path: root/drivers/gpu/drm
2011-05-21drm/radeon/kms: fix extended lvds info parsingAlex Deucher
commit 05fa7ea7d23980de0014417a0e0af2048a0f9fc1 upstream. On rev <= 1.1 tables, the offset is absolute, on newer tables, it's relative. Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=700326 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-21drm/i915: Release object along create user fb error pathChris Wilson
commit 2dd251f0a294300a1cf8f4b63768145fa6153c4d upstream. Reported-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-21drm/i915/lvds: Only act on lid notify when the device is onAlex Williamson
commit 2fb4e61d9471867677c97bf11dba8f1e9dfa7f7c upstream. If we're using vga switcheroo, the device may be turned off and poking it can return random state. This provokes an OOPS fixed separately by 8ff887c847 (drm/i915/dp: Be paranoid in case we disable a DP before it is attached). Trying to use and respond to events on a device that has been turned off by the user is in principle a silly thing to do. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-21drm/i915/dp: Be paranoid in case we disable a DP before it is attachedChris Wilson
commit 31acbcc408f412d1ba73765b846c38642be553c3 upstream. Given that the hardware may be left in a random condition by the BIOS, it is conceivable that we then attempt to clear the DP_PIPEB_SELECT bit without us ever enabling/attaching the DP encoder to a pipe. Thus causing a NULL deference when we attempt to wait for a vblank on that crtc. Reported-and-tested-by: Bryan Christ <bryan.christ@gmail.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=36314 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=36456 Reported-and-tested-by: Bo Wang <bo.b.wang@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-21drm/radeon/kms: fix gart setup on fusion parts (v2) backportAlex Deucher
Backport of 8aeb96f80232e9a701b5c4715504f4c9173978bd (drm/radeon/kms: fix gart setup on fusion parts (v2)) to the stable tree. Out of the entire GART/VM subsystem, the hw designers changed the location of 3 regs. v2: airlied: add parameter for userspace to work from. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-21drm/radeon/kms: add pci id to acer travelmate quirk for 5730Alex Deucher
commit 4f87af46107499415afd238be104587b5a9d7ac3 upstream. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=34082 Reported by: Sampo Laaksonen <zhamahn@gmail.com> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09drm/radeon: fix regression on atom cards with hardcoded EDID record.Dave Airlie
commit eaa4f5e1d0b816291a59a47917e569c0384f2b6f upstream. Since fafcf94e2b5732d1e13b440291c53115d2b172e9 introduced an edid size, it seems to have broken this path. This manifest as oops on T500 Lenovo laptops with dual graphics primarily. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=33812 Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm: select FRAMEBUFFER_CONSOLE_PRIMARY if we have FRAMEBUFFER_CONSOLEDave Airlie
commit bf5192edcbc1f0a7f9c054649dbf1a0b3210d9b7 upstream. Multi-gpu/switcheroo relies on this option to get the console on the correct GPU at bootup, some distros enable it but it seems some get it wrong. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm/i915/tv: Remember the detected TV typeMathew McKernan
commit d5627663f2088fa4be447fdcfd52bcb233448d85 upstream. During detect() we would probe the connection bits to determine if there was a TV attached, and what video input type (Component, S-Video, Composite, etc) to use. However, we promptly discarded this vital bit of information and never propagated it to where it was used to determine the correct modes and setup the control registers. Fix it! This fixes a regression from 7b334fcb45b757ffb093696ca3de1b0c8b4a33f1. Reported-and-tested-by: Mathew McKernan <matmckernan@rauland.com.au> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=35977 Signed-off-by: Mathew McKernan <matmckernan@rauland.com.au> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm/i915: Sanitize the output registers after resumeChris Wilson
commit f6e5b1603b8bb7131b6778d0d4e2e5dda120a379 upstream. Similar to booting, we need to inspect the state left by the BIOS and remove any conflicting bits before we take over. The example reported by Seth Forshee is very similar to the bug we encountered with the state left by grub2, that the crtc pipe<->planning mapping was reversed from our expectations and so we failed to turn off the outputs when booting or, in this case, resuming. This may be in fact the same bug, but triggered at resume time. This patch rearranges the code we already have to clear up the conflicting state upon init and calls it from reset (which is called after we have lost control of the hardware, i.e. along both the boot and resume paths) instead. Reported-and-tested-by: Seth Forshee <seth.forshee@canonical.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=35796 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm/radeon/kms: fix bad shift in atom iio table parserAlex Deucher
commit 8e461123f28e6b17456225e70eb834b3b30d28bb upstream. Noticed by Patrick Lowry. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm/nouveau: fix notifier memory corruption bugMarcin Slusarz
commit a18d89ca026140eb8ac4459bf70a01c571dd9a32 upstream. nouveau_bo_wr32 expects offset to be in words, but we pass value in bytes, so after commit 73412c3854c877e5f37ad944ee8977addde4d35a ("drm/nouveau: allocate kernel's notifier object at end of block") we started to overwrite some memory after notifier buffer object (previously m2mf_ntfy was always 0, so it didn't matter it was a value in bytes). Reported-by: Dominik Brodowski <linux@dominikbrodowski.net> Reported-by: Nigel Cunningham <lkml@nigelcunningham.com.au> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-02drm/radeon/kms: pll tweaks for r7xxAlex Deucher
commit 5785e53ffa73f77fb19e378c899027afc07272bc upstream. Prefer min m to max p only on pre-r7xx asics. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=36197 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-21radeon: Fix KMS CP writeback on big endian machines.Michel Dänzer
commit dc66b325f161bb651493c7d96ad44876b629cf6a upstream. This is necessary even with PCI(e) GART, and it makes writeback work even with AGP on my PowerBook. Might still be unreliable with older revisions of UniNorth and other AGP bridges though. Signed-off-by: Michel Dänzer <daenzer@vmware.com> Reviewed-by: Alex Deucher <alex.deucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-21drm/radeon/kms: fix suspend on rv530 asicsAlex Deucher
commit 71e16bfbd2b1c63d4d97cc5059694c9346aee340 upstream. Apparently only rv515 asics need the workaround added in f24d86f1a49505cdea56728b853a5d0a3f8e3d11 (drm/radeon/kms: fix resume regression for some r5xx laptops). Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=34709 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-21drm/radeon/kms: pll tweaks for rv6xxAlex Deucher
commit 9bb09fa1b5b07459279301ac6220d575f307597b upstream. Prefer minm over maxp. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35994 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14drm/radeon/kms: add some sanity checks to obj info record parsingi (v2)John Lindgren
commit 97ea530f6fac1f9632b0c4792a2a56411454adbe upstream. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35502 agd5f: also add sanity check to connector records. v2: fix one more case. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm/radeon/kms: fix hardcoded EDID handlingAlex Deucher
commit fafcf94e2b5732d1e13b440291c53115d2b172e9 upstream. On some servers there is a hardcoded EDID provided in the vbios so that the driver will always see a display connected even if something like a KVM prevents traditional means like DDC or load detection from working properly. Also most server boards with DVI are not actually DVI, but DVO connected to a virtual KVM service processor. If we fail to detect a monitor via DDC or load detection and a hardcoded EDID is available, use it. Additionally, when using the hardcoded EDID, use a copy of it rather than the actual one stored in the driver as the detect() and get_modes() functions may free it if DDC is successful. This fixes the virtual KVM on several internal servers. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm/radeon/kms: prefer legacy pll algo for tv-outAlex Deucher
commit 64146f8b2af1ba77fe3c21d9d6d7213b9bb72b40 upstream. ntsc seems to work fine with either algo, some pal TVs seem pickier. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=30832 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm: Fix use-after-free in drm_gem_vm_close()Chris Wilson
commit b74ad5ae14def5e81ad0be3dddb96e485b861b1b upstream. As we may release the last reference, we need to store the device in a local variable in order to unlock afterwards. [ 60.140768] BUG: unable to handle kernel paging request at 6b6b6b9f [ 60.140973] IP: [<c1536d11>] __mutex_unlock_slowpath+0x5a/0x111 [ 60.141014] *pdpt = 0000000024a54001 *pde = 0000000000000000 [ 60.141014] Oops: 0002 [#1] PREEMPT SMP [ 60.141014] last sysfs file: /sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/PNP0C0A:00/power_supply/BAT0/voltage_now [ 60.141014] Modules linked in: uvcvideo ath9k pegasus ath9k_common ath9k_hw hid_egalax ath3k joydev asus_laptop sparse_keymap battery input_polldev [ 60.141014] [ 60.141014] Pid: 771, comm: meego-ux-daemon Not tainted 2.6.37.2-7.1 #1 EXOPC EXOPG06411/EXOPG06411 [ 60.141014] EIP: 0060:[<c1536d11>] EFLAGS: 00010046 CPU: 0 [ 60.141014] EIP is at __mutex_unlock_slowpath+0x5a/0x111 [ 60.141014] EAX: 00000100 EBX: 6b6b6b9b ECX: e9b4a1b0 EDX: e4a4e580 [ 60.141014] ESI: db162558 EDI: 00000246 EBP: e480be50 ESP: e480be44 [ 60.141014] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [ 60.141014] Process meego-ux-daemon (pid: 771, ti=e480a000 task=e9b4a1b0 task.ti=e480a000) [ 60.141014] Stack: [ 60.141014] e4a4e580 db162558 f5a2f838 e480be58 c1536dd0 e480be68 c125ab1b db162558 [ 60.141014] db1624e0 e480be78 c10ba071 db162558 f760241c e480be94 c10bb0bc 000155fe [ 60.141014] f760241c f5a2f838 f5a2f8c8 00000000 e480bea4 c1037c24 00000000 f5a2f838 [ 60.141014] Call Trace: [ 60.141014] [<c1536dd0>] ? mutex_unlock+0x8/0xa [ 60.141014] [<c125ab1b>] ? drm_gem_vm_close+0x39/0x3d [ 60.141014] [<c10ba071>] ? remove_vma+0x2d/0x58 [ 60.141014] [<c10bb0bc>] ? exit_mmap+0x126/0x13f [ 60.141014] [<c1037c24>] ? mmput+0x37/0x9a [ 60.141014] [<c10d450d>] ? exec_mmap+0x178/0x19c [ 60.141014] [<c1537f85>] ? _raw_spin_unlock+0x1d/0x36 [ 60.141014] [<c10d4eb0>] ? flush_old_exec+0x42/0x75 [ 60.141014] [<c1104442>] ? load_elf_binary+0x32a/0x922 [ 60.141014] [<c10d3f76>] ? search_binary_handler+0x200/0x2ea [ 60.141014] [<c10d3ecf>] ? search_binary_handler+0x159/0x2ea [ 60.141014] [<c1104118>] ? load_elf_binary+0x0/0x922 [ 60.141014] [<c10d56b2>] ? do_execve+0x1ff/0x2e6 [ 60.141014] [<c100970e>] ? sys_execve+0x2d/0x55 [ 60.141014] [<c1002a5a>] ? ptregs_execve+0x12/0x18 [ 60.141014] [<c10029dc>] ? sysenter_do_call+0x12/0x3c [ 60.141014] [<c1530000>] ? init_centaur+0x9c/0x1ba [ 60.141014] Code: c1 00 75 0f ba 38 01 00 00 b8 8c 3a 6c c1 e8 cc 2e b0 ff 9c 58 8d 74 26 00 89 c7 fa 90 8d 74 26 00 e8 d2 b4 b2 ff b8 00 01 00 00 <f0> 66 0f c1 43 04 38 e0 74 07 f3 90 8a 43 04 eb f5 83 3d 64 ef [ 60.141014] EIP: [<c1536d11>] __mutex_unlock_slowpath+0x5a/0x111 SS:ESP 0068:e480be44 [ 60.141014] CR2: 000000006b6b6b9f Reported-by: Rusty Lynch <rusty.lynch@intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm/i915: Prevent racy removal of request from client listHerton Ronaldo Krzesinski
commit 09bfa51773c1e90f13000dc2fc0c4b84047009bc upstream. When i915_gem_retire_requests_ring calls i915_gem_request_remove_from_client, the client_list for that request may already be removed in i915_gem_release. So we may call twice list_del(&request->client_list), resulting in an oops like this report: [126167.230394] BUG: unable to handle kernel paging request at 00100104 [126167.230699] IP: [<f8c2ce44>] i915_gem_retire_requests_ring+0xd4/0x240 [i915] [126167.231042] *pdpt = 00000000314c1001 *pde = 0000000000000000 [126167.231314] Oops: 0002 [#1] SMP [126167.231471] last sysfs file: /sys/devices/LNXSYSTM:00/device:00/PNP0C0A:00/power_supply/BAT1/current_now [126167.231901] Modules linked in: snd_seq_dummy nls_utf8 isofs btrfs zlib_deflate libcrc32c ufs qnx4 hfsplus hfs minix ntfs vfat msdos fat jfs xfs exportfs reiserfs cryptd aes_i586 aes_generic binfmt_misc vboxnetadp vboxnetflt vboxdrv parport_pc ppdev snd_hda_codec_hdmi snd_hda_codec_conexant snd_hda_intel snd_hda_codec snd_hwdep arc4 snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq uvcvideo videodev snd_timer snd_seq_device joydev iwlagn iwlcore mac80211 snd cfg80211 soundcore i915 drm_kms_helper snd_page_alloc psmouse drm serio_raw i2c_algo_bit video lp parport usbhid hid sky2 sdhci_pci ahci sdhci libahci [126167.232018] [126167.232018] Pid: 1101, comm: Xorg Not tainted 2.6.38-6-generic-pae #34-Ubuntu Gateway MC7833U / [126167.232018] EIP: 0060:[<f8c2ce44>] EFLAGS: 00213246 CPU: 0 [126167.232018] EIP is at i915_gem_retire_requests_ring+0xd4/0x240 [i915] [126167.232018] EAX: 00200200 EBX: f1ac25b0 ECX: 00000040 EDX: 00100100 [126167.232018] ESI: f1a2801c EDI: e87fc060 EBP: ef4d7dd8 ESP: ef4d7db0 [126167.232018] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 [126167.232018] Process Xorg (pid: 1101, ti=ef4d6000 task=f1ba6500 task.ti=ef4d6000) [126167.232018] Stack: [126167.232018] f1a28000 f1a2809c f1a28094 0058bd97 f1aa2400 f1a2801c 0058bd7b 0058bd85 [126167.232018] f1a2801c f1a28000 ef4d7e38 f8c2e995 ef4d7e30 ef4d7e60 c14d1ebc f6b3a040 [126167.232018] f1522cc0 000000db 00000000 f1ba6500 ffffffa1 00000000 00000001 f1a29214 [126167.232018] Call Trace: Unfortunately the call trace reported was cut, but looking at debug symbols the crash is at __list_del, when probably list_del is called twice on the same request->client_list, as the dereferenced value is LIST_POISON1 + 4, and by looking more at the debug symbols before list_del call it should have being called by i915_gem_request_remove_from_client And as I can see in the code, it seems we indeed have the possibility to remove a request->client_list twice, which would cause the above, because we do list_del(&request->client_list) on both i915_gem_request_remove_from_client and i915_gem_release As Chris Wilson pointed out, it's indeed the case: "(...) I had thought that the actual insertion/deletion was serialised under the struct mutex and the intention of the spinlock was to protect the unlocked list traversal during throttling. However, I missed that i915_gem_release() is also called without struct mutex and so we do need the double check for i915_gem_request_remove_from_client()." This change does the required check to avoid the duplicate remove of request->client_list. Bugzilla: http://bugs.launchpad.net/bugs/733780 Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm/i915: Disable pagefaults along execbuffer relocation fast pathChris Wilson
commit d4aeee776017b6da6dcd12f453cd82a3c951a0dc upstream. Along the fast path for relocation handling, we attempt to copy directly from the user data structures whilst holding our mutex. This causes lockdep to warn about circular lock dependencies if we need to pagefault the user pages. [Since when handling a page fault on a mmapped bo, we need to acquire the struct mutex whilst already holding the mm semaphore, it is then verboten to acquire the mm semaphore when already holding the struct mutex. The likelihood of the user passing in the relocations contained in a GTT mmaped bo is low, but conceivable for extreme pathology.] In order to force the mm to return EFAULT rather than handle the pagefault, we therefore need to disable pagefaults across the relocation fast path. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27drm: check for modesetting on modeset ioctlsDave Airlie
commit fb3b06c8a1fd1a80298f13b738ab38ef8c73baff upstream. Noticed this while working on some other things, helps if we check for modeset enabled on modesetting ioctls. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23drm: Hold the mode mutex whilst probing for sysfs statusChris Wilson
commit 007c80a5497a3f9c8393960ec6e6efd30955dcb1 upstream. As detect will use hw registers and may modify structures, it needs to be serialised by use of the dev->mode_config.mutex. Make it so. Otherwise, we may cause random crashes as the sysfs file is queried whilst a concurrent hotplug poll is being run. For example: [ 1189.189626] BUG: unable to handle kernel NULL pointer dereference at 00000100 [ 1189.189821] IP: [<e0c22019>] intel_tv_detect_type+0xa2/0x203 [i915] [ 1189.190020] *pde = 00000000 [ 1189.190104] Oops: 0000 [#1] SMP [ 1189.190209] last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-SVIDEO-1/status [ 1189.190412] Modules linked in: mperf cpufreq_conservative cpufreq_userspace cpufreq_powersave cpufreq_stats decnet uinput fuse loop joydev snd_hd a_codec_realtek snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm i915 snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq drm_kms_helper snd_timer uvcvideo d rm snd_seq_device eeepc_laptop tpm_tis usbhid videodev i2c_algo_bit v4l1_compat snd sparse_keymap i2c_core hid serio_raw tpm psmouse evdev tpm_bios rfkill shpchp ac processor rng_c ore battery video power_supply soundcore pci_hotplug button output snd_page_alloc usb_storage uas ext3 jbd mbcache sd_mod crc_t10dif ata_generic ahci libahci ata_piix libata uhci_h cd ehci_hcd scsi_mod usbcore thermal atl2 thermal_sys nls_base [last unloaded: scsi_wait_scan] [ 1189.192007] [ 1189.192007] Pid: 1464, comm: upowerd Not tainted 2.6.37-2-686 #1 ASUSTeK Computer INC. 701/701 [ 1189.192007] EIP: 0060:[<e0c22019>] EFLAGS: 00010246 CPU: 0 [ 1189.192007] EIP is at intel_tv_detect_type+0xa2/0x203 [i915] [ 1189.192007] EAX: 00000000 EBX: dca74000 ECX: e0f68004 EDX: 00068004 [ 1189.192007] ESI: dd110c00 EDI: 400c0c37 EBP: dca7429c ESP: de365e2c [ 1189.192007] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 [ 1189.192007] Process upowerd (pid: 1464, ti=de364000 task=dcc8acb0 task.ti=de364000) [ 1189.192007] Stack: Mar 15 03:43:23 hostname kernel: [ 1189.192007] e0c2cda4 70000000 400c0c30 00000000 dd111000 de365e54 de365f24 dd110c00 [ 1189.192007] e0c22203 01000000 00000003 00000000 00000000 00000000 00000000 4353544e [ 1189.192007] 30383420 00000069 00000000 00000000 00000000 00000000 00000000 00000000 [ 1189.192007] Call Trace: Mar 15 03:43:23 hostname kernel: [ 1189.192007] [<e0c22203>] ? intel_tv_detect+0x89/0x12d [i915] [ 1189.192007] [<e0a9dcef>] ? status_show+0x0/0x2f [drm] [ 1189.192007] [<e0a9dd03>] ? status_show+0x14/0x2f [drm] [Digression: what is upowerd doing reading those power hungry files?] Reported-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23drm/radeon/kms: fix typo in atom overscan setupAlex Deucher
commit 942b0e95c34f1ba432d08e1c0288ed032d32c3b2 upstream. Typo in the aspect scale setup. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"Chris Wilson
commit 8692d00e996ed2a6560702623e5cb646da0f9767 upstream. I stumbled over this magic bit in the gen3 INSTPM: Bit11 Interrupt-Based AGPBUSY# Enable: ‘0’ = Pending GMCH interrupts will not cause AGPBUSY# assertion. ‘1’ = Pending GMCH interrupts will cause AGPBUSY# assertion and hence can cause the CPU to exit C3. There is no suppression of cacheable writes. Note that in either case in C3 the interrupts are not lost. They will be forwarded to the ICH when the GMCH is out of C3. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14drm/radeon: fix problem with changing active VRAM size. (v2)Dave Airlie
So we used to use lpfn directly to restrict VRAM when we couldn't access the unmappable area, however this was removed in 93225b0d7bc030f4a93165347a65893685822d70 as it also restricted the gtt placements. However it was only later noticed that this broke on some hw. This removes the active_vram_size, and just explicitly sets it when it changes, TTM/drm_mm will always use the real_vram_size, and the active vram size will change the TTM size used for lpfn setting. We should re-work the fpfn/lpfn to per-placement at some point I suspect, but that is too late for this kernel. Hopefully this addresses: https://bugs.freedesktop.org/show_bug.cgi?id=35254 v2: fix reported useful VRAM size to userspace to be correct. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-13drm/radeon: fix page flipping hangs on r300/r400Dave Airlie
We've been getting reports of complete system lockups with rv3xx hw on AGP and PCIE when running gnome-shell or kwin with compositing. It appears the hw really doesn't like setting these registers while stuff is running, this moves the setting of the registers into the modeset since they aren't required to be changed anywhere else. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35183 Reported-and-tested-by: Álmos <aaalmosss@gmail.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-11drm/radeon: add pageflip hooks for fusionDave Airlie
Looks like these got passed over with both being merged at the same time but not quite meeting in the middle. should fix: https://bugs.freedesktop.org/show_bug.cgi?id=34137 along with Michael's phoronix article. Reported-by: Chi-Thanh Christopher Nguyen Article-written-by: Michael Larabel @ phoronix Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-10drm/i915: Revive combination mode for backlight controlTakashi Iwai
This reverts commit 951f3512dba5bd44cda3e5ee22b4b522e4bb09fb drm/i915: Do not handle backlight combination mode specially since this commit introduced other regressions due to untouched LBPC register, e.g. the backlight dimmed after resume. In addition to the revert, this patch includes a fix for the original issue (weird backlight levels) by removing the wrong bit shift for computing the current backlight level. Also, including typo fixes (lpbc -> lbpc). Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34524 Acked-by: Indan Zupancic <indan@nul.nu> Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-08drm: index i shadowed in 2nd looproel
Index i was already used in thhe first loop Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-08Merge remote branch 'ickle/drm-intel-fixes' into drm-fixesDave Airlie
* ickle/drm-intel-fixes: drm/i915: Rebind the buffer if its alignment constraints changes with tiling drm/i915: Disable GPU semaphores by default drm/i915: Do not overflow the MMADDR write FIFO Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
2011-03-08drm/nv50-nvc0: prevent multiple vm/bar flushes occuring simultanenouslyBen Skeggs
The per-vm mutex doesn't prevent this completely, a flush coming from the BAR VM could potentially happen at the same time as one for the channel VM. Not to mention that if/when we get per-client/channel VM, this will happen far more frequently. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-08drm/nouveau: fix regression causing ttm to not be able to evict vramBen Skeggs
TTM assumes an error condition from man->func->get_node() means that something went horribly wrong, and causes it to bail. The driver is supposed to return 0, and leave mm_node == NULL to signal that it couldn't allocate any memory. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-07drm/i915: Rebind the buffer if its alignment constraints changes with tilingChris Wilson
Early gen3 and gen2 chipset do not have the relaxed per-surface tiling constraints of the later chipsets, so we need to check that the GTT alignment is correct for the new tiling. If it is not, we need to rebind. Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-03-07drm/i915: Disable GPU semaphores by defaultChris Wilson
Andi Kleen narrowed his GPU hangs on his Sugar Bay (SNB desktop) rev 09 down to the use of GPU semaphores, and we already know that they appear broken up to Huron River (mobile) rev 08. (I'm optimistic that disabling GPU semaphores is simply hiding another bug by the latency and side-effects of the additional device interaction it introduces...) However, use of semaphores is a massive performance improvement... Only as long as the system remains stable. Enable at your peril. Reported-by: Andi Kleen <andi-fd@firstfloor.org> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33921 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-03-06drm/i915: Do not overflow the MMADDR write FIFOChris Wilson
Whilst the GT is powered down (rc6), writes to MMADDR are placed in a FIFO by the System Agent. This is a limited resource, only 64 entries, of which 20 are reserved for Display and PCH writes, and so we must take care not to queue up too many writes. To avoid this, there is counter which we can poll to ensure there are sufficient free entries in the fifo. "Issuing a write to a full FIFO is not supported; at worst it could result in corruption or a system hang." Reported-and-Tested-by: Matt Turner <mattst88@gmail.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34056 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-03-06Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"Chris Wilson
This reverts commit c2e0eb167070a6e9dcb49c84c13c79a30d672431. As it turns out, userspace already depends upon being able to enable tiling on existing bo which it promises to be large enough for its purposes i.e. it will not access beyond the end of the last full-tile row. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=35016 Reported-and-tested-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-03-04drm/nouveau: allocate kernel's notifier object at end of blockBen Skeggs
The nv30/nv40 3d driver is about to start using DMA_FENCE from the 3D object which, it turns out, doesn't like its DMA object to not be aligned to a 4KiB boundary. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-01drm/i915: fix memory corruption with GM965 and >4GB RAMJan Niehusmann
On a Thinkpad x61s, I noticed some memory corruption when plugging/unplugging the external VGA connection. The symptoms are that 4 bytes at the beginning of a page get overwritten by zeroes. The address of the corruption varies when rebooting the machine, but stays constant while it's running (so it's possible to repeatedly write some data and then corrupt it again by plugging the cable). Further investigation revealed that the corrupted address is (dev_priv->status_page_dmah->busaddr & 0xffffffff), ie. the beginning of the hardware status page of the i965 graphics card, cut to 32 bits. So it seems that for some memory access, the hardware uses only 32 bit addressing. If the hardware status page is located >4GB, this corrupts unrelated memory. Signed-off-by: Jan Niehusmann <jan@gondor.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2011-02-28Merge remote branch 'nouveau/drm-nouveau-fixes' of /ssd/git/drm-nouveau-next ↵Dave Airlie
into drm-fixes * 'nouveau/drm-nouveau-fixes' of /ssd/git/drm-nouveau-next: drm/nv50-nvc0: make sure vma is definitely unmapped when destroying bo
2011-02-28drm: fix unsigned vs signed comparison issue in modeset ctl ioctl.Dave Airlie
This fixes CVE-2011-1013. Reported-by: Matthiew Herrb (OpenBSD X.org team) Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-28drm/nv50-nvc0: make sure vma is definitely unmapped when destroying boBen Skeggs
Somehow fixes a misrendering + hang at GDM startup on my NVA8... My first guess would have been stale TLB entries laying around that a new bo then accidentally inherits. That doesn't make a great deal of sense however, as when we mapped the pages for the new bo the TLBs would've gotten flushed anyway. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-02-25Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel into drm-fixes * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: Fix unintended recursion in ironlake_disable_rc6
2011-02-24drm/i915: Fix unintended recursion in ironlake_disable_rc6Chris Wilson
After disabling, we're meant to teardown the bo used for the contexts, not recurse into ourselves again and preventing module unload. Reported-and-tested-by: Ben Widawsky <bwidawsk@gmail.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-02-24Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel into drm-fixes * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: fix corruptions on i8xx due to relaxed fencing drm/i915: skip FDI & PCH enabling for DP_A agp/intel: Experiment with a 855GM GWB bit drm/i915: don't enable FDI & transcoder interrupts after all drm/i915: Ignore a hung GPU when flushing the framebuffer prior to a switch
2011-02-24drm/i915: fix corruptions on i8xx due to relaxed fencingDaniel Vetter
It looks like gen2 has a peculiar interleaved 2-row inter-tile layout. Probably inherited from i81x which had 2kb tiles (which naturally fit an even-number-of-tile-rows scheme to fit onto 4kb pages). There is no other mention of this in any docs (also not in the Intel internal documention according to Chris Wilson). Problem manifests itself in corruptions in the second half of the last tile row (if the bo has an odd number of tiles). Which can only happen with relaxed tiling (introduced in a00b10c360b35d6431a9). So reject set_tiling calls that don't satisfy this constrain to prevent broken userspace from causing havoc. While at it, also check the size for newer chipsets. LKML: https://lkml.org/lkml/2011/2/19/5 Reported-by: Indan Zupancic <indan@nul.nu> Tested-by: Indan Zupancic <indan@nul.nu> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-02-23drm/radeon: fix regression with AA resolve checkingDave Airlie
Some userspaces can emit a whole packet without disabling AA resolve by the looks of it, so we have to deal with them. Signed-off-by: Dave Airlie <airlied@redhat.com> Tested-by: Jorg Otte <jrg.otte@googlemail.com>
2011-02-23drm: drop commented out code and preceding commentPaul Bolle
r100_gpu_init() was dropped in 90aca4d ("drm/radeon/kms: simplify & improve GPU reset V2") but here it was only commented out. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23drm/vblank: Enable precise vblank timestamps for interlaced and doublescan ↵Mario Kleiner
modes. Testing showed the current code can already handle doublescan video modes just fine. A trivial tweak makes it work for interlaced scanout as well. Tested and shown to be precise on Radeon rv530, r600 and Intel 945-GME. Signed-off-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
