path: root/drivers/crypto/Kconfig
2013-08-21crypto: omap-aes - Kconfig: Add build support for AM437xJoel Fernandes
For AM437x SoC, ARCH_OMAP2 and ARCH_OMAP3 is not enabled in the defconfig. We follow same thing as SHA driver, and add depends on ARCH_OMAP2PLUS so that the config is selectable for AES driver on AM437x SoC builds. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-01crypto: omap-sham - Add SHA384 and SHA512 SupportLokesh Vutla
Adding support for SHA348 and SHA512 in addition to MD5, SHA1, SHA224 SHA256 that the omap sha module supports. In order to add the support - Removed hard coded register offsets and passing offsets from pdata - Updating Flag offsets so that they can be used for SHA256 and SHA512 - Adding the algo info. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-28crypto: dcp - Added support for Freescale's DCP co-processorTobias Rauter
This patch enables the DCP crypto functionality on imx28. Currently, only aes-128-cbc is supported. Moreover, the dcpboot misc-device, which is used by Freescale's SDK tools and uses a non-software-readable OTP-key, is added. Changes of v2: - ring buffer for hardware-descriptors - use of ablkcipher walk - OTP key encryption/decryption via misc-device (compatible to Freescale-SDK) - overall cleanup The DCP is also capable of sha1/sha256 but I won't be able to add that anytime soon. Tested with built-in runtime-self-test, tcrypt and openssl via cryptodev 1.6 on imx28-evk and a custom built imx28-board. Signed-off-by: Tobias Rauter <tobias.rauter@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-24crypto: sahara - remove dependency on EXPERIMENTALPaul Bolle
The Kconfig symbol EXPERIMENTAL was removed in v3.9. So this dependency makes it impossible to set CRYPTO_DEV_SAHARA. It's unlikely that this is what is intended, so let's remove this dependency. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-03-21crypto: sahara - Add driver for SAHARA2 accelerator.Javier Martin
SAHARA2 HW module is included in the i.MX27 SoC from Freescale. It is capable of performing cipher algorithms such as AES, 3DES..., hashing and RNG too. This driver provides support for AES-CBC and AES-ECB by now. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-03-10crypto: atmel-sha - add support for latest release of the IP (0x410)Nicolas Royer
Updates from IP release 0x320 to 0x400: - add DMA support (previous IP revision use PDC) - add DMA double input buffer support - add SHA224 support Update from IP release 0x400 to 0x410: - add SHA384 and SHA512 support Signed-off-by: Nicolas Royer <nicolas@eukrea.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Eric Bénard <eric@eukrea.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Added aesni/avx/x86_64 implementations for camellia. - Optimised AVX code for cast5/serpent/twofish/cast6. - Fixed vmac bug with unaligned input. - Allow compression algorithms in FIPS mode. - Optimised crc32c implementation for Intel. - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (32 commits) crypto: caam - Updated SEC-4.0 device tree binding for ERA information. crypto: testmgr - remove superfluous initializers for xts(aes) crypto: testmgr - allow compression algs in fips mode crypto: testmgr - add larger crc32c test vector to test FPU path in crc32c_intel crypto: testmgr - clean alg_test_null entries in alg_test_descs[] crypto: testmgr - remove fips_allowed flag from camellia-aesni null-tests crypto: cast5/cast6 - move lookup tables to shared module padata: use __this_cpu_read per-cpu helper crypto: s5p-sss - Fix compilation error crypto: picoxcell - Add terminating entry for platform_device_id table crypto: omap-aes - select BLKCIPHER2 crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of camellia cipher crypto: camellia-x86_64 - share common functions and move structures and function definitions to header file crypto: tcrypt - add async speed test for camellia cipher crypto: tegra-aes - fix error-valued pointer dereference crypto: tegra - fix missing unlock on error case crypto: cast5/avx - avoid using temporary stack buffers crypto: serpent/avx - avoid using temporary stack buffers crypto: twofish/avx - avoid using temporary stack buffers crypto: cast6/avx - avoid using temporary stack buffers ...
2012-11-22IXP4xx: ixp4xx_crypto driver requires Queue Manager and NPE drivers.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2012-11-09crypto: omap-aes - select BLKCIPHER2Sebastian Andrzej Siewior
without it: |drivers/built-in.o:(.data+0x14588): undefined reference to `crypto_ablkcipher_type' |drivers/built-in.o:(.data+0x14668): undefined reference to `crypto_ablkcipher_type' Not sure when this broke. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-20crypto: atmel - Remove possible typo errorTushar Behera
Commit bd3c7b5c2aba ("crypto: atmel - add Atmel AES driver") possibly has a typo error of adding an extra CONFIG_. CC: Nicolas Royer <nicolas@eukrea.com> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01powerpc/crypto: rework KconfigSeth Jennings
This patch creates a new submenu for the NX cryptographic hardware accelerator and breaks the NX options into their own Kconfig file under drivers/crypto/nx/Kconfig. This will permit additional NX functionality to be easily and more cleanly added in the future without touching drivers/crypto/Makefile|Kconfig. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: atmel - add Atmel SHA1/SHA256 driverNicolas Royer
2012-07-11crypto: atmel - add Atmel DES/TDES driverNicolas Royer
2012-07-11crypto: atmel - add Atmel AES driverNicolas Royer
2012-06-27crypto: nx - fix typo in nx driver config optionSeth Jennings
Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-12crypto: bfin_crc - CRC hardware driver for BF60x family processors.Sonic Zhang
The CRC peripheral is a hardware block used to compute the CRC of the block of data. This is based on a CRC32 engine which computes the CRC value of 32b data words presented to it. For data words of < 32b in size, this driver pack 0 automatically into 32b data units. This driver implements the async hash crypto framework API. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto updates from Herbert Xu: - New cipher/hash driver for ARM ux500. - Code clean-up for aesni-intel. - Misc fixes. Fixed up conflicts in arch/arm/mach-ux500/devices-common.h, where quite frankly some of it made no sense at all (the pull brought in a declaration for the dbx500_add_platform_device_noirq() function, which neither exists nor is used anywhere). Also some trivial add-add context conflicts in the Kconfig file in drivers/{char/hw_random,crypto}/ * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: aesni-intel - move more common code to ablk_init_common crypto: aesni-intel - use crypto_[un]register_algs crypto: ux500 - Cleanup hardware identification crypto: ux500 - Update DMA handling for 3.4 mach-ux500: crypto - core support for CRYP/HASH module. crypto: ux500 - Add driver for HASH hardware crypto: ux500 - Add driver for CRYP hardware hwrng: Kconfig - modify default state for atmel-rng driver hwrng: omap - use devm_request_and_ioremap crypto: crypto4xx - move up err_request_irq label crypto, xor: Sanitize checksumming function selection output crypto: caam - add backward compatible string sec4.0
2012-05-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Here are the powerpc goodies for 3.5. Main highlights are: - Support for the NX crypto engine in Power7+ - A bunch of Anton goodness, including some micro optimization of our syscall entry on Power7 - I converted a pile of our thermal control drivers to the new i2c APIs (essentially turning the old therm_pm72 into a proper set of windfarm drivers). That's one more step toward removing the deprecated i2c APIs, there's still a few drivers to fix, but we are getting close - kexec/kdump support for 47x embedded cores The big missing thing here is no updates from Freescale. Not sure what's up here, but with Kumar not working for them anymore things are a bit in a state of flux in that area." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (71 commits) powerpc: Fix irq distribution Revert "powerpc/hw-breakpoint: Use generic hw-breakpoint interfaces for new PPC ptrace flags" powerpc: Fixing a cputhread code documentation powerpc/crypto: Enable the PFO-based encryption device powerpc/crypto: Build files for the nx device driver powerpc/crypto: debugfs routines and docs for the nx device driver powerpc/crypto: SHA512 hash routines for nx encryption powerpc/crypto: SHA256 hash routines for nx encryption powerpc/crypto: AES-XCBC mode routines for nx encryption powerpc/crypto: AES-GCM mode routines for nx encryption powerpc/crypto: AES-ECB mode routines for nx encryption powerpc/crypto: AES-CTR mode routines for nx encryption powerpc/crypto: AES-CCM mode routines for nx encryption powerpc/crypto: AES-CBC mode routines for nx encryption powerpc/crypto: nx driver code supporting nx encryption powerpc/pseries: Enable the PFO-based RNG accelerator powerpc/pseries/hwrng: PFO-based hwrng driver powerpc/pseries: Add PFO support to the VIO bus powerpc/pseries: Add pseries update notifier for OFDT prop changes powerpc/pseries: Add new hvcall constants to support PFO ...
2012-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "Just a random collection of bug-fixes and cleanups, nothing new in this merge request." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (46 commits) s390/ap: Fix wrong or missing comments s390/ap: move receive callback to message struct s390/dasd: re-prioritize partition detection message s390/qeth: reshuffle initialization s390/qeth: cleanup drv attr usage s390/claw: cleanup drv attr usage s390/lcs: cleanup drv attr usage s390/ctc: cleanup drv attr usage s390/ccwgroup: remove ccwgroup_create_from_string s390/qeth: stop using struct ccwgroup driver for discipline callbacks s390/qeth: switch to ccwgroup_create_dev s390/claw: switch to ccwgroup_create_dev s390/lcs: switch to ccwgroup_create_dev s390/ctcm: switch to ccwgroup_create_dev s390/ccwgroup: exploit ccwdev_by_dev_id s390/ccwgroup: introduce ccwgroup_create_dev s390: fix race on TIF_MCCK_PENDING s390/barrier: make use of fast-bcr facility s390/barrier: cleanup barrier functions s390/claw: remove "eieio" calls ...
2012-05-16s390/crypto des: add missing select statementHeiko Carstens
Add missing "select CRYPTO_DES". Fixes this: ERROR: "des_ekey" [arch/s390/crypto/des_s390.ko] undefined! Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-16powerpc/crypto: Build files for the nx device driverKent Yoder
These files support configuring and building the nx device driver. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-05-15crypto: mv_cesa requires on CRYPTO_HASH to buildAlexander Clouter
Without CRYPTO_HASH being selected, mv_cesa has a lot of hooks into undefined exports. ---- MODPOST 81 modules Kernel: arch/arm/boot/Image is ready AS arch/arm/boot/compressed/head.o GZIP arch/arm/boot/compressed/piggy.gzip CC arch/arm/boot/compressed/misc.o CC arch/arm/boot/compressed/decompress.o ERROR: "crypto_ahash_type" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_final" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_register_ahash" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_unregister_ahash" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_update" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_digest" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_shash_setkey" [drivers/crypto/mv_cesa.ko] undefined! ERROR: "crypto_alloc_shash" [drivers/crypto/mv_cesa.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 make: *** Waiting for unfinished jobs.... ---- Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Cc: stable@vger.kernel.org
2012-05-04crypto: ux500 - Add driver for CRYP hardwareAndreas Westin
This adds a driver for the ST-Ericsson ux500 crypto hardware module. It supports AES, DES and 3DES, the driver implements support for AES-ECB,CBC and CTR. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andreas Westin <andreas.westin@stericsson.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "The biggest patch is the rework of the smp code, something I wanted to do for some time. There are some patches for our various dump methods and one new thing: z/VM LGR detection. LGR stands for linux-guest- relocation and is the guest migration feature of z/VM. For debugging purposes we keep a log of the systems where a specific guest has lived." Fix up trivial conflict in arch/s390/kernel/smp.c due to the scheduler cleanup having removed some code next to removed s390 code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] kernel: Pass correct stack for smp_call_ipl_cpu() [S390] Ensure that vmcore_info pointer is never accessed directly [S390] dasd: prevent validate server for offline devices [S390] Remove monolithic build option for zcrypt driver. [S390] stack dump: fix indentation in output [S390] kernel: Add OS info memory interface [S390] Use block_sigmask() [S390] kernel: Add z/VM LGR detection [S390] irq: external interrupt code passing [S390] irq: set __ARCH_IRQ_EXIT_IRQS_DISABLED [S390] zfcpdump: Implement async sdias event processing [S390] Use copy_to_absolute_zero() instead of "stura/sturg" [S390] rework idle code [S390] rework smp code [S390] rename lowcore field [S390] Fix gcc 4.6.0 compile warning
2012-03-11[S390] Remove monolithic build option for zcrypt driver.Holger Dengler
Remove the option to build a single module z90crypt that contains ap bus, request router and card drivers. Signed-off-by: Holger Dengler <hd@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-01-13crypto: driver for Tegra AES hardwareVarun Wadekar
driver supports ecb/cbc/ofb/ansi_x9.31rng modes, 128, 192 and 256-bit key sizes Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Make hifn_795x build depend on !ARCH_DMA_ADDR_T_64BITRichard Weinberger
hifn_795x works only on 32 bit, remove the detection while loading the module and catch non-32 bit systems at build time. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-20crypto: picoxcell - add dependency on HAVE_CLKJamie Iles
The picoxcell crypto driver requires the clk API, but the platform in mainline does not currently support it. Add an explicit dependency on HAVE_CLK to avoid build breakage. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-23[S390] ap: skip device registration on type probe failureHolger Dengler
The registration of an ap device will be skipped, if the device type probing fails. Add names of current crypto adapters to the Kconfig help. Signed-off-by: Holger Dengler <hd@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-04crypto: s390 - add System z hardware support for CTR modeGerald Schaefer
This patch adds System z hardware acceleration support for AES, DES and 3DES in CTR mode. The hardware support is available starting with System z196. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-04crypto: s390 - cleanup s390 Kconfig optionsJan Glauber
Cleanup the remaining s390 crypto options by mentioning the earliest machine type that supports an accelerated algorithm. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-04crypto: s390 - add System z hardware support for GHASHGerald Schaefer
This patch adds System z hardware acceleration support for the GHASH algorithm for GCM (Galois/Counter Mode). The hardware support is available beginning with System z196. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-04crypto: s390 - add System z hardware support for XTS modeGerald Schaefer
This patch adds System z hardware acceleration support for the AES XTS mode. The hardware support is available beginning with System z196. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-04-08crypto: s5p-sss - add S5PV210 advanced crypto engine supportVladimir Zapolskiy
This change adds support for AES encrypting and decrypting using advanced crypto engine found on Samsung S5PV210 and S5PC110 SoCs. Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-03-27crypto: caam - Add support for the Freescale SEC4/CAAMKim Phillips
The SEC4 supercedes the SEC2.x/3.x as Freescale's Integrated Security Engine. Its programming model is incompatible with all prior versions of the SEC (talitos). The SEC4 is also known as the Cryptographic Accelerator and Assurance Module (CAAM); this driver is named caam. This initial submission does not include support for Data Path mode operation - AEAD descriptors are submitted via the job ring interface, while the Queue Interface (QI) is enabled for use by others. Only AEAD algorithms are implemented at this time, for use with IPsec. Many thanks to the Freescale STC team for their contributions to this driver. Signed-off-by: Steve Cornelius <sec@pobox.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-02-21crypto: picoxcell - add support for the picoxcell crypto enginesJamie Iles
Picochip picoXcell devices have two crypto engines, one targeted at IPSEC offload and the other at WCDMA layer 2 ciphering. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: Makefile - replace the use of <module>-objs with <module>-y crypto: hifn_795x - use cancel_delayed_work_sync() crypto: talitos - sparse check endian fixes crypto: talitos - fix checkpatch warning crypto: talitos - fix warning: 'alg' may be used uninitialized in this function crypto: cryptd - Adding the AEAD interface type support to cryptd crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES crypto: Kconfig - update broken web addresses crypto: omap-sham - Adjust DMA parameters crypto: fips - FIPS requires algorithm self-tests crypto: omap-aes - OMAP2/3 AES hw accelerator driver crypto: updates to enable omap aes padata: add missing __percpu markup in include/linux/padata.h MAINTAINERS: Add maintainer entries for padata/pcrypt
2010-09-12crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DESDavid S. Miller
Reported-by: Dennis Gilmore <dennis@ausil.us> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-09-03crypto: omap-aes - OMAP2/3 AES hw accelerator driverDmitry Kasatkin
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-13[S390] zcrypt: fix Kconfig dependenciesHeiko Carstens
warning: (ZCRYPT && CRYPTO && CRYPTO_HW && S390 && ZCRYPT=y) selects ZCRYPT_MONOLITHIC which has unmet direct dependencies (ZCRYPT=m) ZCRYPT_MONOLITHIC should not depend on ZCRYPT="m" when it gets selected if ZCRYPT="y". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-19crypto: n2 - Add Niagara2 crypto driverDavid S. Miller
Current deficiencies: 1) No HMAC hash support yet. 2) Although the algs are registered as ASYNC they always run synchronously. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-03crypto: omap - sha1 & md5 driverDmitry Kasatkin
Earlier kernel contained omap sha1 and md5 driver, which was not maintained, was not ported to new crypto APIs and removed from the source tree. - implements async crypto API using dma and cpu. - supports multiple sham instances if available - hmac - concurrent requests Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-10crypto: mv_cesa - Add support for Orion5X crypto engineSebastian Andrzej Siewior
This adds support for Marvell's Cryptographic Engines and Security Accelerator (CESA) which can be found on a few SoC. Tested with dm-crypt. Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: padlock - Switch sha to shashHerbert Xu
This patch converts the padlock-sha implementation to shash. In doing so the existing mechanism of storing the data until final is no longer viable as we do not have a way of allocating data in crypto_shash_init and then reliably freeing it. This is just as well because a better way of handling the problem is to hash everything but the last chunk using normal sha code and then provide the intermediate result to the padlock device. This is good enough because the primary application of padlock-sha is IPsec and there the data is laid out in the form of an hmac header followed by the rest of the packet. In essence we can provide all the data to the padlock as the hmac header only needs to be hashed once. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-02crypto: padlock - Restore dependency on x86Herbert Xu
When we added 64-bit support to padlock the dependency on x86 was lost. This causes build failures on non-x86 architectures. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: padlock - Enable on x86_64Sebastian Andrzej Siewior
Almost everything stays the same, we need just to use the extended registers on the bit variant. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: amcc - Add crypt4xx driverJames Hsiao
This patch adds support for AMCC ppc4xx security device driver. This is the initial release that includes the driver framework with AES and SHA1 algorithms support. The remaining algorithms will be released in the near future. Signed-off-by: James Hsiao <jhsiao@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: sha-s390 - Switch to shashHerbert Xu
This patch converts the S390 sha algorithms to the new shash interface. With fixes by Jan Glauber. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
