path: root/drivers/gpu/drm/nouveau/nouveau_fence.h
2017-06-17drm/nouveau/fence/g84-: protect against concurrent access to semaphore buffersBen Skeggs
[ Upstream commit 96692b097ba76d0c637ae8af47b29c73da33c9d0 ] Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-02dma-buf/fence: make fence context 64 bit v2Christian König
Fence contexts are created on the fly (for example) by the GPU scheduler used in the amdgpu driver as a result of an userspace request. Because of this userspace could in theory force a wrap around of the 32bit context number if it doesn't behave well. Avoid this by increasing the context number to 64bits. This way even when userspace manages to allocate a billion contexts per second it takes more than 500 years for the context number to wrap around. v2: fix printf formats as well. Signed-off-by: Christian König <christian.koenig@amd.com> Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Acked-by: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1464786612-5010-2-git-send-email-deathsimple@vodafone.de
2015-08-28drm/nouveau/sw: turn flip completion into an eventBen Skeggs
2015-01-22drm/nouveau: finalise nvkm namespace switch (no binary change)Ben Skeggs
The namespace of NVKM is being changed to nvkm_ instead of nouveau_, which will be used for the DRM part of the driver. This is being done in order to make it very clear as to what part of the driver a given symbol belongs to, and as a minor step towards splitting the DRM driver out to be able to stand on its own (for virt). Because there's already a large amount of churn here anyway, this is as good a time as any to also switch to NVIDIA's device and chipset naming to ease collaboration with them. A comparison of objdump disassemblies proves no code changes. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-12-02drm/nouveau: prevent stale fence->channel pointers, and protect with rcuMaarten Lankhorst
Tested-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-09-30drm/nouveau: assign fence_chan->name correctlyMaarten Lankhorst
Make nouveau_fence_chan refcounted, to make trace_fence_destroy always return the correct name without a race condition. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
2014-09-30drm/nouveau: specify if interruptible wait is desired in nouveau_fence_syncMaarten Lankhorst
2014-09-02drm/nouveau: use shared fences for readable objectsMaarten Lankhorst
nouveau keeps track in userspace whether a buffer is being written to or being read, but it doesn't use that information. Change this to allow multiple readers on the same bo. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Ben Skeggs <bskeggs@redhat.com>
2014-09-02drm/ttm: flip the switch, and convert to dma_fenceMaarten Lankhorst
2014-09-02drm/nouveau: rework to new fence interfaceMaarten Lankhorst
2013-07-01drm/nouveau: delay busy bo vma removal until fence signalsBen Skeggs
As opposed to an explicit wait. Allows userspace to not stall waiting on buffer deletion. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-02-20drm/nv84-/fence: prepare for emit/sync support of sysram sequencesBen Skeggs
2013-02-20drm/nouveau/fence: make internal hooks part of the contextBen Skeggs
A step towards being able to provide fences from other engines not connected to PFIFO. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-02-20drm/nv17/fence: split from nv10 codeBen Skeggs
2013-02-20drm/nv84-/fence: abstract class emit/sync functions to virt+sequenceBen Skeggs
Now can be used to operate on any buffer mapped into the GPU virtual address and not just the main inter-channel sync buffer. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-02-20drm/nv84/fence: access fences with full virtual address, not offsetBen Skeggs
Allows most of the code to be shared between nv84/nvc0 implementations, and paves the way for doing emit/sync on non-VRAM buffers (multi-gpu, dma-buf). Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-02-20drm/nouveau/fence/nv84-: put processes to sleep while waiting on fencesBen Skeggs
2013-01-13drm/nv17-50: restore fence buffer on resumeMarcin Slusarz
Since commit 5e120f6e4b3f35b741c5445dfc755f50128c3c44 "drm/nouveau/fence: convert to exec engine, and improve channel sync" nouveau fence sync implementation for nv17-50 and nvc0+ started to rely on state of fence buffer left by previous sync operation. But as pinned bo's (where fence state is stored) are not saved+restored across suspend/resume, we need to do it manually. nvc0+ was fixed by commit d6ba6d215a538a58f0f0026f0961b0b9125e8042 "drm/nvc0/fence: restore pre-suspend fence buffer context on resume". Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=50121 Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Cc: stable@vger.kernel.org
2012-10-03drm/nouveau: port all engines to new engine module formatBen Skeggs
This is a HUGE commit, but it's not nearly as bad as it looks - any problems can be isolated to a particular chipset and engine combination. It was simply too difficult to port each one at a time, the compat layers are *already* ridiculous. Most of the changes here are simply to the glue, the process for each of the engine modules was to start with a standard skeleton and copy+paste the old code into the appropriate places, fixing up variable names etc as needed. v2: Marcin Slusarz <marcin.slusarz@gmail.com> - fix find/replace bug in license header v3: Ben Skeggs <bskeggs@redhat.com> - bump indirect pushbuf size to 8KiB, 4KiB barely enough for userspace and left no space for kernel's requirements during GEM pushbuf submission. - fix duplicate assignments noticed by clang v4: Marcin Slusarz <marcin.slusarz@gmail.com> - add sparse annotations to nv04_fifo_pause/nv04_fifo_start - use ioread32_native/iowrite32_native for fifo control registers v5: Ben Skeggs <bskeggs@redhat.com> - rebase on v3.6-rc4, modified to keep copy engine fix intact - nv10/fence: unmap fence bo before destroying - fixed fermi regression when using nvidia gr fuc - fixed typo in supported dma_mask checking Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-10-03drm/nouveau/pageflip: kick flip handling out of engsw and into fenceBen Skeggs
This is all very much a policy thing, and hence will not belong in SW after the rework. engsw now only handles receiving the event to say "can flip now" and makes a callback to perform the actual work. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-10-03drm/nouveau/fence: un-port from nouveau_exec_engine interfacesBen Skeggs
Still the same code, but not an "engine" anymore. The fence code is more of a policy decision rather than exposing mechanisms, so it's not appropriate to port it to the new engine subsystem. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-05-24drm/nouveau/fence: fix a race where fence->channel can disappearBen Skeggs
2012-05-24drm/nouveau/fence: convert to exec engine, and improve channel syncBen Skeggs
Now have a somewhat simpler semaphore sync implementation for nv17:nv84, and a switched to using semaphores as fences on nv84+ and making use of the hardware's >= acquire operation. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-05-24drm/nouveau/fence: minor api changes for an upcoming reworkBen Skeggs
