path: root/drivers/cpufreq/pmac64-cpufreq.c
2013-10-31cpufreq: move freq change notifications to cpufreq coreViresh Kumar
Most of the drivers do following in their ->target_index() routines: struct cpufreq_freqs freqs; freqs.old = old freq... freqs.new = new freq... cpufreq_notify_transition(policy, &freqs, CPUFREQ_PRECHANGE); /* Change rate here */ cpufreq_notify_transition(policy, &freqs, CPUFREQ_POSTCHANGE); This is replicated over all cpufreq drivers today and there doesn't exists a good enough reason why this shouldn't be moved to cpufreq core instead. There are few special cases though, like exynos5440, which doesn't do everything on the call to ->target_index() routine and call some kind of bottom halves for doing this work, work/tasklet/etc.. They may continue doing notification from their own code as flag: CPUFREQ_ASYNC_NOTIFICATION is already set for them. All drivers are also modified in this patch to avoid breaking 'git bisect', as double notification would happen otherwise. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-25cpufreq: Implement light weight ->target_index() routineViresh Kumar
Currently, the prototype of cpufreq_drivers target routines is: int target(struct cpufreq_policy *policy, unsigned int target_freq, unsigned int relation); And most of the drivers call cpufreq_frequency_table_target() to get a valid index of their frequency table which is closest to the target_freq. And they don't use target_freq and relation after that. So, it makes sense to just do this work in cpufreq core before calling cpufreq_frequency_table_target() and simply pass index instead. But this can be done only with drivers which expose their frequency table with cpufreq core. For others we need to stick with the old prototype of target() until those drivers are converted to expose frequency tables. This patch implements the new light weight prototype for target_index() routine. It looks like this: int target_index(struct cpufreq_policy *policy, unsigned int index); CPUFreq core will call cpufreq_frequency_table_target() before calling this routine and pass index to it. Because CPUFreq core now requires to call routines present in freq_table.c CONFIG_CPU_FREQ_TABLE must be enabled all the time. This also marks target() interface as deprecated. So, that new drivers avoid using it. And Documentation is updated accordingly. It also converts existing .target() to newly defined light weight .target_index() routine for many driver. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
2013-10-17cpufreq: pmac64: enable cpufreq on iMac G5 (iSight) modelAaro Koskinen
Enable cpufreq on iMac G5 (iSight) model. Tested with the 2.1 GHz version. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-17cpufreq: pmac64: provide cpufreq transition latency for older G5 modelsAaro Koskinen
Currently cpufreq ondemand governor cannot used on older G5 models, because the transition latency is set to CPUFREQ_ETERNAL. Provide a value based on a measurement on Xserve G5, which happens to be also the highest allowed latency. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-17cpufreq: pmac64: speed up frequency switchAaro Koskinen
Some functions on switch path use msleep() which is inaccurate, and depends on HZ. With HZ=100 msleep(1) takes actually over ten times longer. Using usleep_range() we get more accurate sleeps. I measured the "pfunc_slewing_done" polling to take 300us at max (on 2.3GHz dual-processor Xserve G5), so using 500us sleep there should be fine. With the patch, g5_switch_freq() duration drops from ~50ms to ~10ms on Xserve with HZ=100. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: pmac64: use cpufreq_generic_init()Viresh Kumar
Use generic cpufreq_generic_init() routine instead of replicating the same code here. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: pmac: don't initialize part of policy set by coreViresh Kumar
Many common initializations of struct policy are moved to core now and hence this driver doesn't need to do it. This patch removes such code. Most recent of those changes is to call ->get() in the core after calling ->init(). Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: pmac: Use generic cpufreq routinesViresh Kumar
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines and .attr. So its better if we have generic routines for them which can be used by cpufreq drivers then. This patch uses these generic routines in the pmac driver. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-30cpufreq: pmac: use cpufreq_table_validate_and_show()Viresh Kumar
Lets use cpufreq_table_validate_and_show() instead of calling cpufreq_frequency_table_cpuinfo() and cpufreq_frequency_table_get_attr(). Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-23Merge branch 'cpu_of_node' of git://linux-arm.org/linux-skn into pm-cpufreq-nextRafael J. Wysocki
Pull DT/core/cpufreq cpu_ofnode updates for v3.12 from Sudeep KarkadaNagesha. * 'cpu_of_node' of git://linux-arm.org/linux-skn: cpufreq: pmac32-cpufreq: remove device tree parsing for cpu nodes cpufreq: pmac64-cpufreq: remove device tree parsing for cpu nodes cpufreq: maple-cpufreq: remove device tree parsing for cpu nodes cpufreq: arm_big_little: remove device tree parsing for cpu nodes cpufreq: kirkwood-cpufreq: remove device tree parsing for cpu nodes cpufreq: spear-cpufreq: remove device tree parsing for cpu nodes cpufreq: highbank-cpufreq: remove device tree parsing for cpu nodes cpufreq: cpufreq-cpu0: remove device tree parsing for cpu nodes cpufreq: imx6q-cpufreq: remove device tree parsing for cpu nodes drivers/bus: arm-cci: avoid parsing DT for cpu device nodes ARM: mvebu: remove device tree parsing for cpu nodes ARM: topology: remove hwid/MPIDR dependency from cpu_capacity of/device: add helper to get cpu device node from logical cpu index driver/core: cpu: initialize of_node in cpu's device struture ARM: DT/kernel: define ARM specific arch_match_cpu_phys_id of: move of_get_cpu_node implementation to DT core library powerpc: refactor of_get_cpu_node to support other architectures openrisc: remove undefined of_get_cpu_node declaration microblaze: remove undefined of_get_cpu_node declaration
2013-08-21cpufreq: pmac64-cpufreq: remove device tree parsing for cpu nodesSudeep KarkadaNagesha
Now that the cpu device registration initialises the of_node(if available) appropriately for all the cpus, parsing here is redundant. This patch removes all DT parsing and uses cpu->of_node instead. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
2013-08-10cpufreq: Drop the owner field from struct cpufreq_driverViresh Kumar
We don't need to set .owner = THIS_MODULE any more in cpufreq drivers as this field isn't used any more by the cpufreq core. This patch removes it and updates all dependent drivers accordingly. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-07cpufreq: Use sizeof(*ptr) convetion for computing sizesViresh Kumar
Chapter 14 of Documentation/CodingStyle says: The preferred form for passing a size of a struct is the following: p = kmalloc(sizeof(*p), ...); The alternative form where struct name is spelled out hurts readability and introduces an opportunity for a bug when the pointer variable type is changed but the corresponding sizeof that is passed to a memory allocator is not. This wasn't followed consistently in drivers/cpufreq, let's make it more consistent by always following this rule. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-07cpufreq: powerpc: move cpufreq driver to drivers/cpufreqViresh Kumar
Move cpufreq driver of powerpc platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
