This moves the mcp23s08 driver from gpio to pinctrl. Actual
pinctrl support for configuration of the pull-up resistors
follows in its own patch.
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
When an interrupt occurs on an MCP23S08 chip, the INTF register will only
contain one bit as causing the interrupt. If more than two pins change at
the same time on the chip, this causes one of the pins to not be reported.
This patch fixes the logic for checking if a pin has changed, so that
multiple pins will always cause more than one change.
Cc: stable@vger.kernel.org
Signed-off-by: Robert Middleton <robert.middleton@rm5248.com>
Tested-by: Phil Reid <preid@electromag.com.au>
Use regmap API to save some lines of codes and have
debugfs support for all of the MCP's registers.
Signed-off-by: Sebastian Reichel <sre@kernel.org>
This tries to simplify the use of CONFIG_GPIOLIB_IRQCHIP when
using threaded interrupts: add a new call
gpiochip_irqchip_add_nested() to indicate that we're dealing
with a nested rather than a chained irqchip, then create a
separate gpiochip_set_nested_irqchip() to mirror
the gpiochip_set_chained_irqchip() call to connect the
parent and child interrupts.
In the nested case gpiochip_set_nested_irqchip() does nothing
more than call irq_set_parent() on each valid child interrupt,
which has little semantic effect in the kernel, but this is
probably still formally correct.
Update all drivers using nested interrupts to use
gpiochip_irqchip_add_nested() so we can now see clearly
which these users are.
The DLN2 driver can drop its specific hack with
.irq_not_threaded as we now recognize whether a chip is
threaded or not from its use of gpiochip_irqchip_add_nested()
signature rather than from inspecting .can_sleep.
We rename the .irq_parent to .irq_chained_parent since this
parent IRQ is only really kept around for the chained
interrupt handlers.
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Daniel Baluta <daniel.baluta@intel.com>
Cc: Bin Gao <bin.gao@linux.intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Ajay Thomas <ajay.thomas.david.rajamanickam@intel.com>
Cc: Semen Protsenko <semen.protsenko@globallogic.com>
Cc: Alexander Stein <alexander.stein@systec-electronic.com>
Cc: Phil Reid <preid@electromag.com.au>
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Cc: Patrice Chotard <patrice.chotard@st.com>
The MCP23S08 driver certainly accesses fields inside the
struct gpio_chip that are only available under CONFIG_OF_GPIO
not just CONFIG_OF, so update the Kconfig and driver to reflect
this.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
The interrupt for the corresponding pin is configured to trigger when the
pin state changes compared to a preconfigured state (Bit set in INTCON).
This state is set by setting/clearing the bit in DEFVAL.
In the interrupt handler we need also to check if the bit in INTCON is set
for level triggered interrupts.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
When using the GPIOLIB_IRQCHIP the gpiolib provides a
straight-forward implementation of request/release resources,
rely on that instead.
This switches the mcp23s08 driver to use the gpiolib irqchip
helpers.
Signed-off-by: Phil Reid <preid@electromag.com.au>
The mcp23s18 is configurable on clearing the interrupt on either reading
INTCAP or GPIO. Since driver reads INTCAP in IRQ and not the GPIO reg need
to set control byte for this mode.
This patch adds support for the mcp23s18 which is very similar to
the mcp23s17. A couple of control bits are not the same.
Notable IOCON_HAEN (s17 only) & IOCON_INTCC. Which can be ignored.
Patch changes the following:
- Add mcp23s18 types.
- Always set mirror bit if the dts defines mcp23s18. regardless of type.
Mirror bit is ignored on 8 bit devices anyway.
- In mcp23s08_probe use chip.ngpio instead of logic based on type
to determine number of gpio lins to increment by. This is set
appropiately by the call to mcp23s08_probe_one.
- Add mcp23s18 to device tree documentation.
- Remove statement that irqs don't work for spi. They do.
Tested with mcp23s18.
Acked-by: Rob Herring <robh@kernel.org>
Since devm_kzalloc can be failed in memory pressure,
it needs to check and return -ENOMEM
Signed-off-by: Insu Yun <wuninsu@gmail.com>
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: Sonic Zhang <sonic.zhang@analog.com>
Acked-by: Alexander Stein <alexander.stein@systec-electronic.com>
The name .dev in a struct is normally reserved for a struct device
that is let us say a superclass to the thing described by the struct.
struct gpio_chip stands out by confusingly using a struct device *dev
to point to the parent device (such as a platform_device) that
represents the hardware. As we want to give gpio_chip:s real devices,
this is not working. We need to rename this member to parent.
This was done by two coccinelle scripts, I guess it is possible to
combine them into one, but I don't know such stuff. They look like
this:
struct gpio_chip *var;
-var->dev
+var->parent
and:
struct gpio_chip var;
-var.dev
+var.parent
and:
struct bgpio_chip *var;
-var->gc.dev
+var->gc.parent
Plus a few instances of bgpio that I couldn't figure out how
to teach Coccinelle to rewrite.
This patch hits all over the place, but I *strongly* prefer this
solution to any piecemal approaches that just exercise patch
mechanics all over the place. It mainly hits drivers/gpio and
drivers/pinctrl which is my own backyard anyway.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Alek Du <alek.du@intel.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed as most platforms don't use probing.
There appears to be a great deal of blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: linux-gpio@vger.kernel.org
Cc: bcm-kernel-feedback-list@broadcom.com
Cc: linux-tegra@vger.kernel.org
commit 3de07e5aaf290a0b58919 ("drivers: gpio: use devm_kzalloc")
introduce devm_kzalloc() for allocating the memory. In this case kfree
is not required to use. Above commit id introduced the bug that kfree
is not removed from the remove function.
This patch fix the above bug.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
We can use devres API for allocating memory. No need of using kfree.
Create default gpio base if neither device node nor
platform data is defined.
Cc: Stable <stable@vger.kernel.org>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
Tested-by: Antonio Fiol <antonio@fiol.es>
The driver depends on the chip.of_node being present to compile,
which is the case on some target platforms but not others.
Instead, rely on chip.dev->of_node to be used, as struct device
always has an of_node in place.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Default is active low, but if property is specified in DT set INTPOL flag.
Currently this implementation only supports one IRQ for (all) SPI devices
using the same chip select.
Request a shared interrupt when requesting a mcp23s08 GPIO interrupt.
If devm_request_threaded_irq fails for some reason we call
mcp23s08_irq_teardown afterwards.
Do not free the unrequested interrupt in this case. free_irq can also be
omitted for the error free case because we use devm_request_threaded_irq.
This function actually operates on a gpio_chip, so its prefix should
reflect that fact for consistency with other functions defined in
gpio/driver.h.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Device tree is not enabled in some architecture where gpio
driver mcp23s08 is still required.
v2-changes:
- Parse device tree properties into platform data other than
individual variables.
v3-changes:
- Use of_node in gpio_chip device structure, because the
struct device * always has an of_node which is NULL when
OF is not used.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO update from Linus Walleij:
"This is the bulk of GPIO changes for the v3.17 development cycle, and
this time we got a lot of action going on and it will continue:
- The core GPIO library implementation has been split up in three
different files:
- gpiolib.c for the latest and greatest and shiny GPIO library code
using GPIO descriptors only
- gpiolib-legacy.c for the old integer number space API that we are
phasing out gradually
- gpiolib-sysfs.c for the sysfs interface that we are not entirely
happy with, but has to live on for ABI compatibility
- Add a flags argument to *gpiod_get* functions, with some
backward-compatibility macros to ease transitions. We should have
had the flags there from the beginning it seems, now we need to
clean up the mess. There is a plan on how to move forward here
devised by Alexandre Courbot and Mark Brown
- Split off a special <linux/gpio/machine.h> header for the board
gpio table registration, as per example from the regulator
subsystem
- Start to kill off the return value from gpiochip_remove() by
removing the __must_check attribute and removing all checks inside
the drivers/gpio directory. The rationale is: well what were we
supposed to do if there is an error code? Not much: print an error
message. And gpiolib already does that. So make this function
return void eventually
- Some cleanups of hairy gpiolib code, make some functions not to be
used outside the library private and make sure they are not
exported, remove gpiod_lock/unlock_as_irq() as the existing
function is for driver-internal use and fine as it is, delete
gpio_ensure_requested() as it is not meaningful anymore
- Support the GPIOF_ACTIVE_LOW flag from gpio_request_one() function
calls, which is logical since this is already supported when
referencing GPIOs from e.g. device trees
- Switch STMPE, intel-mid, lynxpoint and ACPI (!) to use the gpiolib
irqchip helpers cutting down on GPIO irqchip boilerplate a bit more
- New driver for the Zynq GPIO block
- The usual incremental improvements around a bunch of drivers
- Janitorial syntactic and semantic cleanups by Jingoo Han, and
Rickard Strandqvist especially"
* tag 'gpio-v3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (37 commits)
MAINTAINERS: update GPIO include files
gpio: add missing includes in machine.h
gpio: add flags argument to gpiod_get*() functions
MAINTAINERS: Update Samsung pin control entry
gpio / ACPI: Move event handling registration to gpiolib irqchip helpers
gpio: lynxpoint: Convert to use gpiolib irqchip
gpio: split gpiod board registration into machine header
gpio: remove gpio_ensure_requested()
gpio: remove useless check in gpiolib_sysfs_init()
gpiolib: Export gpiochip_request_own_desc and gpiochip_free_own_desc
gpio: move gpio_ensure_requested() into legacy C file
gpio: remove gpiod_lock/unlock_as_irq()
gpio: make gpiochip_get_desc() gpiolib-private
gpio: simplify gpiochip_export()
gpio: remove export of private of_get_named_gpio_flags()
gpio: Add support for GPIOF_ACTIVE_LOW to gpio_request_one functions
gpio: zynq: Clear pending interrupt when enabling a IRQ
gpio: drop retval check enforcing from gpiochip_remove()
gpio: remove all usage of gpio_remove retval in driver/gpio
devicetree: Add Zynq GPIO devicetree bindings documentation
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com>
Unnecessary checking was added during the merge of the gpio branch.
This patch removes the extra unnecessary checking.
Signed-off-by: Michael Welling <mwelling@ieee.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio into next
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v3.16 series.
There is a lot of action in the GPIO subsystem doing refactorings and
cleanups, almost as many deletions as insertions and minor feature
growth and no new drivers this time. Which is actually pretty nice.
Some GPIO-related stuff will come in through the pin control tree as
well.
Details:
- We are finalizing and fixing up the gpiochip irqchip helpers
bringing a helpful irqchip implementation into the gpiolib core and
avoiding duplicate code and, more importantly, duplicate bug fixes:
* Support for using the helpers with threaded interrupt handlers as
used on sleeping GPIO-irqchips
* Do not set up hardware triggers for edges or levels if the
default IRQ type is IRQ_TYPE_NONE - some drivers would exploit
the fact that you could get default initialization of the IRQ
type from the core at probe() but if no default type is set up
from the helper, we should not call the driver to configure
anything. Wait until a consumer requests the interrupt instead.
* Make the irqchip helpers put the GPIO irqs into their own lock
class. The GPIO irqchips can often emit (harmless, but annoying)
lockdep warnings about recursions when they are in fact just
cascaded IRQs. By putting them into their own lock class we help
the lockdep core to keep track of things.
* Switch the tc3589x GPIO expanders to use the irqchip helpers
* Switch the OMAP GPIO driver to use the irqchip helpers
* Add some documentation for the irqchip helpers
* select IRQ_DOMAIN when using the helpers since some platforms may
not be using this by default and it's a strict dependency.
- Continued GPIO descriptor refactoring:
* Remove the one instance of gpio_to_desc() from the device tree
code, making the OF GPIO code use GPIO descriptors only.
* Introduce gpiod_get_optional() and gpiod_get_optional_index()
akin to the similar regulator functions for cases where the use
of GPIO is optional and not strictly required.
* Make of_get_named_gpiod_flags() private - we do not want to
unnecessarily expose APIs to drivers that make the gpiolib harder
than necessary to maintain and refactor. Privatize this
function.
- Support "-gpio" suffix for the OF GPIO retrieveal path. We used to
look for "foo-gpios" or just "gpios" in device tree nodes, but it
turns out that some drivers with a single GPIO line will just state
"foo-gpio" (singularis). Sigh. Support this with a fallback
looking for it, as this simplifies driver code and handles it in
core code.
- Switch the ACPI GPIO core to fetch GPIOs with the *_cansleep
function variants as the GPIO operation region handler can sleep,
and shall be able to handle gpiochips that sleep.
- Tons of cleanups and janitorial work from Jingoo Han, Axel Lin,
Javier Martinez Canillas and Abdoulaye Berthe. Notably Jingoo cut
off a ton of pointless OOM messages.
- Incremental development and fixes for various drivers, nothing
really special here"
* tag 'gpio-v3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits)
gpio: select IRQ_DOMAIN for gpiolib irqchip helpers
gpio: pca953x: use gpiolib irqchip helpers
gpio: pcf857x: Add IRQF_SHARED when request irq
gpio: pcf857x: Avoid calling irq_domain_cleanup twice
gpio: mcp23s08: switch chip count to int
gpio: dwapb: use a second irq chip
gpio: ep93xx: Use devm_ioremap_resource()
gpio: mcp23s08: fixed count variable for devicetree probing
gpio: Add run-time dependencies to R-Car driver
gpio: pch: add slab include
Documentation / ACPI: Fix location of GPIO documentation
gpio / ACPI: use *_cansleep version of gpiod_get/set APIs
gpio: generic: add request function pointer
gpio-pch: Fix Kconfig dependencies
gpio: make of_get_named_gpiod_flags() private
gpio: gpioep93xx: use devm functions
gpio: janzttl: use devm function
gpio: timberdale: use devm functions
gpio: bt8xx: use devm function for memory allocation
gpio: include linux/bug.h in interface header
Commit 3e3bed913e8bbd78f38cefd5d575475f45c05dd0
"gpio: mcp23s08: fixed count variable for devicetree probing"
introduced a loop check to see if the number of chips were
unconsistent and going below zero counting downwards, but
this requires the counting variable to be able to be
negative, so switch the variable from unsigned to int.
Cc: Michael Stickel <ms@mycable.de>
Fixed missing increase of count variable for devicetree path in driver
probing.
The gpio-mcp23s08 driver has two paths for getting the platform
registration information. One for the classic platform initialization
and one for openfirmware devicetree based initialization. The devicetree
based path is missing the increase of the count variable, which results
in the count variable to become negative in the later use, where it is
decreased. The count variable is used as an index into a vector. This
results in accessing invalid memory space and can result in an exception.
Tested this with an AM3352 SoC with two mcp23s17 on two chip selects as
well as on a shared chip select.
Signed-off-by: Michael Stickel <ms@mycable.de>
Make of_device_id array const, because all OF functions
handle it as const.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The chips variable needs to be incremented for each chip that is
found in the spi_present_mask when registering via device tree.
Without this and the checking a negative index is passed to the
data->chip array in a subsequent loop.
Acked-by: Peter Korsgaard <peter@korsgaard.com>
This switches all GPIO and pin control drivers with irqchips
that were using .startup() and .shutdown() callbacks to lock
GPIO lines for IRQ usage over to using the .request_resources()
and .release_resources() callbacks just introduced into the
irqchip vtable.
Cc: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
This coding style issue was detected using the checkpatch.pl script
Signed-off-by: Gary Servin <garyservin@gmail.com>
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
This adds interrupt functionality for i2c chips to the driver.
They can act as a interrupt-controller and generate interrupts, if
the inputs change.
This is tested with a mcp23017 chip on an arm based platform.
v3:
- be a bit more clear that the irq functionality is also available
on spi versions of the chips, but the linux driver does not support
this yet
v2:
- some more word about irq-mirror property in binding doc
- use of_read_bool instead of of_find_property for
"interrupt-contrller" and "irq-mirror"
- cache the "interrupt-controller" for remove function
- do set the irq-mirror bit only if device is marked as
- do create the irq mapping and setup of irq_desc of all possible
interrupts in probe path instead of in gpio_to_irq
- mark gpios as in use as interrupts in irq in irq_startup and
unlock it in irq_shutdown
- rename virq to child_irq
- remove dev argument from mcp23s08_irq_setup function
- move gpiochip_add before mcp23s08_irq_setup in probe path
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
This switches the two members of struct gpio_chip that were
defined as unsigned foo:1 to bool, because that is indeed what
they are. Switch all users in the gpio and pinctrl subsystems
to assign these values with true/false instead of 0/1. The
users outside these subsystems will survive since true/false
is 1/0, atleast we set some kind of more strict typing example.
The device tree property should be more descriptive.
microchip seems more reasonable than mcp. The old mcp
prefix is still supported but marked as deprecated.
Users of mcp have to switch to the microchip prefix.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
The call to gpiochip_add made by this driver is capable of auto-selecting a
base if one is not provided. However, it was not called unless there was
already a DT entry or platform data. This patch calls it even if the base is
not already known so that gpiochip_add can attempt to find a usable base.
Signed-off-by: Daniel M. Weeks <dan@danweeks.net>
Acked-by: Lars Poeschel <poeschel@lemonage.de>
This converts the mcp23s08 driver to be able to be used with
device tree.
There is a "spi-present-mask" device tree property, that allows to
use multiple of this spi chips on the same chipselect.
v4:
- removed the ability to specify the pullup from device tree
- updated binding doc
v3:
- removed mcp,chips device tree property in favour of a
mcp,spi-present-mask and a flag for the pullup of every gpio
- seperated the match table. Now there is one for i2c and one for spi
- do the of reading stuff on stack of the probe function - no devm
any more
v2:
- squashed booth patches together
- fixed build warning, when CONFIG_OF is not defined
- use of_match_ptr macro for of_match_table
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the large driver core updates for 3.8-rc1.
The biggest thing here is the various __dev* marking removals. This
is going to be a pain for the merge with different subsystem trees, I
know, but all of the patches included here have been ACKed by their
various subsystem maintainers, as they wanted them to go through here.
If this is too much of a pain, I can pull all of them out of this tree
and just send you one with the other fixes/updates and then, after
3.8-rc1 is out, do the rest of the removals to ensure we catch them
all, it's up to you. The merges should all be trivial, and Stephen
has been doing them all in linux-next for a few weeks now quite
easily.
Other than the __dev* marking removals, there's nothing major here,
some firmware loading updates and other minor things in the driver
core.
All of these have (much to Stephen's annoyance), been in linux-next
for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio
update.
* tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits)
modpost.c: Stop checking __dev* section mismatches
init.h: Remove __dev* sections from the kernel
acpi: remove use of __devinit
PCI: Remove __dev* markings
PCI: Always build setup-bus when PCI is enabled
PCI: Move pci_uevent into pci-driver.c
PCI: Remove CONFIG_HOTPLUG ifdefs
unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs
sh/PCI: Remove CONFIG_HOTPLUG ifdefs
powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs
mips/PCI: Remove CONFIG_HOTPLUG ifdefs
microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs
dma: remove use of __devinit
dma: remove use of __devexit_p
firewire: remove use of __devinitdata
leds: remove use of __devexit
leds: remove use of __devinit
leds: remove use of __devexit_p
mmc: remove use of __devexit
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Peter Tyser <ptyser@xes-inc.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
The driver has both SPI and I2C pieces. The appropriate pieces are built based
on whether SPI and/or I2C is/are enabled. However, it was only checking if I2C
was built-in, never if it was built as a module. This patch checks for either
since building both this driver and I2C as modules is possible.
Pullups are enabled when bits are set, not when cleared.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
A pending cleanup will mean that module.h won't be implicitly
everywhere anymore. Make sure the modular drivers in gpio
are actually calling out for <module.h> explicitly in advance.
Add i2c bindings for the mcp230xx devices. This is quite a lot simpler
than the spi one as there's no funky sub addressing done (one struct
i2c_client per struct gpio_chip).
The mcp23s08_platform_data structure is reused for i2c, even though
only a single mcp23s08_chip_info structure is needed.
To use, simply fill out a platform_data structure and pass it in
i2c_board_info, E.G.:
static const struct mcp23s08_platform_data mcp23017_data = {
.chip[0] = {
.pullups = 0x00ff,
.base = 240,
static struct i2c_board_info __initdata i2c_devs[] = {
{ I2C_BOARD_INFO("mcp23017", 0x20),
.platform_data = &smartview_mcp23017_data, },
