path: root/drivers/gpu/drm/i915/i915_dma.c
2012-05-02drm/i915: Only enable IPS polling for gen5Chris Wilson
On SandyBridge IPS was entirely implemented in hardware and not reliant on the driver monitoring power consumption and feeding back desired run states, so the hardware is able to adapt quicker and more flexibly. Which is a huge relief for us as we no longer have to carry empirically derived magic algorithms. Yet despite the advance in technology, the driver was still doing its IPS polling on all machines. Restrict it to the only supported hardware, Clarkdale/Arrandale. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Andrey Rahmatullin <wrar@wrar.name> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=49025 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-04-03drm/i915: don't leak struct_mutex lock on ppgtt init failuresDaniel Vetter
Reported-by: Konstantin Belousov <kostikbel@gmail.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-04-02drm/i915: disable ppgtt on snb when dmar is enabledDaniel Vetter
Totally unexpected that this regressed. Luckily it sounds like we just need to have dmar disable on the igfx, not the entire system. At least that's what a few days of testing between Tony Vroon and me indicates. Reported-by: Tony Vroon <tony@linx.net> Cc: Tony Vroon <tony@linx.net> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43024 Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-23Merge remote-tracking branch 'airlied/drm-next' into for-airliedDaniel Vetter
Manually resolve the conflict between the new enum drm property helpers in drm-next and the new "force-dvi" option that the "audio" output property gained in drm-intel-next. While resolving this conflict, switch the new drm_prop_enum_list to use the newly introduced enum defines instead of magic values. Conflicts: drivers/gpu/drm/i915/intel_modes.c Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-16drm: move pci bus master enable into driver.Dave Airlie
The current enabling of bus mastering in the drm midlayer allows a large race condition under kexec. When a kexec'ed kernel re-enables bus mastering for the GPU, previously setup dma blocks may cause writes to random pieces of memory. On radeon the writeback mechanism can cause these sorts of issues. This patch doesn't fix the problem, but it moves the bus master enable under the individual drivers control so they can move enabling it until later in their load cycle and close the race. Fix for radeon kms driver will be in a follow-up patch. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-14Merge tag 'drm-intel-next-2012-02-07' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-core-next * tag 'drm-intel-next-2012-02-07' of git://people.freedesktop.org/~danvet/drm-intel: (29 commits) drm/i915: Handle unmappable buffers during error state capture drm/i915: rewrite shmem_pread_slow to use copy_to_user drm/i915: rewrite shmem_pwrite_slow to use copy_from_user drm/i915: fall through pwrite_gtt_slow to the shmem slow path drm/i915: add debugfs file for swizzling information drm/i915: fix swizzle detection for gen3 drm/i915: Remove the upper limit on the bo size for mapping into the CPU domain drm/i915: add per-ring fault reg to error_state drm/i915: reject GTT domain in relocations drm/i915: remove the i915_batchbuffer_info debugfs file drm/i915: capture error_state also for stuck rings drm/i915: refactor debugfs create functions drm/i915: refactor debugfs open function drm/i915: don't trash the gtt when running out of fences drm/i915: Separate fence pin counting from normal bind pin counting drm/i915/ringbuffer: kill snb blt workaround drm/i915: collect more per ring error state drm/i915: refactor ring error state capture to use arrays drm/i915: switch ring->id to be a real id drm/i915: set AUD_CONFIG N_value_index for DisplayPort ...
2012-02-13drm/i915: fix up locking inconsistency around gem_do_initDaniel Vetter
The locking in our setup and teardown paths is rather arbitrary, but generally we try to protect gem stuff with dev->struct_mutex. Further, the ums/gem ioctl to setup gem _does_ take the look. So fix up this benign inconsistency. Notice while reading through code. v2: Rebased on top of the ppgtt code. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-10Merge remote-tracking branch 'airlied/drm-fixes' into drm-intel-next-queuedDaniel Vetter
Back-merge from drm-fixes into drm-intel-next to sort out two things: - interlaced support: -fixes contains a bugfix to correctly clear interlaced configuration bits in case the bios sets up an interlaced mode and we want to set up the progressive mode (current kernels don't support interlaced). The actual feature work to support interlaced depends upon (and conflicts with) this bugfix. - forcewake voodoo to workaround missed IRQ issues: -fixes only enabled this for ivybridge, but some recent bug reports indicate that we need this on Sandybridge, too. But in a slightly different flavour and with other fixes and reworks on top. Additionally there are some forcewake cleanup patches heading to -next that would conflict with currrent -fixes. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: enable ppgttDaniel Vetter
We want to unconditionally enable ppgtt for two reasons: - Windows uses this on snb and later. - We need the basic hw support to work before we can think about real per-process address spaces and other cool features we want. But Chris Wilson was complaining all over irc and intel-gfx that this will blow up if we don't have a module option to disable it. Hence add one, to prevent this. ppgtt support seems to slightly change the timings and make crashy things slightly more or less crashy. Now in my testing and the testing this got on troublesome snb machines, it seems to have improved things only. But on ivb it makes quite a few crashes happen much more often, see https://bugs.freedesktop.org/show_bug.cgi?id=41353 Luckily Eugeni Dodonov seems to have a set of workarounds that fix this issue. v2: Don't try to enable ppgtt on pre-snb. v3: Pimp commit message and make Chris Wilson less grumpy by adding a module option. v4: New try at making Chris Wilson happy. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: initialization/teardown for the aliasing ppgttDaniel Vetter
This just adds the setup and teardown code for the ppgtt PDE and the last-level pagetables, which are fixed for the entire lifetime, at least for the moment. v2: Kill the stray debug printk noted by and improve the pte definitions as suggested by Chris Wilson. v3: Clean up the aperture stealing code as noted by Ben Widawsky. v4: Paint the init code in a more pleasing colour as suggest by Chris Wilson. v5: Explain the magic numbers noticed by Ben Widawsky. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-08drm/i915: swizzling support for snb/ivbDaniel Vetter
We have to do this manually. Somebody had a Great Idea. I've measured speed-ups just a few percent above the noise level (below 5% for the best case), but no slowdows. Chris Wilson measured quite a bit more (10-20% above the usual snb variance) on a more recent and better tuned version of sna, but also recorded a few slow-downs on benchmarks know for uglier amounts of snb-induced variance. v2: Incorporate Ben Widawsky's preliminary review comments and elaborate a bit about the performance impact in the changelog. v3: Add a comment as to why we don't need to check the 3rd memory channel. v4: Fixup whitespace. Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-07Merge branch 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel ↵Dave Airlie
into drm-core-next * 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: add a LLC feature flag in device description drm/i915: kill i915_mem.c drm/i915: Use kcalloc instead of kzalloc to allocate array drm/i915/dp: Check for AUXCH error before checking for success drm/i915/dp: Use auxch precharge value of 5 everywhere drm/i915/dp: Tweak auxch clock divider for PCH drm/i915: Remove a comment about PCH from the non-PCH path drm/i915: Fix assert_pch_hdmi_disabled to mention HDMI (not DP) drm/i915: Implement plane-disabled assertion for PCH too drivers: i915: Fix BLC PWM register setup drm/i915: Check that plane/pipe is disabled before removing the fb drm/i915: fix typo in function name drm/i915: split out pll divider code drm/i915: split 9xx refclk & sdvo tv code out agp/intel: Add pci id for hostbridge from has/qemu drm/i915: there is no pipe CxSR on ironlake drm/i915: Only look for matching clocks for LVDS downclock drm/i915: Silence _DSM errors
2012-01-26drm/i915: argument to control retiring behaviorBen Widawsky
Sometimes it may be the case when we idle the gpu or wait on something we don't actually want to process the retiring list. This patch allows callers to choose the behavior. Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-19drm/i915: protect force_wake_(get|put) with the gt_lockDaniel Vetter
The problem this patch solves is that the forcewake accounting necessary for register reads is protected by dev->struct_mutex. But the hangcheck and error_capture code need to access registers without grabbing this mutex because we hold it while waiting for the gpu. So a new lock is required. Because currently the error_state capture is called from the error irq handler and the hangcheck code runs from a timer, it needs to be an irqsafe spinlock (note that the registers used by the irq handler (neglecting the error handling part) only uses registers that don't need the forcewake dance). We could tune this down to a normal spinlock when we rework the error_state capture and hangcheck code to run from a workqueue. But we don't have any read in a fastpath that needs forcewake, so I've decided to not care much about overhead. This prevents tests/gem_hangcheck_forcewake from i-g-t from killing my snb on recent kernels - something must have slightly changed the timings. On previous kernels it only trigger a WARN about the broken locking. v2: Drop the previous patch for the register writes. v3: Improve the commit message per Chris Wilson's suggestions. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-17drm/i915: add a LLC feature flag in device descriptionEugeni Dodonov
LLC is not SNB/IVB-specific, so we should check for it in a more generic way. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-17drm/i915: kill i915_mem.cDaniel Vetter
Some decent history digging indicates that this was to be used for the GLX_MESA_allocate_memory extension but never actually implemented for any released i915 userspace code. So just rip it out. v2: Fixup the Makefile. Acked-by: Dave Airlie <airlied@gmail.com> Cc: Keith Whitwell <keithw@vmware.com> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-03drm/i915: Add support for resetting the SO write pointers on gen7.Eric Anholt
These registers are automatically incremented by the hardware during transform feedback to track where the next streamed vertex output should go. Unlike the previous generation, which had a packet for setting the corresponding registers to a defined value, gen7 only has MI_LOAD_REGISTER_IMM to do so. That's a secure packet (since it loads an arbitrary register), so we need to do it from the kernel, and it needs to be settable atomically with the batchbuffer execution so that two clients doing transform feedback don't stomp on each others' state. Instead of building a more complicated interface involcing setting the registers to a specific value, just set them to 0 when asked and userland can tweak its pointers accordingly. Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-03drm/i915: add color key support v4Jesse Barnes
Add new ioctls for getting and setting the current destination color key. This allows for simple overlay display control by matching a color key value in the primary plane before blending the overlay on top. v2: remove unnecessary mutex acquire/release around reg accesses v3: add support for full color key management v4: fix copy & paste bug in snb_get_colorkey don't bother checking min/max values against docs as the docs are likely wrong (how could we handle 10bpc surface formats?) Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-12-16drm/i915: prevent division by zero when asking for chipset powerEugeni Dodonov
This prevents an in-kernel division by zero which happens when we are asking for i915_chipset_val too quickly, or within a race condition between the power monitoring thread and userspace accesses via debugfs. The issue can be reproduced easily via the following command: while ``; do cat /sys/kernel/debug/dri/0/i915_emon_status; done This is particularly dangerous because it can be triggered by a non-privileged user by just reading the debugfs entry. This issue was also found independently by Konstantin Belousov <kostikbel@gmail.com>, who proposed a similar patch. Reported-by: Konstantin Belousov <kostikbel@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Keith Packard <keithp@keithp.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-10-31gpu: add module.h to drivers/gpu files as required.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is removed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-20drm/i915: support 3 pipes on IVB+Jesse Barnes
Well almost anyway. IVB has 3 planes, pipes, transcoders, and FDI interfaces, but only 2 pipe PLLs. So two of the pipes must use the same pipe timings (e.g. 2 DP plus one other, or two HDMI with the same mode and one other, etc.). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-09-19Drivers: i915: Fix all space related issues.Akshay Joshi
Various issues involved with the space character were generating warnings in the checkpatch.pl file. This patch removes most of those warnings. Signed-off-by: Akshay Joshi <me@akshayjoshi.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-22Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
2011-07-22drm/i915: Initialize RCS ring status page address in intel_render_ring_init_driKeith Packard
Physically-addressed hardware status pages are initialized early in the driver load process by i915_init_phys_hws. For UMS environments, the ring structure is not initialized until the X server starts. At that point, the entire ring structure is re-initialized with all new values. Any values set in the ring structure (including ring->status_page.page_addr) will be lost when the ring is re-initialized. This patch moves the initialization of the status_page.page_addr value to intel_render_ring_init_dri. Signed-off-by: Keith Packard <keithp@keithp.com> Cc: stable@kernel.org
2011-07-12Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
2011-07-12drm/i915: Clean up i915_driver_load failure pathKeith Packard
i915_driver_load adds a write-combining MTRR region for the GTT aperture to improve memory speeds through the aperture. If i915_driver_load fails after this, it would not have cleaned up the MTRR. This shouldn't cause any problems, except for consuming an MTRR register. Still, it's best to clean up completely in the failure path, which is easily done by calling mtrr_del if the mtrr was successfully allocated. i915_driver_load calls i915_gem_load which register i915_gem_inactive_shrink. If i915_driver_load fails after calling i915_gem_load, the shrinker will be left registered. When called, it will access freed memory and crash. The fix is to unregister the shrinker in the failure path using code duplicated from i915_driver_unload. i915_driver_load also has some incorrect gotos in the error cleanup paths: * After failing to initialize the GTT (which cannot happen, btw, intel_gtt_get returns a fixed (non-NULL) value), it tries to free the uninitialized WC IO mapping. Fixed this by changing the target from out_iomapfree to out_rmmap Signed-off-by: Keith Packard <keithp@keithp.com> Tested-by: Lin Ming <ming.m.lin@intel.com>
2011-07-08drm/i915: Only export the generic intel_disable_fbc() interfaceChris Wilson
As the enable/disable routines will be gain additional complexity in future patches, it is necessary that all callers do not bypass the generic interface by calling into the chipset routines directly. to do this we make the chipset routines static, so there is no choice. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-29drm/i915: move IRQ function table init to i915_irq.cJesse Barnes
This lets us make the various IRQ functions static and helps avoid problems like the one fixed in "drm/i915: Use chipset-specific irq installers" where one of the exported functions was called rather than the chipset specific version. This also fixes a UMS-mode bug -- the correct irq functions for IRL and later chips were only getting loaded in the KMS path. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-27drm/i915: more struct_mutex lockingHugh Dickins
When auditing the locking in i915_gem.c (for a prospective change which I then abandoned), I noticed two places where struct_mutex is not held across GEM object manipulations that would usually require it. Since one is in initial setup and the other in driver unload, I'm guessing the mutex is not required for either; but post a patch in case it is. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-13drm/i915: interrupt & vblank support for Ivy BridgeJesse Barnes
Add new interrupt handling functions for Ivy Bridge. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-13drm/i915: split enable/disable vblank code into chipset specific functionsJesse Barnes
This makes the Ironlake+ code trivial and generally simplifies things. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-13drm/i915: split irq handling into per-chipset functionsJesse Barnes
Set the IRQ handling functions in driver load so they'll just be used directly, rather than branching over most of the code in the chipset functions. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-10drm/i915: move gen6 rps handling to workqueueBen Widawsky
The render P-state handling code requires reading from a GT register. This means that FORCEWAKE must be written to, a resource which is shared and should be protected by struct_mutex. Hence we can not manipulate that register from within the interrupt handling and so must delegate the task to a workqueue. Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-10drm/i915: Disable all outputs early, before KMS takeoverChris Wilson
If the outputs are active and continuing to access the GATT when we teardown the PTEs, then there is a potential for us to hang the GPU. The hang tends to be a PGTBL_ER with either an invalid host access or an invalid display plane fetch. v2: Reorder IRQ initialisation to defer until after GEM is setup. Reported-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch> (855GM) Tested-by: Pekka Enberg <penberg@kernel.org> # note that this doesn't fix the underlying problem of the PGTBL_ER and pipe underruns being reported immediately upon init on his 965GM MacBook Reported-and-tested-by: Rick Bramley <richard.bramley@hp.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=35635 Reported-and-tested-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=36048 Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
2011-05-10drm/1915: ringbuffer wait for idle functionBen Widawsky
Added a new function which waits for the ringbuffer space to be equal to (total - 8). This is the empty condition of the ringbuffer, and equivalent to head==tail. Also modified two users of this functionality elsewhere in the code. Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-04-27drm/i915: restore only the mode of this driver on lastclose (v2)Dave Airlie
i915 calls the panic handler function on last close to reset the modes, however this is a really bad idea for multi-gpu machines, esp shareable gpus machines. So add a new entry point for the driver to just restore its own fbcon mode. v2: move code into fb helper, fix panic code to block mode change on powered off GPUs. [airlied: this hits drm core and I wrote it and it was reviewed on intel-gfx so really I signed it off twice ;-).] Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-02drm/i915: don't store the reg value for HWS_PGAChris Wilson
It is trivially computable from the real physical address so no need to store both. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-03-01Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
2011-03-01drm/i915: fix memory corruption with GM965 and >4GB RAMJan Niehusmann
On a Thinkpad x61s, I noticed some memory corruption when plugging/unplugging the external VGA connection. The symptoms are that 4 bytes at the beginning of a page get overwritten by zeroes. The address of the corruption varies when rebooting the machine, but stays constant while it's running (so it's possible to repeatedly write some data and then corrupt it again by plugging the cable). Further investigation revealed that the corrupted address is (dev_priv->status_page_dmah->busaddr & 0xffffffff), ie. the beginning of the hardware status page of the i965 graphics card, cut to 32 bits. So it seems that for some memory access, the hardware uses only 32 bit addressing. If the hardware status page is located >4GB, this corrupts unrelated memory. Signed-off-by: Jan Niehusmann <jan@gondor.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2011-03-01drm/i915: Allow relocation deltas outside of target boChris Wilson
Userspace has a legitimate requirement to use a delta that points to outside of the target bo, and so we need to enable this. (As this is an abi break, albeit a relaxation of the current restrictions, mark the change with a new flag.) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-02-07drm/i915: cleanup per-pipe reg usageJesse Barnes
We had some conversions over to the _PIPE macros, but didn't get everything. So hide the per-pipe regs with an _ (still used in a few places for legacy) and add a few _PIPE based macros, then make sure everyone uses them. [update: remove usage of non-existent no-op macro] [update 2: keep modesetting suspend/resume code, update to new reg names] Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> [ickle: stylistic cleanups for checkpatch and taste] Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-02-07drm/i915: Refine tracepointsChris Wilson
A lot of minor tweaks to fix the tracepoints, improve the outputting for ftrace, and to generally make the tracepoints useful again. It is a start and enough to begin identifying performance issues and gaps in our coverage. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-24Merge branch 'drm-intel-fixes' into drm-intel-nextChris Wilson
Merge important suspend and resume regression fixes and resolve the small conflict. Conflicts: drivers/gpu/drm/i915/i915_dma.c
2011-01-23drm/i915: Recognise non-VGA display devicesChris Wilson
Starting with SandyBridge (though possible with earlier hacked BIOSes), the BIOS may initialise the IGFX as secondary to a discrete GPU. Prior, it would simply disable the integrated GPU. So we adjust our PCI class mask to match any DISPLAY_CLASS device. In such a configuration, the IGFX is not a primary VGA controller and so should not take part in VGA arbitration, and the error return from vga_client_register() is expected. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2011-01-20drm/i915: Initialise ring vfuncs for old DRI pathsChris Wilson
We weren't setting up the vfunc table when initialising the old DRI ringbuffer, leading to such OOPSes as: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<(null)>] (null) PGD 10c441067 PUD 1185e5067 PMD 0 Oops: 0010 [#1] PREEMPT SMP last sysfs file: /sys/class/dmi/id/chassis_asset_tag CPU 3 Modules linked in: i915 drm_kms_helper drm fb fbdev i2c_algo_bit cfbcopyarea video backlight output cfbimgblt cfbfillrect autofs4 ipv6 nfs lockd fscache nfs_acl auth_rpcgss sunrpc coretemp hwmon_vid mousedev usbhid hid option usb_wwan snd_hda_codec_via asus_atk0110 atl1e usbserial snd_hda_intel snd_hda_codec firmware_class snd_hwdep snd_pcm snd_seq snd_timer snd_seq_device processor parport_pc thermal snd thermal_sys parport 8250_pnp button rng_core rtc_cmos shpchp hwmon rtc_core ehci_hcd pci_hotplug uhci_hcd soundcore tpm_tis i2c_i801 rtc_lib tpm serio_raw snd_page_alloc tpm_bios i2c_core usbcore psmouse intel_agp sg pcspkr sr_mod evdev cdrom ext3 jbd mbcache dm_mod sd_mod ata_piix libata scsi_mod unix Jan 18 15:49:29 lithui kernel: Pid: 3605, comm: Xorg Not tainted 2.6.36.2 #5 P5KPL-CM/System Product Name RIP: 0010:[<0000000000000000>] [<(null)>] (null) RSP: 0018:ffff8801150d1d40 EFLAGS: 00010202 RAX: 000000000001ffff RBX: ffff88011a011b00 RCX: 000000000001a704 RDX: ffff880118566028 RSI: ffff880118566028 RDI: ffff880117876800 RBP: ffff8801150d1d48 R08: ffff8801195fe300 R09: 00000000c0086444 R10: 0000000000000001 R11: 0000000000003206 R12: ffff880117876800 R13: ffff880118566000 R14: ffff880117876820 R15: ffff8801150d1df8 FS: 00007f1038d456e0(0000) GS:ffff880001780000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 00000001187e7000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process Xorg (pid: 3605, threadinfo ffff8801150d0000, task ffff88011b016e40) Stack: ffffffffa043b8e6 ffff8801150d1d98 ffffffffa041768b dead000000000000 <0> 0000000000000048 00007f1023f2a000 0000000000000044 0000000000000008 <0> ffff88010d26bd80 ffff880117876800 ffff8801150d1df8 ffff8801150d1ea8 Call Trace: [<ffffffffa043b8e6>] ? intel_ring_advance+0x16/0x20 [i915] [<ffffffffa041768b>] i915_irq_emit+0x15b/0x240 [i915] [<ffffffffa03ea7b1>] drm_ioctl+0x1f1/0x460 [drm] [<ffffffffa0417530>] ? i915_irq_emit+0x0/0x240 [i915] [<ffffffff810dd8f1>] ? do_sync_read+0xd1/0x120 [<ffffffff81025b1f>] ? do_page_fault+0x1df/0x3d0 [<ffffffff810ed5c7>] do_vfs_ioctl+0x97/0x550 [<ffffffff8115c2ea>] ? security_file_permission+0x7a/0x90 [<ffffffff810edb19>] sys_ioctl+0x99/0xa0 [<ffffffff810024ab>] system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [<(null)>] (null) RSP <ffff8801150d1d40> CR2: 0000000000000000 Reported-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Herbert Xu <herbert@gondor.apana.org.au> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29153 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=23172 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2011-01-19drm/i915: Trivial sparse fixesChris Wilson
Move code around and invoke iomem annotation in a few more places in order to silence sparse. Still a few more iomem annotations to go... Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-11drm/i915: Remove impossible testChris Wilson
As has_gem is unconditionally set to true, the conditional immediately following that assignment is superfluous. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2011-01-05drm/switcheroo: track state of switch in drivers.Dave Airlie
We need to track the state of the switch in drivers, so that after s/r we don't resume the card we've explicitly switched off before. Also don't allow a userspace open to occur if we've switched the gpu off. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-05vga_switcheroo: add reprobe hook for fbcon to recheck connected outputs.Dave Airlie
This adds a hook after the mux is switched for the driver to reprobe the connected outputs. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-05Merge branch 'master' of /home/airlied/kernel/linux-2.6 into drm-core-nextDave Airlie
