CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio)
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio)
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3)
Acked-by: Barry Song <baohua.song@csr.com> (for sirf)
Reviewed-by: Jean Delvare <khali@linux-fr.org>
[wsa: Fixed "foo* bar" flaws while we are here]
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Generally it is not needed to wait for 1 msec, the SMBus get often ready
in less than 200 usecs.
msleep(1) can wait up to 20 msecs... It has a significant impact when
there is a burst of transactions on the bus.
Signed-off-by: Olivier Sobrie <olivier@sobrie.be>
Convert the drivers in drivers/i2c/busses/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Jochen Friedrich <jochen@scram.de>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Barry Song <21cnbao@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Convert i2c-isch to platform_device for the lpc mfd core to add it at probe
time.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
The id_table field of the struct pci_driver is constant in <linux/pci.h>
so it is worth to make initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Márton Németh <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
When an ACPI resource conflict is detected, error messages are already
printed by ACPI. There's no point in causing the driver core to print
more error messages, so return one of the error codes for which no
message is printed.
This fixes bug #14293:
http://bugzilla.kernel.org/show_bug.cgi?id=14293
with while (timeout++ < MAX_TIMEOUT); timeout reaches MAX_TIMEOUT + 1
after the loop, so the tests below are off by one.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Check for ACPI resource conflicts in i2c bus drivers. I've included
all recent SMBus master drivers for PC hardware.
I've voluntarily left out:
* Drivers that don't run on PCs: they can't conflict with ACPI.
* Bit-banged bus device drivers: it's very unlikely that ACPI would
deal with such buses.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once
this is done, we will be able to tell the eeprom driver to only probe
for SPD EEPROMs and similar on these buses.
Note that I took a conservative approach here, adding I2C_CLASS_SPD to
many drivers that have no idea whether they can host SPD EEPROMs or not.
This is to make sure that the eeprom driver doesn't stop probing buses
where SPD EEPROMs or equivalent live.
So, bus driver maintainers and users should feel free to remove the SPD
class from drivers those buses never have SPD EEPROMs or they don't
want the eeprom driver to bind to them. Likewise, feel free to add the
SPD class to any bus driver I might have missed.
New i2c bus driver for the Intel SCH chipsets (AF82US15W, AF82US15L,
AF82UL11L).
Signed-off-by: Alek Du <alek.du@intel.com>
