At present the G29 is mis-identified as a DFGT, this patch ensures
that the wheel is correctly detected and allows setting the LEDs and
turning range via the '/sys' interface.
This wheel can also emulate other types of Logitech wheels.
Signed-off-by: Simon Wood <simon@mungewell.org>
Since this wheel is now available, and the USBID is listed on their website,
this patch adds it to allow the hid-lg4ff force feedback driver to find it.
I do not have this wheel to test with, but this should at least get it working
in emulation mode.
Note: There is probably more work required for adjust HID descriptor and handle
switching between emulation and native modes.
Signed-off-by: Jiri Kosina <jkosina@suse.com>
Only one of LG_FF flags can be set for a given device.
Signed-off-by: Michal Malý <madcatxster@devoid-pointer.net>
Stop the hid device from lg4ff. Originally hid-lg was responsible for
stopping of the device.
Check return values from lg[N]ff_init(). hid-lg did not check return values from
the lg[N]_init() functions, possibly trying to work with a device whose
initialization has failed.
wait_event_interruptible_timeout() expects a timeout in jiffies so the
numeric constant becomes HZ dependent - put it through msecs_to_jiffies()
to make it HZ independent.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
compatibility mode
Introduce a module parameter to disable automatic switch of Logitech gaming
wheels from compatibility to native mode. This only applies to multimode wheels.
Tested-by: Simon Wood <simon@mungewell.org>
There are a few very theoretical off-by-one bugs in report descriptor size
checking when performing a pre-parsing fixup. Fix those.
Cc: stable@vger.kernel.org
Reported-by: Ben Hawkes <hawkes@google.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
ret = hid_output_raw_report(A, B, C, HID_FEATURE_REPORT);
is equivalent to
ret = hid_hw_raw_request(A, B[0], B, C, HID_FEATURE_REPORT, HID_REQ_SET_REPORT);
whatever the transport layer is.
So use the new API where available
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Add a helper to access hdev->hid_output_raw_report().
To convert the drivers, use the following snippets:
for i in drivers/hid/*.c
do
sed -i.bak "s/[^ \t]*->hid_output_raw_report(/hid_output_raw_report(/g" $i
done
Then manually fix for checkpatch.pl
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
I have two Logitech Dual Action gamepads, both have same Vendor/Device id pair.
Newest gamepad (A) can switch between old mode (HID) and XBox gamepad emulation
mode. Old gamepad (B) can only work in HID mode. In HID mode gamepad A sends
many EPIPE errors during initialization and was disconnected immediately after
connect to usb port. It works fine in Win and Mac. After adding NOGET quirk in
driver, it was working properly. Gamepad B works fine before and after
changes. I tested both gamepads with 3.8.0 and 3.11.6 kernels with modified
driver. Follow patch can apply for current git kernel version. I can send pcap
log from usb bus with both gamepads or any other additional information if it
is needed
Signed-off-by: Vitaly Katraew <zawullon@gmail.com>
By default the Logitech MOMO Force (Black) presents a combined accel/brake
axis ('Y'). This patch modifies the HID descriptor to present seperate
accel/brake axes ('Y' and 'Z').
By default the Logitech Formula Vibration presents a combined accel/brake
Add USB IDs for Logitech Formula Vibration Feedback Wheel (046d:ca04).
The lg2ff force feedback subdriver is used for vibration and
HID_GD_MULTIAXIS is set to avoid deadzone like other Logitech wheels.
Kconfig description etc are also updated accordingly.
Signed-off-by: Elias Vanderstuyft <Elias.vds@gmail.com>
[anssi.hannula@iki.fi: added description and CCs]
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
'for-3.9/thingm' and 'for-3.9/upstream' into for-linus
This patch ensures that the Logitech wheels are not initialised with
default fuzz/flat values, by marking them as multiaxis devices (rather
than joysticks).
Previously 'LG4FF' was only used for the WiiWheel, however it is now used
for all the Logitech Wheels. This patch corrects the detection mechanism
for the patching the report descriptor to ensure only the WiiWheel will
be patched.
This patch provides a modified report descriptor to split accelerator
and brake, and adds the 'NO_GET' flag to prevent it hanging on
connection.
Note: for convience this patch is against the follow patch which was applied
earlier this week.
https://patchwork.kernel.org/patch/2153471/
Signed-off-by: Paul Sbarra <sbarra.paul@gmail.com>
This is the original report descriptor as reported by lsusb -vd 046d:c294.
Use the new module_hid_driver macro in all HID drivers that have
a simple register/unregister init/exit.
This also converts the hid drivers that test for a failure of
hid_register_driver() and report the failure. Using module_hid_driver
in those drivers removes the failure message.
drivers/hid/usbhid/hid-quirks.c
Fixes a couple of minor coding style issues.
Signed-off-by: Michal Malý <madcatxster@gmail.com>
Range limiting command for the Driving Force Pro wheel is only a FF_SPRING
effect so that the wheel creates resistance when the user tries to turn it past
the limit. It is however possible to overpower the FFB motors quite easily which
leads to the X axis value exceeding the expected limit. This confuses
games which dynamically adjust calibration using the highest/lowest min and max
values reported by the wheel. Joydev device driver also doesn't take in account
any changes in an axis range after the joystick device is created.
This patch recalculates received ABS_X axis value so it is always in
<0; 16383> range where 0 is the left limit and 16383 the right limit.
Logitech driver for Windows does the same thing. As for any concerns about
possible loss of precision, I compared a large set of raw/adjusted values
generated by "mult_frac" to values returned by the Windows driver and I got
a 100% match.
Other Logitech wheels will probably need a similar fix, but I currently lack
the information needed to write one.
Paul Walmsley has implemented dynamic quirk handling back in 2007 through
commits:
2eb5dc30eb ("USB HID: encapsulate quirk handling into hid-quirks.c")
8222fbe67c ("USB HID: clarify static quirk handling as squirks")
8cef908235 ("USB HID: add support for dynamically-created quirks")
876b9276b9 ("USB HID: add 'quirks' module parameter")
and as such, his copyright rightly belongs to
drivers/hid/usbhid/hid-quirks.c file.
However when generic HID code has been converted to bus and individual
quirks separated out to individual drivers on the bus, the copyright has
been blindly transfered into all the tiny drivers, which actually don't
contain any of Pauls' copyrighted code.
Remove the copyright from those sub-drivers.
Acked-by: Paul Walmsley <paul@pwsan.com>
priv drvdata
This patch adds support for custom device-specific properties which can now be
stored as private driver data and read/saved using hid_get/set_drvdata().
Tested-by: simon@mungewell.org
Wheel range of certain Logitech wheels - namely Driving Force GT, Driving Force
Pro, G25 and G27 can be adjusted. Minimu is 40 degrees, maximum 900. DFGT, G25
and G27 all use a common command, DFP uses another one. Range can be set from
userspace by writing to
"/sys/module/hid_logitech/drivers/hid:logitech/<dev>range". The driver use list
to store range of each connected wheel; it's not possible to use driver_data in
hid_device struct as it's already b hig-lg driver.
This is the first out of five patches me and Simon Wood (CC'd) have been
working on. It separates the handling of Logite from the generic lgff driver
and adds additional features specific for the Logitech wheels, namely
- Native mode support for Driving Force GT, Driving Force Pro, G25 and G27
wheels Every Logitech wheel reports itself as generic Logitech Driving Force
wheel (VID 046d, PID c294). This is done to ensu wheel will work on every USB
HID-aware system even when no Logitech driver is available. It however limits
the capabilit wheel - range is limited to 200 degrees, G25/G27 don't report the
clutch pedal and there is only one combined axis for t brake. The switch to
native mode is done via hardware-specific command which is different for each
wheel. When the wheel receives such command, it simulates reconnect and reports
to the OS with its actual PID.
- Adjustable wheel range DFGT, DFP, G25 and G27 have variable range of the
steering wheel. The range is limited by applying a maximum constant when the
wheel is turned beyond the allowed range. The limit as also set by a
hardware-specific command. There is a comm command for DFGT, G25 and G27 and
another one for DFP. It is probably possible to use the DFP command to limit
the range other Logitech wheels too, but this is not supported by the official
Logitech driver for Windows. The patch adds a sysfs interface which allows for
the range to be set from userspace.
- Fixed autocentering command All Logitech wheels support FF_AUTOCENTER effect.
The original implementation in the lgff driver didn't work well with patch
fixes it. According to USB communication sniffs the Formula Force EX (pretty
much rebranded original Driving Force accept the generic autocentering command,
this issue is also addressed by the patch
There are still some features this patch doesn't cover, but since some of them
will most likely require modifications of memless driver we have decided not to
include them yet.
As first we decided to move the handling of Logitech wheels from hid-lgff
driver to hid-lg4ff driver (originally used fo At also adds PID of Logitech
Driving Force GT.
- Add the quirk "NOGET" to make the wheel work at all in native mode.
- Replace the somehow broken report descriptor with a custom one to have
separate throttle and brake axes.
As there are significant differences in the descriptor (original descriptor
"hides" the separate axes in a 24 bit FF00 usagepage, new descripter replaces
that with two individual 8 bit desktop.y and desktop.rz usages) I provided a
complete replacement descriptor instead trying to patch the original one.
Patching the descriptor seems not feasible as the new one is much larger.
Note: To actually test this you have to use the tool "ltwheelconf" to put the
DFP into it's native mode - See below for more info.
Background:
Most Logitech wheels are initially reporting themselves with a "fallback"
deviceID (USB_DEVICE_ID_LOGITECH_WHEEL - 0xc294), in order to make sure they
are working even without having the proper driver installed.
If the Logitech driver is installed it sends a special command to the wheel
which sets the wheel to "native mode", enabling enhance features like:
- Clutch pedal
- extended wheel rotation range (up to 900 degrees)
- H-gate shifter
- separate axis for throttle / brake
- all buttons
When the wheel is set to native mode it basically disconnects and reconnects
with a different deviceID (USB_DEVICE_ID_LOGITECH_DFP_WHEEL - 0xc298 in this
case).
I am working on a userspace tool [1] which does the switching from fallback to
native mode. During development I found out that the Driving Force Pro wheel
is not supported in native mode - quierk NOGET is missing and the throttle and
brake axes are reported in a combined way only.
Signed-off-by: Michael Bauer <michael@m-bauer.org>
[1] https://github.com/TripleSpeeder/LTWheelConf
Gere's a small patch to add support for the Logitech G27 wheel, since
the prior patch only added FF support for the Driving Force Pro and G25.
The patch contains the changes from the G25 and DFP, too.
I tested the changes with wine/LFS and got full support for all axes and
buttons.
Signed-off: Peter Gundermann <slim-one@users.sourceforge.net>
Add force feedback support for Logitech Driving Force Pro wheel.
Device IDs reported by Michal Malý.
Reported-by: Michal Malý <madcatxster@gmail.com>
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
Fix wrong merge in hid-lg -- report fixup functions now get
pointer to rdesc.
drivers/hid/hid-ids.h
drivers/hid/hid-lg.c
This patch adds force feedback support for Logitech WingMan RumblePad
gamepads by extending the Logitech Rumblepad 2 force feedback code.
Signed-off-by: Hendrik Iben <Hendrik_Iben@web.de>
The following patch adds support for the Logitech Speed Force Wireless gaming
wheel. Originally designed for the WII console. Details on the protocol:
http://wiibrew.org/wiki/Logitech_USB_steering_wheel
This patch relies on previous patch:
"Don't Send Feature Reports on Interrupt Endpoint"
Logitech as produce a very similar wheel for the PS2/PS3, it is expected that
this patch could also support the PS2/PS3 wheel if the USB ID's are added and
(if required) the HID descriptor is modified.
Update hid_driver's report_fixup prototype to allow changing report
descriptor size and/or returning completely different report descriptor.
Update existing usage accordingly.
This is to give more freedom in descriptor fixup and to allow having a whole
fixed descriptor in the code for the sake of readability.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
The keys are added to the generic wireless mappings in case other
keyboards use them. Note that the product ID for the MX3200 is the same
as USB_DEVICE_ID_S510_RECEIVER_2.
Signed-off-by: Lorenzo Castelli <lcastelli@gmail.com>
Implements a new USB-HID for Force Feedback based on the normal
Logitech Force Feedback code and FF-Memless.
Currently only supports the FF_CONSTANT effect although the joystick
appears to support additional non-standard ones.
Signed-off-by: Gary Stein <LordCnidarian@gmail.com>
Put proper mapping of Media key on Logitech DiNovo Mini.
According to the specification from Logitech webpage, this
key is intended to launch a Media center.
Reported-by: Stefan Plattner <Stefan.Plattner@ilogs.com>
These devices wrongly report their axes as relative instead of absolute.
Fix this in up report descriptor of the device before it enters the parser.
Reported-by: simon.windows@gmail.com
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions of several HID drivers from drivers/hid/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Add force feedback support for Logitech WingMan Formula Force GP
(0x046d/0xc293).
Reported-by: wylda@volny.cz
Tested-by: wylda@volny.cz
Add Product Id 0xc299 for the Logitech G25 force feedback wheel
The Logitech G25 force feedback wheel, is first recognize by the kernel
with the product id "0xc294". In this mode, we can't use all the axes
and buttons of the wheel.
Using a userland utility, it is possible to make the wheel switch to native
mode -- http://svn.vdrift.net/viewvc.cgi/trunk/tools/G25manage/?root=VDrift
In native mode, the wheel change its id number to "0xc299".
The packet that needs to be sent to the wheel to swtich to native mode and
change its PID is
{ 0xf8, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00 }
Signed-off-by: Christophe Borivant <christophe.borivant@wanadoo.fr>
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
This patch (as1146c) makes usbhid automatically call usbhid_set_leds()
for any device that supports the keyboard boot protocol.
In theory this should be perfectly safe. BIOSes send the LED output
report as part of their normal device initialization, so any keyboard
device supporting the boot protocol has to be able to handle it.
As a side effect, the hid-dell and hid-bright drivers are no longer
needed, and the Logitech keyboard driver can be removed from hid-lg.
CC: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This reverts commit 740f370dc61dc478d891d7d47660bb3ae39ddb4f.
It turned out to be correct in the first place: a positive value should
be sent when the wheel is moved to the right, and a negative value when
moved to the left. This is the behavior expected by the Xorg evdev
driver. I must have had a remapping somewhere else in my system when
originally testing this. Testing on another system shows that the
unpatched kernel is correct.
Here is a bug report from Mandriva that brought the problem to my
attention:
https://qa.mandriva.com/show_bug.cgi?id=44309#c19
Signed-off-by: Dan Nicholson <dbn.lists@gmail.com>
Merge the logitech force feedback processing directly into logitech
driver from the usbhid core.
