path: root/drivers/cpufreq/cpufreq.c
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-18[CPUFREQ] drivers/cpufreq/cpufreq.c: static functions mustn't be exportedAdrian Bunk
This patch removes the EXPORT_SYMBOL_GPL of the static function cpufreq_parse_governor(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Jones <davej@redhat.com>
2006-04-18[CPUFREQ] If max_freq got reduced (e.g. by _PPC) a write to sysfs ↵Thomas Renninger
scaling_governor let cpufreq core stuck at low max_freq for ever The previous patch had bugs (locking and refcount). This one could also be related to the latest DELL reports. But they only slip into this if a user prog (e.g. powersave daemon does when AC got (un) plugged due to a scheme change) echos something to /sys/../cpufreq/scaling_governor while the frequencies got limited by BIOS. This one works: Subject: Max freq stucks at low freq if reduced by _PPC and sysfs gov access The problem is reproducable by(if machine is limiting freqs via BIOS): - Unplugging AC -> max freq gets limited - echo ${governor} >/sys/.../cpufreq/scaling_governor (policy->user_data.max gets overridden with policy->max and will never come up again.) This patch exchanged the cpufreq_set_policy call to __cpufreq_set_policy and duplicated it's functionality but did not override user_data.max. The same happens with overridding min/max values. If freqs are limited and you override the min freq value, the max freq global value will also get stuck to the limited freq, even if BIOS allows all freqs again. Last scenario does only happen if BIOS does not reduce the frequency to the lowest value (should never happen, just for correctness...) drivers/cpufreq/cpufreq.c | 17 +++++++++++++++-- 1 files changed, 15 insertions(+), 2 deletions(-) Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-03-29[CPUFREQ] trailing whitespace removal de-jour.Dave Jones
2006-03-29[CPUFREQ] extra debugging in cpufreq_add_dev()Dave Jones
Snipped from an otherwise rejected patch by Jan Beulich <jbeulich@novell.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-05[CPUFREQ] Fix handling for CPU hotplugDave Jones
This patch adds proper logic to cpufreq driver in order to handle CPU Hotplug. When CPUs go on/offline, the affected CPUs data, cpufreq_policy->cpus, is not updated properly. This causes sysfs directories and symlinks to be in an incorrect state after few CPU on/offlines. Signed-off-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[CPUFREQ] Lots of whitespace & CodingStyle cleanup.Dave Jones
2006-02-02[CPUFREQ] Whitespace/CodingStyle cleanupsDave Jones
2006-02-02[CPUFREQ] Check whether driver init did not initialize current freqThomas Renninger
Check whether driver init did not initialize current freq Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-31[CPUFREQ] cpufreq_notify_transition cleanup.Dave Jones
Introduce caching of cpufreq_cpu_data[freqs->cpu], which allows us to make the function a lot more readable, and as a nice side-effect, it now fits in < 80 column displays again. Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-26[CPUFREQ] _PPC frequency change issuesThomas Renninger
BIOS might change frequency behind our back when BIOS changes allowed frequencies via _PPC. In this case cpufreq core got out of sync. Ask driver for current freq and notify governors about a change Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-18[CPUFREQ] Don't free held mutex in cpufreq_add_dev()Andrew Morton
Make the cpufreq code play nicely with the mutex debugging code: don't free a held mutex. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-18[CPUFREQ] convert remaining cpufreq semaphore to a mutexArjan van de Ven
This one fell through the automation at first because it initializes the semaphore to locked, but that's easily remedied Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Dave Jones <davej@redhat.com> drivers/cpufreq/cpufreq.c | 37 +++++++++++++++++++------------------ include/linux/cpufreq.h | 3 ++- 2 files changed, 21 insertions(+), 19 deletions(-)
2006-01-18[CPUFREQ] Convert drivers/cpufreq semaphores to mutexes.akpm@osdl.org
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-06[CPUFREQ] CPU frequency display in /proc/cpuinfoVenkatesh Pallipadi
What is the value shown in "cpu MHz" of /proc/cpuinfo when CPUs are capable of changing frequency? Today the answer is: It depends. On i386: SMP kernel - It is always the boot frequency UP kernel - Scales with the frequency change and shows that was last set. On x86_64: There is one single variable cpu_khz that gets written by all the CPUs. So, the frequency set by last CPU will be seen on /proc/cpuinfo of all the CPUs in the system. What you see also depends on whether you have constant_tsc capable CPU or not. On ia64: It is always boot time frequency of a particular CPU that gets displayed. The patch below changes this to: Show the last known frequency of the particular CPU, when cpufreq is present. If cpu doesnot support changing of frequency through cpufreq, then boot frequency will be shown. The patch affects i386, x86_64 and ia64 architectures. Signed-off-by: Venkatesh Pallipadi<venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-28[PATCH] clean up lock_cpu_hotplug() in cpufreqAshok Raj
There are some callers in cpufreq hotplug notify path that the lowest function calls lock_cpu_hotplug(). The lock is already held during cpu_up() and cpu_down() calls when the notify calls are broadcast to registered clients. Ideally if possible, we could disable_preempt() at the highest caller and make sure we dont sleep in the path down in cpufreq->driver_target() calls but the calls are so intertwined and cumbersome to cleanup. Hence we consistently use lock_cpu_hotplug() and unlock_cpu_hotplug() in all places. - Removed export of cpucontrol semaphore and made it static. - removed explicit uses of up/down with lock_cpu_hotplug() so we can keep track of the the callers in same thread context and just keep refcounts without calling a down() that causes a deadlock. - Removed current_in_hotplug() uses - Removed PF_HOTPLUG_CPU in sched.h introduced for the current_in_hotplug() temporary workaround. Tested with insmod of cpufreq_stat.ko, and logical online/offline to make sure we dont have any hang situations. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Cc: Zwane Mwaikambo <zwane@linuxpower.ca> Cc: Shaohua Li <shaohua.li@intel.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] cpufreq: silence cpufreq for UPGrant Coady
drivers/cpufreq/cpufreq.c: In function `cpufreq_remove_dev': drivers/cpufreq/cpufreq.c:696: warning: unused variable `cpu_sys_dev' Signed-off-by: Grant Coady <gcoady@gmail.com> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] cpu hotplug: fix locking in cpufreq driversAshok Raj
When calling target drivers to set frequency, we take cpucontrol lock. When we modified the code to accomodate CPU hotplug, there was an attempt to take a double lock of cpucontrol leading to a deadlock. Since the current thread context is already holding the cpucontrol lock, we dont need to make another attempt to acquire it. Now we leave a trace in current->flags indicating current thread already is under cpucontrol lock held, so we dont attempt to do this another time. Thanks to Andrew Morton for the beating:-) From: Brice Goglin <Brice.Goglin@ens-lyon.org> Build fix (akpm: this patch is still unpleasant. Ashok continues to look for a cleaner solution, doesn't he? ;)) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
2005-10-30[PATCH] create and destroy cpufreq sysfs entries based on cpu notifiersAshok Raj
cpufreq entries in sysfs should only be populated when CPU is online state. When we either boot with maxcpus=x and then boot the other cpus by echoing to sysfs online file, these entries should be created and destroyed when CPU_DEAD is notified. Same treatement as cache entries under sysfs. We place the processor in the lowest frequency, so hw managed P-State transitions can still work on the other threads to save power. Primary goal was to just make these directories appear/disapper dynamically. There is one in this patch i had to do, which i really dont like myself but probably best if someone handling the cpufreq infrastructure could give this code right treatment if this is not acceptable. I guess its probably good for the first cut. - Converting lock_cpu_hotplug()/unlock_cpu_hotplug() to disable/enable preempt. The locking was smack in the middle of the notification path, when the hotplug is already holding the lock. I tried another solution to avoid this so avoid taking locks if we know we are from notification path. The solution was getting very ugly and i decided this was probably good for this iteration until someone who understands cpufreq could do a better job than me. (akpm: export cpucontrol to GPL modules: drivers/cpufreq/cpufreq_stats.c now does lock_cpu_hotplug()) Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Remove cpu_sys_devices in cpufreq subsystem.Ashok Raj
cpu_sys_devices is redundant with the new API get_cpu_sysdev(). So nuking this usage since its not needed. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Zwane Mwaikambo <zwane@holomorphy.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-20[CPUFREQ] kzalloc conversions for cpufreq core.Dave Jones
2005-08-31[CPUFREQ] Bugfix: Call driver exit in cpufreq_add_dev error pathVenkatesh Pallipadi
A minor fix for cpufreq_add_dev() error path. We need to call driver->exit() if driver_init() call has succeeded. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2005-07-28Here are two possible cleanups in cpufreq.c:Dave Jones
* ret has no need to be unsigned in cpufreq_driver_target() * ret has no need to be initialized in __cpufreq_governor() Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-07-07[PATCH] pm: fix u32 vs. pm_message_t confusion in cpufreqBernard Blackham
Fix u32 vs pm_message_t confusion in cpufreq. Signed-off-by: Bernard Blackham <bernard@blackham.com.au> Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] sysfs: (rest) if show/store is missing return -EIODmitry Torokhov
sysfs: fix the rest of the kernel so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0 or -EINVAL or -EPERM. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-31[CPUFREQ] cpufreq-core: reduce warning messages.Dave Jones
cpufreq core is printing out messages at KERN_WARNING level that the core recovers from without intervention, and that the system administrator can do nothing about. Patch below reduces the severity of these messages to debug. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-02[PATCH] cpufreq annoying warning fixBenjamin Herrenschmidt
The cpufreq core patch I sent earlier got only half-applied. I added a flag to let the low level driver disable an annoying warning on suspend/resume that is normal on ppc, but the "resume" part of it wasn't applied. This just adds back that missing bit. The original patch also reworked the resume() function to avoid nesting too many if () statements along the way I did the suspend() one, but I didn't include that in the patch below. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-29[PATCH] Add suspend method to cpufreq coreBenjamin Herrenschmidt
In order to properly fix some issues with cpufreq vs. sleep on PowerBooks, I had to add a suspend callback to the pmac_cpufreq driver. I must force a switch to full speed before sleep and I switch back to previous speed on resume. I also added a driver flag to disable the warnings in suspend/resume since it is expected in this case to have different speed (and I want it to fixup the jiffies properly). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
