The ACPI subsystem strictly checks for resource conflicts. When there's
a conflict, it outputs a warning message with all the details needed to
properly diagnose the underlying issue. However, the i2c-nforce2 driver
also prints its own message. Not only is the message redundant, it is at
the KERN_ERR level, which overrides some bootsplash screens for no good
reason. This change removes the two lines that print out the error
messages.
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
As warned by checkpatch.pl, <linux/io.h> should be used instead of
<asm/io.h>.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The id_table field of the struct pci_driver is constant in <linux/pci.h>
so it is worth to make initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Márton Németh <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
with while (timeout++ < MAX_TIMEOUT); timeout reaches MAX_TIMEOUT + 1
after the loop, so the tests below are off by one.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The MCP78S and MCP79 appear to be compatible with the previous nForce
chips as far as the SMBus controller is concerned. The MCP67 and MCP73
were not tested yet but I'd be very surprised if they weren't
compatible too.
Cc: Oleg Ryjkov <olegr@olegr.ca>
Cc: Malcolm Lalkaka <mlalkaka@gmail.com>
Cc: Zbigniew Luszpinski <zbiggy@o2.pl>
Check for ACPI resource conflicts in i2c bus drivers. I've included
all recent SMBus master drivers for PC hardware.
I've voluntarily left out:
* Drivers that don't run on PCs: they can't conflict with ACPI.
* Bit-banged bus device drivers: it's very unlikely that ACPI would
deal with such buses.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once
this is done, we will be able to tell the eeprom driver to only probe
for SPD EEPROMs and similar on these buses.
Note that I took a conservative approach here, adding I2C_CLASS_SPD to
many drivers that have no idea whether they can host SPD EEPROMs or not.
This is to make sure that the eeprom driver doesn't stop probing buses
where SPD EEPROMs or equivalent live.
So, bus driver maintainers and users should feel free to remove the SPD
class from drivers those buses never have SPD EEPROMs or they don't
want the eeprom driver to bind to them. Likewise, feel free to add the
SPD class to any bus driver I might have missed.
Tighten error paths used by various i2c adapters (mostly x86) so
they return real fault/errno codes instead of a "-1" (which is
most often interpreted as "-EPERM"). Build tested, with eyeball
review.
One minor initial goal is to have adapters consistently return
the code "-ENXIO" when addressing a device doesn't get an ACK
response, at least in the probe paths where they are already
good at stifling related logspam.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Just like the Tyan S4882, the S4985 uses a multiplexer to give access
to all 16 memory module SPD EEPROMs. This specific i2c-nforce2-s4985
driver adds support for this. It is heavily based on the older
i2c-amd756-s4882 driver.
As more mainboards will use multiplexer chips, we will have to find a
way to support them without having to write a new specfic driver for
each. The recent changes to the i2c subsystem should help us, and the
new gpio subsystem might help, too.
There is a strange chip at 0x2e on the second SMBus channel of the
DFI Lanparty NF4 Expert motherboard. Accessing the chip reboots the
system. As there's nothing interesting on this SMBus channel, the
easiest and safest thing to do is to disable it on that board.
This is a better fix to bug #5889 than the it87 driver update that was
done originally:
http://bugzilla.kernel.org/show_bug.cgi?id=5889
My guess is that all the chips supported by this driver support block
transactions and reset, but for now we play it safe and only list the
ones for which this was actually tested.
The i2c-nforce2 driver has SMBus PEC support, so it should say so.
This patch is to add an abort function that will bring back the MCP51/55
controller if it was blocked by a block-read operation, in particular.
(When a slave sends a wrong byte count on a byte read, the host gets
locked up). I've only tested it on an MCP51 and MCP55. However, I'm
almost certain it will also work on MCP65, I just did not have the board
to test it on. Thus for now the abort function will only be called
if an MCP51/55 was detected.
Signed-off-by: Oleg Ryjkov <olegr@olegr.ca>
This is the first part of the patch that adds a function to reset the
nvidia MCP51/55 i2c controller, if something bad happens to it (e.g.
a slave sends a wrong byte count during a block transaction).
This patch just adds nforce2_check_status function. It was originally
written by Hans-Frieder Vogt.
The reason that I'm the one sending it is:
- I relied on it for the second part of the patch,
- It makes the driver code cleaner/better.
Add support for SMBus block read/write transactions to i2c-nforce2
driver, in particular to host controllers MCP51 and MCP55.
Signed-off-by: Oleg Ryjkov <olegr@google.com>
Cc: Hans-Frieder Vogt <hfvogt@gmx.net>
This shrinks the size of "struct i2c_client" by 40 bytes:
- Substantially shrinks the string used to identify the chip type
- The "flags" don't need to be so big
- Removes some internal padding
It also adds kerneldoc for that struct, explaining how "name" is really a
chip type identifier; it's otherwise potentially confusing.
Because the I2C_NAME_SIZE symbol was abused for both i2c_client.name
and for i2c_adapter.name, this needed to affect i2c_adapter too. The
adapters which used that symbol now use the more-obviously-correct
idiom of taking the size of that field.
JD: Shorten i2c_adapter.name from 50 to 48 bytes while we're here, to
avoid wasting space in padding.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
IDs have been defined but not used by most of the I2C adapters.
By having a unique ID, clients can check for correct connection
during probe.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Summary of changes:
- fixes:
o legacy I/O region size is 64 bytes, not 8 bytes
- general cleanup:
o removed code for the unsupported I2C block data, block data,
proc call and block proc call transfer modes
o removed detail warnings about unsupported modes that are
covered in a general warning (unsupported transaction...)
anyway
o removed necessity of a definition of struct i2c_adapter
o moved definition of struct i2c_algorithm, making forward
declarations of nforce2_access and nforce2_func unnecessary
- minor changes:
o in the description mention the nForce 5xx chipsets
o changes my e-mail address in MODULE_AUTHOR
Theses cleanups shrink the driver binary size from 4.0 kB to 2.7 kB
on i386.
Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net>
i2c: Constify i2c_algorithm declarations, part 2
Make struct i2c_algorithm declarations const in all i2c bus drivers
where it is possible.
Cc: David Brownell <david-b@pacbell.net>
Add support for the new nForce4 MCP51 (also known as nForce 410 or
430) and nForce4 MCP55 to the i2c-nforce2 driver. Some code changes
were required because the base I/O address registers have changed in
these versions. Standard BARs are now being used, while the original
nForce2 chips used non-standard ones.
One more supported PCI ID for the i2c-nforce2 driver.
The new SMBus PEC implementation doesn't support PEC emulation on
non-PEC non-I2C SMBus masters, so we can drop all related code.
Drop useless casts on kzalloc returned values, as suggested by
Jiri Slaby.
Use kzalloc instead of kmalloc+memset in all remaining i2c bus and
chip drivers.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
This patch updates .owner field for various struct pci_driver variables.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Clean up name string usage in 12 i2c bus drivers:
* Use the i2c_adapter name for requesting the I/O region rather than
redefining a new string.
* Do not initialize the i2c_adapter name to "unset".
This should save a few data bytes here and there.
drivers/i2c/busses/i2c-ali1535.c | 6 +++---
drivers/i2c/busses/i2c-ali1563.c | 6 ++++--
drivers/i2c/busses/i2c-ali15x3.c | 5 +++--
drivers/i2c/busses/i2c-amd756.c | 5 ++---
drivers/i2c/busses/i2c-amd8111.c | 4 +++-
drivers/i2c/busses/i2c-i801.c | 4 ++--
drivers/i2c/busses/i2c-nforce2.c | 4 ++--
drivers/i2c/busses/i2c-piix4.c | 4 ++--
drivers/i2c/busses/i2c-sis5595.c | 5 +++--
drivers/i2c/busses/i2c-sis630.c | 6 ++++--
drivers/i2c/busses/i2c-sis96x.c | 5 +++--
drivers/i2c/busses/i2c-via.c | 4 ++--
12 files changed, 33 insertions(+), 25 deletions(-)
One more cleanup in i2c-nforce2.
There are no more users of i2c_algorithm.id, so we can finally drop
this structure member.
The name member of the i2c_algorithm is never used, although all
drivers conscientiously fill it. We can drop it completely, this
structure doesn't need to have a name.
attached is a small patch that removes unused code from i2c-nforce2 and
adds a single debug message. The patch is against 2.6.13-rc3-mm1.
I have tested the patch with 2.6.13-rc3: compiles cleanly and works as
without the patch (as expected).
Signed-off-by: Hans-Frieder Vogt <hfvogt@arcor.de>
Files that don't use CONFIG_* stuff shouldn't include config.h
Files that use CONFIG_* stuff should include config.h
It's that simple. ;-)
Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru>
infrastructure for it.
Let it rip!
