path: root/drivers/hid/usbhid/hiddev.c
2009-11-05HID: remove BKL from hiddev_ioctl_usage()Jiri Kosina
The race between ioctl and disconnect is guarded by low level hiddev device mutex (existancelock) since the commit 07903407 ("HID: hiddev cleanup -- handle all error conditions properly"), therefore we can remove the lock_kernel() from hiddev_ioctl_usage(). Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-20HID: support larger reports than 64 bytes in hiddevJiri Kosina
hiddev userspace driver uses a rignbuffer to store the parsed usages that should be returned through read(). This buffer is 64 bytes long, which is sufficient for queueing single USB 1.0 low-speed report, which is of maximum size 48 bytes. There are however USB HID devices which are full-speed USB devices, and therefore they are free to produce reports 64 bytes long. This is correctly handled by HID core, but read() on hiddev node gets stuck forever, because the ring buffer loops infinitely (as it is exactly 64 bytes long as well), never advancing the buffer pointer. Plus, the core driver is ready to handle highspeed devices, so we should be able to handle reports from such devices in the hiddev driver as well, which means we need larger ringbuffer. Reported-by: Michael Zeisel <michael.zeisel@philips.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Move dereferences below a NULL test HID: hiddev, fix lock imbalance
2009-06-22HID: hiddev, fix lock imbalanceJiri Slaby
Add omitted BKL to one switch/case. Cc: Stable <stable@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-15Driver Core: usb: add nodename support for usb drivers.Kay Sievers
This adds support for USB drivers to report their requested nodename to userspace. It also updates a number of USB drivers to provide the needed subdirectory and device name to be used for them. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-30Merge branch 'autosuspend' into for-nextJiri Kosina
Conflicts: drivers/hid/hid-core.c
2009-03-30HID: fix race between usb_register_dev() and hiddev_open()Oliver Neukum
upon further thought this code is still racy. retval = usb_register_dev(usbhid->intf, &hiddev_class); here you open a window during which open can happen if (retval) { err_hid("Not able to get a minor for this device."); hid->hiddev = NULL; kfree(hiddev); return -1; } else { hid->minor = usbhid->intf->minor; hiddev_table[usbhid->intf->minor - HIDDEV_MINOR_BASE] = hiddev; and will fail because hiddev_table hasn't been updated The obvious fix of using a mutex to guard hiddev_table doesn't work because usb_open() and usb_register_dev() take minor_rwsem and we'd have an AB-BA deadlock. We need a lock usb_open() also takes in the right order and that leaves only one option, BKL. I don't like it but I see no alternative. Once the usb_open() implements something better than lock_kernel(), we could also do so. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-25HID: autosuspend support for USB HIDOliver Neukum
This uses the USB busy mechanism for aggessive autosuspend of USB HID devices. It autosuspends all opened devices supporting remote wakeup after a timeout unless - output is being done to the device - a key is being held down (remote wakeup isn't triggered upon key release) - LED(s) are lit - hiddev is opened As in the current driver closed devices will be autosuspended even if they don't support remote wakeup. The patch is quite large because output to devices is done in hard interrupt context meaning a lot a queuing and locking had to be touched. The LED stuff has been solved by means of a simple counter. Additions to the generic HID code could be avoided. In addition it now covers hidraw. It contains an embryonic version of an API to let the generic HID code tell the lower levels which capabilities with respect to power management are needed. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-10HID: fix waitqueue usage in hiddevJohannes Weiner
DECLARE_WAITQUEUE doesn't initialize the wait descriptor's task_list to 'empty' but to zero. prepare_to_wait() will not enqueue the descriptor to the waitqueue and finish_wait() will do list_del_init() on a list head that contains NULL pointers, which oopses. This was introduced by 079034073 "HID: hiddev cleanup -- handle all error conditions properly". The prior code used an unconditional add_to_waitqueue() which didn't care about the wait descriptor's list head and enqueued the thing unconditionally. The new code uses prepare_to_wait() which DOES check the prior list state, so use DEFINE_WAIT instead. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-10HID: fix incorrect free in hiddevJohannes Weiner
If hiddev_open() fails, it wrongly frees the shared hiddev structure kept in hiddev_table instead of the hiddev_list structure allocated for the opened file descriptor. Existing references to this structure will then accessed free memory. This was introduced by 079034073 "HID: hiddev cleanup -- handle all error conditions properly". Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-29HID: fix reversed logic in disconnect testing of hiddevOliver Neukum
The logic for testing for disconnection is reversed in an ioctl leading to false reports of disconnection. Signed-off-by: Oliver Neukum <oneukum@suse.de> Tested-by: Folkert van Heusden <folkert@vanheusden.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-07HID: fix hid->hiddev initialization in hiddev_connect()Jiri Kosina
Commit 079034073fa ("HID: hiddev cleanup -- handle all error conditions properly") by mistake removed proper initialization of hid->hiddev pointer in hiddev_connect() in case usb_register_dev() succeeds for the hiddev node. Put it properly back in place. Reported-and-tested-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04HID: hiddev cleanup -- handle all error conditions properlyOliver Neukum
This is a cleanup of hiddev and fixes the following issues: - thread safety by locking in read & ioctl, introducing a per device mutex - race between ioctl and disconnect, introducing a flag and locking in form of a per low level device mutex - race between open and other methods, making sure only successfully opened devices are put on the list, changing order of events - range checking both upper and lower limits of the minor range - make sure further calls to open fail for unplugged devices even if the device still has opened files - error checking for low level open - possible loss of wakeup events, using standard waiting macros - race in initialisation by moving registration after full initialisation Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23HID: fix lock imbalance in hiddevJiri Slaby
Don't forget to unlock_kernel() in hiddev_ioctl_usage(). Added in 7961df16819085b8a357720d89d0239036e6af2a (HID: Switch hiddev to unlocked_ioctl). Corresponing sparse warning: drivers/hid/usbhid/hiddev.c:515:10: warning: context imbalance in 'hiddev_ioctl_usage': wrong count at exit drivers/hid/usbhid/hiddev.c:515:10: context 'kernel_lock': wanted 0, got 1 Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: move connect quirksJiri Slaby
Move connecting from usbhid to the hid layer and fix also hidp in that manner. This removes all the ignore/force hidinput/hiddev connecting quirks. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-23HID: remove unused variable from hiddev compat ioctlJiri Kosina
Remove unused inode variable from hiddev compat ioctl handler. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-23HID: fix compile issue in hiddev ioctlJiri Kosina
Fix build failure introduced by Alan's ioctl -> unlocked_ioctl (pushing BKL down to the driver) conversion patch for hiddev. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-23HID: Switch hiddev to unlocked_ioctlAlan Cox
Push down the BKL. In some cases compat_ioctl already doesn't take the BKL so we don't either. Some of the locking here seems already dubious and object lifetimes want documenting Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-22HID: fix build failure in hiddev_ioctl with gcc 3.2Jean Delvare
Fix build failure in hiddev_ioctl with gcc 3.2: http://bugzilla.kernel.org/show_bug.cgi?id=10121 The trick is to move the handling of ioctls which need to allocate memory to separate functions. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-31HID: hiddev - fix compiler warningJiri Kosina
drivers/hid/usbhid/hiddev.c: In function 'hiddev_compat_ioctl': drivers/hid/usbhid/hiddev.c:746: warning: passing argument 4 of 'hiddev_ioctl' makes integer from pointer without a cast Add cast to hiddev_compat_ioctl() Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14HID: hiddev: Add 32bit ioctl compatibiltyPhilip Langdale
The hiddev driver currently lacks 32bit ioctl compatibility, so if you're running with a 64bit kernel and 32bit userspace, it won't work. I'm pretty sure that the only thing missing is a compat_ioctl implementation as all structs have fixed size fields. With this change I can use revoco to configure my MX Revolution mouse. Signed-off-by: Philip Langdale <philipl@overt.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-07-09HID: make debugging output runtime-configurableJiri Kosina
There have been many reports recently about broken HID devices, the diagnosis of which required users to recompile their kernels in order to be able to provide debugging output needed for coding a quirk for a particular device. This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it possible to control debugging output produced by HID code by supplying 'debug=1' module parameter. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-05-10USB HID: hiddev - fix race between hiddev_send_event() and hiddev_release()Jiri Kosina
There is a small race window in which hiddev_release() could corrupt the list that is being processed for new event in hiddev_send_event(). Synchronize the operations over this list. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-04-11USB HID: move usbhid code from drivers/usb/input to drivers/hid/usbhidJiri Kosina
Separate usbhid code into dedicated drivers/hid/usbhid directory as discussed previously with Greg, so that it eases maintaineance process. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
