path: root/drivers/hwmon/lm90.c
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2013-12-12hwmon: (lm90) Unregister hwmon device if interrupt setup failsGuenter Roeck
Commit 109b1283fb (hwmon: (lm90) Add support to handle IRQ) introduced interrupt support. Its error handling code fails to unregister the already registered hwmon device. Fixes: 109b1283fb532ac773a076748ffccf76a7067cab Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Add power controlWei Ni
The device lm90 can be controlled by the vcc rail. Adding the regulator support to power on/off the vcc rail. Enable the "vcc" regulator before accessing the device. [JD: Rename variables to avoid confusion with registers.] Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Add support for TI TMP451Wei Ni
TI TMP451 is mostly compatible with ADT7461, except for local temperature low byte and max conversion rate. Add support to the LM90 driver. Signed-off-by: Wei Ni <wni@nvidia.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Use enums for the indexes of temp8 and temp11Wei Ni
Using enums for the indexes and nrs of temp8 and temp11. This make the code much more readable. Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Add support to handle IRQWei Ni
When the temperature exceed the limit range value, the driver can handle the interrupt. Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Define status bitsWei Ni
Add bit defines for the status register. And add a function lm90_is_tripped() which will read status register and return tripped or not, then lm90_alert can call it directly, and in the future the IRQ thread also can use it. [JD: Adjusted to include all the new MAX6696 status flags.] Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-11-15hwmon: (lm90) Fix max6696 alarm handlingGuenter Roeck
Bit 2 of status register 2 on MAX6696 (external diode 2 open) sets ALERT; the bit thus has to be listed in alert_alarms. Also display a message in the alert handler if the condition is encountered. Even though not all overtemperature conditions cause ALERT to be set, we should not ignore them in the alert handler. Display messages for all out-of-range conditions. Reported-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: stable@vger.kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-07-08hwmon: (lm90) Drop redundant safety on cache lifetimeJean Delvare
time_after (as opposed to time_after_equal) already ensures that the cache lifetime is at least as much as requested. There is no point in manually adding another jiffy to that value, and this can confuse the reader into wrong interpretation. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Imre Deak <imre.deak@intel.com>
2013-01-25hwmon: Replace SENSORS_LIMIT with clamp_valGuenter Roeck
SENSORS_LIMIT and the generic clamp_val have the same functionality, and clamp_val is more efficient. This patch reduces text size by 9052 bytes and bss size by 11624 bytes for x86_64 builds. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: George Joseph <george.joseph@fairview5.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-07-21hwmon: (lm90) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-23hwmon: (lm90) Restore original configuration if probe function failsGuenter Roeck
The lm90 driver restores the original chip configuration in its exit function. However, the chip configuration is not restored if the probe function fails. Restore it there as well. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-03-23hwmon: (lm90) Add support for GMT G781Guenter Roeck
GMT G781 is a ADM1032-compatible temperature sensor chip. Add support to the LM90 driver. Cc: Mike Gorchak <lestat@i.com.ua> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-03-23hwmon: (lm90) Fix multi-line commentsGuenter Roeck
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-16hwmon: (lm90) Add range check to set_update_intervalGuenter Roeck
When writing the update_interval attribute, the parameter value was not range checked, which could cause an integer overflow and result in an arbitrary update interval. Fix by limiting the value range to <0, 100000>. Reported-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-05hwmon: replaced strict_str* with kstr*Frans Meulenbroeks
replaced strict_strtol with kstrtol and replaced strict_strtuol with kstrtuol This satisfies checkpatch -f Compile tested only: no warnings or errors given Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-11-04hwmon: (lm90) Make code more readableJean Delvare
Clean up the code to make it more readable: * Remove reg_ and new_ prefixes from variable names, they made the names longer, causing extra line breaks, while not adding much value. * Introduce struct device dev* = &client->dev in two functions, to avoid repeating client->dev everywhere in these functions. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-11-04hwmon: (lm90) Fix warningsJean Delvare
With some configuration option combinations, we get the following warnings: drivers/hwmon/lm90.c: In function 'lm90_detect': drivers/hwmon/lm90.c:1114: warning: 'chip_id' may be used uninitialized in this function drivers/hwmon/lm90.c:1114: warning: 'reg_config1' may be used uninitialized in this function drivers/hwmon/lm90.c:1114: warning: 'reg_convrate' may be used uninitialized in this function drivers/hwmon/lm90.c:1187: warning: 'reg_emerg2' may be used uninitialized in this function drivers/hwmon/lm90.c:1187: warning: 'reg_status2' may be used uninitialized in this function We can solve these easily by reading the register values first and checking for errors later. These errors should be very rare, even in the case of failed detection, so this change has no impact on performance. And this makes checkpatch.pl happier. Reported-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm90) Refactor reading of config2 registerJean Delvare
Several vendors implement a second configuration register, which we check during device detection. Refactor the code to avoid duplication. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stijn Devriendt <sdevrien@cisco.com> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm90) Make SA56004 detection more robustJean Delvare
With a device ID register value of 0, the SA56004 detection is rather weak. Check several other register too to confirm the detection, as we do for other supported devices. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stijn Devriendt <sdevrien@cisco.com> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Stijn Devriendt <sdevrien@cisco.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm90) Simplify handling of extended local temp registerJean Delvare
The optional extended local temperature register can never have address 0, as this address is already used by another register. Thus we can get rid of flag LM90_HAVE_LOCAL_EXT and simply rely on reg_local_ext being non-zero to determine if a given chip has this extension or not. This makes the code more simple. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stijn Devriendt <sdevrien@cisco.com> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm90) Add support for Philips SA56004Stijn Devriendt
Add support for Philips SA56004, an LM86 compatible temperature sensor. Signed-off-by: Stijn Devriendt <sdevrien@cisco.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-04-29hwmon: (lm90) Add support for ADT7461A and NCT1008Guenter Roeck
This patch adds support for ADT7461A and NCT1008 to the lm90 driver. Both chips have identical functionality and report the same manufacturing ID and device ID values. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm90) Add support for the W83L771W/GJean Delvare
I was wondering if that chip ever existed publicly... Apparently yes, so add support for it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (lm90) Add support for update_interval sysfs attributeGuenter Roeck
2010-10-28hwmon: (lm90) Introduce capability flag to indicate broken ALERT functionalityGuenter Roeck
2010-10-28hwmon: (lm90) Introduce chip parameter structureGuenter Roeck
Instead of using switch/case and if statements in probe, define chip specific functionality in a parameter structure array. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm90) Rearrange code to no longer require forward declarationsGuenter Roeck
2010-10-28hwmon: (lm90) Add support for max6695 and max6696Guenter Roeck
2010-10-28hwmon: (lm90) Add support for extra features of max6659Guenter Roeck
2010-10-28hwmon: (lm90) Add explicit support for max6659Guenter Roeck
2010-10-28hwmon: (lm90) Simplify set_temp11 register calculationsGuenter Roeck
2010-10-28hwmon: (lm90) Introduce function to delete sysfs filesGuenter Roeck
2010-10-28hwmon: (lm90) Introduce device feature bitsGuenter Roeck
2010-10-28hwmon: (lm90) Fix checkpatch errorsGuenter Roeck
2010-05-27hwmon: (lm90) Use programmed update rateIra W. Snyder
The lm90 driver programs the sensor chip to update its readings at 2 Hz (500 ms between readings). However, the driver only does reads from the chip at intervals of 2 * HZ (2000 ms between readings). Change the driver update rate to the programmed update rate. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (lm90) Add SMBus alert supportJean Delvare
Tested successfully with an ADM1032 chip on its evaluation board. It should work fine with all other chips as well. At this point this is more of a proof-of-concept, we don't do anything terribly useful on SMBus alert: we simply log the event. But this could later evolve into libsensors signaling so that user-space applications can take an appropriate action. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-05hwmon: (lm90) Restore configuration on exitJean Delvare
Restore the chip configuration when unloading the driver. This ensures we don't leave the chip running if it was initially stopped. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (lm90) Add support for the Winbond/Nuvoton W83L771AWG/ASGJean Delvare
This chips is found on several Zotac Ion ITX boards, amongst others. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: MC Matti <mcmatti17@googlemail.com> Cc: Manuel Lamotte-Schubert <mls@pronego.com>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_2 to 8Jean Delvare
These macros simply declare an enum, so drivers might as well declare it themselves. This puts an end to the arbitrary limit of 8 chip types per i2c driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: (lm90) Clean up detect functionJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-12hwmon: (lm90) Document support for the MAX6648/6692 chipsDarrick J. Wong
Update documentation to prevent further confusion/duplication. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-26hwmon: (lm90) Add support for the LM99 16 degree offsetJean Delvare
The LM99 differs from the LM86, LM89 and LM90 in that it reports remote temperatures (temp2) 16 degrees lower than they really are. So far we have been cheating and handled this in userspace but it really should be handled by the driver directly. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org>
2008-10-26hwmon: (lm90) Fix handling of hysteresis valueJean Delvare
There are several problems in the way the hysteresis value is handled by the lm90 driver: * In show_temphyst(), specific handling of the MAX6646 is missing, so the hysteresis is reported incorrectly if the critical temperature is over 127 degrees C. * In set_temphyst(), the new hysteresis register value is written to the chip but data->temp_hyst isn't updated accordingly, so there is a short period of time (up to 2 seconds) where the old hystereris value will be returned while the new one is already active. * In set_temphyst(), the critical temperature which is used as a base to compute the value of the hysteresis register lacks device-specific handling. As a result, the value of the hysteresis register might be incorrect for the ADT7461 and MAX6646 chips. Fix these 3 bugs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Nate Case <ncase@xes-inc.com>
2008-10-17hwmon: (lm90) Don't spam the kernel logJean Delvare
Degrade the "Unsupported chip" message from info to debug level. There's nothing wrong with this, so no need to bother the user. Also make the message slightly more descriptive. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Martyn Welch <martyn.welch@gefanuc.com>
2008-10-17hwmon: (lm90) Support MAX6646, MAX6647 and MAX6649Ben Hutchings
These Maxim chips are similar to MAX6657 but use unsigned temperature values to allow for readings up to 145 degrees. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
