path: root/drivers/gpio/gpio-tc3589x.c
2016-01-05gpio: tc3589x: use gpiochip data pointerLinus Walleij
This makes the driver use the data pointer added to the gpio_chip to store a pointer to the state container instead of relying on container_of(). Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-26gpio: tc3589x: Be sure to clamp return valueLinus Walleij
As we want gpio_chip .get() calls to be able to return negative error codes and propagate to drivers, we need to go over all drivers and make sure their return values are clamped to [0,1]. We do this by using the ret = !!(val) design pattern. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-19gpio: change member .dev to .parentLinus Walleij
The name .dev in a struct is normally reserved for a struct device that is let us say a superclass to the thing described by the struct. struct gpio_chip stands out by confusingly using a struct device *dev to point to the parent device (such as a platform_device) that represents the hardware. As we want to give gpio_chip:s real devices, this is not working. We need to rename this member to parent. This was done by two coccinelle scripts, I guess it is possible to combine them into one, but I don't know such stuff. They look like this: @@ struct gpio_chip *var; @@ -var->dev +var->parent and: @@ struct gpio_chip var; @@ -var.dev +var.parent and: @@ struct bgpio_chip *var; @@ -var->gc.dev +var->gc.parent Plus a few instances of bgpio that I couldn't figure out how to teach Coccinelle to rewrite. This patch hits all over the place, but I *strongly* prefer this solution to any piecemal approaches that just exercise patch mechanics all over the place. It mainly hits drivers/gpio and drivers/pinctrl which is my own backyard anyway. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Alek Du <alek.du@intel.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-27gpio: tc3589x: use static container helperLinus Walleij
There is a helper function to do the container_of() magic for the tc3589x GPIO, so use it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-26mfd: tc3589x: Enforce device-tree only modeLinus Walleij
All systems using the TC3589x multifunction expander uses devicetree, so don't clutter the place with a lot of and assume it is there. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-01-15gpio: tc3589x: get rid of platform dataLinus Walleij
This device is only used from the device tree, and the startup() and remove() callbacks are not used anywhere in the kernel, so retire them and the pdata altogether. Cc: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-11-25mfd: tc3589x: get rid of static baseLinus Walleij
The TC3589x driver is now a device tree-only driver, so we want only dynamic IRQs and GPIO numbers from the tc3589x, no static assignments. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-26gpio: handle also nested irqchips in the chained handler set-upLinus Walleij
To unify how we connect cascaded IRQ chips to parent IRQs, if NULL us passed as handler to the gpiochip_set_chained_irqchip() function, assume the chips is nested rather than chained, and we still get the parent set up correctly by way of this function call. Alter the drivers for tc3589x and stmpe to use this to set up their chained handlers as a demonstration of the usage. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: use gpiolib irqchip helpersLinus Walleij
Now that the gpiolib irqchip helpers can support nested, threaded IRQ handlers, switch the TC3589x driver over to using this new infrastructure. Tested on the Ux500. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: get rid of static IRQ baseLinus Walleij
The static IRQ base is not used on any platforms with this chip (only Ux500). Get rid of it forever, and rely on dynamic IRQ descriptor allocation. Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-04-28gpio: tc3589x: use managed resourcesLinus Walleij
Grab state container and irq using the devm_* functions and save some lines of hairy clean-up code. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-11gpio: tc3589x: drop references to "virtual" IRQLinus Walleij
Rename the argument "virq" to just "irq", this IRQ isn't any more "virtual" than any other Linux IRQ number, we use "hwirq" for the actual hw-numbers, "virq" is just bogus. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-30gpio: tc3589x: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-27gpio: gpio-tc3589x.c: fix checkpatch errorsLaurent Navet
Fix : gpio/gpio-tc3589x.c:285: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:286: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:287: ERROR: code indent should use tabs where possible gpio/gpio-tc3589x.c:347: ERROR: code indent should use tabs where possible Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-26gpio/tc3589x: convert to use the simple irqdomainLinus Walleij
The special checks for whether we have a base IRQ offset or not is surplus if we use the simple IRQ domain. The IRQ offset zero will be interpreted as a linear domain case. Plus this makes sure we allocate descriptors where need be, or warn if they are preallocated with SPARSE_IRQ. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-12gpio: Enable the tc3298x GPIO expander driver for Device TreeLee Jones
Here we provide a means to probe and extract vital information from Device Tree when booting with it enabled. Without this patch sub-devices wouldn't be able to reference the tc3589x-gpio expander from Device Tree. CC: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-12gpio: Provide the tc3589x GPIO expander driver with an IRQ domainLee Jones
In preparation for Device Tree enablement all IRQ controllers should control their own IRQ domain. This patch provides just that for the tc3589x GPIO expander. CC: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
