path: root/drivers/gpio/gpio-tegra.c
2016-06-22gpio: tegra: Make lockdep class file-scopedThierry Reding
Commit b546be0db955 ("gpio: tegra: Get rid of all file scoped global variables") moved all file scoped variables into the driver-private structure to allow potentially multiple instances of the driver. The change also included turning the lockdep class into a driver-private field, which doesn't work and produces error messages such as this: [ 0.142310] BUG: key ffff8000fb3f7ab0 not in .data! Make the lockdep class file-scoped again to fix this issue. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-30gpio: tegra: Implement gpio_get_direction callbackLaxman Dewangan
Implement gpio_get_direction() callback for Tegra GPIO. The direction is only valid if the pin is configured as GPIO. If pin is not configured in GPIO mode then this function return error. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: tegra: Add support for gpio debounceLaxman Dewangan
NVIDIA's Tegra210 support the HW debounce in the GPIO controller for all its GPIO pins. Add support for setting debounce timing by implementing the set_debounce callback of gpiochip. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: tegra: Get rid of all file scoped global variablesLaxman Dewangan
Move the file scoped multiple global variable from Tegra GPIO driver to the structure and make this as gpiochip data which can be referred from GPIO chip callbacks. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: tegra: Make of_device_id compatible data to constantLaxman Dewangan
The data member of the of_device_id is the constant type and hence all static structure which is used for this initialisation as static. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Suggested-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-29gpio: tegra: Don't open code of_device_get_match_data()Laxman Dewangan
Use of_device_get_match_data() for getting matched data instead of implementing this locally. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-23gpio: tegra: Use devm_gpiochip_add_data() for gpio registrationLaxman Dewangan
Use devm_gpiochip_add_data() for GPIO registration. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com>
2016-01-05gpio: convert remaining users to gpiochip_add_data()Linus Walleij
For completion, sweep the floor from all gpiochip_add() usage so we can remove that function and get rid of the function wrapper gpiochip_add(). Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-17gpio-tegra: Do not create the debugfs entry by defaultSuzuki K. Poulose
The tegra gpio driver creates the debugfs entry irrespective of whether the device exists or not. This is enabled on an arm64_defconfig and leaves an entry in debugfs on all platforms where it is not useful. This patch fixes the issue by creating the entry only when a device exists. Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-07-28gpio: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed as most platforms don't use probing. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Ray Jui <rjui@broadcom.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-gpio@vger.kernel.org Cc: bcm-kernel-feedback-list@broadcom.com Cc: linux-tegra@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-14gpio: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Preparatory patch for the removal of the 'irq' argument from irq flow handlers. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-14gpio/gpio-tegra: Use irq_set_handler_locked()Thomas Gleixner
Use irq_set_handler_locked() as it avoids a redundant lookup of the irq descriptor. Search and replacement was done with coccinelle: Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-gpio@vger.kernel.org
2015-06-23Merge tag 'gpio-v4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio updates from Linus Walleij: "This is the big bulk of GPIO changes queued for the v4.2 kernel series: - a big set of cleanups to the aged sysfs interface from Johan Hovold. To get these in, v4.1-rc3 was merged into the tree as the first patch in that series had to go into stable. This makes the locking much more fine-grained (get rid of the "big GPIO lock(s)" and store states in the GPIO descriptors. - rename gpiod_[g|s]et_array() to gpiod_[g|s]et_array_value() to avoid confusions. - New drivers for: * NXP LPC18xx (currently LPC1850) * NetLogic XLP * Broadcom STB SoC's * Axis ETRAXFS * Zynq Ultrascale+ (subdriver) - ACPI: * make it possible to retrieve GpioInt resources from a GPIO device using acpi_dev_gpio_irq_get() * merge some dependent I2C changes exploiting this. * support the ARM X-Gene GPIO standby driver. - make it possible for the generic GPIO driver to read back the value set registers to reflect current status. - loads of OMAP IRQ handling fixes. - incremental improvements to Kona, max732x, OMAP, MXC, RCAR, PCA953x, STP-XWAY, PCF857x, Crystalcove, TB10x. - janitorial (constification, checkpatch cleanups)" * tag 'gpio-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits) gpio: Fix checkpatch.pl issues gpio: pcf857x: handle only enabled irqs gpio / ACPI: Return -EPROBE_DEFER if the gpiochip was not found GPIO / ACPI: export acpi_gpiochip_request(free)_interrupts for module use gpio: improve error reporting on own descriptors gpio: promote own request failure to pr_err() gpio: Added support to Zynq Ultrascale+ MPSoC gpio: add ETRAXFS GPIO driver fix documentation after renaming gpiod_set_array to gpiod_set_array_value gpio: Add GPIO support for Broadcom STB SoCs gpio: xgene: add ACPI support for APM X-Gene GPIO standby driver gpio: tb10x: Drop unneeded free_irq() call gpio: crystalcove: set IRQCHIP_SKIP_SET_WAKE for the irqchip gpio: stp-xway: Use the of_property_read_u32 helper gpio: pcf857x: Check for irq_set_irq_wake() failures gpio-stp-xway: Fix enabling the highest bit of the PHY LEDs gpio: Prevent an integer overflow in the pca953x driver gpio: omap: rework omap_gpio_irq_startup to handle current pin state properly gpio: omap: rework omap_gpio_request to touch only gpio specific registers gpio: omap: rework omap_x_irq_shutdown to touch only irqs specific registers ...
2015-06-18gpio: gpio-tegra: Fix race in installing chained IRQ handlerRussell King
Fix a race where a pending interrupt could be received and the handler called before the handler's data has been setup, by converting to irq_set_chained_handler_and_data(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Lee Jones <lee.jones@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/E1Z4z0M-0002Sl-Ti@rmk-PC.arm.linux.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-19Drivers: gpio: Fix spelling errorsColin Cronin
Fixed several spelling errors in gpio-lynxpoint, gpio-pca953x, gpio-tegra, gpio-zynq, gpiolib-of, gpiolib. Signed-off-by: Colin Cronin <colinpatrickcronin@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-28gpio: rename gpio_lock_as_irq to gpiochip_lock_as_irqAlexandre Courbot
This function actually operates on a gpio_chip, so its prefix should reflect that fact for consistency with other functions defined in gpio/driver.h. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20gpio: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-05-09gpio: tegra: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: tegra: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-11gpio: tegra: add missing error handling to probeStephen Warren
The call to gpiochip_add() is not currently error-checked. Add the missing checking. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-17gpio: tegra: use new gpio_lock_as_irq() APIStephen Warren
Whenever an IRQ is claimed or freed, call gpio_lock_as_irq() or gpio_unlock_as_irq() on the associated GPIO, to prevent that GPIO from being configured in a manner incompatible with an interrupt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-18drivers/gpio: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-05-06Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull GPIO changes from Grant Likely: "The usual selection of bug fixes and driver updates for GPIO. Nothing really stands out except the addition of the GRGPIO driver and some enhacements to ACPI support" I'm pulling this despite the earlier mess. Let's hope it compiles these days. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (46 commits) gpio: grgpio: Add irq support gpio: grgpio: Add device driver for GRGPIO cores gpiolib-acpi: introduce acpi_get_gpio_by_index() helper GPIO: gpio-generic: remove kfree() from bgpio_remove call gpio / ACPI: Handle ACPI events in accordance with the spec gpio: lpc32xx: Fix off-by-one valid range checking for bank gpio: mcp23s08: convert driver to DT gpio/omap: force restore if context loss is not detectable gpio/omap: optimise interrupt service routine gpio/omap: remove extra context restores in *_runtime_resume() gpio/omap: free irq domain in probe() failure paths gpio: gpio-generic: Add 16 and 32 bit big endian byte order support gpio: samsung: Add terminating entry for exynos_pinctrl_ids gpio: mvebu: add dbg_show function MAX7301 GPIO: Do not force SPI speed when using OF Platform gpio: gpio-tps65910.c: fix checkpatch error gpio: gpio-timberdale.c: fix checkpatch error gpio: gpio-tc3589x.c: fix checkpatch errors gpio: gpio-stp-xway.c: fix checkpatch error gpio: gpio-sch.c: fix checkpatch error ...
2013-04-28Merge branch 'gic/cleanup' into next/socOlof Johansson
Merge in the gic cleanup since it has a handful of annoying internal conflicts with soc development branches. All of them are delete/delete conflicts. * gic/cleanup: irqchip: vic: add include of linux/irq.h irqchip: gic: Perform the gic_secondary_init() call via CPU notifier irqchip: gic: Call handle_bad_irq() directly arm: Move chained_irq_(enter|exit) to a generic file arm: Move the set_handle_irq and handle_arch_irq declarations to asm/irq.h Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-shmobile/smp-emev2.c arch/arm/mach-shmobile/smp-r8a7779.c arch/arm/mach-shmobile/smp-sh73a0.c arch/arm/mach-socfpga/platsmp.c
2013-04-03gpio: tegra: add gpio wakeup source handlingJoseph Lo
This patch add the gpio wakeup source handling for the Tegra platform. It was be done by enabling the irq for the gpio in the gpio controller and enabling the bank irq of the gpio in the Tegra legacy irq controller when the system going to suspend. Based on the work by: Varun Wadekar <vwadekar@nvidia.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Joseph Lo <josephl@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-03-26arm: Move chained_irq_(enter|exit) to a generic fileCatalin Marinas
These functions have been introduced by commit 10a8c383 (irq: introduce entry and exit functions for chained handlers) in asm/mach/irq.h. This patch moves them to linux/irqchip/chained_irq.h so that generic irqchip drivers do not rely on architecture specific header files. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2013-03-04gpio/tegra: assume CONFIG_OFStephen Warren
Tegra only supports, and always enables, device tree. Remove all ifdefs and runtime checks for DT support from the driver. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-01-22gpio: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-11-28gpio: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17gpio: tegra: read output value when gpio is set in direction_outLaxman Dewangan
Read the output value when gpio is set for the output mode for gpio_get_value(). Reading input value in direction out does not give correct value. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-08gpio: tegra: Drop exporting static functionsAxel Lin
Both tegra_gpio_enable() and tegra_gpio_disable() are static functions, it does not make sense to export them. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-08gpio: tegra: Staticize non-exported symbolsAxel Lin
Both tegra_gpio_request() and tegra_gpio_free() are not referenced outside of this file, make them static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-08gpio: tegra: fix suspend/resume apisLaxman Dewangan
Following are changes done to fix the suspend/resume functionality of tegra gpio driver: - Protect suspend/resume callbacks with CONFIG_PM_SLEEP because CONFIG_PM doesn't actually enable any of the PM callbacks, it only allows to enable CONFIG_PM_SLEEP and CONFIG_PM_RUNTIME. This means if CONFIG_PM is used to protect system sleep callbacks then it may end up unreferenced if only runtime PM is enabled. - Fix the suspend/resume APIs declaration as per callback prototype. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-10-26gpio/tegra: convert to use linear irqdomainLinus Walleij
The Tegra driver tries to do the work of irq_domain_add_linear() by reserving a bunch of descriptors somewhere and keeping track of the base offset, then calling irq_domain_add_legacy(). Let's stop doing that and simply use the linear IRQ domain. For this to work: use irq_create_mapping() in the IRQ iterator so that the descriptors get allocated here. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Grant Likely <grant.likely@secretlab.ca> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-06gpio: tegra: remove useless includes of <mach/*.h>Stephen Warren
Nothing from these files is needed, so remove the includes. This helps single zImage work by reducing use of the mach-tegra/include/mach/ directory. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-18gpio: tegra: Hide tegra_gpio_enable/disable()Stephen Warren
Recent pinctrl discussions concluded that gpiolib APIs should in fact do whatever is required to mux a GPIO onto pins, by calling pinctrl APIs if required. This change implements this for the Tegra GPIO driver, and removes calls to the Tegra-specific APIs from drivers and board files. Cc: Chris Ball <cjb@laptop.org> Cc: linux-mmc@vger.kernel.org Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Chris Ball <cjb@laptop.org> # for sdhci-tegra.c Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Olof Johansson <olof@lixom.net>
2012-04-18gpio: tegra: configure pins during irq_set_typeStephen Warren
When a Tegra GPIO is used as an IRQ, it should be enabled as a GPIO (so the pinmux module isn't driving it as an output) and configured as a GPIO input (so the GPIO module isn't driving it as an output). Set this up automatically whenever an IRQ is requested, so that users of IRQs don't need to do this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net>
2012-04-04gpio: tegra: Iterate over the correct number of banksStephen Warren
When Tegra30 support was added to the Tegra GPIO driver, a few places which iterated over all banks were not converted to use the variable tegra_gpio_bank_count rather than hard-coding the bank count. Fix this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net>
2012-04-04gpio: tegra: fix register address calculations for Tegra30Stephen Warren
Tegra20 and Tegra30 share the same register layout within registers, but the addresses of the registers is a little different. Fix the driver to cope with this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net>
2012-03-28Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO changes for v3.4 from Grant Likely: "Primarily gpio device driver changes with some minor side effects under arch/arm and arch/x86. Also includes a few core changes such as explicitly supporting (electrical) open source and open drain outputs and some help for parsing gpio devicetree properties." Fix up context conflict due to Laxman Dewangan adding sleep control for the tps65910 driver separately for gpio's and regulators. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio/ep93xx: Remove unused inline function and useless pr_err message gpio/sodaville: Mark broken due to core irqdomain migration gpio/omap: fix redundant decoding of gpio offset gpio/omap: fix incorrect update to context.irqenable1 gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_* gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg gpio/omap: fix _set_gpio_irqenable implementation gpio/omap: fix trigger type to unsigned gpio/omap: fix wakeup_en register update in _set_gpio_wakeup() gpio: tegra: tegra_gpio_config shouldn't be __init gpio/davinci: fix enabling unbanked GPIO IRQs gpio/davinci: fix oops on unbanked gpio irq request gpio/omap: Fix section warning for omap_mpuio_alloc_gc() ARM: tegra: export tegra_gpio_{en,dis}able gpio/gpio-stmpe: Fix the value returned by _get_value routine Documentation/gpio.txt: Explain expected pinctrl interaction GPIO: LPC32xx: Add output reading to GPO P3 GPIO: LPC32xx: Fix missing bit selection mask gpio/omap: fix wakeups on level-triggered GPIOs gpio/omap: Fix IRQ handling for SPARSE_IRQ ...
2012-03-19gpio: tegra: tegra_gpio_config shouldn't be __initStephen Warren
This function is called from non-__init context, just like tegra_gpio_enable()/disable(). Remove the __init annotation to avoid section mismatch warnings during compile. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-12ARM: tegra: export tegra_gpio_{en,dis}ableArnd Bergmann
These two functions are used in drivers that can be modules, so they need to be exported. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-02-26gpio: tegra: Fix build issue due to irq_domain rework.Stephen Warren
Commit 7da5a66 "irq_domain: Remove 'new' irq_domain in favour of the ppc one" changed the set of available irq domain APIs. Update the Tegra GPIO driver to account for those changes, to solve a build break. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06gpio: tegra: Parameterize the number of banksStephen Warren
Tegra20's GPIO controller has 7 banks, and Tegra30's controller has 8 banks. Allow the number of banks to be configured at run-time by the device tree. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06gpio: tegra: Dynamically allocate IRQ base, and support DTStephen Warren
Enhance the driver to dynamically allocate the base IRQ number, and create an IRQ domain for itself. The use of an IRQ domain ensures that any device tree node interrupts properties are correctly parsed. Describe interrupt-related properties in the device tree binding docs, and the contents of "child" node interrupts property. Update tegra*.dtsi to specify the required interrupt-related properties. Finally, remove the definition of TEGRA_GPIO_TO_IRQ; this macro no longer gives correct results since the IRQ numbers for GPIOs are dynamically allocated. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-02drivers/gpio/gpio-tegra.c: use devm_request_and_ioremapJulia Lawall
Reimplement a call to devm_request_mem_region followed by a call to ioremap or ioremap_nocache by a call to devm_request_and_ioremap. The semantic patch that makes this transformation is as follows: (http://coccinelle.lip6.fr/) // <smpl> @nm@ expression myname; identifier i; @@ struct platform_driver i = { .driver = { .name = myname } }; @@ expression dev,res,size; expression nm.myname; @@ -if (!devm_request_mem_region(dev, res->start, size, - \(res->name\|dev_name(dev)\|myname\))) { - ... - return ...; -} ... when != res->start ( -devm_ioremap(dev,res->start,size) +devm_request_and_ioremap(dev,res) | -devm_ioremap_nocache(dev,res->start,size) +devm_request_and_ioremap(dev,res) ) ... when any when != res->start // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
