path: root/drivers/cpufreq/freq_table.c
2013-10-16cpufreq: define generic .attr, .exit() and .verify() routinesViresh Kumar
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines and .attr. So its better if we have generic routines for them which can be used by cpufreq drivers then. This patch introduces generic .attr, .exit() and .verify() cpufreq drivers. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: add new routine cpufreq_verify_within_cpu_limits()Viresh Kumar
Most of the users of cpufreq_verify_within_limits() calls it for limiting with min/max from policy->cpuinfo. We can make that code simple by introducing another routine which will do this for them automatically. This patch adds another routine cpufreq_verify_within_cpu_limits() and updates others to use it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: Optimize cpufreq_frequency_table_verify()Viresh Kumar
cpufreq_frequency_table_verify() is rewritten here to make it more logical and efficient. - merge multiple lines for variable declarations together. - quit early if any frequency between min/max is found. - don't call cpufreq_verify_within_limits() in case any valid freq is found as it is of no use. - rename the count variable as found and change its type to boolean. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-30cpufreq: Add new helper cpufreq_table_validate_and_show()Viresh Kumar
Almost every cpufreq driver is required to validate its frequency table with: cpufreq_frequency_table_cpuinfo() and then expose it to cpufreq core with: cpufreq_frequency_table_get_attr(). This patch creates another helper routine cpufreq_table_validate_and_show() that will do both these steps in a single call and will return 0 for success, error otherwise. This also fixes potential bugs in cpufreq drivers where people have called cpufreq_frequency_table_get_attr() before calling cpufreq_frequency_table_cpuinfo(), as the later may fail. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-07cpufreq: Clean up header files included in the coreViresh Kumar
This patch addresses the following issues in the header files in the cpufreq core: - Include headers in ascending order, so that we don't add same many times by mistake. - <asm/> must be included after <linux/>, so that they override whatever they need to. - Remove unnecessary includes. - Don't include files already included by cpufreq.h or cpufreq_governor.h. [rjw: Changelog] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-04cpufreq: rename index as driver_data in cpufreq_frequency_tableViresh Kumar
The "index" field of struct cpufreq_frequency_table was never an index and isn't used at all by the cpufreq core. It only is useful for cpufreq drivers for their internal purposes. Many people nowadays blindly set it in ascending order with the assumption that the core will use it, which is a mistake. Rename it to "driver_data" as that's what its purpose is. All of its users are updated accordingly. [rjw: Changelog] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-09cpufreq: Don't check cpu_online(policy->cpu)Viresh Kumar
policy->cpu or cpus in policy->cpus can't be offline anymore. And so we don't need to check if they are online or not. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02cpufreq: Simplify __cpufreq_remove_dev()Viresh Kumar
__cpufreq_remove_dev() is called on multiple occasions: cpufreq_driver unregister and cpu removals. Current implementation of this routine is overly complex without much need. If the cpu to be removed is the policy->cpu, we remove the policy first and add all other cpus again from policy->cpus and then finally call __cpufreq_remove_dev() again to remove the cpu to be deleted. Haahhhh.. There exist a simple solution to removal of a cpu: - Simply use the old policy structure - update its fields like: policy->cpu, etc. - notify any users of cpufreq, which depend on changing policy->cpu Hence this patch, which tries to implement the above theory. It is tested well by myself on ARM big.LITTLE TC2 SoC, which has 5 cores (2 A15 and 3 A7). Both A15's share same struct policy and all A7's share same policy structure. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15cpufreq: Improve debug printsViresh Kumar
With debug options on, it is difficult to locate cpufreq core's debug prints. Fix this by prefixing debug prints with KBUILD_MODNAME. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2009-10-29percpu: make percpu symbols in cpufreq uniqueTejun Heo
This patch updates percpu related symbols in cpufreq such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * drivers/cpufreq/cpufreq.c: s/policy_cpu/cpufreq_policy_cpu/ * drivers/cpufreq/freq_table.c: s/show_table/cpufreq_show_table/ * arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.c: s/drv_data/acfreq_data/ s/old_perf/acfreq_old_perf/ Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au>
2009-02-24[CPUFREQ] checkpatch cleanups for freq_tableDave Jones
2008-07-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] cpufreq: remove CVS keywords [CPUFREQ] change cpu freq arrays to per_cpu variables
2008-05-22[CPUFREQ] clarify license of freq_table.cDominik Brodowski
2008-05-19[CPUFREQ] change cpu freq arrays to per_cpu variablesMike Travis
Change cpufreq_policy and cpufreq_governor pointer tables from arrays to per_cpu variables in the cpufreq subsystem. Also some minor complaints from checkpatch.pl fixed. Based on: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86.git Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Dave Jones <davej@redhat.com>
2008-02-06[CPUFREQ] fix incorrect comment on show_available_freqs() in freq_table.cFenghua Yu
In freq_table.c, show_available_freqs()'s comment is oberviously wrong. Change the comment to a new one to avoid confusion. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-06[CPUFREQ] Fix coding style issues in cpufreq.Gautham R Shenoy
Clean up cpufreq subsystem to fix coding style issues and to improve the readability. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-05-30[CPUFREQ] Remove more freq_table reinitialisations.Dave Jones
2006-05-30[CPUFREQ] Fix another redundant initialisation in freq_tableDave Jones
2006-05-30[CPUFREQ] Remove duplicate assignment in freq_tableDave Jones
2006-02-28[CPUFREQ] Lots of whitespace & CodingStyle cleanup.Dave Jones
