linuxLinus Torvalds
* 'unicore32' of git://github.com/gxt/linux: rtc-puv3: solve section mismatch in rtc-puv3.c rtc-puv3: using module_platform_driver() i2c-puv3: using module_platform_driver() rtc-puv3: irq: remove IRQF_DISABLED unicore32: Remove IRQF_DISABLED unicore32: Use set_current_blocked() unicore32: add ioremap_nocache definition unicore32: delete specified xlate_dev_mem_ptr of: add include asm/setup.h in drivers/of/fdt.c unicore32: standardize /proc/iomem "Kernel code" name
2012-01-10i2c-puv3: using module_platform_driver()Guan Xuetao
This patch converts the driver to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2012-01-09Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Driver specific changes Again, a lot of platforms have changes in here: pxa, samsung, omap, at91, imx, ... * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: sa1100: clean up of the clock support ARM: pxa: add dummy clock for sa1100-rtc RTC: sa1100: support sa1100, pxa and mmp soc families RTC: sa1100: remove redundant code of setting alarm RTC: sa1100: Clean out ost register Input: zylonite-wm97xx - replace IRQ_GPIO() with gpio_to_irq() pcmcia: pxa: replace IRQ_GPIO() with gpio_to_irq() ARM: EXYNOS: Modified files for SPI consolidation work ARM: S5P64X0: Enable SDHCI support ARM: S5P64X0: Add lookup of sdhci-s3c clocks using generic names ARM: S5P64X0: Add HSMMC setup for host Controller ARM: EXYNOS: Add USB OHCI support to ORIGEN board USB: Add Samsung Exynos OHCI diver ARM: EXYNOS: Add USB OHCI support to SMDKV310 board ARM: EXYNOS: Add USB OHCI device net: macb: fix build break with !CONFIG_OF i2c: tegra: Support DVC controller in device tree i2c: tegra: Add __devinit/exit to probe/remove net/at91_ether: use gpio_is_valid for phy IRQ line ARM: at91/net: add macb ethernet controller in 9g45/9g20 DT ...
2012-01-09Merge branch 'samsung/driver' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/common.h Pull in previous samsung conflict merges and do a trivial merge of an mxs double-add conflict. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-07Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
devicetree/next changes queued for v3.3 merge window * tag 'devicetree-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6: ARM: prom.h: Fix build error by removing unneeded header file irq: check domain hwirq range for DT translate dt: add empty of_get_node/of_put_node functions of/pdt: fix section mismatch warning i2c-designware: add OF binding support dt/i2c: Enumerate some of the known trivial i2c devices dt: reform for_each_property to for_each_property_of_node ARM/of: allow *machine_desc.dt_compat to be const of/base: Take NULL string into account for property with multiple strings OF/device-tree: Add some entries to vendor-prefixes.txt Fix up trivial add-add conflicts in include/linux/of.h
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-02misc latin1 to utf8 conversionsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-12-27i2c-designware: add OF binding supportRob Herring
Add of_match_table and DT style i2c registration to designware i2c driver. Refactored for pci/plat split by Dirk Brandewie. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2011-12-19i2c: tegra: Support DVC controller in device treeStephen Warren
One of the Tegra I2C blocks is inside the DVC (Digital Voltage Controller) block. This block is identical to the rest of the I2C blocks, except that it only supports master mode, it has registers moved around, and it needs some extra init to get it into I2C mode. The register moves are handled by i2c_readl and i2c_writel This patch adds a new compatible value for controllers of this "DVC" type; I figured that this approach was reasonable, as opposed to adding an is-dvc property under the existing compatible value, since the HW truly is different. v2: Call of_device_is_compatible() to determine is_dvc, instead of storing the flag in tegra_i2c_of_match[]'s .data field. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-19i2c: tegra: Add __devinit/exit to probe/removeStephen Warren
This fixes some section mismatch build warnings. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-18i2c-eg20t: correct the driver init order of pch_i2c_probe()Feng Tang
Before registering an adapter to i2c subsystem, we need make sure driver is ready for incoming i2c xfer, becasue the i2c_add_adapter() may trigger a i2c device driver's proble function which may start some real i2c xfer. I met this issue when integrating a TSC2007 i2c touch screen device with the i2c-eg20t driver. This patch will call request_irq() and hw init before calling i2c_add_adapter(). Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18I2C: OMAP: fix FIFO usage for OMAP4Shubhrajyoti D
Currently the fifo depth is set to zero for OMAP4 which disables the FIFO usage. This patch enables the FIFO usage for I2C transactions on OMAP4 also. Tested on omap4430 and 3430. Tested-and-Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18i2c-s3c2410: Fix return code of s3c24xx_i2c_parse_dt_gpioTushar Behera
s3c24xx_i2c_parse_dt_gpio is called when cfg_gpio is not defined in the platform data of the i2c device. When DT is not enabled, the above function always returns -EINVAL. Since there can be some i2c devices which don't need to configure any gpio lines, the probe of such devices would fail here. Changing the default return value to success would fix this issue. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18i2c: i2c-s3c2410: Add a cpu_relax() to busy wait for bus idleMark Brown
Be a bit more friendly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-07MIPS: Alchemy: Au1300 SoC supportManuel Lauss
Add basic support for the Au1300 variant(s): - New GPIO/Interrupt controller - DBDMA ids - USB setup - MMC support - enable various PSC drivers - detection code. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2866/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-01Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7182/1: ARM cpu topology: fix warning ARM: 7181/1: Restrict kprobes probing SWP instructions to ARMv5 and below ARM: 7180/1: Change kprobes testcase with unpredictable STRD instruction ARM: 7177/1: GIC: avoid skipping non-existent PPIs in irq_start calculation ARM: 7176/1: cpu_pm: register GIC PM notifier only once ARM: 7175/1: add subname parameter to mfp_set_groupg callers ARM: 7174/1: Fix build error in kprobes test code on Thumb2 kernels ARM: 7172/1: dma: Drop GFP_COMP for DMA memory allocations ARM: 7171/1: unwind: add unwind directives to bitops assembly macros ARM: 7170/2: fix compilation breakage in entry-armv.S ARM: 7168/1: use cache type functions for arch_get_unmapped_area ARM: perf: check that we have a platform device when reserving PMU ARM: 7166/1: Use PMD_SHIFT instead of PGDIR_SHIFT in dma-consistent.c ARM: 7165/2: PL330: Fix typo in _prepare_ccr() ARM: 7163/2: PL330: Only register usable channels ARM: 7162/1: errata: tidy up Kconfig options for PL310 errata workarounds ARM: 7161/1: errata: no automatic store buffer drain ARM: perf: initialise used_mask for fake PMU during validation ARM: PMU: remove pmu_init declaration ARM: PMU: re-export release_pmu symbol to modules
2011-11-26ARM: 7175/1: add subname parameter to mfp_set_groupg callersAxel Lin
commit 798681bf "ARM: 7158/1: add new MFP implement for NUC900" adds subname parameter for mfp_set_groupg. Thus add subname parameter to the callers. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wan Zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-23i2c: Make i2cdev_notifier_call staticShubhrajyoti D
The function i2cdev_notifier_call is used only in i2c-dev file making it static. Also removes the following sparse warning drivers/i2c/i2c-dev.c:582:5: warning: symbol 'i2cdev_notifier_call' was not declared. Should it be static? Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-11-23i2c: Fix device name for 10-bit slave addressJean Delvare
10-bit addresses overlap with traditional 7-bit addresses, leading in device name collisions. Add an arbitrary offset to 10-bit addresses to prevent this collision. The offset was chosen so that the address is still easily recognizable. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-11-23i2c-algo-bit: Generate correct i2c address sequence for 10-bit targetJeffrey (Sheng-Hui) Chu
The wrong bits were put on the wire, fix that. This fixes kernel bug #42562. Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-11-18USB: convert some miscellanies drivers to use module_usb_driver()Greg Kroah-Hartman
This converts the remaining USB drivers in the kernel to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Till Harbaum <till@harbaum.org> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
