When ina3221 is in suspend mode or off mode, ignore all cpu
notifications
Bug 1283995
Change-Id: I5c6bf66bfb401ce697b18828fbcb34ed916bfe3e
Signed-off-by: Jun Yan <juyan@nvidia.com>
Reviewed-on: http://git-master/r/230999
GVS: Gerrit_Virtual_Submit
Reviewed-by: Anshul Jain (SW) <anshulj@nvidia.com>
Change-Id: I882038b2dee419daf7c402a9c03aad06a0a25807
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/216315
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Chaitanya Bandi <bandik@nvidia.com>
Tested-by: Jun Yan <juyan@nvidia.com>
Reviewed-by: Tao Xie <txie@nvidia.com>
turn off ina3221 when online_cores < 2 and freq < 1GHz
turn on ina3221 when online_cores >=2 or freq >= 1GHz
Bug 1241820
Change-Id: Ie2d6d703711a33b14c73f765421e9565ecda64f6
Reviewed-on: http://git-master/r/210071
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Tested-by: Anshul Jain (SW) <anshulj@nvidia.com>
Bug 1228591
Change-Id: I5a4b2b59d32118d57ee0ff6c21b8423268fc1926
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/197993
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 1225028
Change-Id: I252cfc136f5fe2c2118ae4d24d5c2ba64fb94437
Reviewed-on: http://git-master/r/195027
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
TI HPA01112 is sw compatible with ina230. Add the module id for HPA01112.
Change-Id: If9c054d09c1fd8a2d29b363062a021ad0e99bb97
Reviewed-on: http://git-master/r/197499
The TI current/power monitor device INA230 is compatible with the
HAP02149. Add module ID for the HPA02149.
This device is also compatible with INA226 and hence adding ina226
as module-id.
In this way, this driver can regsitered with the name as "ina226" or
"ina230" or "hpa02149".
bug 1218687
Change-Id: Ic67227bc6d415fd559d804f4bd97e4ea4018d872
Reviewed-on: http://git-master/r/196411
This is an optimization to turn off INA device based on number of cores
online. Also, this change removes support for turning on/off INA at runtime
using sysfs node. Additionaly, this change creates a new API power2_*,
which return 0 if ina device is turned off.
Bug 1223376
Bug 1207777
Change-Id: I0beedffa10d7e11e280e96c2c58c4dd191b87819
Reviewed-on: http://git-master/r/193580
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
-power down ina devices by setting register values
-earlier power down method was a conditional one
and left ina devices ON after init
Bug 1211188
Change-Id: I113a1e7dc3eb6c211dab58596090c6c508364e25
Reviewed-on: http://git-master/r/187946
Tested-by: Daniel Solomon <daniels@nvidia.com>
Fix the debug print and trigger config data for INA3221 device
Bug 1160066
Change-Id: Ib544489a8cd8861d98ee7e276e92559c0077ce51
Reviewed-on: http://git-master/r/167598
Update thermal zone device register in drivers due to updated thermal API.
Bug 1059470
Change-Id: I02e068c2b6c5756edb1f7928d2a822f3f2536867
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/166119
Reviewed-by: Simone Willett <swillett@nvidia.com>
The clk_enable/clk_disable pair of APIs are replaced with
clk_prepare_enable and clk_disable_unprepare.
This is needed for the migration to common clk framework.
Bug 920915
Change-Id: I1b5939d7714c21549b4e7e63c223bcac8e66f951
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/162324
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
-add driver to support INA3221 in both
triggered/continuous mode
-add header file in include/linux
-modify Makefile, Kconfig
Bug 1160066
Change-Id: Id0e001d680bb6896e263c0d6c848e1f978290520
Reviewed-on: http://git-master/r/161227
Reviewed-by: Liang Cheng (SW) <licheng@nvidia.com>
-do calculation using calibration_data, power_lsb,
divisor received from respective board files
-remove sysdev include
Bug 1049224
Change-Id: I673e67cb42972aad1a3c5e5ea995072d40839d05
Reviewed-on: http://git-master/r/162025
Change the init sequence to reset first and then power-down the INA
Bug 1174904
Change-Id: Ic337e10d9799e21329b08adab3011ba17dea2844
Signed-off-by: Aly Hirani <ahirani@nvidia.com>
Reviewed-on: http://git-master/r/163179
This new driver allows state change of the INA219 device using this sysds node:
To turn the ina219 device on,
echo 1 > /<i2c device path>/cur_state
To turn it off:
echo 0 > /<i2c device path>/cur_state
It has new sysfs nodes current2_input and power2_input that contains
current and power calculated using shunt resistor and voltage drop
across shunt resistor.
This driver is backward compatible with the old driver.
Bug 1160868
Change-Id: I5e05947e8e3b20a85f02188a48ea4441218e27a8
Reviewed-on: http://git-master/r/160070
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Updated thermal register function for tsensor and nct thermal
drivers due to Linux thermal API change.
bug 1059470
Change-Id: Ic4ca347c6fcc1aad156122147a7c94a5f3880985
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/159967
Update the bind function in the tsensor and nct driver to
reflect the new Thermal API.
bug 1059470
Change-Id: I527383d426ff1f70fe531a02d600735cbedea7b8
Reviewed-on: http://git-master/r/159963
bug 1046331
Change-Id: I1be17d9343b004a6cb0a81c13fd0f322ada9d109
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/159541
-Precision multiplier declared
-This multiplier will be defined in respective board files
-Finally multiplier is divided to get normalized value
Bug 1049224
Change-Id: Ia84c622c1f1f5ee845806d26b64600be4564b5b9
Reviewed-on: http://git-master/r/147578
Added nct functionality to change trip points. This
will be useful for EDP and thermal throttling.
Change-Id: I4fef643263261701164027f9bb13794b37e4907e
Reviewed-on: http://git-master/r/139083
(cherry picked from commit 0dd4d083d4379752f7db241800d9501460b63d07)
Signed-off-by: Gaurav Batra <gbatra@nvidia.com>
Reviewed-on: http://git-master/r/146674
Removed outside interface of tsensor driver. Tsensor driver
interacts with cooling devices via Linux thermal framework
which it registers to on its own.
Change-Id: I349761a28eac94f7f6c05d192394bc2739e93cb6
Reviewed-on: http://git-master/r/132882
(cherry picked from commit 6645d1062b2d76a504ef7a109b919d631169f479)
Reviewed-on: http://git-master/r/130288
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Bug 1024886
Resolved compilation error for unused code.
Signed-off-by: Nagaraja Kolur <nkolur@nvidia.com>
Change-Id: I9167d8129a9cba0fc6cb203180e07192d66db439
Reviewed-on: http://git-master/r/120581
Reviewed-by: Nagaraj Kolur <nkolur@nvidia.com>
Tested-by: Nagaraj Kolur <nkolur@nvidia.com>
Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com>
Reviewed-by: Wahed Syed <wsyed@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
arch/arm/boot/compressed/Makefile
arch/arm/boot/compressed/atags_to_fdt.c
arch/arm/boot/compressed/head.S
arch/arm/boot/dts/tegra30.dtsi
arch/arm/include/asm/bug.h
arch/arm/kernel/traps.c
arch/arm/mach-tegra/Makefile.boot
arch/arm/mach-tegra/board-cardhu-sdhci.c
arch/arm/mach-tegra/board-cardhu.c
arch/arm/mach-tegra/board-enterprise-sdhci.c
arch/arm/mach-tegra/board-enterprise.c
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-kai-sdhci.c
arch/arm/mach-tegra/board-ventana.c
arch/arm/mach-tegra/board-whistler.c
arch/arm/mach-tegra/clock.h
arch/arm/mach-tegra/fuse.h
arch/arm/mach-tegra/tegra2_usb_phy.c
arch/arm/mach-tegra/tegra3_clocks.c
arch/arm/mach-tegra/tegra3_dvfs.c
arch/arm/mach-tegra/tegra3_speedo.c
arch/arm/mach-tegra/timer.c
arch/arm/mach-tegra/usb_phy.c
arch/arm/mach-tegra/wakeups-t3.c
drivers/cpufreq/cpufreq_interactive.c
drivers/input/touchscreen/atmel_mxt_ts.c
drivers/mfd/tps65090.c
drivers/mmc/core/mmc.c
drivers/mmc/host/sdhci-tegra.c
drivers/mmc/host/sdhci.c
drivers/net/wireless/bcmdhd/bcmsdh_sdmmc_linux.c
drivers/regulator/Kconfig
drivers/regulator/core.c
drivers/regulator/tps80031-regulator.c
drivers/spi/Makefile
drivers/staging/nvec/nvec.c
drivers/tty/serial/Makefile
include/linux/mmc/card.h
sound/soc/tegra/tegra_max98095.c
sound/usb/card.c
Change-Id: I65043bc6ce9e97d0592683462215a39e50f403fd
Reviewed-on: http://git-master/r/121392
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Bo Yan <byan@nvidia.com>
Linux v3.4.6
Change-Id: I4518a173ca2852188ebd48121723c8be29d0c682
commit 41002f8dd5938d5ad1d008ce5bfdbfe47fa7b4e8 upstream.
We were accidentally losing one bit in the configuration register on
device initialization. It was reported to freeze one specific system
right away. Properly preserve all bits we don't explicitly want to
change in order to prevent that.
Reported-by: Stevie Trujillo <stevie.trujillo@gmail.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Linux v3.4.5
drivers/base/power/main.c
Change-Id: I782e650a89665caea8aed9e5598234888dc11088
Simplify the temp to counter conversion in tsensor,
Also it can improve a little bit accuracy of temp to
counter conversion.
Change-Id: I5764334d5d94e317dd9400bc03cb5d7a64096ee0
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/115340
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
commit 4ad33411308596f2f918603509729922a1ec4411 upstream.
It makes sense to label "Digital Thermal Sensor" as "DTS", but
unfortunately the string "dts" was already used for "Debug Store", and
/proc/cpuinfo is a user space ABI.
Therefore, rename this to "dtherm".
This conflict went into mainline via the hwmon tree without any x86
maintainer ack, and without any kind of hint in the subject.
a4659053 x86/hwmon: fix initialization of coretemp
Reported-by: Jean Delvare <khali@linux-fr.org>
Link: http://lkml.kernel.org/r/4FE34BCB.5050305@linux.intel.com
Cc: Jan Beulich <JBeulich@suse.com>
commit ac852edb47b15900886ba2564eeeb13b3b526e3e upstream.
Key lookups may call read_smc() with a fixed-length key string,
and if the lookup fails, trailing stack content may appear in the
kernel log. Fixed with this patch.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
When set threshold of tsensor,convert the temp to counter.
The counter convert from temp is with ~1.8C average error.
Improved the accuracy, make it to be ~0.1C.
Bug 1015288
Change-Id: Icab03b559eaeb8846dd1191869afe39c9965f934
Reviewed-on: http://git-master/r/114904
Changed the low temp to 0C since 20C is very easy to trigger thermal
alert under -15C to 15C environment temperature. And the thermal alert
will run into endless alert from tsensor_work_func.
Also revised suspend and resume routine to cancel the work when suspending
and disable/enable irq.
Bug 999175
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
(cherry picked from commit 6a909bfa690991438be298d4933946a92e4929c4)
Change-Id: Icafc6d5f0164204cc0cb7bea64bef2fadadbfbfd
Reviewed-on: http://git-master/r/111550
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
tsensor driver uses fixed point approximations.
Improved accuracy of tsensor temperature reading
- adding support to handle negative temperature to counter
conversions and vice-versa
bug 1001632
bug 999175
(cherry picked from commit 86ae0bdc3fbd34a5a1d0e08f7721ed527ddf5408)
Change-Id: I5f6df85611d502a6dda1186234078fe973d7ca75
Reviewed-on: http://git-master/r/100576
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
CPU core ID is used to index the core_data[] array. The core ID is, however, not
sequential; 10-core CPUS can have a core ID as high as 25. Increase the limit to
32 to be able to deal with current CPUs.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: stable@vger.kernel.org # 3.0+
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Durgadoss R <durgadoss.r@intel.com>
coretemp tries to access core_data array beyond bounds on cpu unplug if
core id of the cpu if more than NUM_REAL_CORES-1.
BUG: unable to handle kernel NULL pointer dereference at 000000000000013c
IP: [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
PGD 673e5a067 PUD 66e9b3067 PMD 0
Oops: 0000 [#1] SMP
CPU 79
Modules linked in: sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf bnep bluetooth rfkill ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter nf_conntrack_ipv4 nf_defrag_ipv4 ip6_tables xt_state nf_conntrack coretemp crc32c_intel asix tpm_tis pcspkr usbnet iTCO_wdt i2c_i801 microcode mii joydev tpm i2c_core iTCO_vendor_support tpm_bios i7core_edac igb ioatdma edac_core dca megaraid_sas [last unloaded: oprofile]
Pid: 3315, comm: set-cpus Tainted: G W 3.4.0-rc5+ #2 QCI QSSC-S4R/QSSC-S4R
RIP: 0010:[<ffffffffa00159af>] [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
RSP: 0018:ffff880472fb3d48 EFLAGS: 00010246
RAX: 0000000000000124 RBX: 0000000000000034 RCX: 00000000ffffffff
RDX: 0000000000000000 RSI: 0000000000000046 RDI: 0000000000000246
RBP: ffff880472fb3d88 R08: ffff88077fcd36c0 R09: 0000000000000001
R10: ffffffff8184bc48 R11: 0000000000000000 R12: ffff880273095800
R13: 0000000000000013 R14: ffff8802730a1810 R15: 0000000000000000
FS: 00007f694a20f720(0000) GS:ffff88077fcc0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000000013c CR3: 000000067209b000 CR4: 00000000000007e0
Process set-cpus (pid: 3315, threadinfo ffff880472fb2000, task ffff880471fa0000)
Stack:
ffff880277b4c308 0000000000000003 ffff880472fb3d88 0000000000000005
0000000000000034 00000000ffffffd1 ffffffff81cadc70 ffff880472fb3e14
ffff880472fb3dc8 ffffffff8161f48d ffff880471fa0000 0000000000000034
Call Trace:
[<ffffffff8161f48d>] notifier_call_chain+0x4d/0x70
[<ffffffff8107f1be>] __raw_notifier_call_chain+0xe/0x10
[<ffffffff81059d30>] __cpu_notify+0x20/0x40
[<ffffffff815fa251>] _cpu_down+0x81/0x270
[<ffffffff815fa477>] cpu_down+0x37/0x50
[<ffffffff815fd6a3>] store_online+0x63/0xc0
[<ffffffff813c7078>] dev_attr_store+0x18/0x30
[<ffffffff811f02cf>] sysfs_write_file+0xef/0x170
[<ffffffff81180443>] vfs_write+0xb3/0x180
[<ffffffff8118076a>] sys_write+0x4a/0x90
[<ffffffff816236a9>] system_call_fastpath+0x16/0x1b
Code: 48 c7 c7 94 60 01 a0 44 0f b7 ac 10 ac 00 00 00 31 c0 e8 41 b7 5f e1 41 83 c5 02 49 63 c5 49 8b 44 c4 10 48 85 c0 74 56 45 31 ff <39> 58 18 75 4e eb 1f 49 63 d7 4c 89 f7 48 89 45 c8 48 6b d2 28
RIP [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
RSP <ffff880472fb3d48>
Oops: 0000 [#1] SMP
CPU 79
Stack:
Call Trace:
pci_match_id() takes an *array* of IDs which must be properly zero-
terminated.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: stable@vger.kernel.org # 3.0+: 00250ec hwmon: fam15h_power: fix bogus values
The following build warning is seen in some configurations.
drivers/hwmon/ad7314.c: In function 'ad7314_show_temperature':
drivers/hwmon/ad7314.c:70: warning: 'data' may be used uninitialized in this function
Fix by overloading the return value from ad7314_spi_read with both data and
error code (the returned data is really u16 and needs to be converted into a
signed value anyway).
Cc: Jonathan Cameron <jic23@cam.ac.uk>
terminated.
drivers/hwmon/ads1015.c: In function 'show_in':
drivers/hwmon/ads1015.c:129: warning: 'in' may be used uninitialized in this function
Fix by separating the register read function from the code converting the result
into mV.
Cc: Dirk Eibach <eibach@gdsys.de>
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
Newer BKDG[1] versions recommend a different initialization value for
the running average range register in the northbridge. This improves
the power reading by avoiding counter saturations resulting in bogus
values for anything below about 80% of TDP power consumption.
Updated BIOSes will have this new value set up from the beginning,
but meanwhile we correct this value ourselves.
This needs to be done on all northbridges, even on those where the
driver itself does not register at.
This fixes the driver on all current machines to provide proper
values for idle load.
[1]
http://support.amd.com/us/Processor_TechDocs/42301_15h_Mod_00h-0Fh_BKDG.pdf
Chapter 3.8: D18F5xE0 Processor TDP Running Average (p. 452)
Signed-off-by: Andre Przywara <andre.przywara@amd.com>
[guenter.roeck@ericsson.com: Removed unnecessary return statement]
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
drivers/usb/host/ehci.h
into mV.
[1]
Some configurations produce the following compiler warning:
drivers/hwmon/pmbus/pmbus_core.c: In function 'pmbus_show_boolean':
drivers/hwmon/pmbus/pmbus_core.c:752: warning: 'val' may be used uninitialized in this function
While this is a false positive, it can easily be fixed by overloading the return
value from pmbus_get_boolean with both val and error return code (val is a
boolean and thus never negative).
drivers/hwmon/smsc47m1.c: In function 'sm_smsc47m1_init':
drivers/hwmon/smsc47m1.c:938: warning: 'address' may be used uninitialized in this function
value from smsc47m1_find with both address and error return code (the address
is an unsigned short and thus never negative). This also reduces module size by
a few bytes (46 bytes for x86_64).
In some configurations, BUG() does not result in an endless loop but returns
to the caller. This results in the following compiler warning:
drivers/hwmon/acpi_power_meter.c: In function 'show_str':
drivers/hwmon/acpi_power_meter.c:380: warning: 'val' may be used uninitialized in this function
Fix the warning by setting val to an empty string after BUG().
drivers/hwmon/smsc47b397.c: In function 'smsc47b397_init':
drivers/hwmon/smsc47b397.c:385: warning: 'address' may be used uninitialized in this function
value from smsc47b397_find with both address and error return code (the address
a few bytes (64 bytes for x86_64).
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
