commit f02b4b72d12cbae7020a959e2ed0410a464b4cc4 upstream.
clockevents_exchange_device is calling clockevents_shutdown() on the new
clockenvents device but it may have never been enabled in the first place.
This results in the tcb clock being disabled without being enabled first:
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_disable+0x28/0x34()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.0+ #6
Hardware name: Atmel AT91SAM9
[<c000f2b8>] (unwind_backtrace) from [<c000d01c>] (show_stack+0x10/0x14)
[<c000d01c>] (show_stack) from [<c00172f0>] (warn_slowpath_common+0x78/0xa0)
[<c00172f0>] (warn_slowpath_common) from [<c00173a8>] (warn_slowpath_null+0x18/0x20)
[<c00173a8>] (warn_slowpath_null) from [<c0361528>] (clk_disable+0x28/0x34)
[<c0361528>] (clk_disable) from [<c034d560>] (tc_shutdown+0x38/0x4c)
[<c034d560>] (tc_shutdown) from [<c0059ad4>] (clockevents_switch_state+0x38/0x6c)
[<c0059ad4>] (clockevents_switch_state) from [<c0059b18>] (clockevents_shutdown+0x10/0x24)
[<c0059b18>] (clockevents_shutdown) from [<c005a458>] (tick_check_new_device+0x84/0xac)
[<c005a458>] (tick_check_new_device) from [<c0059660>] (clockevents_register_device+0x7c/0x108)
[<c0059660>] (clockevents_register_device) from [<c06b5a68>] (tcb_clksrc_init+0x390/0x3e8)
[<c06b5a68>] (tcb_clksrc_init) from [<c00097cc>] (do_one_initcall+0x114/0x1d4)
[<c00097cc>] (do_one_initcall) from [<c069bd54>] (kernel_init_freeable+0xfc/0x1b8)
[<c069bd54>] (kernel_init_freeable) from [<c04c3818>] (kernel_init+0x8/0xe0)
[<c04c3818>] (kernel_init) from [<c000a410>] (ret_from_fork+0x14/0x24)
---[ end trace 0000000000000001 ]---
Check what state we were in before trying to disable the clock.
Fixes: cf4541c101ea ("clockevents/drivers/tcb_clksrc: Migrate to new 'set-state' interface")
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Link: http://lkml.kernel.org/r/1452854061-30370-1-git-send-email-alexandre.belloni@free-electrons.com
Commit dca1a4b5ff6e ("clk: at91: keep slow clk enabled to prevent system
hang") added a workaround for the slow clock as it is not properly handled
by its users.
Get and use the slow clock as it is necessary for the timer counters.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
t2_clk is already disabled before request_irq(), it must not be disabled
again.
Migrate tcb_clksrc driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
The clock is not unprepared in case of the request IRQ fails.
Also update to request_irq.
Signed-off-by: Gaël PORTAY <gael.portay@gmail.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Move resource retrieval from atmel_tc_alloc to tc_probe to avoid lately
reporting resource related issues when a TC block user request a TC block.
Moreover, resources retrieval are usually done in the probe function,
thus moving them add some consistency with other drivers.
Initialization is done once, ie not every time a tc block is requested.
If it fails, the device is not appended to the list of tc blocks.
Furhermore, the device id is retrieved at probe as well, avoiding parsing
DT every time the user requests of tc block.
tc_mode() can be called from interrupt context and thus must not call
clk_*prepare*() functions.
Signed-off-by: David Jander <david@protonic.nl>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Remove the deprecated IRQF_DISABLED flag.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Check function return values to avoid false positive driver init.
clk_prepare_enable/disable_unprepare
Replace clk_enable/disable with clk_prepare_enable/disable_unprepare to
avoid common clk framework warnings.
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Andres Salomon <dilinger@queued.net>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Some SoC have a 32 bit variant of Timer Counter Blocks. We do not
need the chaining of two 16 bit counters anymore for them.
The SoC nature is deduced from the device tree "compatible" string.
For non-device-tree configurations, backward compatibility is maintained
by using the default 16 bit counter configuration.
This patch addresses both the atmel_tclib and its user: tcb_clksrc
clocksource.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Convert tcb_clksrc to use clocksource_register_hz.
CC: Nikolaus Voss <n.voss@weinmann.de>
CC: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Nikolaus Voss <n.voss@weinmann.de>
Signed-off-by: John Stultz <john.stultz@linaro.org>
setup_irq() was called before clockevents_register_device() which is
needed by the irq handler. Bug was reproducible by restarting the
kernel using kexec (reliable crash).
Signed-off-by: Nikolaus Voss <n.voss@weinmann.de>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Pass clocksource pointer to the read() callback for clocksources. This
allows us to share the callback between multiple instances.
[hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods]
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Impact: change calling convention of existing clock_event APIs
struct clock_event_timer's cpumask field gets changed to take pointer,
as does the ->broadcast function.
Another single-patch change. For safety, we BUG_ON() in
clockevents_register_device() if it's not set.
Does that have something analagous to this "remove warnings" patch?
Seems setup_clkevents() no longer needs a t0_clk parameter either...
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Clocksource and clockevent device based on the Atmel TC blocks.
The clockevent device handles both periodic and oneshot modes, so this
enables NO_HZ and high res timers on some platforms that previously
couldn't use those mechanisms.
This works on both AVR32 and AT91 chips, given relevant patches for
tclib support (always) and clockevents (or else this will only look
like a higher precision clocksource). It's an updated and modularized
version of an AT91-only patch that has circulated for some time now.
Changes relative to the original patch:
* Update to use new tclib API
* Replace open-coded do-while loop using goto with a real do-while loop
* Minor irq handler optimization: Load register base address from
dev_id instead of a global variable.
* Aggressively turn off clocks when the clockevent isn't being used
* Include the clockevent code on AT91RM9200 as well. The rating is
lower than the System Timer, so the clock will usually stay off.
* Don't assume that the number of clocks is always equal to the
number of irqs.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
