path: root/drivers/hid/hid-ntrig.c
2009-03-30HID: remove compat stuffJiri Slaby
This removal was scheduled and there is no problem with later distros to adapt for the new bus, thanks to aliases. module-init-tools map files are deprecated nowadays, so that the patch which introduced hid ones into the m-i-t won't be accepted and hence there is no reason for leaving compat stuff in. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: add n-trig digitizer supportRafi Rubin
Added quirks for the N-Trig digitizer. Signed-off-by: Rafi Rubin <rafi@seas.upenn.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
