git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"Quite a lot of activity in SPI this cycle, almost all of it in drivers
with a few minor improvements and tweaks in the core.
- Updates to pxa2xx to support Intel Broxton and multiple chip selects.
- Support for big endian in the bcm63xx driver.
- Multiple slave support for the mt8173
- New driver for the auxiliary SPI controller in bcm2835 SoCs.
- Support for Layerscale SoCs in the Freescale DSPI driver"
* tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits)
spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI
spi: pxa2xx: Add support for Intel Broxton
spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals
spi: pxa2xx: Add output control for multiple Intel LPSS chip selects
spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific
spi: Add DSPI support for layerscape family
spi: ti-qspi: improve ->remove() callback
spi/spi-xilinx: Fix race condition on last word read
spi: Drop owner assignment from spi_drivers
spi: Add THIS_MODULE to spi_driver in SPI core
spi: Setup the master controller driver before setting the chipselect
spi: dw: replace magic constant by DW_SPI_DR
spi: mediatek: mt8173 spi multiple devices support
spi: mediatek: handle controller_data in mtk_spi_setup
spi: mediatek: remove mtk_spi_config
spi: mediatek: Update document devicetree bindings to support multiple devices
spi: fix kernel-doc warnings about missing return desc in spi.c
spi: fix kernel-doc warnings about missing return desc in spi.h
spi: pxa2xx: Align a few defines
spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select
Pull power management and ACPI updates from Rafael Wysocki:
"Quite a new features are included this time.
First off, the Collaborative Processor Performance Control interface
(version 2) defined by ACPI will now be supported on ARM64 along with
a cpufreq frontend for CPU performance scaling.
Second, ACPI gets a new infrastructure for the early probing of IRQ
chips and clock sources (along the lines of the existing similar
mechanism for DT).
Next, the ACPI core and the generic device properties API will now
support a recently introduced hierarchical properties extension of the
_DSD (Device Specific Data) ACPI device configuration object. If the
ACPI platform firmware uses that extension to organize device
properties in a hierarchical way, the kernel will automatically handle
it and make those properties available to device drivers via the
generic device properties API.
It also will be possible to build the ACPICA's AML interpreter
debugger into the kernel now and use that to diagnose AML-related
problems more efficiently. In the future, this should make it
possible to single-step AML execution and do similar things.
Interesting stuff, although somewhat experimental at this point.
Finally, the PM core gets a new mechanism that can be used by device
drivers to distinguish between suspend-to-RAM (based on platform
firmware support) and suspend-to-idle (or other variants of system
suspend the platform firmware is not involved in) and possibly
optimize their device suspend/resume handling accordingly.
In addition to that, some existing features are re-organized quite
substantially.
First, the ACPI-based handling of PCI host bridges on x86 and ia64 is
unified and the common code goes into the ACPI core (so as to reduce
code duplication and eliminate non-essential differences between the
two architectures in that area).
Second, the Operating Performance Points (OPP) framework is
reorganized to make the code easier to find and follow.
Next, the cpufreq core's sysfs interface is reorganized to get rid of
the "primary CPU" concept for configurations in which the same
performance scaling settings are shared between multiple CPUs.
Finally, some interfaces that aren't necessary any more are dropped
from the generic power domains framework.
On top of the above we have some minor extensions, cleanups and bug
fixes in multiple places, as usual.
Specifics:
- ACPICA update to upstream revision 20150930 (Bob Moore, Lv Zheng).
The most significant change is to allow the AML debugger to be
built into the kernel. On top of that there is an update related
to the NFIT table (the ACPI persistent memory interface) and a few
fixes and cleanups.
- ACPI CPPC2 (Collaborative Processor Performance Control v2) support
along with a cpufreq frontend (Ashwin Chaugule).
This can only be enabled on ARM64 at this point.
- New ACPI infrastructure for the early probing of IRQ chips and
clock sources (Marc Zyngier).
- Support for a new hierarchical properties extension of the ACPI
_DSD (Device Specific Data) device configuration object allowing
the kernel to handle hierarchical properties (provided by the
platform firmware this way) automatically and make them available
to device drivers via the generic device properties interface
(Rafael Wysocki).
- Generic device properties API extension to obtain an index of
certain string value in an array of strings, along the lines of
of_property_match_string(), but working for all of the supported
firmware node types, and support for the "dma-names" device
property based on it (Mika Westerberg).
- ACPI core fix to parse the MADT (Multiple APIC Description Table)
entries in the order expected by platform firmware (and mandated by
the specification) to avoid confusion on systems with more than 255
logical CPUs (Lukasz Anaczkowski).
- Consolidation of the ACPI-based handling of PCI host bridges on x86
and ia64 (Jiang Liu).
- ACPI core fixes to ensure that the correct IRQ number is used to
represent the SCI (System Control Interrupt) in the cases when it
has been re-mapped (Chen Yu).
- New ACPI backlight quirk for Lenovo IdeaPad S405 (Hans de Goede).
- ACPI EC driver fixes (Lv Zheng).
- Assorted ACPI fixes and cleanups (Dan Carpenter, Insu Yun, Jiri
Kosina, Rami Rosen, Rasmus Villemoes).
- New mechanism in the PM core allowing drivers to check if the
platform firmware is going to be involved in the upcoming system
suspend or if it has been involved in the suspend the system is
resuming from at the moment (Rafael Wysocki).
This should allow drivers to optimize their suspend/resume handling
in some cases and the changes include a couple of users of it (the
i8042 input driver, PCI PM).
- PCI PM fix to prevent runtime-suspended devices with PME enabled
from being resumed during system suspend even if they aren't
configured to wake up the system from sleep (Rafael Wysocki).
- New mechanism to report the number of a wakeup IRQ that woke up the
system from sleep last time (Alexandra Yates).
- Removal of unused interfaces from the generic power domains
framework and fixes related to latency measurements in that code
(Ulf Hansson, Daniel Lezcano).
- cpufreq core sysfs interface rework to make it handle CPUs that
share performance scaling settings (represented by a common cpufreq
policy object) more symmetrically (Viresh Kumar).
This should help to simplify the CPU offline/online handling among
other things.
- cpufreq core fixes and cleanups (Viresh Kumar).
- intel_pstate fixes related to the Turbo Activation Ratio (TAR)
mechanism on client platforms which causes the turbo P-states range
to vary depending on platform firmware settings (Srinivas
Pandruvada).
- intel_pstate sysfs interface fix (Prarit Bhargava).
- Assorted cpufreq driver (imx, tegra20, powernv, integrator) fixes
and cleanups (Bai Ping, Bartlomiej Zolnierkiewicz, Shilpasri G
Bhat, Luis de Bethencourt).
- cpuidle mvebu driver cleanups (Russell King).
- OPP (Operating Performance Points) framework code reorganization to
make it more maintainable (Viresh Kumar).
- Intel Broxton support for the RAPL (Running Average Power Limits)
power capping driver (Amy Wiles).
- Assorted power management code fixes and cleanups (Dan Carpenter,
Geert Uytterhoeven, Geliang Tang, Luis de Bethencourt, Rasmus
Villemoes)"
* tag 'pm+acpi-4.4-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (108 commits)
cpufreq: postfix policy directory with the first CPU in related_cpus
cpufreq: create cpu/cpufreq/policyX directories
cpufreq: remove cpufreq_sysfs_{create|remove}_file()
cpufreq: create cpu/cpufreq at boot time
cpufreq: Use cpumask_copy instead of cpumask_or to copy a mask
cpufreq: ondemand: Drop unnecessary locks from update_sampling_rate()
PM / Domains: Merge measurements for PM QoS device latencies
PM / Domains: Don't measure ->start|stop() latency in system PM callbacks
PM / clk: Fix broken build due to non-matching code and header #ifdefs
ACPI / Documentation: add copy_dsdt to ACPI format options
ACPI / sysfs: correctly check failing memory allocation
ACPI / video: Add a quirk to force native backlight on Lenovo IdeaPad S405
ACPI / CPPC: Fix potential memory leak
ACPI / CPPC: signedness bug in register_pcc_channel()
ACPI / PAD: power_saving_thread() is not freezable
ACPI / PM: Fix incorrect wakeup IRQ setting during suspend-to-idle
ACPI: Using correct irq when waiting for events
ACPI: Use correct IRQ when uninstalling ACPI interrupt handler
cpuidle: mvebu: disable the bind/unbind attributes and use builtin_platform_driver
cpuidle: mvebu: clean up multiple platform drivers
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
Pull irq updates from Thomas Gleixner:
"The irq departement delivers:
- Rework the irqdomain core infrastructure to accomodate ACPI based
systems. This is required to support ARM64 without creating
artificial device tree nodes.
- Sanitize the ACPI based ARM GIC initialization by making use of the
new firmware independent irqdomain core
- Further improvements to the generic MSI management
- Generalize the irq migration on CPU hotplug
- Improvements to the threaded interrupt infrastructure
- Allow the migration of "chained" low level interrupt handlers
- Allow optional force masking of interrupts in disable_irq[_nosysnc]
- Support for two new interrupt chips - Sigh!
- A larger set of errata fixes for ARM gicv3
- The usual pile of fixes, updates, improvements and cleanups all
over the place"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
Document that IRQ_NONE should be returned when IRQ not actually handled
PCI/MSI: Allow the MSI domain to be device-specific
PCI: Add per-device MSI domain hook
of/irq: Use the msi-map property to provide device-specific MSI domain
of/irq: Split of_msi_map_rid to reuse msi-map lookup
irqchip/gic-v3-its: Parse new version of msi-parent property
PCI/MSI: Use of_msi_get_domain instead of open-coded "msi-parent" parsing
of/irq: Use of_msi_get_domain instead of open-coded "msi-parent" parsing
of/irq: Add support code for multi-parent version of "msi-parent"
irqchip/gic-v3-its: Add handling of PCI requester id.
PCI/MSI: Add helper function pci_msi_domain_get_msi_rid().
of/irq: Add new function of_msi_map_rid()
Docs: dt: Add PCI MSI map bindings
irqchip/gic-v2m: Add support for multiple MSI frames
irqchip/gic-v3: Fix translation of LPIs after conversion to irq_fwspec
irqchip/mxs: Add Alphascale ASM9260 support
irqchip/mxs: Prepare driver for hardware with different offsets
irqchip/mxs: Panic if ioremap or domain creation fails
irqdomain: Documentation updates
irqdomain/msi: Use fwnode instead of of_node
- Relax dependencies on SPI_MASTER for drivers in the SPI menu
that already has this dependency.
- Move out the expander that would be hidden for I2C access if
SPI_MASTER was not selected. Tentatively create a separate
menu for this.
- Move the ZX SoC driver to memory-mapped drivers, this must be
a mistake and only worked because the system has an SPI master
enabled at the same time.
The I2C expander menu already depends on I2C, drop subdependecies
on individual drivers. Keep the instances of depends on I2C=y
though, so these are still restricted to the compiled-in case.
Port-mapped I/O depends on X86 already, so individual drivers need
not specify this dependency.
Suggested-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
In Microsoft Surface3 the GPIO detecting lid state is shared between GPIO
event and operation region. Below is simplied version of the DSDT from
Surface3 including relevant parts:
Scope (GPO0)
Name (_AEI, ResourceTemplate ()
GpioInt (Edge, ActiveBoth, Shared, PullNone, 0x0000,
"\\_SB.GPO0", 0x00, ResourceConsumer, ,
{ // Pin list
0x004C
OperationRegion (GPOR, GeneralPurposeIo, Zero, One)
Field (GPOR, ByteAcc, NoLock, Preserve)
Connection (
GpioIo (Shared, PullNone, 0x0000, 0x0000,
IoRestrictionNone, "\\_SB.GPO0", 0x00,
ResourceConsumer,,)
{ // Pin list
0x004C
HELD, 1
Method (_E4C, 0, Serialized) // _Exx: Edge-Triggered GPE
If ((HELD == One))
^^LID.LIDB = One
Else
^^LID.LIDB = Zero
Notify (LID, 0x80) // Status Change
Notify (^^PCI0.SPI1.NTRG, One) // Device Check
When GPIO 0x4c changes we call ASL method _E4C which tries to read HELD
field (the same GPIO). This triggers following error on the console:
ACPI Error: Method parse/execution failed [\_SB.GPO0._E4C]
(Node ffff88013f4b4438), AE_ERROR (20150930/psparse-542)
The error happens because ACPI GPIO operation region handler
(acpi_gpio_adr_space_handler()) tries to acquire the very same GPIO which
returns an error (-EBUSY) because the GPIO is already reserved for the GPIO
event.
Fix this so that we "borrow" the event GPIO if we find the GPIO belongs to
an event. Allow this only for GPIOs that are read.
To be able to go through acpi_gpio->events list for operation region access
we need to make sure the list is properly initialized whenever GPIO chip is
registered.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=106571
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Create a Kconfig submenu for drivers using X86 port-mapped I/O
and depend on X86 for this.
Suggested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: William Breathitt Gray <vilhelm.gray@gmail.com>
Cc: Andreas Bofjall <andreas@gazonk.org>
Cc: Diego Elio Pettenò <flameeyes@flameeyes.eu>
Cc: Daniel Krueger <daniel.krueger@systec-electronic.com>
Cc: Bruno Randolf <br1@einfach.org>
Cc: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Acked-by: Simon Guinot <simon.guinot@sequanux.org>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
The driver does not have any real architecture dependencies. To avoid
listing each architecture that might use this driver on some
FPGA-enabled platform, drop these dependencies.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Returning an error instead of NULL in bgpio_map if
platform_get_resource_byname does not find a resource was introduced with
commit cf3f2a2c8bae ("gpio: generic: improve error handling in bgpio_map").
This results in several qemu runtime failures with default and non-default
configurations, if attempts are made to boot from mmcblk0. Examples for
failures with multi_v7_defconfig are
Machine: vexpress-a9 dtb: vexpress-v2p-ca9
Machine: vexpress-a15 dtb: vexpress-v2p-ca15-tc1
Crash:
VFS: Cannot open root device "mmcblk0" or unknown-block(0,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Looking into the code, always returning an error if bgpio_map fails
does not appear to make much sense, since the code in bgpio_setup_io
specifically supports some of the resources to be NULL.
Fixes: cf3f2a2c8bae ("gpio: generic: improve error handling in bgpio_map")
Cc: Heiner Kallweit <hkallweit1@gmail.com>
The ACCES 104-IDIO-16 family of PC/104 utility boards feature 16
optically isolated inputs and 16 optically isolated FET solid state
outputs. This driver provides GPIO support for these 32 channels of
digital I/O. Change-of-State detection interrupts are not supported.
GPIO 0-15 correspond to digital outputs 0-15, while GPIO 16-31
correspond to digital inputs 0-15. The base port address for the device
may be set via the idio_16_base module parameter.
Signed-off-by: William Breathitt Gray <vilhelm.gray@gmail.com>
This patch adds a new GPIO driver for AMD Promontory chip.
This GPIO controller is enumerated by ACPI and the ACPI compliant
hardware ID is AMDF030.
Change history:
v2: 1. fix coding style
2. registers renaming
v3: 1. change include file
2. fix coding style
3. remove module_init/exit, add module_platform_driver
4. remove MODULE_ALIAS
v4: 1. change TOTAL_GPIO_PINS to PT_TOTAL_GPIO
2. remove PCI dependency in Kconfig
3. fix subject line
Signed-off-by: YD Tseng <Yd_Tseng@asmedia.com.tw>
* device-properties:
ACPI / property: Fix subnode lookup scope for data-only subnodes
acpi-dma: Add support for "dma-names" device property
device property: Add fwnode_property_match_string()
ACPI / property: Extend device_get_next_child_node() to data-only nodes
ACPI / gpio: Split acpi_get_gpiod_by_index()
ACPI / property: Extend fwnode_property_* to data-only subnodes
ACPI / property: Expose data-only subnodes via sysfs
ACPI / property: Add support for data-only subnodes
ACPI / property: Add routine for extraction of _DSD properties
commit "325f0a (MIPS: Netlogic: Use chip_data for irq_chip methods)"
Updates "mips/netlogic/common/irq.c" to use chip_data to store interrupt
controller data pointer. Before this commit handler_data was used to
store interrupt controller data which caused errors while using
gpiochip_set_chained_irqchip.
Update XLP GPIO driver to use the gpiolib irqchip helpers.
And add missing depends on OF_GPIO in Kconfig.
Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com>
MIPSfpga uses the axi gpio controller. Enable the driver for MIPS.
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
The flag matches the DT GPIO_SINGLE_ENDED flag and allows drivers to
parse and use the DT flag to handle single-ended (open-drain or
open-source) GPIOs.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
When requesting a GPIO through the legacy or the gpiod_* API the
gpiochip request operation is first called and then the GPIO flags are
parsed and the GPIO is configured. This prevents the gpiochip from
rejecting the request if the flags are not supported by the device.
To fix this split the parse-and-configure operation in two and parse
flags before requesting the GPIO.
Instead of storing in the chip data whether the chip uses pinctrl and
conditionally call pinctrl_{request,free}_gpio, just don't populate
request/free in that case.
This makes the implementations trivial and the same as the generic
implementations, thus we can just use them.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Replace all trivial request/free callbacks that do nothing but call into
pinctrl code with the generic versions.
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Acked-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Provide generic request/free implementations that pinctrl aware gpio
drivers can use instead of open coding if they use a 1:1 pin to gpio
signal mapping.
This patch fixes below static checker warning by changing
type of irq field in struct gpio_bank from u16 to int.
drivers/gpio/gpio-omap.c:1191 omap_gpio_probe()
warn: assigning (-6) to unsigned variable 'bank->irq'
1188 bank->irq = platform_get_irq(pdev, 0);
1189 if (bank->irq <= 0) {
bank->irq is u16.
1190 if (!bank->irq)
1191 bank->irq = -ENXIO;
Does not work.
1192 if (bank->irq != -EPROBE_DEFER)
Does not work.
1193 dev_err(dev,
1194 "can't get irq resource ret=%d\n", bank->irq);
1195 return bank->irq;
1196 }
Fixes: commit 89d18e3af8b9: "gpio: omap: switch to use platform_get_irq"
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
The PL061 can handle level IRQs and edge IRQs, however it is
just utilizing handle_simple_irq() for all IRQs. Inspired by
Stefan Agners patch to vf610, this assigns the right handler
depending on what type is set up, and after this
handle_bad_irq() is only used as default and if the type is
not specified, as is done in the OMAP driver: defining the
IRQ type is really not optional for this driver.
The interrupt handler was just writing the interrupt clearing
register for all lines that were high when entering the handling
loop, this is wrong: that register is only supposed to be
written (on a per-line basis) for edge IRQs, so this ACK
was moved to the .irq_ack() callback as is proper.
Tested with PL061 on the ARM RealView PB11MPCore and the
MMC/SC card detect GPIO.
Cc: Jonas Gorski <jogo@openwrt.org>
Cc: Stefan Agner <stefan@agner.ch>
We were returning with "chip->lock" held by mistake. It's safe to
move the return to before we take the spinlock.
Fixes: 1dbf7f299f90 ('gpio: pl061: detail IRQ trigger handling')
The struct irq_domain contains a "struct device_node *" field
(of_node) that is almost the only link between the irqdomain
and the device tree infrastructure.
In order to prepare for the removal of that field, convert all
users to use irq_domain_get_of_node() instead.
Reviewed-and-tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Tomasz Nowicki <tomasz.nowicki@linaro.org>
Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Cc: Graeme Gregory <graeme@xora.org.uk>
Cc: Jake Oshins <jakeo@microsoft.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: http://lkml.kernel.org/r/1444737105-31573-2-git-send-email-marc.zyngier@arm.com
This reverts commit ddd5404007b8496f20ad2efe1147e102e6226634.
We need to preserve only using this naming strategy for names
coming from chip->names[], the descripor->name field is for the
new interface.
This patch adds a support of the expandes found on Intel Galileo Gen2 board.
The platform information comes from ACPI.
Instead of using id->driver_data directly we copied it to the internal
structure. This will help to adapt driver for ACPI use.
Use the ERRPTR standard way to return an error code in a pointer
thus simplifiying the code.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Replace devm_request_mem_region / devm_ioremap with devm_ioremap_resource.
If bgpio_map returns NULL then err should always be set.
The TCA9539 is almost identical to the PCA9555 and software-compatible
with this driver. It exposes 16 general purpose I/O pins in two 8-bit
configurations.
Signed-off-by: Thierry Reding <treding@nvidia.com>
The function __max730x_remove is called from the remove functions of
drivers/gpio/gpio-max7300.c and drivers/gpio/gpio-max7301.c. In both
cases, the probe function allocates ts using devm_kzalloc. Explicitly
freeing such a value with kfree will cause a double free.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
This patch converts TI OMAP GPIO driver to use generic irq handler
instead of chained IRQ handler. This way OMAP GPIO driver will be
compatible with RT kernel where it will be forced thread IRQ handler
while in non-RT kernel it still will be executed in HW IRQ context.
As part of this change the IRQ wakeup configuration is applied to
GPIO Bank IRQ as it now will be under control of IRQ PM Core during
suspend.
There are also additional benefits:
- on-RT kernel there will be no complains any more about PM runtime usage
in atomic context "BUG: sleeping function called from invalid context";
- GPIO bank IRQs will appear in /proc/interrupts and its usage statistic
will be visible;
- GPIO bank IRQs could be configured through IRQ proc_fs interface and,
as result, could be a part of IRQ balancing process if needed;
- GPIO bank IRQs will be under control of IRQ PM Core during
suspend to RAM.
Disadvantage:
- additional runtime overhed as call chain till
omap_gpio_irq_handler() will be longer now
- necessity to use wa_lock in omap_gpio_irq_handler() to W/A warning
in handle_irq_event_percpu()
WARNING: CPU: 1 PID: 35 at kernel/irq/handle.c:149 handle_irq_event_percpu+0x51c/0x638()
This patch doesn't fully follows recommendations provided by Sebastian
Andrzej Siewior [1], because It's required to go through and check all
GPIO IRQ pin states as fast as possible and pass control to handle_level_irq
or handle_edge_irq. handle_level_irq or handle_edge_irq will perform actions
specific for IRQ triggering type and wakeup corresponding registered
threaded IRQ handler (at least it's expected to be threaded).
IRQs can be lost if handle_nested_irq() will be used, because excecution
time of some pin specific GPIO IRQ handler can be very significant and
require accessing ext. devices (I2C).
Idea of such kind reworking was also discussed in [2].
[1] http://www.spinics.net/lists/linux-omap/msg120665.html
[2] http://www.spinics.net/lists/linux-omap/msg119516.html
Tested-by: Tony Lindgren <tony@atomide.com>
Tested-by: Austin Schuh <austin@peloton-tech.com>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
The PM runtime API can't be used in atomic contex on -RT even if
it's configured as irqsafe. As result, below error report can
be seen when PM runtime API called from IRQ chip's callbacks
irq_startup/irq_shutdown/irq_set_type, because they are
protected by RAW spinlock:
BUG: sleeping function called from invalid context at kernel/locking/rtmutex.c:917
in_atomic(): 1, irqs_disabled(): 128, pid: 96, name: insmod
3 locks held by insmod/96:
#0: (&dev->mutex){......}, at: [<c04752c8>] __driver_attach+0x54/0xa0
#1: (&dev->mutex){......}, at: [<c04752d4>] __driver_attach+0x60/0xa0
#2: (class){......}, at: [<c00a408c>] __irq_get_desc_lock+0x60/0xa4
irq event stamp: 1834
hardirqs last enabled at (1833): [<c06ab2a4>] _raw_spin_unlock_irqrestore+0x88/0x90
hardirqs last disabled at (1834): [<c06ab068>] _raw_spin_lock_irqsave+0x2c/0x64
softirqs last enabled at (0): [<c003d220>] copy_process.part.52+0x410/0x19d8
softirqs last disabled at (0): [< (null)>] (null)
Preemption disabled at:[< (null)>] (null)
CPU: 1 PID: 96 Comm: insmod Tainted: G W O 4.1.3-rt3-00618-g57e2387-dirty #184
Hardware name: Generic DRA74X (Flattened Device Tree)
[<c00190f4>] (unwind_backtrace) from [<c0014734>] (show_stack+0x20/0x24)
[<c0014734>] (show_stack) from [<c06a62ec>] (dump_stack+0x88/0xdc)
[<c06a62ec>] (dump_stack) from [<c006ca44>] (___might_sleep+0x198/0x2a8)
[<c006ca44>] (___might_sleep) from [<c06ab6d4>] (rt_spin_lock+0x30/0x70)
[<c06ab6d4>] (rt_spin_lock) from [<c04815ac>] (__pm_runtime_resume+0x68/0xa4)
[<c04815ac>] (__pm_runtime_resume) from [<c04123f4>] (omap_gpio_irq_type+0x188/0x1d8)
[<c04123f4>] (omap_gpio_irq_type) from [<c00a64e4>] (__irq_set_trigger+0x68/0x130)
[<c00a64e4>] (__irq_set_trigger) from [<c00a7bc4>] (irq_set_irq_type+0x44/0x6c)
[<c00a7bc4>] (irq_set_irq_type) from [<c00abbf8>] (irq_create_of_mapping+0x120/0x174)
[<c00abbf8>] (irq_create_of_mapping) from [<c0577b74>] (of_irq_get+0x48/0x58)
[<c0577b74>] (of_irq_get) from [<c0540a14>] (i2c_device_probe+0x54/0x15c)
[<c0540a14>] (i2c_device_probe) from [<c04750dc>] (driver_probe_device+0x184/0x2c8)
[<c04750dc>] (driver_probe_device) from [<c0475310>] (__driver_attach+0x9c/0xa0)
[<c0475310>] (__driver_attach) from [<c0473238>] (bus_for_each_dev+0x7c/0xb0)
[<c0473238>] (bus_for_each_dev) from [<c0474af4>] (driver_attach+0x28/0x30)
[<c0474af4>] (driver_attach) from [<c0474760>] (bus_add_driver+0x154/0x200)
[<c0474760>] (bus_add_driver) from [<c0476348>] (driver_register+0x88/0x108)
[<c0476348>] (driver_register) from [<c0541600>] (i2c_register_driver+0x3c/0x90)
[<c0541600>] (i2c_register_driver) from [<bf003018>] (pcf857x_init+0x18/0x24 [gpio_pcf857x])
[<bf003018>] (pcf857x_init [gpio_pcf857x]) from [<c000998c>] (do_one_initcall+0x128/0x1e8)
[<c000998c>] (do_one_initcall) from [<c06a4220>] (do_init_module+0x6c/0x1bc)
[<c06a4220>] (do_init_module) from [<c00dd0c8>] (load_module+0x18e8/0x21c4)
[<c00dd0c8>] (load_module) from [<c00ddaa0>] (SyS_init_module+0xfc/0x158)
[<c00ddaa0>] (SyS_init_module) from [<c000ff40>] (ret_fast_syscall+0x0/0x54)
The IRQ chip interface defines only two callbacks which are executed in
non-atomic contex - irq_bus_lock/irq_bus_sync_unlock, so lets move
PM runtime calls there.
This patch adds support for the GPIOs found on the ITE super-I/O chips
IT87xx.
Signed-off-by: Diego Elio Pettenò <flameeyes@flameeyes.eu>
Signed-off-by: Christophe Vu-Brugier <cvubrugier@fastmail.fm>
The parameter offset is an unsigned, so it makes no sense to compare
it for >= 0. Fix the compiler warning regarding this by removing this
comparison.
As the macro GPIO_OFFSET_VALID is only used at this single place, simplify
the code by dropping the macro completely and dropping the invert, too.
No functional change.
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
This fixes error checking in the function device_pca957x_init
to properly check and return error code values from the calls
to the function pca953x_write_regs if they fail as to properly
signal callers when a error occurs due a failure when writing
registers for this gpio based device.
Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
Turn the ath79 driver into a true driver supporting multiple
instances. While at it also removed unneed includes and make use of
the BIT() macro.
Signed-off-by: Alban Bedel <albeu@free.fr>
Remove this driver now that Bjorn has introduced a pinctrl driver
for msm8660 and the dts files have been updated with the pinctrl
compatibles.
Cc: Andy Gross <agross@codeaurora.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
The state container of the Zynq GPIO driver is sometimes
extracted from the gpio_chip exploiting the fact that offsetof()
the struct gpio_chip inside the struct zynq_gpio is 0, so
the container_of() is in practice a noop. However if a member
is added to struct zynq_gpio in front of struct gpio_chip,
things will break. Using proper container_of() avoids this
problem.
Semantically this is a noop, the compiler will optimize it away,
but syntactically it makes me happier.
Also replace some explicit container_of() calls with the helper
function.
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Ezra Savard <ezra.savard@xilinx.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Harini Katakam <harinik@xilinx.com>
The state container of the vf610 GPIO driver is sometimes
the struct gpio_chip inside the struct vf610_gpio_port is 0, so
is added to struct vf610_gpio_port in front of struct gpio_chip,
problem.
function.
The state container of the sx150x GPIO driver is sometimes
the struct gpio_chip inside the struct sx150x_chip is 0, so
is added to struct sx150_chip in front of struct gpio_chip, things
will break. Using proper container_of() avoids this problem.
Cc: Wei Chen <Wei.Chen@csr.com>
The state container of the Altera GPIO driver is extracted from
the gpio_chip exploiting the fact that offsetof() the
struct gpio_chip inside the struct of_mm_gpio_chip are both 0, so
is added to struct altera_gpio_chip in front of
struct of_mm_gpio_chip, things will break. Using proper
Cc: Tien Hock Loh <thloh@altera.com>
The state container of the etraxfs GPIO driver is extracted from
struct gpio_chip inside the struct bgpio_chip are both 0, so
is added to struct etraxfs_gpio_chip in front of
struct bgpio_chip, things will break. Using proper container_of()
Acked-by: Rabin Vincent <rabin@rab.in>
I couldn't follow this code flow. Make it dirt simple to figure
out what is going on and get proper debug prints. Warn if we
set up an IRQ without any trigger. Should make no semantic
difference.
This refactors the changes to the GPIO line naming mechanism to
not have so widespread effects, instead we conclude the patch series
by having created a name attribute in the GPIO descriptor, that need
not be globally unique, and it will be initialized from the old
.names array in struct gpio_chip if it exists, then used in the legacy
sysfs code like the array was used previously.
The associated changes to name lines from the device tree are
controversial and need to stand alone from this. Resulting changes:
1. Remove the export and the header for the gpio_name_to_desc() as so
far the only use is inside gpiolib.c. Staticize gpio_name_to_desc()
and move it above the only function using it.
2. Only print a warning if there are two GPIO lines with the same name.
The reason is to preserve current behaviour: before the previous
changes to the naming mechanism this would not reject probing the
driver, instead the error would occur when trying to export the line
in sysfs, so restore this behaviour, but print a friendly warning
if names collide.
Cc: Johan Hovold <johan@kernel.org>
Cc: Markus Pargmann <mpa@pengutronix.de>
