If tpkbd_probe_tp() bails out, the probe() function return an error,
but hid_hw_stop() is never called.
fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=1003998
Cc: stable@vger.kernel.org
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
A HID device could send a malicious output report that would cause the
lenovo-tpkbd HID driver to write just beyond the output report allocation
during initialization, causing a heap overflow:
[ 76.109807] usb 1-1: New USB device found, idVendor=17ef, idProduct=6009
[ 80.462540] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2894
'for-3.10/upstream' into for-linus
drivers/hid/Kconfig
In pointer_press_speed_show, we do
data_pointer = hid_get_drvdata(hdev);
twice in a row. Remove one of those.
This allows the hid drivers to be independent from the transport layer.
The patch was constructed by replacing all occurences of
usbhid_submit_report() by its hid_hw_request() counterpart.
Then, drivers not requiring USB_HID anymore have their USB_HID
dependency cleaned in the Kconfig file.
Finally, few drivers still depends on USB_HID. Many of them
are requiring the io wait callback. They are found in the next patch.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
For the sensor-hub part:
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Use the new module_hid_driver macro in all HID drivers that have
a simple register/unregister init/exit.
This also converts the hid drivers that test for a failure of
hid_register_driver() and report the failure. Using module_hid_driver
in those drivers removes the failure message.
drivers/hid/usbhid/hid-quirks.c
We need to kfree names for led_mute and led_micmute in tpkbd_remove_tp().
Acked-by: Bernhard Seibold <mail@bernhard-seibold.de>
container_of() never returns NULL, thus also remove the NULL checking for it.
This driver for the "Lenovo ThinkPad USB Keyboard with Trackpoint" supports
setting various device attributes, controlling mute and microphone mute
LEDs and enables use of the microphone mute key.
Signed-off-by: Bernhard Seibold <mail@bernhard-seibold.de>
