Commit dd34c37aa3e (gpio: of: Allow -gpio suffix for property names)
added parsing for both -gpio and -gpios suffix but also changed
the handling for deferred probe unintentionally. Because of the
looping the second name will now return -ENOENT instead of
-EPROBE_DEFER. Fix the issue by breaking out of the loop if
-EPROBE_DEFER is encountered.
Reviewed-by: Thierry Reding <treding@nvidia.com>
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers
that make it easier for drivers to handle optional GPIOs.
Currently in order to handle optional GPIOs, a driver needs to special
case error handling for -ENOENT, such as this:
gpio = gpiod_get(dev, "foo");
if (IS_ERR(gpio)) {
if (PTR_ERR(gpio) != -ENOENT)
return PTR_ERR(gpio);
gpio = NULL;
if (gpio) {
/* set up GPIO */
With these new helpers the above is reduced to:
gpio = gpiod_get_optional(dev, "foo");
if (IS_ERR(gpio))
if (gpio) {
/* set up GPIO */
While at it, device-managed variants of these functions are also
provided.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
The function is called gpiod_get(), not gpio_get(). Fix the kernel-doc
comment to match the name.
Many bindings use the -gpio suffix in property names. Support this in
addition to the -gpios suffix when requesting GPIOs using the new
descriptor-based API.
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
of_find_gpio() is always called under an IS_ENABLED(CONFIG_OF), so the
dummy implementation provided for !OF configurations is not needed.
Some GPIO irqchip drivers exploit the irqdomain mapping
function to set up the IRQ default type in the hardware,
make sure that if we pass IRQ_TYPE_NONE, no hardware setup
whatsoever takes place (this should be the norm) until
later when the IRQ gets utilized.
Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: linux-omap <linux-omap@vger.kernel.org>
Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
Tested-by: Nishanth Menon <nm@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Another feature that is duplicated in a number of GPIO irqchips
is that these cascades IRQs are assigned their own lock class
so as to avoid warnings about lockdep recursions. Do this also
in the generic GPIO irqchip helpers for smooth transition to
this core infrastructure.
Some off-chip GPIO expanders need to be communicated by I2C or
SPI traffic, but may still support IRQs. By the sleeping nature
of such buses, such IRQ handlers need to be threaded. Support
such handlers in the gpiochip irqchip helpers by flagging IRQs
as threaded if the .can_sleep property of the gpiochip is
true.
Helpfully deny registration of chained IRQ handlers if the
.can_sleep property is set, as such chips will invariably need
a nested handler rather than a chained handler.
During irq mapping, in irq_set_chip_and_handler() the process
of setting this up may incur calls to lock the irqchip, which
in turn may need to dereference and use the chip data. So set
the data first, then set the chip and handler.
When using the irqchip helper inside the gpiolib, make sure
the IRQs are unmapped/disposed before the irqdomain is removed
as part of removing the gpiochip.
This provides a function gpiochip_irqchip_add() to set
up an irqchip for a GPIO controller, and a function
gpiochip_set_chained_irqchip() to chain it to a parent
irqchip.
Most GPIOs are of the type where a number of lines form
a cascaded interrupt controller chained onto
the primary system interrupt controller (or further down the
chain) so let's add this helper and factor the code to
request the lines to be used as IRQs, the .to_irq() function
and the irqdomain into the core as well.
Nothing prevents GPIO drivers from returning values outside the
boolean range, and as it turns out a few drivers are actually doing so.
These values were passed as-is to unsuspecting consumers and created
confusion.
This patch makes the internal _gpiod_get_raw_value() function return a
bool, effectively clamping the GPIO value to the boolean range no
matter what the driver does.
While we are at it, we also change the value parameter of
_gpiod_set_raw_value() to bool type before drivers start doing funny
things with it as well.
Another way to fix this would be to change the prototypes of the driver
interface to use bool directly, but this would require a huge
cross-systems patch so this simpler solution is preferred.
Changes since v1:
- Change local variable type to bool as well, use boolean values in
code
- Also change prototype of open drain/open source setting functions
since they are only called from _gpiod_set_raw_value()
This probably calls for a larger booleanization of gpiolib, but let's
keep that for a latter change - right now we need to address the issue
of non-boolean values returned by drivers.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
The current ACPI GPIO event handling code was never tested against real
hardware with functioning GPIO triggered events (at the time such hardware
wasn't available). Thus it misses certain things like requesting the GPIOs
properly, passing correct flags to the interrupt handler and so on.
This patch reworks ACPI GPIO event handling so that we:
1) Use struct acpi_gpio_event for all GPIO signaled events.
2) Switch to use GPIO descriptor API and request GPIOs by calling
gpiochip_request_own_desc() that we added in a previous patch.
3) Pass proper flags from ACPI GPIO resource to request_threaded_irq().
Also instead of open-coding the _AEI iteration loop we can use
acpi_walk_resources(). This simplifies the code a bit and fixes memory leak
that was caused by missing kfree() for buffer returned by
acpi_get_event_resources().
Since the remove path now calls gpiochip_free_own_desc() which takes GPIO
spinlock we need to call acpi_gpiochip_remove() outside of that lock
(analogous to acpi_gpiochip_add() path where the lock is released before
those funtions are called).
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Sometimes it is useful to allow GPIO chips themselves to request GPIOs they
own through gpiolib API. One use case is ACPI ASL code that should be able
to toggle GPIOs through GPIO operation regions.
We can't use gpio_request() because it will pin the module to the kernel
forever (it calls try_module_get()). To solve this we move module refcount
manipulation to gpiod_request() and let __gpiod_request() handle the actual
request. This changes the sequence a bit as now try_module_get() is called
outside of gpio_lock (I think this is safe, try_module_get() handles
serialization it needs already).
Then we provide gpiolib internal functions gpiochip_request/free_own_desc()
that do the same as gpio_request() but don't manipulate module refrence
count. This allows the GPIO chip driver to request and free descriptors it
owns without being pinned to the kernel forever.
It is currently debated where the functions to lock a certain
GPIO line as used for IRQs should be called. Delete all
misleading documentation.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
Some drivers dealing with a gpio_chip might need to act on its
descriptors directly; one example is pinctrl drivers that need to lock a
GPIO for being used as IRQ using gpiod_lock_as_irq().
This patch exports a gpiochip_get_desc() function that returns the
GPIO descriptor at the requested index. It also sweeps the
gpio_to_chip() function out of the consumer interface since any holder
of a gpio_chip reference can manipulate its GPIOs way beyond what a
consumer should be allowed to do.
As a result, gpio_chip is not visible anymore to simple GPIO consumers.
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com>
The documentation was not clear about whether
gpio_direction_output should take a logical value or the physical
level on the output line, i.e. whether the ACTIVE_LOW status
would be taken into account.
This converts gpiod_direction_output to use the logical level
and adds a new gpiod_direction_output_raw for the raw value.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO tree bulk changes from Linus Walleij:
"A big set this merge window, as we have much going on in this
subsystem. The changes to other subsystems (notably a slew of ARM
machines as I am doing away with their custom APIs) have all been
ACKed to the extent possible.
Major changes this time:
- Some core improvements and cleanups to the new GPIO descriptor API.
This seems to be working now so we can start the exodus to this
API, moving gradually away from the global GPIO numberspace.
- Incremental improvements to the ACPI GPIO core, and move the few
GPIO ACPI clients we have to the GPIO descriptor API right *now*
before we go any further. We actually managed to contain this
*before* we started to litter the kernel with yet another hackish
global numberspace for the ACPI GPIOs, which is a big win.
- The RFkill GPIO driver and all platforms using it have been
migrated to use the GPIO descriptors rather than fixed number
assignments. Tegra machine has been migrated as part of this.
- New drivers for MOXA ART, Xtensa GPIO32 and SMSC SCH311x. Those
should be really good examples of how I expect a nice GPIO driver
to look these days.
- Do away with custom GPIO implementations on a major part of the ARM
machines: ks8695, lpc32xx, mv78xx0. Make a first step towards the
same in the horribly convoluted Samsung S3C include forest. We
expect to continue to clean this up as we move forward.
- Flag GPIO lines used for IRQ on adnp, bcm-kona, em, intel-mid and
lynxpoint.
This makes the GPIOlib core aware that a certain GPIO line is used
for IRQs and can then enforce some semantics such as disallowing a
GPIO line marked as in use for IRQ to be switched to output mode.
- Drop all use of irq_set_chip_and_handler_name(). The name provided
in these cases were just unhelpful tags like "mux" or "demux".
- Extend the MCP23s08 driver to handle interrupts.
- Minor incremental improvements for rcar, lynxpoint, em 74x164 and
msm drivers.
- Some non-urgent bug fixes here and there, duplicate #includes and
that usual kind of cleanups"
Fix up broken Kconfig file manually to make this all compile.
* tag 'gpio-v3.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits)
gpio: mcp23s08: fix casting caused build warning
gpio: mcp23s08: depend on OF_GPIO
gpio: mcp23s08: Add irq functionality for i2c chips
ARM: S5P[v210|c100|64x0]: Fix build error
gpio: pxa: clamp gpio get value to [0,1]
ARM: s3c24xx: explicit dependency on <plat/gpio-cfg.h>
ARM: S3C[24|64]xx: move includes back under <mach/> scope
Documentation / ACPI: update to GPIO descriptor API
gpio / ACPI: get rid of acpi_gpio.h
gpio / ACPI: register to ACPI events automatically
mmc: sdhci-acpi: convert to use GPIO descriptor API
ARM: s3c24xx: fix build error
gpio: f7188x: set can_sleep attribute
gpio: samsung: Update documentation
gpio: samsung: Remove hardware.h inclusion
gpio: xtensa: depend on HAVE_XTENSA_GPIO32
gpio: clps711x: Enable driver compilation with COMPILE_TEST
gpio: clps711x: Use of_match_ptr()
net: rfkill: gpio: convert to descriptor-based GPIO interface
leds: s3c24xx: Fix build failure
Now that all users of acpi_gpio.h have been moved to use either the GPIO
descriptor interface or to the internal gpiolib.h we can get rid of
acpi_gpio.h entirely.
Once this is done the only interface to get GPIOs to drivers enumerated
from ACPI namespace is the descriptor based interface.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Instead of asking each driver to register to ACPI events we can just call
acpi_gpiochip_register_interrupts() for each chip that has an ACPI handle.
The function checks chip->to_irq and if it is set to NULL (a GPIO driver
that doesn't do interrupts) the function does nothing.
We also add the a new header drivers/gpio/gpiolib.h that is used for
functions internal to gpiolib and add ACPI GPIO chip registering functions
to that header.
Once that is done we can remove call to acpi_gpiochip_register_interrupts()
from its only user, pinctrl-baytrail.c
Some devices drivers make use of optional GPIO parameters. For such
drivers, it is important to discriminate between the case where no
GPIO mapping has been defined for the function they are requesting, and
the case where a mapping exists but an error occured while resolving it
or when acquiring the GPIO.
This patch changes the family of gpiod_get() functions such that they
will return -ENOENT if and only if no GPIO mapping is defined for the
requested function. Other error codes are used when an actual error
occured during the GPIO resolution.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
kernfs has just been separated out from sysfs and we're already in
full conflict mode. Nothing can make the situation any worse. Let's
take the chance to name things properly.
This patch performs the following renames.
* s/sysfs_elem_dir/kernfs_elem_dir/
* s/sysfs_elem_symlink/kernfs_elem_symlink/
* s/sysfs_elem_attr/kernfs_elem_file/
* s/sysfs_dirent/kernfs_node/
* s/sd/kn/ in kernfs proper
* s/parent_sd/parent/
* s/target_sd/target/
* s/dir_sd/parent/
* s/to_sysfs_dirent()/rb_to_kn()/
* misc renames of local vars when they conflict with the above
Because md, mic and gpio dig into sysfs details, this patch ends up
modifying them. All are sysfs_dirent renames and trivial. While we
can avoid these by introducing a dummy wrapping struct sysfs_dirent
around kernfs_node, given the limited usage outside kernfs and sysfs
proper, I don't think such workaround is called for.
This patch is strictly rename only and doesn't introduce any
functional difference.
- mic / gpio renames were missing. Spotted by kbuild test robot.
Cc: Neil Brown <neilb@suse.de>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Ashutosh Dixit <ashutosh.dixit@intel.com>
Cc: kbuild test robot <fengguang.wu@intel.com>
The patch just accents that @dev could be NULL.
There is no functional change.
In several places we are printing messages with prefix based on chip->label.
Introduced macros help us to do this easier and in uniform way.
This patch includes the following amendments:
1) use "?" as a label when the last one is not defined in gpiod_*;
2) whenever it's possible gpiod_* are used;
3) print a function name, if it's already used in other messages.
Additionally it fixes an indentation in few places.
Change the format of the platform GPIO lookup tables to make them less
confusing and improve lookup efficiency.
The previous format was a single linked-list that required to compare
the device name and function ID of every single GPIO defined for each
lookup. Switch that to a list of per-device tables, so that the lookup
can be done in two steps, omitting the GPIOs that are not relevant for a
particular device.
The matching rules are now defined as follows:
- The device name must match *exactly*, and can be NULL for GPIOs not
assigned to a particular device,
- If the function ID in the lookup table is NULL, the con_id argument of
gpiod_get() will not be used for lookup. However, if it is defined, it
must match exactly.
- The index must always match.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Linux 3.13-rc3
This switches the two members of struct gpio_chip that were
defined as unsigned foo:1 to bool, because that is indeed what
they are. Switch all users in the gpio and pinctrl subsystems
to assign these values with true/false instead of 0/1. The
users outside these subsystems will survive since true/false
is 1/0, atleast we set some kind of more strict typing example.
gpiochip_offset_to_desc() was using gpio_to_desc(), which directly
addresses the global GPIO array we are hoping to get rid of someday.
Reimplement it using the descriptor array of the chip itself, after
checking the requested offset is within the valid bounds of the chip.
It's the drivers responsibility to react on failure to get
the gpio descriptors and not the frameworks. Since there are
some common peripherals that may or may not have certain
pins connected to gpio lines, depending on the platform,
printing the warning there may end up generating useless bug
reports.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
For platforms that use device tree or ACPI as the standard way to look
GPIOs up, allow the platform-defined GPIO mappings to be used as a
fallback. This may be useful for platforms that need extra GPIOs mappings
not defined by the firmware.
A typo resulted in GPIO lookup failing unconditionally.
Reported-by: Stephen Warren <swarren@wwwdotorg.org>
The prototype for static GPIO lookup functions has been updated to use
an explicit type for GPIO lookup flags. Unfortunately the definition of
of_find_gpio() when CONFIG_OF is not defined has been omitted, which
triggers a warning. This patch fixes this.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
GPIO mapping properties were defined using the GPIOF_* flags, which are
declared in linux/gpio.h. This file is not included when using the
GPIO descriptor interface.
This patch declares the flags that can be used as GPIO mappings
properties in linux/gpio/driver.h, and uses them in gpiolib, so that no
deprecated declarations are used by the GPIO descriptor interface.
This patch also allows GPIO_OPEN_DRAIN and GPIO_OPEN_SOURCE to be
specified as GPIO mapping properties.
find_chip_by_name() was incorrectly implemented by using
gpio_lookup_list instead of gpiod_chips to iterate through all the
registered GPIO controllers. This patch reimplements it by using
gpiochip_find() with a custom search function, which simplifies the code
on top of fixing the mistake.
Modify struct acpi_dev_node to contain a pointer to struct acpi_device
associated with the given device object (that is, its ACPI companion
device) instead of an ACPI handle corresponding to it. Introduce two
new macros for manipulating that pointer in a CONFIG_ACPI-safe way,
ACPI_COMPANION() and ACPI_COMPANION_SET(), and rework the
ACPI_HANDLE() macro to take the above changes into account.
Drop the ACPI_HANDLE_SET() macro entirely and rework its users to
use ACPI_COMPANION_SET() instead. For some of them who used to
pass the result of acpi_get_child() directly to ACPI_HANDLE_SET()
introduce a helper routine acpi_preset_companion() doing an
equivalent thing.
The main motivation for doing this is that there are things
represented by struct acpi_device objects that don't have valid
ACPI handles (so called fixed ACPI hardware features, such as
power and sleep buttons) and we would like to create platform
device objects for them and "glue" them to their ACPI companions
in the usual way (which currently is impossible due to the
lack of valid ACPI handles). However, there are more reasons
why it may be useful.
First, struct acpi_device pointers allow of much better type checking
than void pointers which are ACPI handles, so it should be more
difficult to write buggy code using modified struct acpi_dev_node
and the new macros. Second, the change should help to reduce (over
time) the number of places in which the result of ACPI_HANDLE() is
passed to acpi_bus_get_device() in order to obtain a pointer to the
struct acpi_device associated with the given "physical" device,
because now that pointer is returned by ACPI_COMPANION() directly.
Finally, the change should make it easier to write generic code that
will build both for CONFIG_ACPI set and unset without adding explicit
compiler directives to it.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> # on Haswell
Reviewed-by: Aaron Lu <aaron.lu@intel.com> # for ATA and SDIO part
Pull GPIO changes from Linus Walleij:
"Here is the bulk of GPIO changes for the v3.13 development cycle.
I've got ACKs for the things that affect other subsystems (or it's my
own subsystem, like pinctrl). Most of that pertain to an attempt from
my side to consolidate and get rid of custom GPIO implementations in
the ARM tree. I will continue doing this.
The main change this time is the new GPIO descriptor API, background
for this can be found in Corbet's summary from this january in LWN:
http://lwn.net/Articles/533632/
Summary:
- Merged the GPIO descriptor API from Alexandre Courbot. This is a
first step toward trying to get rid of the global GPIO numberspace
for the future.
- Add an API so that driver can flag that a certain GPIO line is
being used by a irqchip backend for generating IRQs, so that we can
enforce checks, like not allowing users to switch that line to an
output at runtime, since this makes no sense. Implemented
corresponding calls in a few select drivers.
- ACPI GPIO cleanups, refactorings and switch to using the
descriptor-based interface.
- Support for the TPS80036 Palmas GPIO variant.
- A new driver for the Broadcom Kona GPIO SoC IP block.
- Device tree support for the PCF857x driver.
- A set of ARM GPIO refactorings with the goal of getting rid of a
bunch of custom GPIO implementations from the arch/arm/* tree:
* Move the IOP GPIO driver to the GPIO subsystem and fix all users
to use the gpiolib API for accessing GPIOs. Delete the old
custom GPIO implementation.
* Delete the unused custom PXA GPIO implemention.
* Convert all users of the IXP4 custom GPIO implementation to use
gpiolib and delete the custom implementation.
* Delete the custom Gemini GPIO implementation, also completely
unused.
- Various cleanups and renamings"
* tag 'gpio-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits)
gpio: gpio-mxs: Remove unneeded dt checks
gpio: pl061: don't depend on CONFIG_ARM
gpio: bcm-kona: add missing .owner to struct gpio_chip
gpiolib: provide a declaration of seq_file in gpio/driver.h
gpiolib: include gpio/consumer.h in of_gpio.h for desc_to_gpio()
gpio: provide stubs for devres gpio functions
gpiolib: devres: add missing headers
gpiolib: make GPIO_DEVRES depend on GPIOLIB
gpiolib: devres: fix devm_gpiod_get_index()
gpiolib / ACPI: document the GPIO descriptor based interface
gpiolib / ACPI: allow passing GPIOF_ACTIVE_LOW for GpioInt resources
gpiolib / ACPI: add ACPI support for gpiod_get_index()
gpiolib / ACPI: convert to gpiod interfaces
gpiolib: add gpiod_get() and gpiod_put() functions
gpiolib: port of_ functions to use gpiod
gpiolib: export descriptor-based GPIO interface
Fixup "MAINTAINERS: GPIO-INTEL-MID: add maintainer"
gpio: bcm281xx: Don't print addresses of GPIO area in probe()
gpio: tegra: use new gpio_lock_as_irq() API
gpio: rcar: Include linux/of.h header
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"Main pin control pull request for the v3.13 cycle.
The changes hitting arch/blackfin are ACKed by the Blackfin
maintainer, and the device tree bindings are ACKed to the extent
possible by someone from the device tree maintainers group.
- Blackfin ADI pin control driver, we move yet another architecture
under this subsystem umbrella.
- Incremental updates to the Renesas Super-H PFC pin control driver.
New subdriver for the r8a7791 SoC.
- Non-linear GPIO ranges from the gpiolib side of things, this
enabled simplified device tree bindings by referring entire groups
of pins on some pin controller to act as back-end for a certain
GPIO-chip driver.
- Add the Abilis TB10x pin control driver used on the ARC
architecture. Also the corresponding GPIO driver is merged through
this tree, so the ARC has full support for pins and GPIOs after
this.
- Subdrivers for Freescale i.MX1, i.MX27 and i.MX50 pin controller
instances. The i.MX1 and i.MX27 is an entirely new family
(silicon) of controllers whereas i.MX50 is a variant of the
previous supported controller.
- Then the usual slew of fixes, cleanups and incremental updates"
The ARC DT changes are apparently still pending, that hopefully gets
sorted out in a timely manner.
* tag 'pinctrl-for-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits)
pinctrl: imx50: add pinctrl support code for the IMX50 SoC
pinctrl: at91: copy define to driver
pinctrl: remove minor dead code
pinctrl: imx: fix using pin->input_val wrongly
pinctrl: imx1: fix return value check in imx1_pinctrl_core_probe()
gpio: tb10x: fix return value check in tb10x_gpio_probe()
gpio: tb10x: use module_platform_driver to simplify the code
pinctrl: imx27: imx27 pincontrol driver
pinctrl: imx1 core driver
pinctrl: sh-pfc: r8a7791 PFC support
sh-pfc: r8a7778: Add CAN pin groups
gpio: add TB10x GPIO driver
pinctrl: at91: correct a few typos
pinctrl: mvebu: remove redundant of_match_ptr
pinctrl: tb10x: use module_platform_driver to simplify the code
pinctrl: tb10x: fix the error handling in tb10x_pinctrl_probe()
pinctrl: add documentation for pinctrl_get_group_pins()
pinctrl: rockchip: emulate both edge triggered interrupts
pinctrl: rockchip: add rk3188 specifics
pinctrl: rockchip: remove redundant check
The ACPI GpioInt resources contain polarity field that is used to specify
whether the interrupt is active high or low. Since gpiolib supports
GPIOF_ACTIVE_LOW we can pass this information in the flags field in
acpi_find_gpio(), analogous to the DeviceTree version.
gpiod_get_index() and gpiod_get() are now the new preferred way to request
GPIOs. Add support for finding the corresponding GPIO descriptor from ACPI
namespace.
Add gpiod_get(), gpiod_get_index() and gpiod_put() functions that
provide safer management of GPIOs.
These functions put the GPIO framework in line with the conventions of
other frameworks in the kernel, and help ensure every GPIO is declared
properly and valid while it is used.
This patch exports the gpiod_* family of API functions, a safer
alternative to the legacy GPIO interface. Differences between the gpiod
and legacy gpio APIs are:
- gpio works with integers, whereas gpiod operates on opaque handlers
which cannot be forged or used before proper acquisition
- gpiod get/set functions are aware of the active low state of a GPIO
- gpio consumers should now include <linux/gpio/consumer.h> to access
the new interface, whereas chips drivers will use
<linux/gpio/driver.h>
The legacy gpio API is now built as inline functions on top of gpiod.
Linux 3.12-rc6
drivers/gpio/gpio-lynxpoint.c
We want these fixes here too.
This patch adds the infrastructure required to register non-linear gpio
ranges through gpiolib and the standard GPIO device tree bindings.
Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com>
It is currently often possible in many GPIO drivers to request
a GPIO line to be used as IRQ after calling gpio_to_irq() and,
as the gpiolib is not aware of this, set the same line to
output and start driving it, with undesired side effects.
As it is a bogus usage scenario to request a line flagged as
output to used as IRQ, we introduce APIs to let gpiolib track
the use of a line as IRQ, and also set this flag from the
userspace ABI.
The API is symmetric so that lines can also be flagged from
.irq_enable() and unflagged from IRQ by .irq_disable().
The debugfs file is altered so that we see if a line is
reserved for IRQ.
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Patch be1a4b brought some improvements to the GPIO error handling code,
but also changed the return value of gpiod_request() when called on a
not yet initialized GPIO descriptor: it now returns -EINVAL instead of
-EPROBE_DEFER, and this affects some drivers.
This patch restores the original behavior for gpiod_request(). It is
safe to do so now that desc_to_gpio() does not rely on the GPIO
descriptor to be initialized. Other functions changed by patch be1a4b
do not see their return value affected, so these are not reverted.
Reported-by: Dr. H. Nikolaus Schaller <hns@goldelico.com>
The current implementation of desc_to_gpio() relies on the chip pointer
to be set to a valid value in order to compute the GPIO number. This
was done in the hope that we can get rid of the gpio_desc global array,
but this is not happening anytime soon.
This patch reimplements desc_to_gpio() in a fashion similar to that of
gpio_to_desc(). As a result, desc_to_gpio(gpio_to_desc(gpio)) == gpio is
now always true. This allows to call desc_to_gpio() on non-initialized
descriptors as some error-handling code currently does.
