path: root/drivers/i2c/busses/i2c-piix4.c
2012-12-22i2c: remove __dev* attributes from subsystemBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio) Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio) Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3) Acked-by: Barry Song <baohua.song@csr.com> (for sirf) Reviewed-by: Jean Delvare <khali@linux-fr.org> [wsa: Fixed "foo* bar" flaws while we are here] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-12-16i2c-piix4: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
dev_<level> calls take less code than dev_printk(KERN_<LEVEL> and reducing object size is good. Coalesce formats for easier grep. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-10-05i2c-piix4: Fix build failureDaniel J Blueman
Fix build failure in Intel PIIX4 I2C driver. Signed-off-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@vger.kernel.org [v3.6]
2012-07-24i2c-piix4: Support AMD auxiliary SMBus controllerAndrew Armenia
Some AMD chipsets, such as the SP5100, have an auxiliary SMBus controller with a second set of registers. This patch adds support for this auxiliary controller. Tested on ASUS KCMA-D8 motherboard. Signed-off-by: Andrew Armenia <andrew@asquaredlabs.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c-piix4: Separate registration and probing codeAndrew Armenia
Some chipsets have multiple sets of SMBus registers each controlling a separate SMBus. Supporting these chipsets properly will require registering multiple I2C adapters for one piix4. The code to initialize and register the i2c_adapter structure has been separated from piix4_probe and allows registration of a piix4 adapter given its base address. Note that the i2c_adapter and i2c_piix4_adapdata structures are now dynamically allocated. Signed-off-by: Andrew Armenia <andrew@asquaredlabs.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c-piix4: Eliminate piix4_smba global variableAndrew Armenia
Some chipsets have multiple sets of piix4-compatible SMBus registers. Eliminating the global variable will allow these chipsets to be fully supported. Return value from piix4_setup and piix4_sb800_setup now returns the smba value detected. This is stored in a struct i2c_piix4_adapdata. Thus the global variable is eliminated. Signed-off-by: Andrew Armenia <andrew@asquaredlabs.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c/busses: Use module_pci_driverAxel Lin
Convert the drivers in drivers/i2c/busses/* to usemodule_pci_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Tomoya MORINAGA <tomoya.rohm@gmail.com>
2012-01-12i2c: Convert to DEFINE_PCI_DEVICE_TABLEAxel Lin
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Use DEFINE_PCI_DEVICE_TABLE ensures we make the pci_device_id table const and marked as __devinitconst. This also fixes some warnings from checkpatch: e.g. WARNING: Use DEFINE_PCI_DEVICE_TABLE for struct pci_device_id #1096: FILE: i2c/busses/i2c-intel-mid.c:1096: +static struct pci_device_id intel_mid_i2c_ids[] = { Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Acked-by: Dirk Brandewie <dirk.brandewie@gmail.com> Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c: Use <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
As warned by checkpatch.pl, <linux/io.h> should be used instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c: Make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-01-16i2c: Test off by one in {piix4,vt596}_transaction()Roel Kluin
With `while (timeout++ < MAX_TIMEOUT)' timeout reaches MAX_TIMEOUT + 1 after the loop. This is probably unlikely to produce a problem. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-11-07i2c-piix4: Modify code name SB900 to Hudson-2Crane Cai
Change SB900 to its formal code name Hudson-2. Signed-off-by: Crane Cai <crane.cai@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-04i2c: Hide probe errors caused by ACPI resource conflictsJean Delvare
When an ACPI resource conflict is detected, error messages are already printed by ACPI. There's no point in causing the driver core to print more error messages, so return one of the error codes for which no message is printed. This fixes bug #14293: http://bugzilla.kernel.org/show_bug.cgi?id=14293 Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-18i2c-piix4: Add AMD SB900 SMBus device IDCrane Cai
Add new SMBus device ID for AMD SB900. Signed-off-by: Crane Cai <crane.cai@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-28i2c-piix4: Add support for the Broadcom HT1100 chipsetFlavio Leitner
Add support for the Broadcom HT1100 LD chipset (SMBus function.) Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-28i2c-piix4: Add support to SB800 SMBus changesShane Huang
Add support for the AMD SB800 Family series of products. Major changes include the changes to addressing the SMBus registers at different location from the locations in the previous compatible parts from AMD such as SB400/SB600/SB700. For SB800, the main features and register definitions of SMBus and other interfaces are still compatible with the previous products with the only change being in how to access the internal registers for these blocks. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2008-07-14i2c: Drop stray references to lm_sensorsJean Delvare
2008-07-14i2c: Check for ACPI resource conflictsJean Delvare
Check for ACPI resource conflicts in i2c bus drivers. I've included all recent SMBus master drivers for PC hardware. I've voluntarily left out: * Drivers that don't run on PCs: they can't conflict with ACPI. * Bit-banged bus device drivers: it's very unlikely that ACPI would deal with such buses. Signed-off-by: Jean Delvare <jdelvare@suse.de>
2008-07-14i2c: Let bus drivers add SPD to their classJean Delvare
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once this is done, we will be able to tell the eeprom driver to only probe for SPD EEPROMs and similar on these buses. Note that I took a conservative approach here, adding I2C_CLASS_SPD to many drivers that have no idea whether they can host SPD EEPROMs or not. This is to make sure that the eeprom driver doesn't stop probing buses where SPD EEPROMs or equivalent live. So, bus driver maintainers and users should feel free to remove the SPD class from drivers those buses never have SPD EEPROMs or they don't want the eeprom driver to bind to them. Likewise, feel free to add the SPD class to any bus driver I might have missed. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Consistently reject unsupported transactionsJean Delvare
Many PC SMBus host controller drivers don't properly handle the case where they are requested to achieve a transaction they do not support. Update them so that the consistently print a warning message and return a single error value in this case. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-piix4: Various cleanups and minor fixesJean Delvare
The i2c-piix4 driver was used recently as a model to write a new SMBus host controller driver and this made me realize that the code of this old driver wasn't exactly good. So, here are many cleanups and minor fixes to this driver, so that these minor mistakes aren't duplicated again: * Delete unused structure. * Delete needless forward function declaration. * Properly announce the SMBus host controller as we find it. * Spell it SMBus not SMB. * Return -EBUSY instead of -ENODEV when the I/O region is already in use. * Drop useless masks on the 7-bit address and the R/W bit. * Reject block transaction requests with an invalid block length. * Check and report block transaction replies with an invalid block length. * Delete a useless comment. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Bus drivers return -Errno not -1David Brownell
Tighten error paths used by various i2c adapters (mostly x86) so they return real fault/errno codes instead of a "-1" (which is most often interpreted as "-EPERM"). Build tested, with eyeball review. One minor initial goal is to have adapters consistently return the code "-ENXIO" when addressing a device doesn't get an ACK response, at least in the probe paths where they are already good at stifling related logspam. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-11i2c-piix4: Blacklist two mainboardsJean Delvare
We had a report that running sensors-detect on a Sapphire AM2RD790 motherbord killed the CPU. While the exact cause is still unknown, I'd rather play it safe and prevent any access to the SMBus on that machine by not letting the i2c-piix4 driver attach to the SMBus host device on that machine. Also blacklist a similar board made by DFI. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-11i2c-piix4: Increase the intitial delay for the ServerWorks CSB5David Milburn
Per the PIIX4 errata, there maybe a delay between setting the start bit in the Smbus Host Controller Register and the transaction actually starting. If the driver doesn't delay long enough, it may appear that the transaction is complete when actually it hasn't started, this may lead to bus collisions. While 1 ms appears to be enough for most chips, the ServerWorks CSB5 wants 2 ms. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c-piix4: Minor cleanupsJean Delvare
* Remove a needless include. * Remove a legacy comment in piix4_access. * Minor optimization in piix4_access. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Spelling fix (successful)Jean Delvare
2008-01-27i2c-piix4: Drop redundant PCI function number checkJean Delvare
Checking the PCI function number doesn't add any value, and it makes adding dynamic IDs to the driver more difficult. Drop this check. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-08-31i2c-piix4: Fix SB700 PCI device IDShane Huang
We find that SB700 and SB800 use the same SMBus device ID as SB600, which is 0x4385, instead of the already submitted 0x4395. Besides removing the wrong SB700 device ID, add SB800 support to kernel, by renaming the PCI_DEVICE_ID_ATI_IXP600_SMBUS into PCI_DEVICE_ID_ATI_SBX00_SMBUS. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12i2c-piix4: Add support for the ATI SB700Henry Su
Add the SMBus device ID for ATI SB700. Signed-off-by: Henry Su <Henry.su@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c: Shrink struct i2c_clientDavid Brownell
This shrinks the size of "struct i2c_client" by 40 bytes: - Substantially shrinks the string used to identify the chip type - The "flags" don't need to be so big - Removes some internal padding It also adds kerneldoc for that struct, explaining how "name" is really a chip type identifier; it's otherwise potentially confusing. Because the I2C_NAME_SIZE symbol was abused for both i2c_client.name and for i2c_adapter.name, this needed to affect i2c_adapter too. The adapters which used that symbol now use the more-obviously-correct idiom of taking the size of that field. JD: Shorten i2c_adapter.name from 50 to 48 bytes while we're here, to avoid wasting space in padding. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-17Replace remaining references to "driverfs" with "sysfs".Robert P. J. Day
Globally, s/driverfs/sysfs/g. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-piix4: Add support for the ATI SB600Jean Delvare
Add support for the ATI SB600 SMBus controller. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-piix4: Document the IBM problem more clearlyJean Delvare
Properly document on which systems the i2c-piix4 SMBus driver will refuse to load. Hopefully this will make it clearer for users, which were often wondering why their destop or server systems were detected as laptops. Closes bug #6429. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-piix4: Remove the fix_hstcfg parameterRudolf Marek
This patch removes the fix_hstcfg option from the driver and related SMBus Interrupt Select register magic because now we know what are valid values for this register. This patch updates the documentation and adds new IRQ mode check so we are sure not to miss any new "unusual" value. The PCI quirk for users of fix_hstcfg was not developed because the chipset lacks of subsystem ID registers and DMI is stated "To be filled". Impact to existing systems is minimal because the problem showed up on motherboards like 10 years back. On the other hand users of newer Serverworks and HT1000 systems won't be misleaded by the message suggesting to try the fix_hstcfg any more. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] i2c-piix4: Add ATI IXP200/300/400 supportRudolf Marek
This patch adds the ATI IXP southbridges support to i2c-piix4, as it turned out those chips are compatible with it. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] I2C: i2c-piix4: Add Broadcom HT-1000 supportMartin Devera
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3 and standard values like 0 or 9 causes hangup. Signed-off-by: Martin Devera <devik@cdi.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-28[PATCH] Owner field additions to many i2c drivers, 1 of 5Laurent Riffard
This patch updates .owner field for various struct pci_driver variables. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Reuse name strings in i2c bus driversJean Delvare
Clean up name string usage in 12 i2c bus drivers: * Use the i2c_adapter name for requesting the I/O region rather than redefining a new string. * Do not initialize the i2c_adapter name to "unset". This should save a few data bytes here and there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/busses/i2c-ali1535.c | 6 +++--- drivers/i2c/busses/i2c-ali1563.c | 6 ++++-- drivers/i2c/busses/i2c-ali15x3.c | 5 +++-- drivers/i2c/busses/i2c-amd756.c | 5 ++--- drivers/i2c/busses/i2c-amd8111.c | 4 +++- drivers/i2c/busses/i2c-i801.c | 4 ++-- drivers/i2c/busses/i2c-nforce2.c | 4 ++-- drivers/i2c/busses/i2c-piix4.c | 4 ++-- drivers/i2c/busses/i2c-sis5595.c | 5 +++-- drivers/i2c/busses/i2c-sis630.c | 6 ++++-- drivers/i2c/busses/i2c-sis96x.c | 5 +++-- drivers/i2c/busses/i2c-via.c | 4 ++-- 12 files changed, 33 insertions(+), 25 deletions(-)
2005-10-28[PATCH] i2c: Discard explicit static initializations to 0Jean Delvare
Kill explicit static initializations to 0 in 10 i2c drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/algos/i2c-algo-pca.c | 2 +- drivers/i2c/algos/i2c-algo-sibyte.c | 2 +- drivers/i2c/busses/i2c-ali15x3.c | 4 ++-- drivers/i2c/busses/i2c-amd756.c | 2 +- drivers/i2c/busses/i2c-iop3xx.c | 2 +- drivers/i2c/busses/i2c-piix4.c | 8 ++++---- drivers/i2c/busses/i2c-sis5595.c | 4 ++-- drivers/i2c/busses/i2c-sis630.c | 2 +- drivers/i2c/busses/i2c-sis96x.c | 2 +- drivers/i2c/busses/i2c-via.c | 2 +- 10 files changed, 15 insertions(+), 15 deletions(-)
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (4/7)Jean Delvare
There are no more users of i2c_algorithm.id, so we can finally drop this structure member. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.name (1/7)Jean Delvare
The name member of the i2c_algorithm is never used, although all drivers conscientiously fill it. We can drop it completely, this structure doesn't need to have a name. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11[PATCH] I2C: Strip trailing whitespace from stringsJean Delvare
Here is a simple patch originally from Denis Vlasenko, which strips a useless trailing whitespace from 8 strings in 4 i2c drivers. Please apply, thanks. From: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
