path: root/drivers/gpio/gpio-lynxpoint.c
2014-08-21gpio-lynxpoint: enable input sensing in resumegpio-v3.17-2Mathias Nyman
It appears that input sensing bit might be reset during suspend/resume. Set input sensing again for all requested gpios in resume Tested-by: Jerome Blin <jerome.blin@intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-28gpio: lynxpoint: Convert to use gpiolib irqchipMika Westerberg
Instead of open-coding irqchip handling in the driver we can take advantage of the new irqchip helpers provided by the gpiolib core. While doing this we also make sure that we call gpiochip_irqchip_add() after the gpiochip itself is registered as required. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-09gpio: lynxpoint: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-28gpio-lynxpoint: force gpio_get() to return "1" and "0" onlyMathias Nyman
Don't return the IN_LVL_BIT directly, a high gpio line returned value "1073741824" intestead of "1" because IN_LVL_BIT is BIT(30) Tested-by: Jerome Blin <jerome.blin@intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-03-18gpio: switch drivers to use new callbackLinus Walleij
This switches all GPIO and pin control drivers with irqchips that were using .startup() and .shutdown() callbacks to lock GPIO lines for IRQ usage over to using the .request_resources() and .release_resources() callbacks just introduced into the irqchip vtable. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean-Jacques Hiblot <jjhiblot@traphandler.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04Merge branch 'mark-irqs' into develLinus Walleij
Conflicts: drivers/gpio/gpio-em.c
2013-12-04gpio: lynxpoint: lock IRQs when starting themLinus Walleij
This uses the new API for tagging GPIO lines as in use by IRQs. This enforces a few semantic checks on how the underlying GPIO line is used. Cc: Mathias Nyman <mathias.nyman@linux.intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-03gpio-lynxpoint: Allow building as a moduleJean Delvare
Change CONFIG_GPIO_LYNXPOINT from bool to tristate so that the gpio-lynxpoint driver can be built as a module. Add the required glue: an exit function to unregister the driver, and module information. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Mathias Nyman <mathias.nyman@linux.intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-03gpio: drop users of irq_set_chip_and_handler_name()Linus Walleij
Switch all users of irq_set_chip_and_handler_name() to simply use irq_set_chip_and_handler(), all just provide a boilerplate name like "demux" or "mux" - a fact which is anyway obvious from the hwirq number from the irqdomain now present in e.g. /proc/interrupts. Cc: Mathias Nyman <mathias.nyman@linux.intel.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: David Cohen <david.a.cohen@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-11-25gpio/lynxpoint: add new ACPI IDMika Westerberg
Newer Intel PCHs have the same GPIO controller than Haswell but the ACPI ID is different. Add this ID to the driver supported IDs list. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-19Merge tag 'v3.12-rc6' into develLinus Walleij
Linux 3.12-rc6 Conflicts: drivers/gpio/gpio-lynxpoint.c
2013-10-16gpio: lynxpoint: drop references to "virtual" IRQLinus Walleij
Rename the argument "virq" to just "irq", this IRQ isn't any more "virtual" than any other Linux IRQ number, we use "hwirq" for the actual hw-numbers, "virq" is just bogus. Take this opportunity to sink a variable into a loop. Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-11gpio/lynxpoint: check if the interrupt is enabled in IRQ handlerMika Westerberg
Checking LP_INT_STAT is not enough in the interrupt handler because its contents get updated regardless of whether the pin has interrupt enabled or not. This causes the driver to loop forever for GPIOs that are pulled up. Fix this by checking the interrupt enable bit for the pin as well. Cc: stable@vger.kernel.org Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-16gpio-lynxpoint: Fix warning about unbalanced pm_runtime_enableMathias Nyman
Missing pm_runtime_disable call in driver remove path caused an unbalanaced pm_runtime_enable warning when driver was reloaded Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-30gpio: lynxpoint: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-27gpio-lynxpoint: Add X86 dependency and io-port handling header.Mathias Nyman
Lynxpoint gpio driver uses X86 specific io-ports to control gpios Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-05gpio/lynxpoint: add chipset gpio driver.Mathias Nyman
Add gpio support for Intel Lynxpoint chipset. Lynxpoint supports 94 gpio pins which can generate interrupts. Driver will fail requests for pins that are marked as owned by ACPI, or set in an alternate mode (non-gpio). Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
