[ Upstream commit 66822d815ae61ecb2d9dba9031517e8a8476969d ]
Higher sclks seem to be unstable on some boards.
bug: https://bugs.freedesktop.org/show_bug.cgi?id=100222
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
[ Upstream commit 0f424de1fd9bc4ab24bd1fe5430ab5618e803e31 ]
OLAND 0x1002:0x6604 0x1028:0x066F 0x00 seems to have problems
with higher sclks.
Acked-by: Christian König <christian.koenig@amd.com>
[ Upstream commit 655d9ca9ac075da1ef2a45012ba48a39f6eb1f58 ]
The AMD ACP driver adds "-I../acp -I../acp/include" to the gcc command
line, which makes no sense, since these are evaluated relative to the
build directory. When we build with "make W=1", they instead cause
a warning:
cc1: error: ../acp/: No such file or directory [-Werror=missing-include-dirs]
cc1: error: ../acp/include: No such file or directory [-Werror=missing-include-dirs]
cc1: all warnings being treated as errors
../scripts/Makefile.build:289: recipe for target 'drivers/gpu/drm/amd/amdgpu/amdgpu_drv.o' failed
../scripts/Makefile.build:289: recipe for target 'drivers/gpu/drm/amd/amdgpu/amdgpu_device.o' failed
../scripts/Makefile.build:289: recipe for target 'drivers/gpu/drm/amd/amdgpu/amdgpu_kms.o' failed
This removes the subdir-ccflags variable that evidently did not
serve any purpose here.
[ Upstream commit 9fa1d7537242bd580ffa99c4725a0407096aad26 ]
omap_gem_dmabuf_mmap() returns an error (with a WARN) when called for a
buffer which is allocated with dma_alloc_*(). This prevents dmabuf mmap
from working on SoCs without DMM, e.g. AM4 and OMAP3.
I could not find any reason for omap_gem_dmabuf_mmap() rejecting such
buffers, and just removing the if() fixes the limitation.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[ Upstream commit 607523d19c9d67ba4cf7bdaced644f11ed04992c ]
If we don't reset the chunk info in the error path, the subsequent
fini path will double free.
Reviewed-by: Christian König <christian.koenig@amd.com>
[ Upstream commit c085bd5119d5d0bdf3ef591a5563566be7dedced ]
Signed-off-by: Jim Qu <Jim.Qu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
This reverts commit 82f260d472c3b4dbb7324624e395c3e91f73a040.
Not required on < 4.10.
commit 120a264f9c2782682027d931d83dcbd22e01da80 upstream.
When no IOMMU is available, all GEM buffers allocated by Exynos DRM driver
are contiguous, because of the underlying dma_alloc_attrs() function
provides only such buffers. In such case it makes no sense to keep
BO_NONCONTIG flag for the allocated GEM buffers. This allows to avoid
failures for buffer contiguity checks in the subsequent operations on GEM
objects.
Signed-off-by: Inki Dae <inki.dae@samsung.com>
[ Upstream commit 3a1d19a29670aa7eb58576a31883d0aa9fb77549 ]
Virtual display doesn't allocate amdgpu_encoder when initializing,
so will get invaild pointer if try to free amdgpu_encoder when
unloading driver.
Signed-off-by: Xiangliang Yu <Xiangliang.Yu@amd.com>
[ Upstream commit 11d8bcef7a0399e1d2519f207fd575fc404306b4 ]
DECON_TV requires STANDALONE_UPDATE after output enabling, otherwise it does
not start. This change is neutral for DECON.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
[ Upstream commit e05208ded1905e500cd5b369d624b071951c68b9 ]
Set the proper bits for clockgating setup.
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
[ Upstream commit 821b40b79db7dedbfe15ab330dfd181e661a533f ]
STANDALONE_UPDATE_F should be set if something changed in plane configurations,
including plane disable.
The patch fixes page-faults bugs, caused by decon still using framebuffers
of disabled planes.
v2: fixed clear-bit code (Thx Marek)
v3: use test_and_clear_bit (Thx Joonyoung)
Tested-by: Joonyoung Shim <jy0922.shim@samsung.com>
[ Upstream commit f65a7c9cb3770ed4d3e7c57c66d7032689081b5e ]
Improper usage of DECON_UPDATE register leads to subtle errors.
If it set in decon_commit when there are no active windows it results
in slow registry updates - all subsequent shadow registry updates takes more
than full vblank. On the other side if it is not set when there are
active windows it results in garbage on the screen after suspend/resume of
FB console.
The patch hopefully fixes it.
commit 9fd99f4f3f5e13ce959900ae57d64b1bdb51d823 upstream.
The resume helpers wait for a vblank to occurre hence IRQ need
to be enabled. This avoids a warning as follows during resume:
WARNING: CPU: 0 PID: 314 at drivers/gpu/drm/drm_atomic_helper.c:1249 drm_atomic_helper_wait_for_vblanks.part.1+0x284/0x288
[CRTC:28:crtc-0] vblank wait timed out
Signed-off-by: Stefan Agner <stefan@agner.ch>
commit 9306e996574f7f57136a62e49cd0075f85713623 upstream.
With commit 0a70c998d0c5 ("drm/fsl-dcu: enable pixel clock when
enabling CRTC") the pixel clock is controlled by the CRTC code.
Disabling the pixel clock in suspend leads to a warning due to
the second clk_disable_unprepare call:
WARNING: CPU: 0 PID: 359 at drivers/clk/clk.c:594 clk_core_disable+0x8c/0x90
Remove clk_disable_unprepare call for pixel clock to avoid
unbalanced clock disable on suspend.
Fixes: 0a70c998d0c5 ("drm/fsl-dcu: enable pixel clock when enabling CRTC")
commit 56350fb8978bbf4aafe08f21234e161dd128b417 upstream.
The hardware always writes one or two bytes in the index portion of
an indexed transfer. Make sure the message we send as the index
doesn't have a zero length.
Cc: Daniel Kurtz <djkurtz@chromium.org>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Sean Paul <seanpaul@chromium.org>
Fixes: 56f9eac05489 ("drm/i915/intel_i2c: use INDEX cycles for i2c read transactions")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171123194157.25367-3-ville.syrjala@linux.intel.com
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
(cherry picked from commit bb9e0d4bca50f429152e74a459160b41f3d60fb2)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
commit ae5c631e605a452a5a0e73205a92810c01ed954b upstream.
We can only specify the one slave address to indexed reads/writes.
Make sure the messages we check are destined to the same slave
address before deciding to do an indexed transfer.
Link: https://patchwork.freedesktop.org/patch/msgid/20171123194157.25367-2-ville.syrjala@linux.intel.com
(cherry picked from commit c4deb62d7821672265b87952bcd1c808f3bf3e8f)
commit 8d8258bdab735d9f3c4b78e091ecfbb2b2b1f2ca upstream.
resulted in unexpected data truncation
commit 4d98e5ee6084f6d7bc578c5d5f86de7156aaa4cb upstream.
When the mutex is locked just in the moment we copy it we end up with a
warning that we release a locked mutex.
Fix this by properly reinitializing the mutex.
Signed-off-by: Christian König <christian.koenig@amd.com>
commit a2f042430784d86eb2b7a6d2a869f552da30edba upstream.
This patch fixes the following soft lockup:
BUG: soft lockup - CPU#0 stuck for 23s! [weston:307]
On weston idle-timeout the IP is powered down and reset
asserted. On weston resume we get a massive vblank
IRQ storm due to the LDI registers having lost some state.
This state loss is caused by ade_crtc_atomic_begin() not
calling ade_ldi_set_mode(). With this patch applied
resuming from Weston idle-timeout works well.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Xinliang Liu <xinliang.liu@linaro.org>
Signed-off-by: Xinliang Liu <xinliang.liu@linaro.org>
commit f3621a8eb59a913612c8e6e37d81f16b649f8b6c upstream.
During panel removal or system shutdown panel_simple_disable() is called
which disables the panel backlight but the panel is still powered due to
missing calls to panel_simple_unprepare().
Fixes: d02fd93e2cd8 ("drm/panel: simple - Disable panel on shutdown")
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170807115545.27747-1-net147@gmail.com
commit 4f626a4ac8f57ddabf06d03870adab91e463217f upstream.
The function for byteswapping the data send to/from atombios was buggy for
num_bytes not divisible by four. The function must be aware of the fact
that after byte-swapping the u32 units, valid bytes might end up after the
num_bytes boundary.
This patch was tested on kernel 3.12 and allowed us to sucesfully use
DisplayPort on and Radeon SI card. Namely it fixed the link training and
EDID readout.
The function is patched both in radeon and amd drivers, since the functions
and the fixes are identical.
Signed-off-by: Roman Kapl <rka@sysgo.com>
commit 78aa02c713fcf19e9bc8511ab61a5fd6c877cc01 upstream.
After commit ea09729c9302 ("drm/amdgpu: rework page directory filling
v2") then it becomes a lot harder to verify that "r" is initialized. My
static checker complains and so I've reviewed the code. It does look
like it might be buggy... Anyway, it doesn't hurt to set "r" to zero
at the start.
commit 40a9960b046290939b56ce8e51f365258f27f264 upstream.
We shifted some code around in commit 9cca0b8e5df0 ("drm/amdgpu: move
amdgpu_cs_sysvm_access_required into find_mapping") and now my static
checker complains that "r" might not be initialized at the end of the
function. I've reviewed the code, and that seems possible, but it's
also possible I may have missed something.
commit 18c437caa5b18a235dd65cec224eab54bebcee65 upstream.
Fixes distorted colors on some cards on resume from suspend.
This reverts commit b9729b17a414f99c61f4db9ac9f9ed987fa0cbfe.
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=98832
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=99163
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=107001
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
[ Upstream commit ae9d2daecf086958a41ad216152ec208d70ba325 ]
fsl is already fully demidlayered in the probe function, but for
convenience stuck with drm_put_dev. Call the unregister/unref parts
separately, to make sure this driver works correct.
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: CK Hu <ck.hu@mediatek.com>
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161208110739.24417-3-daniel.vetter@ffwll.ch
[ Upstream commit 3db93756b501e5f0a3951c79cfa9ed43c26d3455 ]
mm->color_adjust() compares the hole with its neighbouring nodes. They
only abutt before we restrict the hole, so we have to apply color_adjust
before we apply the range restriction.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20161222083641.2691-36-chris@chris-wilson.co.uk
[ Upstream commit 7357f89954b6d005df6ab8929759e78d7d9a80f9 ]
I reported the include issue for tracepoints a while ago, but nothing
seems to have happened. Now it bit us, since the drm_mm_print
conversion was broken for armada. Fix it, so I can re-enable armada
in the drm-misc build configs.
v2: Rebase just the compile fix on top of Chris' build fix.
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Acked: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/1483115932-19584-1-git-send-email-daniel.vetter@ffwll.ch
[ Upstream commit 0f0861e31e3c59ca4bc1ec59d99260cfca79740e ]
If 'sun4i_backend_drm_format_to_layer()' does not return 0, then 'val' is
left unmodified.
As it is not initialized either, the return value can be anything.
It is likely that returning the error code was expected here.
As the only caller of 'sun4i_backend_update_layer_formats()' does not check
the return value, this fix is purely theorical.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This reverts commit 7de694782cbe7840f2c0de6f1e70f41fc1b8b6e8 which is
commit 8777b927b92cf5b6c29f9f9d3c737addea9ac8a7 upstream.
It was reported to cause flickering and other regressions.
Reported-by: Rainer Fiebig <jrf@mailbox.org>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Matt Roper <matthew.d.roper@intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
reverted:
[ Upstream commit 4b0ea93f250afc6c1128e201b0a8a115ae613e47 ]
Here, pci_iomap can fail, handle this case and return -ENOMEM.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1483443027-13444-1-git-send-email-arvind.yadav.cs@gmail.com
[ Upstream commit 42f7f3c4811b3149253ecf2e133832c969884466 ]
Add module alias for Sony ACX565AKM LCD panel. This makes it probe on Nokia
N900 when panel driver is built as a module.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
[ Upstream commit 1ae0d5af347df224a6e76334683f13a96d915a44 ]
Here, If devm_ioremap_nocache will fail. It will return NULL.
Kernel can run into a NULL-pointer dereference. This error check
will avoid NULL pointer dereference.
Acked-by: Vincent Abriou <vincent.abriou@st.com>
commit 3587c856675c45809010c2cee5b21096f6e8e938 upstream.
I've found that by just turning the chip on and off via the
POWER_DOWN register, I end up getting i2c_transfer errors on
HiKey.
Investigating further, it turns out that some of the register
state in hardware is getting lost, as the device registers are
reset when the chip is powered down.
Thus this patch simply re-writes the i2c address to the
ADV7511_REG_EDID_I2C_ADDR register to ensure its properly set
before we try to read the EDID data.
Cc: David Airlie <airlied@linux.ie>
Cc: Archit Taneja <architt@codeaurora.org>
Cc: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-7-git-send-email-john.stultz@linaro.org
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
commit 4226d9b127cf4758ba0e07931b3f0d59f1b1a50c upstream.
Thus this patch changes the EDID probing logic so that we
re-use the __adv7511_power_on/off() calls instead of duplciating
logic.
This does change behavior slightly as it adds the HPD signal
pulse to the EDID probe path, but Archit has had a patch to
add HPD signal pulse to the EDID probe path before, so this
should address the cases where that helped. Another difference
is that regcache_mark_dirty() is also called in the power off
path once EDID is probed.
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-6-git-send-email-john.stultz@linaro.org
internally
commit 651e4769ba2a9f20c4b8a823ae2727bf7fa9c9f0 upstream.
In chasing down issues with EDID probing, I found some
duplicated but incomplete logic used to power the chip on and
off.
This patch refactors the adv7511_power_on/off functions, so
they can be used for internal needs.
Link: http://patchwork.freedesktop.org/patch/msgid/1484614372-15342-5-git-send-email-john.stultz@linaro.org
commit cef75036c40408ba3bc308bcb00a3d440da713fc upstream.
This is an extension of Commit 7c20d213dd3c ("drm/vmwgfx: Work
around mode set failure in 2D VMs")
With Wayland desktop and atomic mode set, during the mode setting
process there is a moment when two framebuffer sized surfaces
are being pinned. This was not an issue with Xorg.
Since this only happens during a mode change, there should be no
performance impact by increasing allowable mem_size.
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
The original intent was to preserve watermarks as much as possible
in intel_pipe_wm.raw_wm, and put the validated ones in intel_pipe_wm.wm.
It seems this approach is insufficient and we don't always preserve
the raw watermarks, so just use the atomic iterator we're already using
to get a const pointer to all bound planes on the crtc.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=102373
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Acked-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Matt Roper <matthew.d.roper@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171019151341.4579-1-maarten.lankhorst@linux.intel.com
(cherry picked from commit 28283f4f359cd7cfa9e65457bb98c507a2cd0cd0)
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
[ Upstream commit c7ffa59cf03c38b91d6ef01e42c1b52fd7a4f285 ]
When updating the rotation fields, one of the assignments zeroes out the
rest of the register fields, which include settings for chroma siting,
inverse gamma, AMBA AXI caching, and alpha blending.
Signed-off-by: Mihail Atanassov <mihail.atanassov@arm.com>
Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com>
[ Upstream commit a67834f8bfa1e2f48bb27d07b9a552ba7c3af82a ]
Call drm_debugfs_cleanup() in case drm_debugfs_init() fails to
cover for failure in the drm_driver.debugfs_init callback.
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20170126225621.12314-3-noralf@tronnes.org
[ Upstream commit e41456bfc811f12b5dcda6f2d6849bdff68f6c0a ]
The size computations done in the ioctl function use an integer.
If userspace submits a request with req->cmd_nr or req->cmd_buf_nr
set to INT_MAX, the integer computations overflow later, leading
to potential (kernel) memory corruption.
Prevent this issue by enforcing a limit on the number of submitted
commands, so that we have enough headroom later for the size
computations.
Note that this change has no impact on the currently available
users in userspace, like e.g. libdrm/exynos.
While at it, also make a comment about the size computation more
detailed.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
[ Upstream commit ef15d36154cc741d7ded4ae4fa0cf7987354e313 ]
clk_prepare_enable() may fail, so we should better check its return
value.
Also place the of_node_put() function right after clk_prepare_enable(),
in order to avoid calling of_node_put() twice in case clk_prepare_enable()
fails.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit 28ed5504ab4b211a4e589e648e5ebd1e0caa7a6a ]
commit 65e93108891e571f177c202add9288eda9ac4100 upstream.
We recently added an integer overflow check but it needs an additional
tweak to work properly on 32 bit systems.
The problem is that we're doing the right hand side of the assignment as
type unsigned long so the max it will have an integer overflow instead
of being larger than SIZE_MAX. That means the "sz > SIZE_MAX" condition
is never true even on 32 bit systems. We need to first cast it to u64
and then do the math.
Fixes: 4a630fadbb29 ("drm/msm: Fix potential buffer overflow issue")
Acked-by: Jordan Crouse <jcrouse@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 4a630fadbb29d9efaedb525f1a8f7449ad107641 upstream.
In function submit_create, if nr_cmds or nr_bos is assigned with
negative value, the allocated buffer may be small than intended.
Using this buffer will lead to buffer overflow issue.
Signed-off-by: Kasin Li <donglil@codeaurora.org>
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
commit 7c838e2a9be5ab79b11c7f1520813bfdf0f45462 upstream.
Per my reading of the eDP spec, DP_DPCD_DISPLAY_CONTROL_CAPABLE bit in
DP_EDP_CONFIGURATION_CAP should be set if the eDP display control
registers starting at offset DP_EDP_DPCD_REV are "enabled". Currently we
check the bit before reading the registers, and DP_EDP_DPCD_REV is the
only way to detect eDP revision.
Turns out there are (likely buggy) displays that require eDP 1.4+
features, such as supported link rates and link rate select, but do not
have the bit set. Read the display control registers
unconditionally. They are supposed to read zero anyway if they are not
supported, so there should be no harm in this.
This fixes the referenced bug by enabling the eDP version check, and
thus reading of the supported link rates. The panel in question has 0 in
DP_MAX_LINK_RATE which is only supported in eDP 1.4+. Without the
supported link rates method we default to RBR which is insufficient for
the panel native mode. As a curiosity, the panel also has a bogus value
of 0x12 in DP_EDP_DPCD_REV, but that passes our check for >= DP_EDP_14
(which is 0x03).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=103400
Reported-and-tested-by: Nicolas P. <issun.artiste@gmail.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Manasi Navare <manasi.d.navare@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171026142932.17737-1-jani.nikula@intel.com
(cherry picked from commit 0501a3b0eb01ac2209ef6fce76153e5d6b07034e)
commit cb4b02d7cac56a69d8137d8d843507cca9182aed upstream.
Fixes init failures on polaris cards with harvested UVD.
Signed-off-by: Leo Liu <leo.liu@amd.com>
commit 8b95f4f730cba02ef6febbdc4ca7e55ca045b00e upstream.
refresh_rate was not initialized when program
display gap.
this patch can fix vce ring test failed
when do S3 on Polaris10.
bug: https://bugs.freedesktop.org/show_bug.cgi?id=103102
bug: https://bugzilla.kernel.org/show_bug.cgi?id=196615
commit 77913bbcb43ac9a07a6fe849c2fd3bf85fc8bdd8 upstream.
Even though we've zeroed the PDE, the GPU may have cached the PD, so we
need to flush when deleting them.
Noticed while working on replacement MMU code, but a backport might be a
good idea, so let's fix it in the current code too.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 194d68dd051c2dd5ac2b522ae16100e774e8d869 upstream.
G92's seem to require some additional bit of initialization before the
BSP engine can work. It feels like clocks are not set up for the
underlying VLD engine, which means that all commands submitted to the
xtensa chip end up hanging. VP seems to work fine though.
This still allows people to force-enable the bsp engine if they want to
play around with it, but makes it harder for the card to hang by
default.
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
