path: root/drivers/gpio/gpio-arizona.c
2014-07-22gpio: remove all usage of gpio_remove retval in driver/gpioabdoulaye berthe
Signed-off-by: abdoulaye berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-04gpio/pinctrl: make gpio_chip members typed booleanLinus Walleij
This switches the two members of struct gpio_chip that were defined as unsigned foo:1 to bool, because that is indeed what they are. Switch all users in the gpio and pinctrl subsystems to assign these values with true/false instead of 0/1. The users outside these subsystems will survive since true/false is 1/0, atleast we set some kind of more strict typing example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-02gpio: arizona: Use the of_node from the Arizona deviceCharles Keepax
We need to use the of_node from the main Arizona device as that holds our configuration. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-20gpio: arizona: Add wm8997 support to probeCharles Keepax
2013-08-16gpio: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-17gpiolib: Add support for Wolfson Microelectronics Arizona class devicesMark Brown
The Arizona class devices provide some GPIOs for use in the system. This driver provides support for these via gpiolib. Currently interrupts are not supported, normally the GPIOs are outputs only. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [Fold in WM5110 support patch] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
