All the clocksource drivers's init function are now converted to return
an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the
clksrc-of table.
Let's convert back the names:
- CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE
- clksrc-of-ret => clksrc-of
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
For exynos_mct and samsung_pwm_timer:
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
For arch/arc:
Acked-by: Vineet Gupta <vgupta@synopsys.com>
For mediatek driver:
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
For the Rockchip-part
Acked-by: Heiko Stuebner <heiko@sntech.de>
For STi :
Acked-by: Patrice Chotard <patrice.chotard@st.com>
For the mps2-timer.c and versatile.c changes:
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
For the OXNAS part :
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
For LPC32xx driver:
Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
For Broadcom Kona timer change:
Acked-by: Ray Jui <ray.jui@broadcom.com>
For Sun4i and Sun5i:
Acked-by: Chen-Yu Tsai <wens@csie.org>
For Meson6:
Acked-by: Carlo Caione <carlo@caione.org>
For Keystone:
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
For NPS:
Acked-by: Noam Camus <noamca@mellanox.com>
For bcm2835:
Acked-by: Eric Anholt <eric@anholt.net>
The init functions do not return any error. They behave as the following:
- panic, thus leading to a kernel crash while another timer may work and
make the system boot up correctly
or
- print an error and let the caller unaware if the state of the system
Change that by converting the init functions to return an error conforming
to the CLOCKSOURCE_OF_RET prototype.
Proper error handling (rollback, errno value) will be changed later case
by case, thus this change just return back an error or success in the init
function.
Introduce a new clocksource driver for Texas
Instruments 32.768 Hz device which is available
on most OMAP-like devices.
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Felipe Balbi <balbi@ti.com>
