path: root/drivers/dma/dmaengine.c
2015-06-12dmaengine: Fix choppy sound because of unimplemented resumeKrzysztof Kozlowski
Some drivers implement only pause operation (no resuming). Example is pl330 where pause is needed for getting residuum. pl330 does not support resume operation, transfer must be stopped after pause. However for slaves this is exposed always as "pause and resume" which introduces subtle errors on Odroid U3 board (Exynos4412 with pl330). After adding pause function to pl330 driver the audio playback (utilizing DMA) gets choppy after some time (approximately 24 hours). Fix this by exposing "cmd_pause" if and only if pause and resume are implemented. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reported-by: gabriel@unseen.is Reported-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: <stable@vger.kernel.org> Fixes: 88987d2c7534 ("dmaengine: pl330: add DMA_PAUSE feature") Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-29dmaengine: increment privatecnt when using dma_get_any_slave_channelChristopher Freeman
Channels allocated via dma_get_any_slave_channel were not increasing the counter tracking private allocations. When these channels were released, privatecnt may erroneously fall to zero. The DMA device would then lose its DMA_PRIVATE cap and fail to allocate future private channels (via private_candidate) as any allocations still outstanding would incorrectly be seen as public allocations. Signed-off-by: Christopher Freeman <cfreeman@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-04-24Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: - new drivers for: - Ingenic JZ4780 controller - APM X-Gene controller - Freescale RaidEngine device - Renesas USB Controller - remove device_alloc_chan_resources dummy handlers - sh driver cleanups for peri peri and related emmc and asoc patches as well - fixes and enhancements spread over the drivers * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits) dmaengine: dw: don't prompt for DW_DMAC_CORE dmaengine: shdmac: avoid unused variable warnings dmaengine: fix platform_no_drv_owner.cocci warnings dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe() dmaengine: at_xdmac: unlock spin lock before return dmaengine: xgene: devm_ioremap() returns NULL on error dmaengine: xgene: buffer overflow in xgene_dma_init_channels() dmaengine: usb-dmac: Fix dereferencing freed memory 'desc' dmaengine: sa11x0: report slave capabilities to upper layers dmaengine: vdma: Fix compilation warnings dmaengine: fsl_raid: statify fsl_re_chan_probe dmaengine: Driver support for FSL RaidEngine device. dmaengine: xgene_dma_init_ring_mngr() can be static Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes dmaengine: Add support for APM X-Gene SoC DMA engine driver dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver dmaengine: renesas,usb-dmac: Add device tree bindings documentation dmaengine: edma: fixed wrongly initialized data parameter to the edma callback dmaengine: ste_dma40: fix implicit conversion ...
2015-04-11Revert "dmaengine: Add a warning for drivers not using the generic slave ↵Linus Torvalds
caps retrieval" This reverts commit ecc19d17868be9c9f8f00ed928791533c420f3e0. It added a new warning to try to encourage driver writers to set the device capabities properly, but drivers haven't been updated and in the meantime it just generaters a scary message that users cannot actually do anything about. Warnings like these are appropriate if you actually expect to fix the code that causes them. They are not appropriate for releases. Requested-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-16dmaengine: Remove FSF mailing addressesJarkko Nikula
Free Software Foundation mailing address has been moved in the past and some of the addresses here are outdated. Remove them from file headers since the COPYING file in the kernel sources includes it. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-03-05dmaengine: Remove net_dma_find_channelMaxime Ripard
Since commit 7bced397510a ("net_dma: simple removal") removed the net_dma support entirely, net_dma_find_channel has no users left. Remove the function entirely. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-01-18dmaengine: Move dma_get_slave_caps() implementation to dmaengine.cLaurent Pinchart
The function is too big to be a static inline. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-12-22dmaengine: Add a warning for drivers not using the generic slave caps retrievalMaxime Ripard
For the slave caps retrieval to be really useful, most drivers need to implement it. Hence, we need to be slightly more aggressive, and trigger a warning at registration time for drivers that don't fill their caps infos in order to encourage them to implement it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-12-22dmaengine: Remove the need to declare device_controlMaxime Ripard
In order to migrate the drivers without triggering a BUG_ON for the converted drivers, which would cause bisectability issues, we need to remove that check before removing the device_control function entirely. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-12-22dmaengine: Make channel allocation callbacks optionalMaxime Ripard
Nowadays, some drivers don't have anything in there channel allocation callbacks anymore. Remove the BUG_ON if those callbacks aren't implemented, in order to allow drivers to not implement them. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-12-22dmaengine: Rework dma_chan_getMaxime Ripard
dma_chan_get uses a rather interesting error handling and code path. Change it to something more usual in the kernel. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-12-09dmaenegine: Delete a check before free_percpu()Markus Elfring
The free_percpu() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-10-07Merge tag 'dmaengine-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine updates from Dan Williams: "Even though this has fixes marked for -stable, given the size and the needed conflict resolutions this is 3.18-rc1/merge-window material. These patches have been languishing in my tree for a long while. The fact that I do not have the time to do proper/prompt maintenance of this tree is a primary factor in the decision to step down as dmaengine maintainer. That and the fact that the bulk of drivers/dma/ activity is going through Vinod these days. The net_dma removal has not been in -next. It has developed simple conflicts against mainline and net-next (for-3.18). Continuing thanks to Vinod for staying on top of drivers/dma/. Summary: 1/ Step down as dmaengine maintainer see commit 08223d80df38 "dmaengine maintainer update" 2/ Removal of net_dma, as it has been marked 'broken' since 3.13 (commit 77873803363c "net_dma: mark broken"), without reports of performance regression. 3/ Miscellaneous fixes" * tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net: make tcp_cleanup_rbuf private net_dma: revert 'copied_early' net_dma: simple removal dmaengine maintainer update dmatest: prevent memory leakage on error path in thread ioat: Use time_before_jiffies() dmaengine: fix xor sources continuation dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup() dma: mv_xor: Remove all callers of mv_xor_slot_cleanup() dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call ioat: Use pci_enable_msix_exact() instead of pci_enable_msix() drivers: dma: Include appropriate header file in dca.c drivers: dma: Mark functions as static in dma_v3.c dma: mv_xor: Add DMA API error checks ioat/dca: Use dev_is_pci() to check whether it is pci device
2014-09-28net_dma: simple removalDan Williams
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used and there is no plan to fix it. This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards. Reverting the remainder of the net_dma induced changes is deferred to subsequent patches. Marked for stable due to Roman's report of a memory leak in dma_pin_iovec_pages(): https://lkml.org/lkml/2014/9/3/177 Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: David Whipple <whipple@securedatainnovations.ch> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: <stable@vger.kernel.org> Reported-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-05-21dmaengine: fix dmaengine_unmap failureXuelin Shi
The count which is used to get_unmap_data maybe not the same as the count computed in dmaengine_unmap which causes to free data in a wrong pool. This patch fixes this issue by keeping the map count with unmap_data structure and use this count to get the pool. Cc: <stable@vger.kernel.org> Signed-off-by: Xuelin Shi <xuelin.shi@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-02-11acpi-dma: convert to return error code when asked for channelAndy Shevchenko
Currently acpi_dma_request_slave_chan_by_index() and acpi_dma_request_slave_chan_by_name() return only requested channel or NULL. This patch converts them to return appropriate error code instead of NULL in case of unsuccessfull request. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-23Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This is the branch where we usually queue up cleanup efforts, moving drivers out of the architecture directory, header file restructuring, etc. Sometimes they tangle with new development so it's hard to keep it strictly to cleanups. Some of the things included in this branch are: * Atmel SAMA5 conversion to common clock * Reset framework conversion for tegra platforms - Some of this depends on tegra clock driver reworks that are shared with Mike Turquette's clk tree. * Tegra DMA refactoring, which are shared branches with the DMA tree. * Removal of some header files on exynos to prepare for multiplatform" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits) ARM: mvebu: move Armada 370/XP specific definitions to armada-370-xp.h ARM: mvebu: remove prototypes of non-existing functions from common.h ARM: mvebu: move ARMADA_XP_MAX_CPUS to armada-370-xp.h serial: sh-sci: Rework baud rate calculation serial: sh-sci: Compute overrun_bit without using baud rate algo serial: sh-sci: Remove unused GPIO request code serial: sh-sci: Move overrun_bit and error_mask fields out of pdata serial: sh-sci: Support resources passed through platform resources serial: sh-sci: Don't check IRQ in verify port operation serial: sh-sci: Set the UPF_FIXED_PORT flag serial: sh-sci: Remove duplicate interrupt check in verify port op serial: sh-sci: Simplify baud rate calculation algorithms serial: sh-sci: Remove baud rate calculation algorithm 5 serial: sh-sci: Sort headers alphabetically ARM: EXYNOS: Kill exynos_pm_late_initcall() ARM: EXYNOS: Consolidate selection of PM_GENERIC_DOMAINS for Exynos4 ARM: at91: switch Calao QIL-A9260 board to DT clk: at91: fix pmc_clk_ids data type attriubte PM / devfreq: use inclusion <mach/map.h> instead of <plat/map-s5p.h> ARM: EXYNOS: remove <mach/regs-clock.h> for exynos ...
2014-01-02Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2013-12-26Merge branches 'depends/asoc-dma', 'depends/dma-of' and 'depends/tegra-clk' ↵Olof Johansson
into next/cleanup Merging in external dependencies for the Tegra DMA and reset controller refactoring from external trees. Per Stephen Warren, the stability of these branches have been negotiated with the relevant parties (Vinod/Mark/Mike) * depends/asoc-dma: ASoC: dmaengine: fix deferred probe detection ASoC: dmaengine: support deferred probe for DMA channels dma: add channel request API that supports deferred probe ASoC: dmaengine: add custom DMA config to snd_dmaengine_pcm_config ASoC: don't leak on error in snd_dmaengine_pcm_register ASoC: restructure dmaengine_pcm_request_chan_of() ASoC: generic-dmaengine-pcm: Set BATCH flag when residue reporting is not supported ASoC: Add resource managed snd_dmaengine_pcm_register() * depends/dma-of: dma: add dma_get_any_slave_channel(), for use in of_xlate() * depends/tegra-clk: (42 commits) clk: tegra: fix __clk_lookup() return value checks clk: tegra: Do not print errors for clk_round_rate() clk: tegra: Initialize DSI low-power clocks clk: tegra: add FUSE clock device clk: tegra: Properly setup PWM clock on Tegra30 clk: tegra: Initialize secondary gr3d clock on Tegra30 clk: tegra114: Initialize clocks needed for HDMI clk: tegra124: add suspend/resume function for tegra_cpu_car_ops clk: tegra124: add wait_for_reset and disable_clock for tegra_cpu_car_ops clk: tegra124: Add support for Tegra124 clocks clk: tegra124: Add new peripheral clocks clk: tegra124: Add common clk IDs to clk-id.h clk: tegra: add TEGRA_PERIPH_NO_GATE clk: tegra: add locking to periph clks clk: tegra: Add periph regs bank X clk: tegra: Add support for PLLSS clk: tegra: move tegra20 to common infra clk: tegra: move tegra30 to common infra clk: tegra: introduce common gen4 super clock clk: tegra: move PMC, fixed clocks to common files ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-13dmaengine: fix sleep in atomicDan Williams
BUG: sleeping function called from invalid context at mm/mempool.c:203 in_atomic(): 1, irqs_disabled(): 0, pid: 43502, name: linbug no locks held by linbug/43502. CPU: 7 PID: 43502 Comm: linbug Not tainted 3.13.0-rc1+ #15 Hardware name: 0000000000000010 ffff88005ebd1878 ffffffff8172d512 ffff8801752bc1c0 ffff8801752bc1c0 ffff88005ebd1898 ffffffff8109d1f6 ffff88005f9a3c58 ffff880177f0f080 ffff88005ebd1918 ffffffff81161f43 ffff88005ebd18f8 Call Trace: [<ffffffff8172d512>] dump_stack+0x4e/0x68 [<ffffffff8109d1f6>] __might_sleep+0xe6/0x120 [<ffffffff81161f43>] mempool_alloc+0x93/0x170 [<ffffffff810c0c34>] ? mark_held_locks+0x74/0x140 [<ffffffff8118a826>] ? follow_page_mask+0x556/0x600 [<ffffffff814107ae>] dmaengine_get_unmap_data+0x2e/0x60 [<ffffffff81410f11>] dma_async_memcpy_pg_to_pg+0x41/0x1c0 [<ffffffff814110e0>] dma_async_memcpy_buf_to_pg+0x50/0x60 [<ffffffff81411bdc>] dma_memcpy_to_iovec+0xfc/0x190 [<ffffffff816163af>] dma_skb_copy_datagram_iovec+0x6f/0x2b0 Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-12dmaengine: fix enable for high order unmap poolsDan Williams
The higher order mempools support raid operations, and we want to disable them when raid support is not enabled. Making them conditional on ASYNC_TX_DMA is not sufficient as other users (specifically dmatest) will also issue raid operations. Make raid drivers explicitly request that the core carry the higher order pools. Reported-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-10dma: add dma_get_any_slave_channel(), for use in of_xlate()Stephen Warren
mmp_pdma.c implements a custom of_xlate() function that is 95% identical to what Tegra will need. Create a function to implement the common part, so everyone doesn't just cut/paste the implementation. Cc: Dan Williams <dan.j.williams@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: dmaengine@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-10dma: add channel request API that supports deferred probeStephen Warren
dma_request_slave_channel() simply returns NULL whenever DMA channel lookup fails. Lookup could fail for two distinct reasons: a) No DMA specification exists for the channel name. This includes situations where no DMA specifications exist at all, or other general lookup problems. b) A DMA specification does exist, yet the driver for that channel is not yet registered. Case (b) should trigger deferred probe in client drivers. However, since they have no way to differentiate the two situations, it cannot. Implement new function dma_request_slave_channel_reason(), which performs identically to dma_request_slave_channel(), except that it returns an error-pointer rather than NULL, which allows callers to detect when deferred probe should occur. Eventually, all drivers should be converted to this new API, the old API removed, and the new API renamed to the more desirable name. This patch doesn't convert the existing API and all drivers in one go, since some drivers call dma_request_slave_channel() then dma_request_channel() if that fails. That would require either modifying dma_request_channel() in the same way, or adding extra error-handling code to all affected drivers, and there are close to 100 drivers using the other API, rather than just the 15-20 or so that use dma_request_slave_channel(), which might be tenable in a single patch. acpi_dma_request_slave_chan_by_name() doesn't currently implement deferred probe. It should, but this will be addressed later. Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-16Merge commit 'dmaengine-3.13-v2' of ↵Vinod Koul
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine changes from Dan 1/ Bartlomiej and Dan finalized a rework of the dma address unmap implementation. 2/ In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus for their review. 3/ Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. 4/ Some minor fixes / cleanups to mv_xor and ioatdma. Conflicts: drivers/dma/dmatest.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-14dmaengine: remove DMA unmap flagsBartlomiej Zolnierkiewicz
Remove no longer needed DMA unmap flags: - DMA_COMPL_SKIP_SRC_UNMAP - DMA_COMPL_SKIP_DEST_UNMAP - DMA_COMPL_SRC_UNMAP_SINGLE - DMA_COMPL_DEST_UNMAP_SINGLE Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jon Mason <jon.mason@intel.com> Acked-by: Mark Brown <broonie@linaro.org> [djbw: clean up straggling skip unmap flags in ntb] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_pq: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: keep temporary dma_dest array in do_async_gen_syndrome()] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_memcpy: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: add missing unmap->len initialization] [bzolnier: fix whitespace damage] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [djbw: add DMA_ENGINE=n support] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-13dmaengine: reference counted unmap dataDan Williams
Hang a common 'unmap' object off of dma descriptors for the purpose of providing a unified unmapping interface. The lifetime of a mapping may span multiple descriptors, so these unmap objects are reference counted by related descriptor. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> [bzolnier: fix IS_ENABLED() check] [bzolnier: fix release ordering in dmaengine_destroy_unmap_pool()] [bzolnier: fix check for success in dmaengine_init_unmap_pool()] [bzolnier: use mempool_free() instead of kmem_cache_free()] [bzolnier: add missing unmap->len initializations] [bzolnier: add __init tag to dmaengine_init_unmap_pool()] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [djbw: move DMAENGINE=n support to this patch for async_tx] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-13dmaengine: consolidate memcpy apisDan Williams
Copying from page to page (dma_async_memcpy_pg_to_pg) is the superset, make the other two apis use that one in preparation for providing a common dma unmap implementation. The common implementation just wants to assume all buffers are mapped with dma_map_page(). Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-10-25dmaengine: use DMA_COMPLETE for dma completion statusVinod Koul
the DMA_SUCCESS is a misnomer as dmaengine indicates the transfer is complete and gives no guarantee of the transfer success. Hence we should use DMA_COMPLTE instead of DMA_SUCCESS Acked-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-09-10Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This pull brings: - Andy's DW driver updates - Guennadi's sh driver updates - Pl08x driver fixes from Tomasz & Alban - Improvements to mmp_pdma by Daniel - TI EDMA fixes by Joel - New drivers: - Hisilicon k3dma driver - Renesas rcar dma driver - New API for publishing slave driver capablities - Various fixes across the subsystem by Andy, Jingoo, Sachin etc..." * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits) dma: edma: Remove limits on number of slots dma: edma: Leave linked to Null slot instead of DUMMY slot dma: edma: Find missed events and issue them ARM: edma: Add function to manually trigger an EDMA channel dma: edma: Write out and handle MAX_NR_SG at a given time dma: edma: Setup parameters to DMA MAX_NR_SG at a time dmaengine: pl330: use dma_set_max_seg_size to set the sg limit dmaengine: dma_slave_caps: remove sg entries dma: replace devm_request_and_ioremap by devm_ioremap_resource dma: ste_dma40: Fix potential null pointer dereference dma: ste_dma40: Remove duplicate const dma: imx-dma: Remove redundant NULL check dma: dmagengine: fix function names in comments dma: add driver for R-Car HPB-DMAC dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap() dma: imx-sdma: Staticize sdma_driver_data structures pch_dma: Add MODULE_DEVICE_TABLE dmaengine: PL08x: Add cyclic transfer support dmaengine: PL08x: Fix reading the byte count in cctl dmaengine: PL08x: Add support for different maximum transfer size ...
2013-09-09Merge tag 'dmaengine-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine update from Dan Williams: "Collection of random updates to the core and some end-driver fixups for ioatdma and mv_xor: - NUMA aware channel allocation - Cleanup dmatest debugfs interface - ioat: make raid-support Atom only - mv_xor: big endian Aside from the top three commits these have all had some soak time in -next. The top commit fixes a recent build breakage. It has been a long while since my last pull request, hopefully it does not show. Thanks to Vinod for keeping an eye on drivers/dma/ this past year" * tag 'dmaengine-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: dmaengine: dma_sync_wait and dma_find_channel undefined MAINTAINERS: update email for Dan Williams dma: mv_xor: Fix incorrect error path ioatdma: silence GCC warnings dmaengine: make dma_channel_rebalance() NUMA aware dmaengine: make dma_submit_error() return an error code ioatdma: disable RAID on non-Atom platforms and reenable unaligned copies mv_xor: support big endian systems using descriptor swap feature mv_xor: use {readl, writel}_relaxed instead of __raw_{readl, writel} dmatest: print message on debug level in case of no error dmatest: remove IS_ERR_OR_NULL checks of debugfs calls dmatest: make module parameters writable
2013-09-02Merge branch 'topic/of' into for-linusVinod Koul
2013-09-02dma: dmagengine: fix function names in commentsDaniel Mack
Trivial fix for function name mismatches I stumbled over. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-22dmaengine: make dma_channel_rebalance() NUMA awareBrice Goglin
dma_channel_rebalance() currently distributes channels by processor ID. These IDs often change with the BIOS, and the order isn't related to the DMA channel list (related to PCI bus ids). * On my SuperMicro dual E5 machine, first socket has processor IDs [0-7] (and [16-23] for hyperthreads), second socket has [8-15]+[24-31] => channels are properly allocated to local CPUs. * On Dells R720 with same processors, first socket has even processor IDs, second socket has odd numbers => half the processors get channels on the remote socket, causing cross-NUMA traffic and lower DMA performance. Change nth_chan() to return the channel with min table_count and in the NUMA node of the given CPU, if any. If none, the (non-local) channel with min table_count is returned. nth_chan() is therefore renamed into min_chan() since we don't iterate until the nth channel anymore. In practice, the behavior is the same because first channels are taken first and are then ignored because they got an additional reference. The new code has a slightly higher complexity since we always scan the entire list of channels for finding the minimal table_count (instead of stopping after N chans), and because we check whether the CPU is in the DMA device locality mask. Overall we still have time complexity = number of chans x number of processors. This rebalance is rarely used, so this won't hurt. On the above SuperMicro machine, channels are still allocated the same. On the Dells, there are no locality issue anymore (MEMCPY channel X goes to processor X and to its hyperthread sibling). Signed-off-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: Dan Williams <djbw@fb.com>
2013-08-19dmaengine: fix - error: potential NULL dereference 'chan'Vinod Koul
commit 7bb587f4 "dmaengine: add interface of dma_get_slave_channel" introduced the above error so fix it Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Suggested-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-08-13dmaengine: add interface of dma_get_slave_channelZhangfei Gao
Suggested by Arnd, add dma_get_slave_channel interface Dma host driver could get specific channel specificied by request line, rather than filter. host example: static struct dma_chan *xx_of_dma_simple_xlate(struct of_phandle_args *dma_spec, struct of_dma *ofdma) { struct xx_dma_dev *d = ofdma->of_dma_data; unsigned int request = dma_spec->args[0]; if (request > d->dma_requests) return NULL; return dma_get_slave_channel(&(d->chans[request].vc.chan)); } probe: of_dma_controller_register((&op->dev)->of_node, xx_of_dma_simple_xlate, d); Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-07-25dma: convert dma_devclass to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the dma dma_devclass code to use the correct field. Cc: Dan Williams <djbw@fb.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03drivers/dma: remove unused support for MEMSET operationsBartlomiej Zolnierkiewicz
There have never been any real users of MEMSET operations since they have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine: refactor dmaengine around dma_async_tx_descriptor"). Therefore remove support for them for now, it can be always brought back when needed. [sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Vinod Koul <vinod.koul@intel.com> Acked-by: Dan Williams <djbw@fb.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-02Merge branch 'topic/of' into for-linusVinod Koul
Conflicts: include/linux/dmaengine.h Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dmaengine: call acpi_dma_request_slave_channel as wellAndy Shevchenko
The slave device could be enumerated by ACPI. In that case the dma_request_slave_channel should use the acpi_dma_request_slave_channel() helper. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15DMA: of: Constant namesMarkus Pargmann
No DMA of-function alters the name, so this patch changes the name arguments to be constant. Most drivers will probably request DMA channels using a constant name. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-04-15dma: Make the 'mask' parameter of __dma_request_channel constLars-Peter Clausen
The 'mask' parameter is not modified in __dma_request_channel and really shouldn't be. Make this explicit by making the parameter const. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-02-27dmaengine: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Dan Williams <djbw@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-07dmaengine: add cpu_relax() to busy-loop in dma_sync_wait()Bartlomiej Zolnierkiewicz
Removal of the busy-loop from dma_sync_wait() is not a trivial task so just add cpu_relax() to the loop for now. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <djbw@fb.com>
2013-01-06dmaengine: add helper function to request a slave DMA channelJon Hunter
Currently slave DMA channels are requested by calling dma_request_channel() and requires DMA clients to pass various filter parameters to obtain the appropriate channel. With device-tree being used by architectures such as arm and the addition of device-tree helper functions to extract the relevant DMA client information from device-tree, add a new function to request a slave DMA channel using device-tree. This function is currently a simple wrapper that calls the device-tree of_dma_request_slave_channel() function. Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Russell King <linux@arm.linux.org.uk> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jon Hunter <jon-hunter@ti.com> Reviewed-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-10-06drivers/dma/dmaengine.c: lower the priority of 'failed to get' dma channel ↵Fabio Estevam
message Do the same as commit a03a202e95fd ("dmaengine: failure to get a specific DMA channel is not critical") to get rid of the following messages during kernel boot: dmaengine_get: failed to get dma1chan0: (-22) dmaengine_get: failed to get dma1chan1: (-22) dmaengine_get: failed to get dma1chan2: (-22) dmaengine_get: failed to get dma1chan3: (-22) .. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-20dmaengine: Cleanup logging messagesJoe Perches
Use a more current logging style. Add pr_fmt to prefix dmaengine: to messages. Convert printk(KERN_ERR to pr_err(. Convert embedded function name use to "%s: ", __func__ Align arguments. Original-patch-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-04-10Merge tag 'dmaengine-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine fixes from Dan Williams: 1/ regression fix for Xen as it now trips over a broken assumption about the dma address size on 32-bit builds 2/ new quirk for netdma to ignore dma channels that cannot meet netdma alignment requirements 3/ fixes for two long standing issues in ioatdma (ring size overflow) and iop-adma (potential stack corruption) * tag 'dmaengine-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: netdma: adding alignment check for NETDMA ops ioatdma: DMA copy alignment needed to address IOAT DMA silicon errata ioat: ring size variables need to be 32bit to avoid overflow iop-adma: Corrected array overflow in RAID6 Xscale(R) test. ioat: fix size of 'completion' for Xen
2012-04-05netdma: adding alignment check for NETDMA opsDave Jiang
This is the fallout from adding memcpy alignment workaround for certain IOATDMA hardware. NetDMA will only use DMA engine that can handle byte align ops. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
