path: root/drivers/i2c/busses/i2c-s6000.c
2013-02-22i2c: Remove unneeded xxx_set_drvdata(..., NULL) callsDoug Anderson
There is simply no reason to be manually setting the private driver data to NULL in the remove/fail to probe cases. This is just extra cruft code that can be removed. A few notes: * Nothing relies on drvdata being set to NULL. * The __device_release_driver() function eventually calls dev_set_drvdata(dev, NULL) anyway, so there's no need to do it twice. * I verified that there were no cases where xxx_get_drvdata() was being called in these drivers and checking for / relying on the NULL return value. This could be cleaned up kernel-wide but for now just take the baby step and remove from the i2c subsystem. Reported-by: Wolfram Sang <wsa@the-dreams.de> Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
2012-12-22i2c: remove __dev* attributes from subsystemBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio) Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio) Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3) Acked-by: Barry Song <baohua.song@csr.com> (for sirf) Reviewed-by: Jean Delvare <khali@linux-fr.org> [wsa: Fixed "foo* bar" flaws while we are here] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-05-17i2c: Change mail address of Oskar SchirmerOskar Schirmer
That old mail address doesnt exist any more. This changes all occurences to my new address. Signed-off-by: Oskar Schirmer <oskar@scara.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-25i2c: Allow i2c_add_numbered_adapter() to assign a bus idGrant Likely
Currently, if an i2c bus driver supports both static and dynamic bus ids, it needs to choose between calling i2c_add_numbered_adapter() and i2c_add_adapter(). This patch makes i2c_add_numbered_adapter() redirect to i2c_add_adapter() if the requested bus id is -1. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c: Use <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
As warned by checkpatch.pl, <linux/io.h> should be used instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-04-07i2c: xtensa s6000 i2c driverOskar Schirmer
Support for the s6000 on-chip i2c controller. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
