path: root/drivers/i2c/busses/i2c-highlander.c
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12i2c/busses: Use module_platform_driver()Axel Lin
Convert the drivers in drivers/i2c/busses/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Barry Song <21cnbao@gmail.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-10-29i2c: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [c58543c8: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Barry Song <21cnbao@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-06-24treewide: transciever/transceiver spelling fixesJoe Perches
Just tyops. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20i2c-highlander: remover superflous variableWolfram Sang
When cppcheck found this flaw [./i2c/busses/i2c-highlander.c:284]: (style) Warning - using char variable in bit operation it was noted that the 'read'-variable could be simply removed as read_write can only be 0 or 1 anyhow. So, we remove the flaw and simplify the code. Reported-by: d binderman <dcb314@hotmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16i2c: Use resource_size macroLinus Walleij
This replace all instances in the i2c busses tree of res->end - res->start + 1 with the handy macro resource_size(res) from ioport.h (coming in from platform_device.h). This was created with a simple sed -i -e 's/\([a-z]*\)->end *- *[a-z]*->start *+ *1/resource_size(\1)/g' Then manually replacing the PXA redefiniton of the same kind of macro manually. Recompiled some ARM defconfigs I could find to make a rough test so it shouldn't break anything, though I couldn't see exactly which configs you need for all the drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-11i2c-highlander: Trivial endian casting fixesHarvey Harrison
Fixes sparse warnings: drivers/i2c/busses/i2c-highlander.c:95:26: warning: incorrect type in argument 1 (different base types) drivers/i2c/busses/i2c-highlander.c:95:26: expected restricted __be16 const [usertype] *p drivers/i2c/busses/i2c-highlander.c:95:26: got unsigned short [usertype] *<noident> drivers/i2c/busses/i2c-highlander.c:106:15: warning: incorrect type in assignment (different base types) drivers/i2c/busses/i2c-highlander.c:106:15: expected unsigned short [unsigned] [short] [usertype] <noident> drivers/i2c/busses/i2c-highlander.c:106:15: got restricted __be16 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-14i2c: Renesas Highlander FPGA SMBus supportPaul Mundt
This adds support for the SMBus adapter found in the various FPGAs on the Renesas Highlander platforms. Particularly the R0P7780LC0011RL and R0P7785LC0011RL FPGAs. Functionality is fairly restricted, in that only byte and block data transfers are supported. Normal/fast mode and IRQ/polling are also supported. Primarily used for various RTCs and thermal sensors. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
