git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto update from Herbert Xu:
"API:
- Add support for cipher output IVs in testmgr
- Add missing crypto_ahash_blocksize helper
- Mark authenc and des ciphers as not allowed under FIPS.
Algorithms:
- Add CRC support to 842 compression
- Add keywrap algorithm
- A number of changes to the akcipher interface:
+ Separate functions for setting public/private keys.
+ Use SG lists.
Drivers:
- Add Intel SHA Extension optimised SHA1 and SHA256
- Use dma_map_sg instead of custom functions in crypto drivers
- Add support for STM32 RNG
- Add support for ST RNG
- Add Device Tree support to exynos RNG driver
- Add support for mxs-dcp crypto device on MX6SL
- Add xts(aes) support to caam
- Add ctr(aes) and xts(aes) support to qat
- A large set of fixes from Russell King for the marvell/cesa driver"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (115 commits)
crypto: asymmetric_keys - Fix unaligned access in x509_get_sig_params()
crypto: akcipher - Don't #include crypto/public_key.h as the contents aren't used
hwrng: exynos - Add Device Tree support
hwrng: exynos - Fix missing configuration after suspend to RAM
hwrng: exynos - Add timeout for waiting on init done
dt-bindings: rng: Describe Exynos4 PRNG bindings
crypto: marvell/cesa - use __le32 for hardware descriptors
crypto: marvell/cesa - fix missing cpu_to_le32() in mv_cesa_dma_add_op()
crypto: marvell/cesa - use memcpy_fromio()/memcpy_toio()
crypto: marvell/cesa - use gfp_t for gfp flags
crypto: marvell/cesa - use dma_addr_t for cur_dma
crypto: marvell/cesa - use readl_relaxed()/writel_relaxed()
crypto: caam - fix indentation of close braces
crypto: caam - only export the state we really need to export
crypto: caam - fix non-block aligned hash calculation
crypto: caam - avoid needlessly saving and restoring caam_hash_ctx
crypto: caam - print errno code when hash registration fails
crypto: marvell/cesa - fix memory leak
crypto: marvell/cesa - fix first-fragment handling in mv_cesa_ahash_dma_last_req()
crypto: marvell/cesa - rearrange handling for sw padded hashes
Use the IO memcpy() functions when copying from/to MMIO memory.
These locations were found via sparse.
Use relaxed IO accessors where appropriate.
The mv_cesa_queue_req() function calls crypto_enqueue_request() to
enqueue a request. In the normal case (i.e the queue isn't full), this
function returns -EINPROGRESS. The current Marvell CESA crypto driver
takes this into account and cleans up the request only if an error
occured, i.e if the return value is not -EINPROGRESS.
Unfortunately this causes problems with
CRYPTO_TFM_REQ_MAY_BACKLOG-flagged requests. When such a request is
passed to crypto_enqueue_request() and the queue is full,
crypto_enqueue_request() will return -EBUSY, but will keep the request
enqueued nonetheless. This situation was not properly handled by the
Marvell CESA driver, which was anyway cleaning up the request in such
a situation. When later on the request was taken out of the backlog
and actually processed, a kernel crash occured due to the internal
driver data structures for this structure having been cleaned up.
To avoid this situation, this commit adds a
mv_cesa_req_needs_cleanup() helper function which indicates if the
request needs to be cleaned up or not after a call to
crypto_enqueue_request(). This helper allows to do the cleanup only in
the appropriate cases, and all call sites of mv_cesa_queue_req() are
fixed to use this new helper function.
Reported-by: Vincent Donnefort <vdonnefort@gmail.com>
Fixes: db509a45339fd ("crypto: marvell/cesa - add TDMA support")
Cc: <stable@vger.kernel.org> # v4.2+
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Vincent Donnefort <vdonnefort@gmail.com>
Add support for Triple-DES operations.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Add support for DES operations.
The CESA IP supports CPU offload through a dedicated DMA engine (TDMA)
which can control the crypto block.
When you use this mode, all the required data (operation metadata and
payload data) are transferred using DMA, and the results are retrieved
through DMA when possible (hash results are not retrieved through DMA yet),
thus reducing the involvement of the CPU and providing better performances
in most cases (for small requests, the cost of DMA preparation might
exceed the performance gain).
Note that some CESA IPs do not embed this dedicated DMA, hence the
activation of this feature on a per platform basis.
The existing mv_cesa driver supports some features of the CESA IP but is
quite limited, and reworking it to support new features (like involving the
TDMA engine to offload the CPU) is almost impossible.
This driver has been rewritten from scratch to take those new features into
account.
This commit introduce the base infrastructure allowing us to add support
for DMA optimization.
It also includes support for one hash (SHA1) and one cipher (AES)
algorithm, and enable those features on the Armada 370 SoC.
Other algorithms and platforms will be added later on.
