path: root/drivers/gpu/drm/bridge/tc358767.c
2019-01-09drm/bridge: tc358767: use DP connector if no panel setTomi Valkeinen
tc358767 driver sets the connector type always to eDP. This patch sets the type to DP if there is no panel defined, which implies that there's a DP connector on the board. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-8-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: fix output H/V syncsTomi Valkeinen
The H and V syncs of the DP output are always set to active high. This patch fixes the syncs by configuring them according to the videomode. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-7-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: reject modes which require too much BWTomi Valkeinen
The current driver accepts any videomode with pclk < 154MHz. This is not correct, as with 1 lane and/or 1.62Mbps speed not all videomodes can be supported. Add code to reject modes that require more bandwidth that is available. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-6-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: fix initial DP0/1_SRCCTRL valueTomi Valkeinen
Initially DP0_SRCCTRL is set to a static value which includes DP0_SRCCTRL_LANES_2 and DP0_SRCCTRL_BW27, even when only 1 lane of 1.62Gbps speed is used. DP1_SRCCTRL is configured to a magic number. This patch changes the configuration as follows: Configure DP0_SRCCTRL by using tc_srcctrl() which provides the correct value. DP1_SRCCTRL needs two bits to be set to the same value as DP0_SRCCTRL: SSCG and BW27. All other bits can be zero. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-5-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: fix single lane configurationTomi Valkeinen
PHY_2LANE bit is always set in DP_PHY_CTRL, breaking 1 lane use. Set PHY_2LANE only when 2 lanes are used. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-4-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: add defines for DP1_SRCCTRL & PHY_2LANETomi Valkeinen
DP1_SRCCTRL register and PHY_2LANE field did not have matching defines. Add these. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-3-tomi.valkeinen@ti.com
2019-01-09drm/bridge: tc358767: add bus flagsTomi Valkeinen
tc358767 driver does not set DRM bus_flags, even if it does configures the polarity settings into its registers. This means that the DPI source can't configure the polarities correctly. Add sync flags accordingly. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190103115954.12785-2-tomi.valkeinen@ti.com
2018-07-13drm: drop _mode_ from drm_mode_connector_attach_encoderDaniel Vetter
Again to align with the usual prefix of just drm_connector_. Again done with sed + manual fixup for indent issues. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180709084016.23750-7-daniel.vetter@ffwll.ch
2018-07-13drm: drop _mode_ from update_edit_property()Daniel Vetter
Just makes it longer, and for most things in drm_connector.[hc] we just use the drm_connector_ prefix. Done with sed + a bit of manual fixup for the indenting. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180709084016.23750-6-daniel.vetter@ffwll.ch
2018-04-25drm/bridge: tc358767: fix mode_valid's return typeLuc Van Oostenryck
The method struct drm_connector_helper_funcs::mode_valid is defined as returning an 'enum drm_mode_status' but the driver implementation for this method uses an 'int' for it. Fix this by using 'enum drm_mode_status' in the driver too. Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: https://patchwork.freedesktop.org/patch/msgid/20180424131453.1961-1-luc.vanoostenryck@gmail.com
2017-12-04Merge tag 'drm-misc-next-2017-11-30' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next Cross-subsystem Changes: - device tree doc for the Mitsubishi AA070MC01 and Tianma TM070RVHG71 panels (Lukasz Majewski) and for a 2nd endpoint on stm32 (Philippe Cornu) Core Changes: The most important changes are: - Add drm_driver .last_close and .output_poll_changed helpers to reduce fbdev emulation footprint in drivers (Noralf) - Fix plane clipping in core and for vmwgfx (Ville) Then we have a bunch of of improvement for print and debug such as the addition of a framebuffer debugfs file. ELD connector, HDMI and improvements. And a bunch of misc improvements, clean ups and style changes and doc updates [airlied: drop eld bits from amdgpu_dm] Driver Changes: - sii8620: filter unsupported modes and add DVI mode support (Maciej Purski) - rockchip: analogix_dp: Remove unnecessary init code (Jeffy Chen) - virtio, cirrus: add fb create_handle support to enable screenshots(Lepton Wu) - virtio: replace reference/unreference with get/put (Aastha Gupta) - vc4, gma500: Convert timers to use timer_setup() (Kees Cook) - vc4: Reject HDMI modes with too high of clocks (Eric) - vc4: Add support for more pixel formats (Dave Stevenson) - stm: dsi: Rename driver name to "stm32-display-dsi" (Philippe Cornu) - stm: ltdc: add a 2nd endpoint (Philippe Cornu) - via: use monotonic time for VIA_WAIT_IRQ (Arnd Bergmann) * tag 'drm-misc-next-2017-11-30' of git://anongit.freedesktop.org/drm/drm-misc: (96 commits) drm/bridge: tc358767: add copyright lines MAINTAINERS: change maintainer for Rockchip drm drivers drm/vblank: Fix vblank timestamp debugs drm/via: use monotonic time for VIA_WAIT_IRQ dma-buf: Fix ifnullfree.cocci warnings drm/printer: Add drm_vprintf() drm/edid: Allow HDMI infoframe without VIC or S3D video/hdmi: Allow "empty" HDMI infoframes dma-buf/fence: Fix lock inversion within dma-fence-array drm/sti: Handle return value of platform_get_irq_byname drm/vc4: Add support for NV21 and NV61. drm/vc4: Use .pixel_order instead of custom .flip_cbcr drm/vc4: Add support for DRM_FORMAT_RGB888 and DRM_FORMAT_BGR888 drm: Move drm_plane_helper_check_state() into drm_atomic_helper.c drm: Check crtc_state->enable rather than crtc->enabled in drm_plane_helper_check_state() drm/vmwgfx: Try to fix plane clipping drm/vmwgfx: Use drm_plane_helper_check_state() drm/vmwgfx: Remove bogus crtc coords vs fb size check gpu: gma500: remove unneeded DRIVER_LICENSE #define drm: don't link DP aux i2c adapter to the hardware device node ...
2017-11-30drm/bridge: tc358767: add copyright linesAndrey Gusakov
Add copyright lines for Zodiac who paid for driver development. Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Acked-by: Chris Healy <cphealy@gmail.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-8-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: fix 1-lane behaviorAndrey Gusakov
Use drm_dp_channel_eq_ok helper Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-7-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: fix AUXDATAn registers accessAndrey Gusakov
First four bytes should go to DP0_AUXWDATA0. Due to bug if len > 4 first four bytes was writen to DP0_AUXWDATA1 and all data get shifted by 4 bytes. Fix it. Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-6-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: fix timing calculationsAndrey Gusakov
Fields in HTIM01 and HTIM02 regs should be even. Recomended thresh_dly value is max_tu_symbol. Remove set of VPCTRL0.VSDELAY as it is related to DSI input interface. Currently driver supports only DPI. Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-5-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: fix DP0_MISC register setAndrey Gusakov
Remove shift from TU_SIZE_RECOMMENDED define as it used to calculate max_tu_symbols. Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-4-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: filter out too high modesAndrey Gusakov
Pixel clock limitation for DPI is 154 MHz. Do not accept modes with higher pixel clock rate. Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-3-git-send-email-andrey.gusakov@cogentembedded.com
2017-11-30drm/bridge: tc358767: do no fail on hi-res displaysAndrey Gusakov
Do not fail data rates higher than 2.7 and more than 2 lanes. Try to fall back to 2.7Gbps and 2 lanes. Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Link: https://patchwork.freedesktop.org/patch/msgid/1510073785-16108-2-git-send-email-andrey.gusakov@cogentembedded.com
2017-08-15Backmerge tag 'v4.13-rc5' into drm-nextDave Airlie
Linux 4.13-rc5 There's a really nasty nouveau collision, hopefully someone can take a look once I pushed this out.
2017-08-08drm: Nuke drm_atomic_helper_connector_dpmsDaniel Vetter
It's dead code, the core handles all this directly now. The only special case is nouveau and tda988x which used one function for both legacy modeset code and -nv50 atomic world instead of 2 vtables. But amounts to exactly the same. v2: Rebase over the panel/brideg refactorings in stm/ltdc. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Cc: Archit Taneja <architt@codeaurora.org> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Laurent Pinchart <Laurent.pinchart@ideasonboard.com> Cc: Peter Senna Tschudin <peter.senna@collabora.com> Cc: Martin Donnelly <martin.donnelly@ge.com> Cc: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Daniel Vetter <daniel.vetter@intel.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Sean Paul <seanpaul@chromium.org> Cc: David Airlie <airlied@linux.ie> Cc: Inki Dae <inki.dae@samsung.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Seung-Woo Kim <sw0312.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Kukjin Kim <kgene@kernel.org> Cc: Krzysztof Kozlowski <krzk@kernel.org> Cc: Stefan Agner <stefan@agner.ch> Cc: Alison Wang <alison.wang@freescale.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: CK Hu <ck.hu@mediatek.com> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Neil Armstrong <narmstrong@baylibre.com> Cc: Carlo Caione <carlo@caione.org> Cc: Kevin Hilman <khilman@baylibre.com> Cc: Marek Vasut <marex@denx.de> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Eric Anholt <eric@anholt.net> Cc: Mark Yao <mark.yao@rock-chips.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org> Cc: Vincent Abriou <vincent.abriou@st.com> Cc: Yannick Fertre <yannick.fertre@st.com> Cc: Philippe Cornu <philippe.cornu@st.com> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Jonathan Hunter <jonathanh@nvidia.com> Cc: Jyri Sarha <jsarha@ti.com> Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Cc: Jeffy Chen <jeffy.chen@rock-chips.com> Cc: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Yakir Yang <kuankuan.y@gmail.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Jose Abreu <Jose.Abreu@synopsys.com> Cc: Romain Perier <romain.perier@collabora.com> Cc: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com> Cc: Xinliang Liu <z.liuxinliang@hisilicon.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Alex Deucher <alexander.deucher@amd.com> Cc: Rongrong Zou <zourongrong@gmail.com> Cc: Rob Clark <robdclark@gmail.com> Cc: Hai Li <hali@codeaurora.org> Cc: "Noralf Trønnes" <noralf@tronnes.org> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-samsung-soc@vger.kernel.org Cc: intel-gfx@lists.freedesktop.org Cc: linux-mediatek@lists.infradead.org Cc: linux-amlogic@lists.infradead.org Cc: nouveau@lists.freedesktop.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-rockchip@lists.infradead.org Cc: linux-tegra@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Cc: zain wang <wzz@rock-chips.com> Cc: Baoyou Xie <baoyou.xie@linaro.org> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170725080122.20548-8-daniel.vetter@ffwll.ch Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Archit Taneja <architt@codeaurora.org> Tested-by: Philippe Cornu <philippe.cornu@st.com> (on stm) Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Noralf Trønnes <noralf@tronnes.org> Acked-by: Vincent Abriou <vincent.abriou@st.com>
2017-07-28drm/bridge: tc358767: fix probe without attached output nodeLucas Stach
The output node of the TC358767 is only used if another bridge is chained behind it. Panels attached to the TC358767 can be detected using the usual DP AUX probing. This restores the old behavior of ignoring the output if no endpoint is found. Fixes: ebc944613567 (drm: convert drivers to use drm_of_find_panel_or_bridge) CC: stable@vger.kernel.org Acked-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Archit Taneja <architt@codeaurora.org> Link: https://patchwork.freedesktop.org/patch/msgid/20170710124125.9019-1-l.stach@pengutronix.de
2017-07-06drm/bridge: tc358767: clean up drm_bridge_add callInki Dae
This patch removes unnecessary checking of return value. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Archit Taneja <architt@codeaurora.org> Link: http://patchwork.freedesktop.org/patch/msgid/1499071350-25168-11-git-send-email-inki.dae@samsung.com
2017-04-06drm: convert drivers to use drm_of_find_panel_or_bridgeRob Herring
Similar to the previous commit, convert drivers open coding OF graph parsing to use drm_of_find_panel_or_bridge instead. This changes some error messages to debug messages (in the graph core). Graph connections are often "no connects" depending on the particular board, so we want to avoid spurious messages. Plus the kernel is not a DT validator. Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Archit Taneja <architt@codeaurora.org> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [seanpaul dropped rockchip changes since they're now obsolete] Signed-off-by: Sean Paul <seanpaul@chromium.org>
2016-12-01drm: Make the connector .detect() callback optionalLaurent Pinchart
Many drivers (21 to be exact) create connectors that are always connected (for instance to an LVDS or DSI panel). Instead of forcing them to implement a dummy .detect() handler, make the callback optional and consider the connector as always connected in that case. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Jyri Sarha <jsarha@ti.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Vincent Abriou <vincent.abriou@st.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> [seanpaul fixed small conflict in rcar-du/rcar_du_lvdscon.c] Signed-off-by: Sean Paul <seanpaul@chromium.org>
2016-12-01drm/bridge: tc358767: don't warn if display side ASSR enable failsLucas Stach
ASSR is an optional feature, so it's a valid operating condition for the display to reject ASSR enable. Demote the warning to the debug level. Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by:Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Archit Taneja <architt@codeaurora.org> Link: http://patchwork.freedesktop.org/patch/msgid/20161130114810.3245-1-l.stach@pengutronix.de
2016-10-10drm/bridge: Drop drm_connector_unregister and call drm_connector_cleanup ↵Marek Vasut
directly Drop unneeded drm_connector_unregister() and remove the unnecessary wrapper functions around drm_connector_cleanup(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/20161005143133.5549-1-marex@denx.de
2016-07-17drm/bridge: tc358767: Add DPI to eDP bridge driverAndrey Gusakov
Add a drm_bridge driver for the Toshiba TC358767 DPI/DSI to eDP/DP bridge. Currently only DPI input with 24-bit RGB is supported. Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Archit Taneja <architt@codeaurora.org>
