Kernel will report "BUG: spinlock lockup suspected on CPU#0"
when CONFIG_DEBUG_SPINLOCK is enabled in kernel config and the
spinlock is used at the first time. It's caused by uninitialized
spinlock, so just initialize it in probe.
Signed-off-by: Leilei Zhao <leilei.zhao@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fix typo, "intialization" -> "initialization"
If only one of the 2 __get_free_pages fails, then there is a memory leak.
Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
This patch switches data allocation from kzalloc to devm_kzalloc.
It also removes some kfree() on data that was earlier allocated
using devm_kzalloc() from probe as well as remove funtions.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: "David S. Miller" <davem@davemloft.net>
CC: Grant Likely <grant.likely@linaro.org>
CC: Rob Herring <robh+dt@kernel.org>
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com>
Add support for Device Tree and use of the DMA DT API to
get the channels if needed.
Documentation is added for these DT nodes.
Initial code by: Nicolas Royer and Eukrea.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Update from previous IP release (0x600):
- add DMA support (previous IP release use PDC)
Signed-off-by: Nicolas Royer <nicolas@eukrea.com>
Acked-by: Eric Bénard <eric@eukrea.com>
Tested-by: Eric Bénard <eric@eukrea.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: Jamie Iles <jamie@jamieiles.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Remove duplicated include.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Initialization of cra_list is currently mixed, most ciphers initialize this
field and most shashes do not. Initialization however is not needed at all
since cra_list is initialized/overwritten in __crypto_register_alg() with
list_add(). Therefore perform cleanup to remove all unneeded initializations
of this field in 'crypto/drivers/'.
Cc: linux-geode@lists.infradead.org
Cc: Michal Ludvig <michal@logix.cz>
Cc: Dmitry Kasatkin <dmitry.kasatkin@nokia.com>
Cc: Varun Wadekar <vwadekar@nvidia.com>
Cc: Eric Bénard <eric@eukrea.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Acked-by: Kent Yoder <key@linux.vnet.ibm.com>
Acked-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
