Use the irq_chip bus_sync_unlock method to update hardware registers
instead of scheduling work from the mask/unmask methods. This simplifies
a bit the driver and make it more uniform with the other GPIO IRQ
drivers.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
dln2_gpio_direction_output() ignored the state passed into it. Fix it.
Also make dln2_gpio_pin_set_out_val return int, so we can check the error value.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Tested-by: Daniel Baluta <daniel.baluta@intel.com>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Octavian Purdila <octavian.purdila@intel.com>
As noticed during suspend/resume operations, the IRQ can be unmasked
then disabled in suspend and eventually enabled in resume, but without
being unmasked.
The current implementation does not take into account interactions
between mask/unmask and enable/disable interrupts, and thus in the
above scenarios the IRQs remain unactive.
To fix this we removed the enable/disable operations as they fallback
to mask/unmask anyway.
We also remove the pending bitmaks as it is already done in irq_data
(i.e. IRQS_PENDING).
This patch adds GPIO and IRQ support for the Diolan DLN-2 GPIO module.
Information about the USB protocol interface can be found in the
Programmer's Reference Manual [1], see section 2.9 for the GPIO
module commands and responses.
[1] https://www.diolan.com/downloads/dln-api-manual.pdf
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
