This patch alters the renamed extcon API to set the state of the external
connectors instead of deprecated extcon_set_cable_state_().
Because the patch[1] modifies the function name to maintain the function
naming pattern.
- extcon_set_cable_state_() -> extcon_set_state_sync()
- extcon_get_cable_state_() -> extcon_get_state()
[1] https://lkml.org/lkml/2016/8/4/729
- extcon: Rename the extcon_set/get_state() to maintain the function naming pattern
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Roger Quadros <rogerq@ti.com>
Change my email address to kernel.org instead of Samsung one for the
purpose of any future contact. The copyrights remain untouched and are
attributed to Samsung.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
This patch adds the new EXTCON_CHG_USB_SDP connector to support SDP (Standard
Downstream Port) USB charging port. The commit 11eecf910bd8 ("extcon: Modify
the id and name of external connector") add the new EXTCON_CHG_USB_SDP
connector which support the both data transfer and usb charging at the same
time.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The function can return negative values, so its result should
be assigned to signed variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
This patch modifies the id and name of external connector with the
additional prefix to clarify both attribute and meaning of external
connector as following:
- EXTCON_CHG_* mean the charger connector.
- EXTCON_JACK_* mean the jack connector.
- EXTCON_DISP_* mean the display port connector.
Following table show the new name of external connector with old name:
Old extcon name | New extcon name |
EXTCON_TA | EXTCON_CHG_USB_DCP |
EXTCON_CHARGE_DOWNSTREAM| EXTCON_CHG_USB_CDP |
EXTCON_FAST_CHARGER | EXTCON_CHG_USB_FAST |
EXTCON_SLOW_CHARGER | EXTCON_CHG_USB_SLOW |
EXTCON_MICROPHONE | EXTCON_JACK_MICROPHONE |
EXTCON_HEADPHONE | EXTCON_JACK_HEADPHONE |
EXTCON_LINE_IN | EXTCON_JACK_LINE_IN |
EXTCON_LINE_OUT | EXTCON_JACK_LINE_OUT |
EXTCON_VIDEO_IN | EXTCON_JACK_VIDEO_IN |
EXTCON_VIDEO_OUT | EXTCON_JACK_VIDEO_OUT |
EXTCON_SPDIF_IN | EXTCON_JACK_SPDIF_IN |
EXTCON_SPDIF_OUT | EXTCON_JACK_SPDIF_OUT |
EXTCON_HMDI | EXTCON_DISP_HDMI |
EXTCON_MHL | EXTCON_DISP_MHL |
EXTCON_DVI | EXTCON_DISP_DVI |
EXTCON_VGA | EXTCON_DISP_VGA |
And, when altering the name of USB charger connector, EXTCON refers to the
"Battery Charging v1.2 Spec and Adopters Agreement"[1] to use the standard
name of USB charging port as following. Following name of USB charging port
are already used in power_supply subsystem. We chan check it on patch[2].
- EXTCON_CHG_USB_SDP /* Standard Downstream Port */
- EXTCON_CHG_USB_DCP /* Dedicated Charging Port */
- EXTCON_CHG_USB_CDP /* Charging Downstream Port */
- EXTCON_CHG_USB_ACA /* Accessory Charger Adapter */
[1] www.usb.org/developers/docs/devclass_docs/BCv1.2_070312.zip
[2] commit 85efc8a18ced ("power_supply: Add types for USB chargers")
[ckeepax: For the Arizona changes]
Reviewed-by: Roger Quadros <rogerq@ti.com>
'enum extcon' type
This patch just redefine the unique id of supported external connectors without
'enum extcon' type. Because unique id would be used on devictree file(*.dts) to
indicate the specific external connectors like key number of input framework.
So, I have the plan to move this definitions to following header file which
includes the unique id of supported external connectors.
- include/dt-bindings/extcon/extcon.h
Fixes: 2a9de9c0f08d ("extcon: Use the unique id for external connector instead of string")
This patch uses the unique id to identify the type of external connector instead
of string name. The string name have the many potential issues. So, this patch
defines the 'extcon' enumeration which includes all supported external connector
on EXTCON subsystem. If new external connector is necessary, the unique id of
new connector have to be added in 'extcon' enumeration. There are current
supported external connector in 'enum extcon' as following:
enum extcon {
EXTCON_NONE = 0x0,
/* USB external connector */
EXTCON_USB = 0x1,
EXTCON_USB_HOST = 0x2,
/* Charger external connector */
EXTCON_TA = 0x10,
EXTCON_FAST_CHARGER = 0x11,
EXTCON_SLOW_CHARGER = 0x12,
EXTCON_CHARGE_DOWNSTREAM = 0x13,
/* Audio and video external connector */
EXTCON_LINE_IN = 0x20,
EXTCON_LINE_OUT = 0x21,
EXTCON_MICROPHONE = 0x22,
EXTCON_HEADPHONE = 0x23,
EXTCON_HDMI = 0x30,
EXTCON_MHL = 0x31,
EXTCON_DVI = 0x32,
EXTCON_VGA = 0x33,
EXTCON_SPDIF_IN = 0x34,
EXTCON_SPDIF_OUT = 0x35,
EXTCON_VIDEO_IN = 0x36,
EXTCON_VIDEO_OUT = 0x37,
/* Miscellaneous external connector */
EXTCON_DOCK = 0x50,
EXTCON_JIG = 0x51,
EXTCON_MECHANICAL = 0x52,
EXTCON_END,
For example in extcon-arizona.c:
To use unique id removes the potential issue about handling
the inconsistent name of external connector with string.
- Previously, use the string to register the type of arizona jack connector
static const char *arizona_cable[] = {
"Mechanical",
"Microphone",
"Headphone",
"Line-out",
- Newly, use the unique id to register the type of arizona jack connector
static const enum extcon arizona_cable[] = {
EXTCON_MECHANICAL,
EXTCON_MICROPHONE,
EXTCON_HEADPHONE,
EXTCON_LINE_OUT,
EXTCON_NONE,
And this patch modify the prototype of extcon_{get|set}_cable_state_() which
uses the 'enum extcon id' instead of 'cable_index'. Because although one more
extcon drivers support USB cable, each extcon driver might has the differnt
'cable_index' for USB cable. All extcon drivers can use the unique id number
for same external connector with modified extcon_{get|set}_cable_state_().
- Previously, use 'cable_index' on these functions:
extcon_get_cable_state_(struct extcon_dev*, int cable_index)
extcon_set_cable_state_(struct extcon_dev*, int cable_index, bool state)
-Newly, use 'enum extcon id' on these functions:
extcon_get_cable_state_(struct extcon_dev*, enum extcon id)
extcon_set_cable_state_(struct extcon_dev*, enum extcon id, bool state)
Cc: Felipe Balbi <balbi@ti.com>
Acked-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com>
[arnd: Report the build break about drivers/usb/phy/phy-tahvo.c after using the
unique id for external connector insteadf of string]
[dan.carpenter: Report the build warning of extcon_{set|get}_cable_state_()]
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This patch removes the optional name of extcon device. Instead,
extcon_dev_register() set the device name as 'extcon[number]' naming pattern.
- /sys/class/extcon/[hardcoded device name] -> /sys/class/extcon/extcon[number]
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: Graeme Gregory <gg@slimlogic.co.uk>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Jaewon Kim <jaewon02.kim@samsung.com>
This patch change the name of various jig cables as 'JIG' because the name of
various jig cables are strange and ambiguous on user-space aspect. They include
the different information of either USB and UART state. It is never important
for user-space process. This patch unifies the name of jig cables as following:
- JIG-USB-ON -->|--> JIG
- JIG-USB-OFF -->|
- JIG-UART-ON -->|
- JIG-UART-OFF -->|
This patch fixes the checkpatch warning about coding style.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver update for 3.19-rc1
Lots of little things all over the place in different drivers, and a
new subsystem, "coresight" has been added. Full details are in the
shortlog"
* tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits)
parport: parport_pc, do not remove parent devices early
spmi: Remove shutdown/suspend/resume kernel-doc
carma-fpga-program: drop videobuf dependency
carma-fpga: drop videobuf dependency
carma-fpga-program.c: fix compile errors
i8k: Fix temperature bug handling in i8k_get_temp()
cxl: Name interrupts in /proc/interrupt
CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning
coresight-replicator: remove .owner field for driver
coresight: fixed comments in coresight.h
coresight: fix typo in comment in coresight-priv.h
coresight: bindings for coresight drivers
coresight: Adding ABI documentation
w1: support auto-load of w1_bq27000 module.
w1: avoid potential u16 overflow
cn: verify msg->len before making callback
mei: export fw status registers through sysfs
mei: read and print all six FW status registers
mei: txe: add cherrytrail device id
mei: kill cached host and me csr values
Fix a typo in name of company in copyright comment.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The site-specific OOM messages are unnecessary, because they
duplicate the MM subsystem generic OOM message. The following
checkpatch warning is also removed.
WARNING: Possible unnecessary 'out of memory' message
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
[Acked by Charles Keepax for arizona part]
This patch use devm_extcon_dev_allocate() to simplify the memory control
of extcon device.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Use the resource-managed extcon device register function (i.e.
devm_extcon_dev_register()) instead of extcon_dev_register(). If extcon device
is attached with this function, that extcon device is automatically unregistered
on driver detach. That reduces tiresome managing code.
Signed-off-by: Sangjung Woo <sangjung.woo@samsung.com>
The regmap_irq_get_virq may return 0 or -EINVAL on error. Fail the probe
in both situations.
Cc: <stable@vger.kernel.org>
In probe the driver queued delayed work for cable detection and
returned the result of queue_delayed_work() call. However the return
value of queue_delayed_work() does not indicate an error and in normal
condition it returns true which means successful work queue.
This effectively resulted in probe failure:
[ 2.088204] max14577-muic: probe of max77836-muic failed with error 1
Fixes: 962e56bfcf0b ("extcon: max14577: Add extcon-max14577 driver...")
Add support for MAX77836 chipset to the max14577 extcon driver. The
MAX77836 MUIC has additional interrupts (VIDRM, ADC1K) so IRQ handling
is split up into two functions: max14577_parse_irq() and
max77836_parse_irq().
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
Tested-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
This patch continues the preparation for adding support for max77836
device to existing max14577 driver.
During probe choose muic_irqs according to device type. Currently there
are only "max14577_muic_irqs" but later patch will add max77836
interrupts.
Add max14577 prefix to muic_irqs array. This prepares for max77836
support in this extcon driver.
device type
This patch use device name to make sysfs path according to device type:
max14577-muic
- /sys/class/extcon/max14577-muic/
max77836-muic
- /sys/class/extcon/max77836-muic/
This patch supports Maxim MAX14577 MUIC(Micro USB Interface Controller)
device by using EXTCON subsystem to handle various external connectors.
The max14577 device uses regmap method for i2c communication and
supports irq domain.
