There is simply no reason to be manually setting the private driver
data to NULL in the remove/fail to probe cases. This is just extra
cruft code that can be removed.
A few notes:
* Nothing relies on drvdata being set to NULL.
* The __device_release_driver() function eventually calls
dev_set_drvdata(dev, NULL) anyway, so there's no need to do it
twice.
* I verified that there were no cases where xxx_get_drvdata() was
being called in these drivers and checking for / relying on the NULL
return value.
This could be cleaned up kernel-wide but for now just take the baby
step and remove from the i2c subsystem.
Reported-by: Wolfram Sang <wsa@the-dreams.de>
Reported-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio)
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio)
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3)
Acked-by: Barry Song <baohua.song@csr.com> (for sirf)
[wsa: Fixed "foo* bar" flaws while we are here]
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Convert the drivers in drivers/i2c/busses/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Jochen Friedrich <jochen@scram.de>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Barry Song <21cnbao@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Samuel Ortiz <sameo@linux.intel.com>
With the addition of a device platform mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com>
The cell's platform_data is now accessed with a helper function;
change clients to use that, and remove the now-unused data_size.
Note that the mfd's platform_data is marked __devinitdata. This
is still correct in all cases except for the timbgpio driver, whose
remove hook has been changed to no longer reference the pdata.
Signed-off-by: Andres Salomon <dilinger@queued.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
drivers/i2c/busses/i2c-xiic.c:493: error: implicit declaration of function 'mdelay'
Cc: "Richard Röjfors" <richard.rojfors@pelagicore.com>
Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org>
Cc: linux-i2c@vger.kernel.org
This patch adds support for the Xilinx XPS IIC Bus Interface.
The driver uses the dynamic mode, supporting to put several
I2C messages in the FIFO to reduce the number of interrupts.
It has the same feature as ocores, it can be passed a list
of devices that will be added when the bus is probed.
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
