path: root/drivers/i2c/chips/menelaus.c
2007-08-14i2c/menelaus: Build fixDavid Brownell
Fix Menelaus build error, and remove needless "#define DEBUG". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-17OMAP: add TI TWL92330/Menelaus Power Management chip driverTony Lindgren
Add Texas Instruments TWL92330/Menelaus Power Management chip driver. This includes voltage regulators, Dual slot memory card tranceivers and real-time clock(RTC). The support for RTC is integrated with this driver only; it is not separate module. Passes 'rtctest' on OMAP H4 EVM, other than lack of "periodic" (1/N second) IRQs. System wakeup alarms (from suspend-to-RAM) work too. The battery keeps the RTC active over power off, so once you set clock (rdate/ntpdate/etc, then "hwclock -w") then RTC_HCTOSYS at boot time will behave as expected. Cc: "Jean Delvare" <khali@linux-fr.org> Cc: "Tony Lindgren" <tony@atomide.com> Cc: "David Brownell" <david-b@pacbell.net> Signed-off-by: Trilok Soni <soni.trilok@gmail.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
