path: root/drivers/gpio/rdc321x-gpio.c
2011-03-23rdc321x-southbridge: Use mfd_data instead of driver_dataAndres Salomon
Use mfd_data for passing information from mfd drivers to soc clients. The mfd_cell's driver_data field is being phased out. Clients that were using driver_data now access .mfd_data via mfd_get_data(). Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-12-22gpio: Fix null pointer dereference while accessing rdc321x platform_dataFlorian Fainelli
rdc321x-gpio currently fetches its driver specific data by using the platform_device->platform_data pointer, this is wrong because the mfd device which registers our platform_device has been added using mfd_add_device() which sets the platform_device->driver_data pointer instead. Signed-off-by: Florian Fainelli <florian@openwrt.org> CC: stable@kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: Fix inverted rdc321x gpio data out registersFlorian Fainelli
rdc_gpio_set_value_impl has the gpio data registers 1 and 2 inverted, fix this. Signed-off-by: Bernhard Loos <bernhardloos@gmail.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Change rdc321x resources flags to IORESOURCE_IOFlorian Fainelli
The rdc321x southbridge PCI device has no MEM PCI resources that we could pass to mfd_add_devices. Since 33254dd5, mfd_add_device checks for the mem_base argument that we set to NULL. Changing the resources passed to our MFD cells from IORESOURCE_MEM to IORESOURCE_IO fixes that. Since we use those resources as offsets to the PCI configuration space base address of the southbridge device this is also more adequate. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: Update gfp/slab.h includes for rdc321xTejun Heo
Implicit slab.h inclusion via percpu.h is about to go away. Make sure gfp.h or slab.h is included as necessary. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-05-28gpio: Add support for RDC321x GPIO controllerFlorian Fainelli
This patch adds a new GPIO driver for the RDC321x SoC GPIO controller. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
