- Use updated printk format for OF node names
- Fix TI code to only search DT subnodes
- Various static analysis finds
* clk-dt-name:
clk: Convert to using %pOFn instead of device_node.name
* clk-ti-of-node:
clk: ti: fix OF child-node lookup
* clk-sa:
clk: mvebu: armada-37xx-tbg: Switch to clk_get and balance it in probe
reset: hisilicon: fix potential NULL pointer dereference
clk: cdce925: release child device nodes
clk: qcom: clk-branch: Use true and false for boolean values
This patch updates license to use SPDX-License-Identifier
instead of verbose license text.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[rebased against clk-spdx]
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
In preparation to remove the node name pointer from struct device_node,
convert printf users to use the %pOFn format specifier.
Cc: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Cc: Michael Turquette <mturquette@baylibre.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: linux-clk@vger.kernel.org
Cc: linux-renesas-soc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into clk-renesas
Pull Renesas clk driver updates from Geert Uytterhoeven:
- Fix the incorrect display clock on R-Car M3-N,
- Always use readl()/writel(),
- Small fixes.
* tag 'clk-renesas-for-v4.17-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers:
clk: renesas: cpg-mssr: Adjust r8a77980 ifdef
clk: renesas: rcar-gen3: Always use readl()/writel()
clk: renesas: sh73a0: Always use readl()/writel()
clk: renesas: rza1: Always use readl()/writel()
clk: renesas: rcar-gen2: Always use readl()/writel()
clk: renesas: r8a7740: Always use readl()/writel()
clk: renesas: r8a73a4: Always use readl()/writel()
clk: renesas: mstp: Always use readl()/writel()
clk: renesas: div6: Always use readl()/writel()
clk: renesas: r8a77965: Replace DU2 clock
On arm32, there is no reason to use the (soon deprecated)
clk_readl()/clk_writel(). Hence use the generic readl()/writel()
instead.
When we build this driver with on x86-32, gcc produces a false-positive warning:
drivers/clk/renesas/clk-sh73a0.c: In function 'sh73a0_cpg_clocks_init':
drivers/clk/renesas/clk-sh73a0.c:155:10: error: 'parent_name' may be used uninitialized in this function [-Werror=maybe-uninitialized]
return clk_register_fixed_factor(NULL, name, parent_name, 0,
We can work around that warning by adding a fake initialization, I tried
and failed to come up with any better workaround. This is currently one
of few remaining warnings for a 4.14.y randconfig build, so it would be
good to also have it backported at least to that version. Older versions
have more randconfig warnings, so we might not care.
I had not noticed this earlier, because one patch in my randconfig test
tree removes the '-ffreestanding' option on x86-32, and that avoids
the warning. The -ffreestanding flag was originally global but moved
into arch/i386 by Andi Kleen in commit 6edfba1b33c7 ("[PATCH] x86_64:
Don't define string functions to builtin") as a 'temporary workaround'.
Like many temporary hacks, this turned out to be rather long-lived, from
all I can tell we still need a simple fix to asm/string_32.h before it
can be removed, but I'm not sure about how to best do that.
Cc: stable@vger.kernel.org
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
This is part of an ongoing process to migrate from ARCH_SHMOBILE to
ARCH_RENESAS the motivation for which being that RENESAS seems to be a more
appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs.
Along with the above mentioned Kconfig changes it seems appropriate
to also rename files.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
to also rename directories that only hold drivers for such SoCs.
