path: root/drivers/gpio/gpiolib.h
2014-05-21gpio: make of_get_named_gpiod_flags() privateAlexandre Courbot
of_get_named_gpiod_flags() is visible and directly usable by GPIO consumers, but it really should not as the gpiod interface relies on the simpler gpiod_get() to provide properly-configured GPIOs. of_get_named_gpiod_flags() is just used internally by gpiolib to implement gpiod_get(), and by the old of_get_named_gpio_flags() function, therefore it makes sense to make it gpiolib-private. As a side-effect, the unused (and unneeded) of_get_gpiod_flags() inline function is also removed, and of_get_named_gpio_flags() is moved from a static inline function to a regular one in gpiolib-of.c This results in all references to gpiod_* functions in of_gpio.h being gone, which is the way it should be since this file is part of the old integer GPIO interface. Changes since v1: - Fixed compilation error when CONFIG_OF_GPIO is not defined - Fixed warning due to of_gpio_flags enum not being declared in private gpiolib.h header Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-13gpiolib: Allow GPIO chips to request their own GPIOsMika Westerberg
Sometimes it is useful to allow GPIO chips themselves to request GPIOs they own through gpiolib API. One use case is ACPI ASL code that should be able to toggle GPIOs through GPIO operation regions. We can't use gpio_request() because it will pin the module to the kernel forever (it calls try_module_get()). To solve this we move module refcount manipulation to gpiod_request() and let __gpiod_request() handle the actual request. This changes the sequence a bit as now try_module_get() is called outside of gpio_lock (I think this is safe, try_module_get() handles serialization it needs already). Then we provide gpiolib internal functions gpiochip_request/free_own_desc() that do the same as gpio_request() but don't manipulate module refrence count. This allows the GPIO chip driver to request and free descriptors it owns without being pinned to the kernel forever. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08gpio / ACPI: get rid of acpi_gpio.hMika Westerberg
Now that all users of acpi_gpio.h have been moved to use either the GPIO descriptor interface or to the internal gpiolib.h we can get rid of acpi_gpio.h entirely. Once this is done the only interface to get GPIOs to drivers enumerated from ACPI namespace is the descriptor based interface. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08gpio / ACPI: register to ACPI events automaticallyMika Westerberg
Instead of asking each driver to register to ACPI events we can just call acpi_gpiochip_register_interrupts() for each chip that has an ACPI handle. The function checks chip->to_irq and if it is set to NULL (a GPIO driver that doesn't do interrupts) the function does nothing. We also add the a new header drivers/gpio/gpiolib.h that is used for functions internal to gpiolib and add ACPI GPIO chip registering functions to that header. Once that is done we can remove call to acpi_gpiochip_register_interrupts() from its only user, pinctrl-baytrail.c Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
