path: root/drivers/dma
2017-03-22dmaengine: iota: ioat_alloc_chan_resources should not perform sleeping ↵Krister Johansen
allocations. commit 21d25f6a4217e755906cb548b55ddab39d0e88b9 upstream. On a kernel with DEBUG_LOCKS, ioat_free_chan_resources triggers an in_interrupt() warning. With PROVE_LOCKING, it reports detecting a SOFTIRQ-safe to SOFTIRQ-unsafe lock ordering in the same code path. This is because dma_generic_alloc_coherent() checks if the GFP flags permit blocking. It allocates from different subsystems if blocking is permitted. The free path knows how to return the memory to the correct allocator. If GFP_KERNEL is specified then the alloc and free end up going through cma_alloc(), which uses mutexes. Given that ioat_free_chan_resources() can be called in interrupt context, ioat_alloc_chan_resources() must specify GFP_NOWAIT so that the allocations do not block and instead use an allocator that uses spinlocks. Signed-off-by: Krister Johansen <kjlx@templeofstupid.com> Acked-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-15dmaengine: imx-sdma - correct the dma transfer residue calculationNandor Han
commit 85f57752b33cf12f1d583f0c10b752292de00abe upstream. The residue calculation was taking in consideration that dma transaction status will be always retrieved in the dma callback used to inform that dma transfer is complete. However this is not the case for all subsystems that use dma. Some subsystems use a timer to check the dma status periodically. Therefore the calculation was updated and residue is calculated accordingly by a) update the residue calculation taking in consideration the last used buffer index by using *buf_ptail* variable and b) chn_real_count (number of bytes transferred) is initialized to zero, when dma channel is created, to avoid using an uninitialized value in residue calculation when dma status is checked without waiting dma complete event. Signed-off-by: Nandor Han <nandor.han@ge.com> Acked-by: Peter Senna Tschudin <peter.senna@collabora.com> Tested-by: Peter Senna Tschudin <peter.senna@collabora.com> Tested-by: Marek Vasut <marex@denx.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Cc: Fabio Estevam <festevam@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12dmaengine: ipu: Make sure the interrupt routine checks all interrupts.Magnus Lilja
commit adee40b265d7568296e218f079f478197ffa15bf upstream. Commit 3d8cc00073d6 ("dmaengine: ipu: Consolidate duplicated irq handlers") consolidated the two interrupts routines into one, but the remaining interrupt routine only checks the status of the error interrupts, not the normal interrupts. This patch fixes that problem (tested on i.MX31 PDK board). Fixes: 3d8cc00073d6 ("dmaengine: ipu: Consolidate duplicated irq handlers") Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09dmaengine: cppi41: Fix oops in cppi41_runtime_resumeTony Lindgren
commit 362f4562466c3b9490e733e06999025638310d4a upstream. Commit fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") together with recent MUSB changes allowed USB and DMA on BeagleBone to idle when no cable is connected. But looks like few corner case issues still remain. Looks like just by re-plugging USB cable about ten or so times on BeagleBone when configured in USB peripheral mode we can get warnings and eventually trigger an oops in cppi41 DMA: WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:1154 cppi41_runtime_suspend+ x28/0x38 [cppi41] ... WARNING: CPU: 0 PID: 14 at drivers/dma/cppi41.c:452 push_desc_queue+0x94/0x9c [cppi41] ... Unable to handle kernel NULL pointer dereference at virtual address 00000104 pgd = c0004000 [00000104] *pgd=00000000 Internal error: Oops: 805 [#1] SMP ARM ... [<bf0d92cc>] (cppi41_runtime_resume [cppi41]) from [<c0589838>] (__rpm_callback+0xc0/0x214) [<c0589838>] (__rpm_callback) from [<c05899ac>] (rpm_callback+0x20/0x80) [<c05899ac>] (rpm_callback) from [<c0589460>] (rpm_resume+0x504/0x78c) [<c0589460>] (rpm_resume) from [<c058a1a0>] (pm_runtime_work+0x60/0xa8) [<c058a1a0>] (pm_runtime_work) from [<c0156120>] (process_one_work+0x2b4/0x808) This is because of a race with runtime PM and cppi41_dma_issue_pending() as reported by Alexandre Bailon <abailon@baylibre.com> in earlier set of patches. Based on mailing list discussions we however came to the conclusion that a different fix from Alexandre's fix is needed in order to guarantee that DMA is really active when we try to use it. To fix the issue, we need to add a driver specific flag as we otherwise can have -EINPROGRESS state set by runtime PM and can't rely on pm_runtime_active() to tell us when we can use the DMA. And we need to make sure the DMA transfers get triggered in the queued order. So let's always queue the transfers, then flush the queue from both cppi41_dma_issue_pending() and cppi41_runtime_resume() as suggested by Grygorii Strashko <grygorii.strashko@ti.com> in an earlier example patch. For reference, this is also documented in Documentation/power/runtime_pm.txt in the example at the end of the file as pointed out by Grygorii Strashko <grygorii.strashko@ti.com>. Based on earlier patches from Alexandre Bailon <abailon@baylibre.com> and Grygorii Strashko <grygorii.strashko@ti.com> modified based on testing and what was discussed on the mailing lists. Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Bin Liu <b-liu@ti.com> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Kevin Hilman <khilman@baylibre.com> Cc: Patrick Titiano <ptitiano@baylibre.com> Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Reported-by: Alexandre Bailon <abailon@baylibre.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Bin Liu <b-liu@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09dmaengine: cppi41: Fix runtime PM timeouts with USB mass storageTony Lindgren
commit ae4a3e028bb8b59e7cfeb0cc9ef03d885182ce8b upstream. Commit fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") added runtime PM support for cppi41, but had corner case issues. Some of the issues were fixed with commit 098de42ad670 ("dmaengine: cppi41: Fix unpaired pm runtime when only a USB hub is connected"). That fix however caused a new regression where we can get error -115 messages with USB on BeagleBone when connecting a USB mass storage device to a hub. This is because when connecting a USB mass storage device to a hub, the initial DMA transfers can take over 200ms to complete and cppi41 autosuspend delay times out. To fix the issue, we want to implement refcounting for chan_busy array that contains the active dma transfers. Increasing the autosuspend delay won't help as that the delay could be potentially seconds, and it's best to let the USB subsystem to deal with the timeouts on errors. The earlier attempt for runtime PM was buggy as the pm_runtime_get/put() calls could get unpaired easily as they did not follow the state of the chan_busy array as described in commit 098de42ad670 ("dmaengine: cppi41: Fix unpaired pm runtime when only a USB hub is connected". Let's fix the issue by adding pm_runtime_get() to where a new transfer is added to the chan_busy array, and calls to pm_runtime_put() where chan_busy array entry is cleared. This prevents any autosuspend timeouts from happening while dma transfers are active. Fixes: 098de42ad670 ("dmaengine: cppi41: Fix unpaired pm runtime when only a USB hub is connected") Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Bin Liu <b-liu@ti.com> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Kevin Hilman <khilman@baylibre.com> Cc: Patrick Titiano <ptitiano@baylibre.com> Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Bin Liu <b-liu@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26dmaengine: pl330: Fix runtime PM support for terminated transfersMarek Szyprowski
commit 5c9e6c2b2ba3ec3a442e2fb5b4286498f8b4dcb7 upstream. PL330 DMA engine driver is leaking a runtime reference after any terminated DMA transactions. This patch fixes this issue by tracking runtime PM state of the device and making additional call to pm_runtime_put() in terminate_all callback if needed. Fixes: ae43b3289186 ("ARM: 8202/1: dmaengine: pl330: Add runtime Power Management support v12") Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26dmaengine: rcar-dmac: unmap slave resource when channel is freedNiklas Söderlund
commit 3139dc8ded6f27552a248d23fe9f086e3027fa12 upstream. The slave mapping should be removed together with other channel resources when the channel is freed. If it's not unmapped it will hang around forever after the channel is freed. Fixes: 9f878603dbdb7db3 ("dmaengine: rcar-dmac: add iommu support for slave transfers") Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19dmaengine: omap-dma: Fix dynamic lch_map allocationPeter Ujfalusi
commit 836c3ce2566fb8c1754f8d7c9534cad9bc8a6879 upstream. The original patch did not done what it was supposed to be doing and even worst it broke legacy boot (OMAP1). The lch_map size should be the number of available logical channels in sDMA and the od->dma_requests should store the number of available DMA request lines usable in sDMA. In legacy mode we do not have a way to get the DMA request count, in that case we use OMAP_SDMA_REQUESTS (127), despite the fact that OMAP1510 have only 31 DMA request line. Fixes: 2d1a9a946fae ("dmaengine: omap-dma: Dynamically allocate memory for lch_map") Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-17dmaengine: cppi41: More PM runtime fixesTony Lindgren
Fix use of u32 instead of int for checking for negative errors values as pointed out by Dan Carpenter <dan.carpenter@oracle.com>. And while testing the PM runtime error path by randomly returning failed values in runtime resume, I noticed two more places that need fixing: - If pm_runtime_get_sync() fails in probe, we still need to do pm_runtime_put_sync() to keep the use count happy. We could call pm_runtime_put_noidle() on the error path, but we're just going to call pm_runtime_disable() after that so pm_runtime_put_sync() will do what we want - We should print an error if pm_runtime_get_sync() fails in cppi41_dma_alloc_chan_resources() so we know where it happens Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 740b4be3f742 ("dmaengine: cpp41: Fix handling of error path") Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-11-14dmaengine: cpp41: Fix handling of error pathTony Lindgren
If we return early on pm_runtime_get() error, we need to also call pm_runtime_put_noidle() as pointed out in a musb related thread by Johan Hovold <johan@kernel.org>. This is to keep the PM runtime use counts happy. Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") Cc: Johan Hovold <johan@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-11-14dmaengine: cppi41: Fix unpaired pm runtime when only a USB hub is connectedTony Lindgren
On am335x with musb host we can end up with unpaired pm runtime calls if a hub with no devices is connected and disconnected. This is because of the conditional pm runtime calls which are always a bad idea. Let's fix the issue by making them unconditional and paired in each function. Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-11-14dmaengine: cppi41: Fix list not empty warning on module removalTony Lindgren
If musb controller is configured with USB peripherals and we have enumerated with a USB host, we can get warnings on removal of the modules: WARNING: CPU: 0 PID: 1269 at drivers/dma/cppi41.c:391 cppi41_dma_free_chan_resources Fix the issue by adding the missing pm_runtime_get to cppi41_dma_free_chan_resources to make sure the pending work list is cleared on removal. Fixes: fdea2d09b997 ("dmaengine: cppi41: Add basic PM runtime support") Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-11-14dmaengine: sun6i: fix the uninitialized value for v_lliAxl-zhang
dma_pool_alloc does not initialize the value of the newly allocated block for the v_lli, and the uninitilize value make the tests failed which is on pine64 with dmatest. we can fix it just change the "|=" to "=" for the v_lli->cfg. Signed-off-by: Hao Zhang <hao5781286@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-10-18dmaengine: mmp_tdma: add missing select GENERIC_ALLOCATOR in KconfigJérémy Lefaure
There are some compilation errors when CONFIG_MMP_TDMA is enabled and CONFIG_GENERIC_ALLOCATOR is disabled: drivers/built-in.o: In function `mmp_tdma_prep_dma_cyclic': mmp_tdma.c:(.text+0x7890e): undefined reference to `gen_pool_dma_alloc' drivers/built-in.o: In function `mmp_tdma_free_chan_resources': mmp_tdma.c:(.text+0x78aca): undefined reference to `gen_pool_free' drivers/built-in.o: In function `mmp_tdma_probe': mmp_tdma.c:(.text+0x78ea8): undefined reference to `of_gen_pool_get' This commit fix this problem by selecting GENERIC_ALLOCATOR when CONFIG_MMP_TDMA is enabled. Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-10-18dmaengine: edma: Fix error return code in edma_alloc_chan_resources()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-10-06Merge tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This is bit large pile of code which bring in some nice additions: - Error reporting: we have added a new mechanism for users of dmaenegine to register a callback_result which tells them the result of the dma transaction. Right now only one user (ntb) is using it. - As we discussed on KS mailing list and pointed out NO_IRQ has no place in kernel, this also remove NO_IRQ from dmaengine subsystem (both arm and ppc users) - Support for IOMMU slave transfers and its implementation for arm. - To get better build coverage, enable COMPILE_TEST for bunch of driver, and fix the warning and sparse complaints on these. - Apart from above, usual updates spread across drivers" * tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (169 commits) async_pq_val: fix DMA memory leak dmaengine: virt-dma: move function declarations dmaengine: omap-dma: Enable burst and data pack for SG DT: dmaengine: rcar-dmac: document R8A7743/5 support dmaengine: fsldma: Unmap region obtained by of_iomap dmaengine: jz4780: fix resource leaks on error exit return dma-debug: fix ia64 build, use PHYS_PFN dmaengine: coh901318: fix integer overflow when shifting more than 32 places dmaengine: edma: avoid uninitialized variable use dma-mapping: fix m32r build warning dma-mapping: fix ia64 build, use PHYS_PFN dmaengine: ti-dma-crossbar: enable COMPILE_TEST dmaengine: omap-dma: enable COMPILE_TEST dmaengine: edma: enable COMPILE_TEST dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usage dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameter dmaengine/ARM: omap-dma: Fix the DMAengine compile test on non OMAP configs dmaengine: edma: Rename set_bits and remove unused clear_bits helper dmaengine: edma: Use correct type for of_find_property() third parameter dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC) ...
2016-10-03Merge branch 'topic/unmap_cleanup' into for-linusVinod Koul
2016-10-03Merge branch 'topic/tegra' into for-linusVinod Koul
2016-10-03Merge branch 'topic/ste_dma40' into for-linusVinod Koul
2016-10-03Merge branch 'topic/pl330' into for-linusVinod Koul
2016-10-03Merge branch 'topic/omap' into for-linusVinod Koul
2016-10-03Merge branch 'topic/no_irq' into for-linusVinod Koul
2016-10-03Merge branch 'topic/mv_xor' into for-linusVinod Koul
2016-10-03Merge branch 'topic/k3' into for-linusVinod Koul
2016-10-03Merge branch 'topic/iommu' into for-linusVinod Koul
2016-10-03Merge branch 'topic/ioatdma' into for-linusVinod Koul
2016-10-03Merge branch 'topic/imx' into for-linusVinod Koul
2016-10-03Merge branch 'topic/hsu' into for-linusVinod Koul
2016-10-03Merge branch 'topic/err_reporting' into for-linusVinod Koul
Signed-off-by: Vinod Koul <vinod.koul@intel.com> Conflicts: drivers/dma/cppi41.c
2016-10-03Merge branch 'topic/dmatest' into for-linusVinod Koul
2016-10-03Merge branch 'topic/cppi' into for-linusVinod Koul
2016-10-03Merge branch 'topic/core' into for-linusVinod Koul
2016-10-03Merge branch 'topic/compile_test' into for-linusVinod Koul
2016-10-01dmaengine: virt-dma: move function declarationsBaoyou Xie
We get 2 warnings when building kernel with W=1: drivers/dma/virt-dma.c:22:14: warning: no previous prototype for 'vchan_tx_submit' [-Wmissing-prototypes] drivers/dma/virt-dma.c:52:5: warning: no previous prototype for 'vchan_tx_desc_free' [-Wmissing-prototypes] In fact, these two functions are incorrectly declared in a function. So this patch moves function declarations out of this function. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-10-01dmaengine: omap-dma: Enable burst and data pack for SGMisael Lopez Cruz
Enable the burst and data pack modes for the scatter-gather in order to improve the throughput of the data transfers. The improvement has been verified with MMC HS200 mode in the DRA72 EVM using the iozone tool to compare the read throughput (in kB/s) with and without burst/pack for different reclens (in kB). With reclen Baseline sDMA burst/pack ------ -------- --------------- 64 46568 50820 128 57564 63413 256 65634 74937 512 72427 83483 1024 74563 84504 2048 76265 86079 4096 78045 87335 8192 78989 88154 16384 81265 91034 Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-30dmaengine: fsldma: Unmap region obtained by of_iomapArvind Yadav
Free memory mapping, if probe is not successful. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Acked-by: Li Yang <leoyang.li@nxp.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-30dmaengine: jz4780: fix resource leaks on error exit returnColin Ian King
In two cases when jz4780_dma_setup_hwdesc fails, there is a memory leak on the allocated desc and associated DMA pools on the error exit return path. Fix this by free'ing the resources before returning. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-30dmaengine: coh901318: fix integer overflow when shifting more than 32 placesColin Ian King
Currently U300_DMA_CHANNELS is set to 40, meaning that the shift of 1 can be more than 32 places, which leads to a 32 bit integer overflow. Fix this by using 1ULL instead of 1 before shifting it. Also add braces on the for-loop to keep with coding style conventions. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-30dmaengine: edma: avoid uninitialized variable useArnd Bergmann
If edma_read_slot() gets an invalid argument, it does not set a result, as found by "gcc -Wmaybe-uninitialized" drivers/dma/edma.c: In function 'dma_ccerr_handler': drivers/dma/edma.c:1499:21: error: 'p.a_b_cnt' may be used uninitialized in this function [-Werror=maybe-uninitialized] drivers/dma/edma.c:1499:21: error: 'p.ccnt' may be used uninitialized in this function [-Werror=maybe-uninitialized] if (p.a_b_cnt == 0 && p.ccnt == 0) { If we change the function to return an error in this case, we can handle the failure more gracefully and treat this the same way as a null slot that we already catch. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: ti-dma-crossbar: enable COMPILE_TESTPeter Ujfalusi
To get more coverage, enable COMPILE_TEST for this driver. When compile testing eDMA or omap-dma, select also the ti-dma-crossbar so it is also covered by the compile testing. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: omap-dma: enable COMPILE_TESTPeter Ujfalusi
To get more coverage, enable COMPILE_TEST for this driver. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: edma: enable COMPILE_TESTPeter Ujfalusi
2016-09-28dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usagePeter Ujfalusi
Use pointers to static constant variables for crossbar type and for DMA offset configuration. Fixes compiler warnings on 64bit architectures: drivers/dma/ti-dma-crossbar.c: In function ‘ti_dra7_xbar_probe’: drivers/dma/ti-dma-crossbar.c:398:21: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] xbar->dma_offset = (u32)match->data; ^ drivers/dma/ti-dma-crossbar.c: In function ‘ti_dma_xbar_probe’: drivers/dma/ti-dma-crossbar.c:431:10: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] switch ((u32)match->data) { ^ Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameterPeter Ujfalusi
The correct type is int and not for the third parameter of of_find_property(). Fixes compilation for 64bit architectures (x86_64, aarch64). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: edma: Rename set_bits and remove unused clear_bits helperPeter Ujfalusi
The clear_bits() helper is not used by the driver so it can be removed. powerpc architecture defines the set_bits() in arch/powerpc/include/asm/bitops.h which results failed compile testing on powerpc architecture: >> drivers/dma/edma.c:415:20: error: conflicting types for 'set_bits' static inline void set_bits(int offset, int len, unsigned long *p) ^~~~~~~~ In file included from include/linux/bitops.h:36:0, from include/linux/kernel.h:10, from include/linux/list.h:8, from include/linux/kobject.h:20, from include/linux/device.h:17, from include/linux/dmaengine.h:20, from drivers/dma/edma.c:16: arch/powerpc/include/asm/bitops.h:75:14: note: previous definition of 'set_bits' was here DEFINE_BITOP(set_bits, or, "") ^ arch/powerpc/include/asm/bitops.h:58:24: note: in definition of macro 'DEFINE_BITOP' static __inline__ void fn(unsigned long mask, \ ^~ >> drivers/dma/edma.c:421:20: error: conflicting types for 'clear_bits' static inline void clear_bits(int offset, int len, unsigned long *p) ^~~~~~~~~~ In file included from include/linux/bitops.h:36:0, from include/linux/kernel.h:10, from include/linux/list.h:8, from include/linux/kobject.h:20, from include/linux/device.h:17, from include/linux/dmaengine.h:20, from drivers/dma/edma.c:16: arch/powerpc/include/asm/bitops.h:76:14: note: previous definition of 'clear_bits' was here DEFINE_BITOP(clear_bits, andc, "") ^ arch/powerpc/include/asm/bitops.h:58:24: note: in definition of macro 'DEFINE_BITOP' static __inline__ void fn(unsigned long mask, \ ^~ Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: edma: Use correct type for of_find_property() third parameterPeter Ujfalusi
2016-09-28dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC)Peter Ujfalusi
Use pointers to static constant variables for eDMA binding type (legacy vs TPCC). Fixes the following warning when compiling the driver for 64bit architectures (x86_64 for example): drivers/dma/edma.c:2185:16: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] if (match && (u32)match->data == EDMA_BINDING_TPCC) ^ Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-28dmaengine: edma: Add missing MODULE_DEVICE_TABLE() for of_device_id structsPeter Ujfalusi
The MODULE_DEVICE_TABLE() were missing from the driver for the of_device_id structures. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-27dmaengine: tegra-adma: enable COMPILE_TESTVinod Koul
To get more coverage, enable COMPILE_TEST for this driver. Suggested-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-09-26dmaengine: sun6i: Add support for Allwinner A83T (sun8i) variantJean-Francois Moine
The A83T SoC has the same dma engine as the A31 (sun6i), with a reduced amount of endpoints and physical channels. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
