Tegra124 and later support interlacing, but the driver doesn't support
it yet. Make sure interlacing stays disabled on hardware that supports
it.
Signed-off-by: Thierry Reding <treding@nvidia.com>
A lot of the modern userspace is capable of working without the legacy
fbdev support. kmscon can be used as a replacement for the framebuffer
console, and KMS X drivers create their own framebuffers.
Most people don't have a system where all of this works yet, though, so
leave support enabled by default.
This commit adds support for both DSI outputs found on Tegra. Only very
minimal functionality is implemented, so advanced features like ganged
mode won't work.
Due to the lack of other test hardware, some sections of the driver are
hardcoded to work with Dalmore.
Use the DRM panel framework to attach a panel to an output. If the panel
attached to a connector supports supports the backlight brightness
accessors, a property will be available to allow the brightness to be
modified from userspace.
ARM: tegra: implement common DMA and resets DT bindings
This series converts the Tegra DTs and drivers to use the common/
standard DMA and reset bindings, rather than custom bindings. It also
adds complete documentation for the Tegra clock bindings without
actually changing any binding definitions.
This conversion relies on a few sets of patches in branches from outside
the Tegra tree:
1) A patch to add an DMA channel request API which allows deferred probe
to be implemented.
2) A patch to implement a common part of the of_xlate function for DMA
controllers.
3) Some ASoC patches (which in turn rely on (1) above), which support
deferred probe during DMA channel allocation.
4) The Tegra clock driver changes for 3.14.
Consequently, this branch is based on a merge of all of those external
branches.
In turn, this branch is or will be pulled into a few places that either
rely on features introduced here, or would otherwise conflict with the
patches:
a) Tegra's own for-3.14/powergate and for-4.14/dt branches, to avoid
conflicts.
b) The DRM tree, which introduces new code that relies on the reset
controller framework introduced in this branch, and to avoid
conflicts.
Tegra's clock driver now provides an implementation of the common
reset API (include/linux/reset.h). Use this instead of the old Tegra-
specific API; that will soon be removed.
Acked-By: Terje Bergstrom <tbergstrom@nvidia.com>
When upcasting a NULL CRTC object, propagate the NULL pointer instead of
some invalid pointer. This allows subsequent code to check that the cast
object is valid.
The gr3d engine renders images bottom-up. Allow buffers that are used
for 3D content to be marked as such and implement support in the display
controller to present them properly.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The gr2d and gr3d engines work more efficiently on buffers with a tiled
memory layout. Allow created buffers to be marked as tiled so that the
display controller can scan them out properly.
Initialize and power the 3D unit on Tegra20, Tegra30 and Tegra114 and
register a channel with the Tegra DRM driver so that the unit can be
used from userspace.
Command stream submissions are the same across all devices that expose
a channel to userspace, so move the code into a generic function.
Since the .init() and .exit() functions are executed whenever the DRM
driver is loaded or unloaded, care must be taken not to use them for
resource allocation. Otherwise deferred probing cannot be used, since
the .init() and .exit() are not run at probe time. Similarly the code
that frees resources must be run at .remove() time. If it is run from
the .exit() function, it can release resources multiple times.
To handle this more consistently, rename the tegra_output_parse_dt()
function to tegra_output_probe() and introduce tegra_output_remove()
which can be used to free output-related resources.
In order to make subsystem-wide changes easier, move the Tegra DRM
driver back into the DRM tree.
Make drm part of host1x driver.
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Tested-by: Erik Faye-Lund <kusmabite@gmail.com>
All the necessary support bits like .mode_set_base() and VBLANK are now
available, so page-flipping case easily be implemented on top.
Implement support for the VBLANK IOCTL. Note that Tegra is somewhat
special in this case because it doesn't use the generic IRQ support
provided by the DRM core (DRIVER_HAVE_IRQ) but rather registers one
interrupt handler for each display controller.
While at it, clean up the way that interrupts are enabled to ensure
that the VBLANK interrupt only gets enabled when required.
Add support for the B and C planes which support RGB and YUV pixel
formats and can be used as overlays or hardware cursor. Currently 32-bit
XRGB as well as UYVY, YUV420 and YUV422 pixel formats are advertised.
Other formats should be easy to add but these are the most common ones
and should cover the majority of use-cases.
Tegra uses the CMA FB helpers so framebuffers passed to the driver need
to use the corresponding functions to access the underlying GEM objects.
This used to work because struct tegra_framebuffer was sufficiently
similar to struct drm_fb_cma but that isn't guaranteed to stay that way.
This reverts commit 83c0bcb694be31dcd6c04bdd935b96a95a0af548.
Lucas pointed out this was a mistake, and I missed the discussion,
so just revert it out to save a rebase.
There is no gem.c anymore, those functions are implemented by the
drm_cma_helpers now.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Window properties are programmed through a shared aperture and have to
happen atomically. Also we do the read-update-write dance on some of the
shared regs.
To make sure that different functions don't stumble over each other
protect the register access with a mutex.
This commit adds support for the HDMI output on the Tegra20 SoC. Only
one such output is available, but it can be driven by either of the two
display controllers.
A lot of work on this patch has been contributed by NVIDIA's Mark Zhang
<markz@nvidia.com> and many other people at NVIDIA were very helpful in
getting the HDMI support and surrounding infrastructure to work.
Acked-by: Mark Zhang <markz@nvidia.com>
Reviewed-by: Mark Zhang <markz@nvidia.com>
Tested-by: Mark Zhang <markz@nvidia.com>
Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
This commit adds a KMS driver for the Tegra20 SoC. This includes basic
support for host1x and the two display controllers found on the Tegra20
SoC. Each display controller can drive a separate RGB/LVDS output.
