Some machines detect an eDP port even if it's not really there, and eDP
initialization has a fail path for this. Typically such machines have an
LVDS display instead. A regression introduced in
commit 82ed61fa1a4e08d5f9e86fb1b715b50ed678b6ac
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Sat Oct 20 20:57:41 2012 +0200
drm/i915: make edp panel power sequence setup more robust
updated the power sequence registers PCH_PP_ON_DELAYS, PCH_PP_OFF_DELAYS,
and PCH_PP_DIVISOR also in the ghost eDP case, messing up the LVDS display.
Split the power sequencer initialization into two, delaying the register
updates until after we know the eDP is real.
Note: Keep the PP_CONTROL unlocking in the first part, even if it does not
update registers, per the commit message of the above mentioned commit.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52601
Reported-and-tested-by: Ryan Coe <ryan@rycomotorsports.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
One new drm_connector_attach_property() snuck in after the initial patch
was written.
Signed-off-by: Rob Clark <rob@ti.com>
v2: Rebased.
Reviewed-by: Jani Nikula <jani.nikula@intel.com> (v1)
[danvet: Pimp commit message a bit.]
into drm-next
Daniel writes:
Highlights of this -next round:
- ivb fdi B/C fixes
- hsw sprite/plane offset fixes from Damien
- unified dp/hdmi encoder for hsw, finally external dp support on hsw
(Paulo)
- kill-agp and some other prep work in the gtt code from Ben
- some fb handling fixes from Ville
- massive pile of patches to align hsw VGA with the spec and make it
actually work (Paulo)
- pile of workarounds from Jesse, mostly for vlv, but also some other
related platforms
- start of a dev_priv reorg, that thing grew out of bounds and chaotic
- small bits&pieces all over the place, down to better error handling for
load-detect on gen2 (Chris, Jani, Mika, Zhenyu, ...)
On top of the previous pile (just copypasta):
- tons of hsw dp prep patches form Paulo
- round scheduled work items and timers to nearest second (Chris)
- some hw workarounds (Jesse&Damien)
- vlv dp support and related fixups (Vijay et al.)
- basic haswell dp support, not yet wired up for external ports (Paulo)
- edp support (Paulo)
- tons of refactorings to prepare for the above (Paulo)
- panel rework, unifiying code between lvds and edp panels (Jani)
- panel fitter scaling modes (Jani + Yuly Novikov)
- panel power improvements, should now work without the BIOS setting it up
- extracting some dp helpers from radeon/i915 and move them to
drm_dp_helper.c
- randome pile of workarounds (Damien, Ben, ...)
- some cleanups for the register restore code for suspend/resume
- secure batchbuffer support, should enable tear-free blits on gen6+
Chris)
- random smaller fixlets and cleanups.
* 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel: (231 commits)
drm/i915: Restore physical HWS_PGA after resume
drm/i915: Report amount of usable graphics memory in MiB
drm/i915/i2c: Track users of GMBUS force-bit
drm/i915: Allocate the proper size for contexts.
drm/i915: Update load-detect failure paths for modeset-rework
drm/i915: Clear unused fields of mode for framebuffer creation
drm/i915: Always calculate 8xx WM values based on a 32-bpp framebuffer
drm/i915: Fix sparse warnings in from AGP kill code
drm/i915: Missed lock change with rps lock
drm/i915: Move the remaining gtt code
drm/i915: flush system agent TLBs on SNB
drm/i915: Kill off now unused gen6+ AGP code
drm/i915: Calculate correct stolen size for GEN7+
drm/i915: Stop using AGP layer for GEN6+
drm/i915: drop the double-OP_STOREDW usage in blt_ring_flush
drm/i915: don't rewrite the GTT on resume v4
drm/i915: protect RPS/RC6 related accesses (including PCU) with a new mutex
drm/i915: put ring frequency and turbo setup into a work queue v5
drm/i915: don't block resume on fb console resume v2
drm/i915: extract l3_parity substruct from dev_priv
Now intel_ddi_init is just like intel_hdmi_init and intel_dp_init: it
inits the encoder and then calls the proper init_connector functions.
Notice that for non-eDP ports we call both HDMI and DP connector init,
so we have 2 connectors attached to each DDI encoder.
After this change, intel_hdmi_init and intel_dp_init are only called
by Ivy Bridge and earlier, while hardware containing DDI outputs
should call intel_ddi_init.
Also added/removed quite a few "static" keywords due to the fact that
some function pointers were moved from intel_dp.c and intel_hdmi.c to
intel_ddi.c.
DP finally works on Haswell now! \o/
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
We need this since now on DDI we will have 2 connectors on each
encoder.
Both "intel_dp" and "intel_hdmi" structs had a "port" field, which
always had the same value. It makes more sense to move this to
intel_digital_port, so we can know the port independently of the
connector type.
When intel_hdmi_detect detects a monitor, set intel_encoder->type with
INTEL_OUTPUT_HDMI. Same for DP.
This should not break the current code because these variables never
change. This will be used after we create the DDI encoder because it
will have both DP and HDMI connectors.
We won't support eDP+HDMI on the same port, so if an encoder is eDP we
should expect it to always remain eDP and never change.
Same reason as the previous HDMI commit: the DDI code will have its
own encoder init function but still use the DP and HDMI connectors.
[danvet: kill the unnecessarily added line that Damien spotted in
review.]
The goal is to have one single encoder capable of controlling both DP
and HDMI outputs. This patch just adds the initial infrastructure, no
functional changes.
Previously, both intel_dp and intel_hdmi were intel_encoders. Now,
these 2 structs do not have intel_encoder as members anymore. The new
struct intel_digital_port has intel_encoder as a member, and it also
includes intel_dp and intel_hdmi as members. In other words: see the
changes inside intel_drv.h: it's the most important change, everything
else is only to make it compile and work.
For now, each intel_digital_port is still only able to control one of
HDMI or DP, but not both together.
In the future we should also try to merge the common fields from
intel_dp and intel_hdmi (e.g., port).
[danvet: Add the missing ' ' spotted by Damien Lespiau.]
When we add struct intel_digital_port, there will be no direct way of
going from intel_{dp,hdmi} to drm_device: we will need to call
container_of().
This patch adds functions to go from intel_{dp,hdmi} to drm_device.
The main goal here is to greatly reduce the size of the next patch,
where we will change the implementation of the functions we just
added here (among other things).
Reviewed-by: Damien Lespiau <damien.lespiau@gmail.com>
- Replace container_of with enc_to_intel_dp.
- Walk through less structures when making assignments.
- Rename some variables to keep our naming standards.
As a bonus, this will reduce the usage of "struct intel_dp", making
the future patch that introduces intel_digital_port smaller and easier
to review.
The debug message is only relevant on CPT/PPT PCH ports, so move
it into the correct if clause.
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Signed-off-by: Yuly Novikov <ynovikov@chromium.org>
[Jani: ripped this change separate from the scaling mode change support]
Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
LVDS allowed changing panel fitting scaling mode, while eDP didn't. Copied
relevant code from LVDS to eDP.
[Jani: use fitting mode in intel_panel, remove default mode change]
At some point the DPCD size was increased, but the debug print not. While
at it, switch to using hex dump.
Reviewed-by: Mika Kuoppala <mika.kuoppala@intel.com>
It's an important step :)
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
The cdclk frequency is not always the same, so the value here should
be adjusted to match it.
Version 2: call intel_ddi_get_cdclk_freq instead of reading
CDCLK_FREQ, because the register is just for earlier HW steppings.
Same thing as the previous commits. Not renaming this one since it
exists since way before Haswell.
That thing has grown way too big already.
Also move around a comment to the right spot.
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Otherwise dp aux won't work on some hsw platforms, since they use a
different rawclk than the 125MHz clock used thus far.
To absolutely not change anything, round up: That way we get the old
63 divider for the default 125MHz clock.
We need this when the bios forgets even to set that bit up. Most seem
to do that, even when they don't set up anything else in the panel
power sequencer.
Note that on IBX the rawclk is variable according to Bspec, but
everyone is using 125MHz. The rawclk is fixed to 125MHz on CPT, but
luckily we still have the same register available. On hsw, different
variants have different clocks, hence we need to check the register.
Since other pieces are driven by the rawclock, too, keep the little
helper in a central place.
Like we already do for the LVDS panels. This seems to help greatly
in setting up the backlight, since the BIOS might refuse to cooperate.
v2: Move the backlight_off call from panel_off to edp_backlight_off,
noticed by Paulo Zanoni.
Reviewed-by: Paulo Zanoni <przanoni@gmail.com>
3 changes:
- If a given value is unset, use the maximal limits from the eDP spec.
- Write back the new values, since otherwise the panel power sequencing
hw will not dtrt.
- Revert the early bail-out in case the register values are unset.
The last change reverts
commit bfa3384a9a84aaaa59443bbd776c142e7dba4b0f
Author: Jesse Barnes <jbarnes@virtuousgeek.org>
Date: Tue Apr 10 11:58:04 2012 -0700
drm/i915: check PPS regs for sanity when using eDP
v2:
- Unlock the PP regs as the very first thing. This is a required w/a
for cpu eDP on port A, and generally a good idea.
- Fixup the panel power control port selection bits.
v3: Paulo Zanoni noticed that I've fumbled the computation of the spec
limit values. Fix them up. We've also noticed that the t8/t9 values in
the vbt/bios-programmed pp are much larger than any limits. My guess
is that this is to conceal any backlight enable/disable delays. So by
using the much shorter limits from the spec, which only concerns the
sink, we risk that we might display before the backlight is fully on,
or disable the output while the backlight still has afterglow. I've
figured I don't care too much, since this will only happen when both
the pp regs are not programmed, and the vbt tables don't contain
anything useful.
v4: Don't set the port selection bits on hsw/LPT, they don't exist any
more.
v5: Fixup spelling issues in comments, as noticed by Jesse Barnes.
... like the comment says. No idea whether this has any effect, but
I guess it's better to not lie to the display by acking a test request
and never following through with it. This goes back to the commit that
originally introduced this code:
commit a60f0e38d72a5e24085d6e7e27a4cadc20ae268a
Date: Thu Oct 20 15:09:17 2011 -0700
drm/i915: add DP test request handling
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Meh'ed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Dave Airlie <airlied@gmail.com>
Only really required for dp 1.2. I've hoped this would help with some
link training woes I'm fighting, but alas those are only dp 1.1
devices.
Also move a comment that went misplaced in the recent refactorings to
the right spot again.
This requires a few changes since that dpcd value is above the
range currently cached by radeon. I've check the dp specs, and
above 0xf there's a big gap and nothing that looks like we should
cache it while a given device is plugged in. It's also the same value
that i915.ko uses.
Hence extend the various dpcd arrays in the radeon driver, use
proper symbolic constants where applicable (one place overallocated
the dpcd array to 25 bytes). Then also drop the rd_interval cache -
radeon_dp_link_train_init re-reads the dpcd block, so the values we'll
consume in train_cr and train_ce will always be fresh.
To avoid needless diff-churn, #define the old size of dpcd as the new
one and keep it around.
v2: Alex Deucher noticed one place where I've forgotten to replace 8
with DP_RECEIVER_CAP_SIZE.
Safe for the minor difference that the intel versions get an offset
into the link_status as an argument, both are the same again.
radeon and intel use the exact same definition.
v2: Kill 2 more helpers in intel_dp.c that I've missed.
Move the cached EDID from intel_dp and intel_lvds_connector to
intel_connector. Unify cached EDID handling for LVDS and eDP, in
preparation for adding more generic EDID caching later.
Pave the way for sharing some logic between eDP and LVDS.
Based on earlier work by Chris Wilson <chris@chris-wilson.co.uk>
CC: Chris Wilson <chris@chris-wilson.co.uk>
Create a generic struct intel_panel for sharing a data structure and code
between eDP and LVDS panels. Add the new struct to intel_connector so that
later on we can have generic EDID and mode reading functions with EDID
caching that transparently fallback to fixed mode when EDID is not
available.
Add intel_panel as a dummy first, and move data (such as the mentioned
fixed mode) to it in later patches.
[danvet: Fixup tiny conflict in intel_dp_destroy.]
Since we do EDID caching in intel_dp_init, we can do the fixed mode
initialization there too. This should not change the functionality apart
from initializing fixed mode earlier. Particularly retain the behaviour of
only falling back to VBT if EDID is not available to not regress
commit 47f0eb2234a2a1c790825393bbaccfadf82463d3
Author: Keith Packard <keithp@keithp.com>
Date: Mon Sep 19 14:33:26 2011 -0700
drm/i915: Only use VBT panel mode on eDP if no EDID is found
Get rid of saved int_lvds_connector and int_edp_connector in
drm_i915_private.
Linux 3.7-rc2
Backmerge to solve two ugly conflicts:
- uapi. We've already added new ioctl definitions for -next. Do I need to say more?
- wc support gtt ptes. We've had to revert this for snb+ for 3.7 and
also fix a few other things in the code. Now we know how to make it
work on snb+, but to avoid losing the other fixes do the backmerge
first before re-enabling wc gtt ptes on snb+.
And a few other minor things, among them git getting confused in
intel_dp.c and seemingly causing a conflict out of nothing ...
drivers/gpu/drm/i915/i915_reg.h
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/i915/intel_dp.c
drivers/gpu/drm/i915/intel_modes.c
include/drm/i915_drm.h
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Daniel writes:
The big thing is the disabling of the hsw support by default, cc: stable.
We've aimed for basic hsw support in 3.6, but due to a few bad
happenstances we've screwed up and only 3.8 will have better modeset
support than vesa. To avoid yet another round of fallout from such a
gaffle on for the next platform we've added a module option to disable
early hw support by default. That should also give us more flexibility in
bring-up.
Otherwise just small fixes:
- 3 fixes from Egbert for sdvo corner cases
- invert-brightness quirk entry from Egbert
- revert a dp link training change, it regresses some setups
- and shut up a spurious WARN in our gem fault handler.
- regression fix for an oops on bit17 swizzling machines, introduce in 3.7
- another no-lvds quirk
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
drm/i915: Initialize obj->pages before use by i915_gem_object_do_bit17_swizzle()
drm/i915: Add no-lvds quirk for Supermicro X7SPA-H
drm/i915: Insert i915_preliminary_hw_support variable.
drm/i915: shut up spurious WARN in the gtt fault handler
Revert "drm/i915: Try harder to complete DP training pattern 1"
DRM/i915: Restore sdvo_flags after dtd->mode->dtd Roundrtrip.
DRM/i915: Don't clone SDVO LVDS with analog.
DRM/i915: Add QUIRK_INVERT_BRIGHTNESS for NCR machines.
DRM/i915: Don't delete DPLL Multiplier during DAC init.
This is the final remaining piece of Haswell DP enablement. After this
patch, just calling intel_dp_init on any port will make DP work. We
still do not do this because we're currently initializing HDMI on all
the ports, so if we replace intel_hdmi_init with intel_dp_init, we
will break HDMI, and we can't call both because they share the same
registers.
Previous patch "drm/i915: add basic Haswell DP link train bits"
implemented the basic structure to set the voltage levels and training
patterns. This patch adds the higher-level bits that are part of the
mode set sequence and hot plug.
We have to write the correct values inside intel_dp_set_m_n and then
prevent these values from being overwritten later.
V2: Unconfuse double negation.
The old rule that the AUX registers are just an offset (+4 and +10)
from output_reg is not true anymore, since output_reg in on the CPU
and some AUX regs are on the PCH.
[danvet: use the existing #defines as spotted by Damien Lespiau.]
Much simpler and looks more like the M/N code inside intel_display.c.
Previously, the DP register was used for everything. On Haswell, it
was split into DDI_BUF_CTL (which is the new intel_dp->DP register)
and DP_TP_CTL.
The logic behind this patch is based on a patch written by Shobhit
Kumar, but the way the code was written is very different.
Credits-to: Shobhit Kumar <shobhit.kumar@intel.com>
[danvet: Fixup the logic error spotted by Jani Nikula.]
This reverts commit 2477367083b3eaa97f87993ab26627a02f350551.
If (for whatever reason) the DP sink device never asks for the maximal
voltage level, we never don't hit the check that should bail us out
after 5 retries of the same voltage. Which leads to an endless loop in
the DP link training code, which hangs the driver.
Now some more DP link training experiments on eDP panels seem to
indicate that our training algorithm isn't robust enough anyway and
needs more work. Hence for 3.7-fixes, let's just revert the regressing
commit instead of trying to apply more duct-tape.
Reported-by: Oleksij Rempel <bug-track@fisher-privat.net>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Daniel writes:
"- some register magic to fix hsw crw (Paulo&Ben)
- fix backlight destruction for cpu edp (Jani)
- fix gen ch7xxx dvo ->get_hw_state
- fixup the plane->pipe fixup code, the broken version massively angers
the modeset sanity checks
- kill pipe A quirk for i855gm, otherwise I get a black screen with the
above patch
- fixup for gem_get_page helper (Chris)
- fixup guardband clipping w/a (Ken), without this mesa master can erronously
drop vertices on snb, mesa 9.0 has the optimization reverted
- another pageflip vs. modeset fix
- kill bogus BUG_ON which broke ums+gem from Willy Tarreau (gasp, people
are still using this!)"
drm/i915: fix non-DP-D eDP backlight cleanup and module reload
drm/i915: HSW CRW stability magic
drm/i915/dvo-ch7xxx: fix get_hw_state
drm/i915: fixup the plane->pipe fixup code
drm/i915: rip out the pipe A quirk for i855gm
drm/i915: disable wc gtt pte mappings on gen2
drm/i915: fixup i915_gem_object_get_page inline helper
drm/i915: Disallow preallocation of requests
drm/i915: Set guardband clipping workaround bit in the right register.
drm/i915: paper over a pipe-enable vs pageflip race
drm/i915: remove useless BUG_ON which caused a regression in 3.5.
