path: root/drivers/clk/clk-gate.c
2016-04-19clk: gate: Add hw based registration APIsStephen Boyd
Add registration APIs in the clk gate code to return struct clk_hw pointers instead of struct clk pointers. This way we hide the struct clk pointer from providers unless they need to use consumer facing APIs. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2016-01-29clk: move the common clock's to_clk_*(_hw) macros to clk-provider.hGeliang Tang
to_clk_*(_hw) macros have been repeatedly defined in many places. This patch moves all the to_clk_*(_hw) definitions in the common clock framework to public header clk-provider.h, and drop the local definitions. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-28clk: basic-type: Silence warnings about lock imbalancesStephen Boyd
The basic clock types use conditional locking for the register accessor spinlocks. Add __acquire() and __release() markings in the right locations so that sparse isn't tripped up on the conditional locking. drivers/clk/clk-mux.c:68:12: warning: context imbalance in 'clk_mux_set_parent' - different lock contexts for basic block drivers/clk/clk-divider.c:379:12: warning: context imbalance in 'clk_divider_set_rate' - different lock contexts for basic block drivers/clk/clk-gate.c:71:9: warning: context imbalance in 'clk_gate_endisable' - different lock contexts for basic block drivers/clk/clk-fractional-divider.c:36:9: warning: context imbalance in 'clk_fd_recalc_rate' - different lock contexts for basic block drivers/clk/clk-fractional-divider.c:68:12: warning: context imbalance in 'clk_fd_set_rate' - different lock contexts for basic block Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-05-14clk: basic-types: Remove useless allocation failure printksStephen Boyd
Printing an error on kmalloc() failures is unnecessary. Remove the print and use *ptr in sizeof() for future-proof code. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-01-20clk-gate: fix bit # check in clk_register_gate()Sergei Shtylyov
In case CLK_GATE_HIWORD_MASK flag is passed to clk_register_gate(), the bit # should be no higher than 15, however the corresponding check is obviously off- by-one. Fixes: 045779942c04 ("clk: gate: add CLK_GATE_HIWORD_MASK") Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2015-01-17clk: Add clk_unregister_{divider, gate, mux} to close memory leakKrzysztof Kozlowski
The common clk_register_{divider,gate,mux} functions allocated memory for internal data which wasn't freed anywhere. Drivers using these helpers could only unregister clocks but the memory would still leak. Add corresponding unregister functions which will release all resources. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-09-27clk: use uninitialized_var instead setting 'flags' to 0 directly.Xiubo Li
Setting 'flags' to zero will be certainly a misleading way to avoid warning of 'flags' may be used uninitialized. uninitialized_var is a correct way because the warning is a false possitive. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-08-27clk: wrap I/O access for improved portabilityGerhard Sittig
the common clock drivers were motivated/initiated by ARM development and apparently assume little endian peripherals wrap register/peripherals access in the common code (div, gate, mux) in preparation of adding COMMON_CLK support for other platforms Signed-off-by: Gerhard Sittig <gsi@denx.de> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-08-16clk: export fixed-factor, gate & mux registrationMike Turquette
These registration calls may be used by loadable modules. Export them. Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-06-15clk: gate: add CLK_GATE_HIWORD_MASKHaojian Zhuang
In Rockchip Cortex-A9 based chips, they don't use paradigm of reading-changing-writing the register contents. Instead they use a hiword mask to indicate the changed bits. When b1 should be set as gate, it also needs to indicate the change by setting hiword mask (b1 << 16). The patch adds gate flag for this usage. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-07-11clk: Add CLK_IS_BASIC flag to identify basic clocksRajendra Nayak
Most platforms end up using a mix of basic clock types and some which use clk_hw_foo struct for filling in custom platform information when the clocks don't fit into basic types supported. In platform code, its useful to know if a clock is using a basic type or clk_hw_foo, which helps platforms know if they can safely use to_clk_hw_foo to derive the clk_hw_foo pointer from clk_hw. Mark all basic clocks with a CLK_IS_BASIC flag. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-01clk: Use a separate struct for holding init data.Saravana Kannan
Create a struct clk_init_data to hold all data that needs to be passed from the platfrom specific driver to the common clock framework during clock registration. Add a pointer to this struct inside clk_hw. This has several advantages: * Completely hides struct clk from many clock platform drivers and static clock initialization code that don't care for static initialization of the struct clks. * For platforms that want to do complete static initialization, it removed the need to directly mess with the struct clk's fields while still allowing to statically allocate struct clk. This keeps the code more future proof even if they include clk-private.h. * Simplifies the generic clk_register() function and allows adding optional fields in the future without modifying the function signature. * Simplifies the static initialization of clocks on all platforms by removing the need for forward delcarations or convoluted macros. Signed-off-by: Saravana Kannan <skannan@codeaurora.org> [mturquette@linaro.org: kept DEFINE_CLK_* macros and __clk_init] Signed-off-by: Mike Turquette <mturquette@linaro.org> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Jeremy Kerr <jeremy.kerr@canonical.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergman <arnd.bergmann@linaro.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Richard Zhao <richard.zhao@linaro.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Deepak Saxena <dsaxena@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca>
2012-04-24clk: clk-gate: Create clk_gate_endisable()Viresh Kumar
This patch tries to remove duplicate code for clk_gate clocks. This creates another routine clk_gate_endisable() which will take care of enable/disable clock with knowledge of CLK_GATE_SET_TO_DISABLE flag. It works on following logic: For enabling clock, enable = 1 set2dis = 1 -> clear bit -> set = 0 set2dis = 0 -> set bit -> set = 1 For disabling clock, enable = 0 set2dis = 1 -> set bit -> set = 1 set2dis = 0 -> clear bit -> set = 0 So, result is always: enable xor set2dis. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: basic: improve parent_names & return errorsMike Turquette
This patch is the basic clk version of 'clk: core: copy parent_names & return error codes'. The registration functions are changed to allow the core code to copy the array of strings and allow platforms to declare those arrays as __initdata. This patch also converts all of the basic clk registration functions to return error codes which better aligns them with the existing clk.h api. Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: add "const" for clk_ops of basic clksShawn Guo
The clk_ops of basic clks should have "const" to match the definition in "struct clk" and clk_register prototype. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-04-24clk: remove unnecessary EXPORT_SYMBOL_GPLShawn Guo
It makes no sense to have EXPORT_SYMBOL_GPL on static functions. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-03-16clk: basic clock hardware typesMike Turquette
Many platforms support simple gateable clocks, fixed-rate clocks, adjustable divider clocks and multi-parent multiplexer clocks. This patch introduces basic clock types for the above-mentioned hardware which share some common characteristics. Based on original work by Jeremy Kerr and contribution by Jamie Iles. Dividers and multiplexor clocks originally contributed by Richard Zhao & Sascha Hauer. Signed-off-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Mike Turquette <mturquette@ti.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Jeremy Kerr <jeremy.kerr@canonical.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergman <arnd.bergmann@linaro.org> Cc: Paul Walmsley <paul@pwsan.com> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Richard Zhao <richard.zhao@linaro.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Amit Kucheria <amit.kucheria@linaro.org> Cc: Deepak Saxena <dsaxena@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
