path: root/drivers/cpufreq/cpufreq_stats.c
2006-09-22[CPUFREQ] Fix some more CPU hotplug locking.Dave Jones
Lukewarm IQ detected in hotplug locking BUG: warning at kernel/cpu.c:38/lock_cpu_hotplug() [<b0134a42>] lock_cpu_hotplug+0x42/0x65 [<b02f8af1>] cpufreq_update_policy+0x25/0xad [<b0358756>] kprobe_flush_task+0x18/0x40 [<b0355aab>] schedule+0x63f/0x68b [<b01377c2>] __link_module+0x0/0x1f [<b0119e7d>] __cond_resched+0x16/0x34 [<b03560bf>] cond_resched+0x26/0x31 [<b0355b0e>] wait_for_completion+0x17/0xb1 [<f965c547>] cpufreq_stat_cpu_callback+0x13/0x20 [cpufreq_stats] [<f9670074>] cpufreq_stats_init+0x74/0x8b [cpufreq_stats] [<b0137872>] sys_init_module+0x91/0x174 [<b0102c81>] sysenter_past_esp+0x56/0x79 As there are other places that call cpufreq_update_policy without the hotplug lock, it seems better to keep the hotplug locking at the lower level for the time being until this is revamped. Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-27[PATCH] cpu hotplug: make [un]register_cpu_notifier init time onlyChandra Seetharaman
CPUs come online only at init time (unless CONFIG_HOTPLUG_CPU is defined). So, cpu_notifier functionality need to be available only at init time. This patch makes register_cpu_notifier() available only at init time, unless CONFIG_HOTPLUG_CPU is defined. This patch exports register_cpu_notifier() and unregister_cpu_notifier() only if CONFIG_HOTPLUG_CPU is defined. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[CPUFREQ] CodingStyle nits in cpufreq_stats.cDave Jones
2006-03-11[PATCH] cpufreq: fix section mismatch warningsSam Ravnborg
cpufreq are the only remaining bit to be solved for me to have a modpost clean build for sparc64 - so I took one more look at it. changelog entry: Fix section mismatch warnings in cpufreq: WARNING: drivers/cpufreq/cpufreq_stats.o - Section mismatch: reference to .init.text: from .data between 'cpufreq_stat_cpu_notifier' (at offset 0xa8) and 'notifier_policy_block' WARNING: drivers/cpufreq/cpufreq_stats.o - Section mismatch: reference to .init.text: from .exit.text after 'cleanup_module' (at offset 0x30) The culprint is the function: cpufreq_stat_cpu_callback It is marked __cpuinit which get's redefined to __init in case HOTPLUG_CPU is not enabled as per. init.h: #ifdef CONFIG_HOTPLUG_CPU #define __cpuinit #else #define __cpuinit __init #endif $> grep HOTPLUG .config CONFIG_HOTPLUG=y But cpufreq_stat_cpu_callback() is used in: __exit cpufreq_stats_exit() static struct notifier_block cpufreq_stat_cpu_notifier cpufreq_stat_cpu_notifier is again used in: __init cpufreq_stats_init() __exit cpufreq_stats_exit() So in both cases used from both __init and __exit context. Only solution seems to drop __cpuinit tag. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[CPUFREQ] Lots of whitespace & CodingStyle cleanup.Dave Jones
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
2005-11-01[CPUFREQ] Fix up compile of cpufreq_statsDave Jones
Whoops, I lost a hunk of the last patch somehow. Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-30[PATCH] create and destroy cpufreq sysfs entries based on cpu notifiersAshok Raj
cpufreq entries in sysfs should only be populated when CPU is online state. When we either boot with maxcpus=x and then boot the other cpus by echoing to sysfs online file, these entries should be created and destroyed when CPU_DEAD is notified. Same treatement as cache entries under sysfs. We place the processor in the lowest frequency, so hw managed P-State transitions can still work on the other threads to save power. Primary goal was to just make these directories appear/disapper dynamically. There is one in this patch i had to do, which i really dont like myself but probably best if someone handling the cpufreq infrastructure could give this code right treatment if this is not acceptable. I guess its probably good for the first cut. - Converting lock_cpu_hotplug()/unlock_cpu_hotplug() to disable/enable preempt. The locking was smack in the middle of the notification path, when the hotplug is already holding the lock. I tried another solution to avoid this so avoid taking locks if we know we are from notification path. The solution was getting very ugly and i decided this was probably good for this iteration until someone who understands cpufreq could do a better job than me. (akpm: export cpucontrol to GPL modules: drivers/cpufreq/cpufreq_stats.c now does lock_cpu_hotplug()) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-27[CPUFREQ] Check return value of cpufreq_cpu_get in cpufreq_statsDave Jones
This fixes an issue found in drivers/cpufreq/cpufreq_stats.c by Coverity. Error reported: CID: 2642 Checker: NULL_RETURNS (help) File: /export2/p4-coverity/mc2/linux26/drivers/cpufreq/cpufreq_stats.c Function: cpufreq_stats_create_table Description: Dereferencing NULL value "data" Patch description: The return of cpufreq_cpu_get can be NULL, check return code and return -EINVAL if it is NULL. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-20[CPUFREQ] kzalloc conversions for cpufreq core.Dave Jones
2005-05-31[PATCH] cpufreq-stats driver updatesVenkatesh Pallipadi
Changes to the cpufreq stats driver: * Changes the way P-state transition table looks in /sysfs providing more clear output * Changes the time unit in the output from HZ to clock_t Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
