Original report: """I used to force my console to black-on-white by the
command `setterm -inversescreen on`. In 2.6.26-rc4, I get lots of black
background characters."""
Another addendum to commit c9e587ab. This was previously missed out since
I was not aware of what vc_decscnm was for.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Reported-by: <thunder7@xs4all.nl>
Tested-by: <thunder7@xs4all.nl>
As commit 6089093e588ee3f6aed99d08b1cf5ea37c52cf97 ("ip2: fix crashes on
load/unload") fixed the ip2 crashes on load/unload by making ip2/ip2main
one module (ip2), Kconfig shouldn't mention a now non-existing module.
Signed-off-by: Roland.Kletzing <devzero@web.de>
Acked-by: Alan Cox <alan@redhat.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Note that by itself, having a "hardware" random generator does very
little: you should probably run "rngd" in your guest to feed this into
the kernel entropy pool.
Included:
virtio_rng: dont use vmalloced addresses for virtio
If virtio_rng is build as a module, random_data is an address
in vmalloc space. As virtio expects guest real addresses, this
can cause any kind of funny behaviour, so lets allocate
random_data dynamically with kmalloc.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
This doesn't need to be two modules, and making it one cleans up the
problem
Signed-off-by: Alan Cox <alan@redhat.com>
Not sure how this snuck upstream, but it really doesn't belong there. We
don't need a KERN_ERR printk in the suspend path to know what's going on (at
least not anymore).
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
I don't use my IBM email address normally and people can find me in
CREDITS.
When a cpu really is stuck in the kernel, it can be often
impossible to figure out which cpu is stuck where. The
worst case is when the stuck cpu has interrupts disabled.
Therefore, implement a global cpu state capture that uses
SMP message interrupts which are not disabled by the
normal IRQ enable/disable APIs of the kernel.
As long as we can get a sysrq 'y' to the kernel, we can
get a dump. Even if the console interrupt cpu is wedged,
we can trigger it from userspace using /proc/sysrq-trigger
The output is made compact so that this facility is more
useful on high cpu count systems, which is where this
facility will likely find itself the most useful :)
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: save and restore dsparb and d_state registers.
drm/i915: fix off by one in VGA save/restore of AR & CR regs.
drm: disable tasklets not IRQs when taking the drm lock spinlock
Revert "drm/vbl rework: rework how the drm deals with vblank."
m68k vme_scc:
- make scc_ports[] static
- kill unused global scc_initialized
Use asm/byteorder.h instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Enabling the BKL to be lockdep tracked uncovered the following
upstream kernel bug in the tty code, which caused a BKL
reference leak:
[ BUG: lock held when returning to user space! ]
dmesg/3121 is leaving the kernel with locks still held!
1 lock held by dmesg/3121:
#0: (kernel_mutex){--..}, at: [<c02f34d9>] opost+0x24/0x194
this might explain some of the atomicity warnings and crashes
that -tip tree testing has been experiencing since the BKL
was converted back to a spinlock.
May 11 09:42:27 [kernel] [ 1104.496819] rarian-sk-get-c[5630]: segfault at 0 ip 7f478556caf0 sp 7fff8e3fe338 error 4 in libc-2.6.1.so[7f47854f9000+136000]
May 11 10:59:48 [kernel] [ 2494.165792]
May 11 10:59:48 [kernel] [ 2494.165794] =======================================================
May 11 10:59:48 [kernel] [ 2494.165801] [ INFO: possible circular locking dependency detected ]
May 11 10:59:48 [kernel] [ 2494.165805] 2.6.26-rc1-00007-g91b3a7a #217
May 11 10:59:48 [kernel] [ 2494.165807] -------------------------------------------------------
May 11 10:59:48 [kernel] [ 2494.165809] less/7053 is trying to acquire lock:
May 11 10:59:48 [kernel] [ 2494.165812] (tasklist_lock){..??}, at: [<ffffffff80232e95>] is_current_pgrp_orphaned+0x15/0x50
May 11 10:59:48 [kernel] [ 2494.165821]
May 11 10:59:48 [kernel] [ 2494.165822] but task is already holding lock:
May 11 10:59:48 [kernel] [ 2494.165824] (&tty->ctrl_lock){....}, at: [<ffffffff803d5f31>] tty_check_change+0x61/0x110
May 11 10:59:48 [kernel] [ 2494.165831]
May 11 10:59:48 [kernel] [ 2494.165832] which lock already depends on the new lock.
May 11 10:59:48 [kernel] [ 2494.165833]
May 11 10:59:48 [kernel] [ 2494.165835]
May 11 10:59:48 [kernel] [ 2494.165836] the existing dependency chain (in reverse order) is:
May 11 10:59:48 [kernel] [ 2494.165838]
May 11 10:59:48 [kernel] [ 2494.165839] -> #2 (&tty->ctrl_lock){....}:
May 11 10:59:48 [kernel] [ 2494.165843] [<ffffffff80253796>] __lock_acquire+0xf86/0x1080
May 11 10:59:48 [kernel] [ 2494.165851] [<ffffffff80253922>] lock_acquire+0x92/0xc0
May 11 10:59:48 [kernel] [ 2494.165858] [<ffffffff804deee0>] _spin_lock_irqsave+0x40/0x60
May 11 10:59:48 [kernel] [ 2494.165866] [<ffffffff803d31b5>] __proc_set_tty+0x35/0xe0
May 11 10:59:48 [kernel] [ 2494.165873] [<ffffffff803d76d4>] tty_ioctl+0xbf4/0xfe0
May 11 10:59:48 [kernel] [ 2494.165880] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90
May 11 10:59:48 [kernel] [ 2494.165888] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0
May 11 10:59:48 [kernel] [ 2494.165895] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80
May 11 10:59:48 [kernel] [ 2494.165902] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80
May 11 10:59:48 [kernel] [ 2494.165910] [<ffffffffffffffff>] 0xffffffffffffffff
May 11 10:59:48 [kernel] [ 2494.165924]
May 11 10:59:48 [kernel] [ 2494.165925] -> #1 (&sighand->siglock){++..}:
May 11 10:59:48 [kernel] [ 2494.165929] [<ffffffff80253796>] __lock_acquire+0xf86/0x1080
May 11 10:59:48 [kernel] [ 2494.165936] [<ffffffff80253922>] lock_acquire+0x92/0xc0
May 11 10:59:48 [kernel] [ 2494.165943] [<ffffffff804dec1f>] _spin_lock+0x2f/0x40
May 11 10:59:48 [kernel] [ 2494.165951] [<ffffffff8022d5a3>] copy_process+0x973/0x1210
May 11 10:59:48 [kernel] [ 2494.165959] [<ffffffff8022df12>] do_fork+0x82/0x2f0
May 11 10:59:48 [kernel] [ 2494.165967] [<ffffffff8020bfe1>] kernel_thread+0x81/0xde
May 11 10:59:48 [kernel] [ 2494.165974] [<ffffffff8020c048>] child_rip+0xa/0x12
May 11 10:59:48 [kernel] [ 2494.165981] [<ffffffffffffffff>] 0xffffffffffffffff
May 11 10:59:48 [kernel] [ 2494.166038]
May 11 10:59:48 [kernel] [ 2494.166039] -> #0 (tasklist_lock){..??}:
May 11 10:59:48 [kernel] [ 2494.166043] [<ffffffff802535ab>] __lock_acquire+0xd9b/0x1080
May 11 10:59:48 [kernel] [ 2494.166050] [<ffffffff80253922>] lock_acquire+0x92/0xc0
May 11 10:59:48 [kernel] [ 2494.166057] [<ffffffff804dede2>] _read_lock+0x32/0x50
May 11 10:59:48 [kernel] [ 2494.166063] [<ffffffff80232e95>] is_current_pgrp_orphaned+0x15/0x50
May 11 10:59:48 [kernel] [ 2494.166071] [<ffffffff803d5f80>] tty_check_change+0xb0/0x110
May 11 10:59:48 [kernel] [ 2494.166078] [<ffffffff803dac5f>] set_termios+0x1f/0x4c0
May 11 10:59:48 [kernel] [ 2494.166085] [<ffffffff803db379>] tty_mode_ioctl+0x279/0x3e0
May 11 10:59:48 [kernel] [ 2494.166092] [<ffffffff803db51d>] n_tty_ioctl+0x3d/0x260
May 11 10:59:48 [kernel] [ 2494.166100] [<ffffffff803d6c34>] tty_ioctl+0x154/0xfe0
May 11 10:59:48 [kernel] [ 2494.166107] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90
May 11 10:59:48 [kernel] [ 2494.166114] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0
May 11 10:59:48 [kernel] [ 2494.166121] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80
May 11 10:59:48 [kernel] [ 2494.166128] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80
May 11 10:59:48 [kernel] [ 2494.166135] [<ffffffffffffffff>] 0xffffffffffffffff
May 11 10:59:48 [kernel] [ 2494.166142]
May 11 10:59:48 [kernel] [ 2494.166143] other info that might help us debug this:
May 11 10:59:48 [kernel] [ 2494.166144]
May 11 10:59:48 [kernel] [ 2494.166146] 1 lock held by less/7053:
May 11 10:59:48 [kernel] [ 2494.166148] #0: (&tty->ctrl_lock){....}, at: [<ffffffff803d5f31>] tty_check_change+0x61/0x110
May 11 10:59:48 [kernel] [ 2494.166155]
May 11 10:59:48 [kernel] [ 2494.166156] stack backtrace:
May 11 10:59:48 [kernel] [ 2494.166159] Pid: 7053, comm: less Not tainted 2.6.26-rc1-00007-g91b3a7a #217
May 11 10:59:48 [kernel] [ 2494.166161]
May 11 10:59:48 [kernel] [ 2494.166162] Call Trace:
May 11 10:59:48 [kernel] [ 2494.166168] [<ffffffff80251223>] print_circular_bug_tail+0x83/0x90
May 11 10:59:48 [kernel] [ 2494.166172] [<ffffffff80250889>] ? print_circular_bug_entry+0x49/0x60
May 11 10:59:48 [kernel] [ 2494.166178] [<ffffffff802535ab>] __lock_acquire+0xd9b/0x1080
May 11 10:59:48 [kernel] [ 2494.166184] [<ffffffff80232e95>] ? is_current_pgrp_orphaned+0x15/0x50
May 11 10:59:48 [kernel] [ 2494.166189] [<ffffffff80253922>] lock_acquire+0x92/0xc0
May 11 10:59:48 [kernel] [ 2494.166206] [<ffffffff803d5f80>] tty_check_change+0xb0/0x110
May 11 10:59:48 [kernel] [ 2494.166211] [<ffffffff803dac5f>] set_termios+0x1f/0x4c0
May 11 10:59:48 [kernel] [ 2494.166216] [<ffffffff803d3423>] ? tty_ldisc_try+0x23/0x60
May 11 10:59:48 [kernel] [ 2494.166220] [<ffffffff803d3444>] ? tty_ldisc_try+0x44/0x60
May 11 10:59:48 [kernel] [ 2494.166224] [<ffffffff804df2c5>] ? _spin_unlock_irqrestore+0x65/0x80
May 11 10:59:48 [kernel] [ 2494.166230] [<ffffffff803db379>] tty_mode_ioctl+0x279/0x3e0
May 11 10:59:48 [kernel] [ 2494.166234] [<ffffffff803d3444>] ? tty_ldisc_try+0x44/0x60
May 11 10:59:48 [kernel] [ 2494.166239] [<ffffffff803db51d>] n_tty_ioctl+0x3d/0x260
May 11 10:59:48 [kernel] [ 2494.166244] [<ffffffff803d6c34>] tty_ioctl+0x154/0xfe0
May 11 10:59:48 [kernel] [ 2494.166249] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080
May 11 10:59:48 [kernel] [ 2494.166256] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080
May 11 10:59:48 [kernel] [ 2494.166263] [<ffffffff80252baa>] ? __lock_acquire+0x39a/0x1080
May 11 10:59:48 [kernel] [ 2494.166269] [<ffffffff802a05e1>] vfs_ioctl+0x31/0x90
May 11 10:59:48 [kernel] [ 2494.166274] [<ffffffff802a06b3>] do_vfs_ioctl+0x73/0x2d0
May 11 10:59:48 [kernel] [ 2494.166280] [<ffffffff802a095a>] sys_ioctl+0x4a/0x80
May 11 10:59:48 [kernel] [ 2494.166286] [<ffffffff8020b5ab>] system_call_after_swapgs+0x7b/0x80
May 11 10:59:48 [kernel] [ 2494.166292]
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Select FW_LOADER since moxa needs it, otherwise we face link problems such
as:
drivers/built-in.o: In function
moxa_pci_probe':moxa.c:(.devinit.text+0x76d8): undefined reference to
request_firmware'
:moxa.c:(.devinit.text+0x7e6e): undefined reference to release_firmware'
make: *** [.tmp_vmlinux1] Error 1
Reported-by: Philippe Roussel <p.o.roussel@free.fr>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
The current OF probing assumes that the resource is IORESOURCE_MEM. This
checks for the IORESOURCE_IO flag and behaves appropriately. An I/O resource
can exist with an ipmi device node on a legacy ISA bus.
Signed-off-by: Nate Case <ncase@xes-inc.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
drivers/char/synclink_gt.c: In function 'put_char':
drivers/char/synclink_gt.c:919: warning: 'ret' may be used uninitialized in this function
The compiler speaketh truth.
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
For e.g. proper TTY canonical support, IUTF8 termios flag has to be set as
appropriate. Linux used to not care about setting that flag for VT TTYs.
This patch fixes that by activating it according to the current mode of the
VT, and sets the default value according to the vt.default_utf8 parameter.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Willy Tarreau <w@1wt.eu>
Cc: <stable@kernel.org>
drivers/char/sx.c: In function 'sx_set_real_termios':
drivers/char/sx.c:973: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
drivers/char/sx.c:999: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'tcflag_t'
drivers/char/sx.c:1012: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'tcflag_t'
sparc32 seems to use weird types for its tty things.
[ Fine by me but this is ancient debug and most of the debug in sx just
wants deleting eventually. - Alan ]
turns out it's important to save/restore AR14 in particular.
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4.
Okay this looks like wasn't as fully baked as I'd led myself to believe.
Revert for now for further baking.
commit a5b08c66194fba02a865b397579b7204688bcb1e
Author: Alan Cox <alan@lxorguk.ukuu.org.uk>
Date: Wed Apr 30 00:54:05 2008 -0700
serial167: switch to int put_char method
missed one case when adding return values.
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Bolt in SLB entry for kernel stack on secondary cpus
[POWERPC] PS3: Update ps3_defconfig
[POWERPC] PS3: Remove unsupported wakeup sources
[POWERPC] PS3: Make ps3_virq_setup and ps3_virq_destroy static
[POWERPC] PS3: Add time include to lpm
[POWERPC] Fix slb.c compile warnings
[POWERPC] Xilinx: Fix compile warnings
[POWERPC] Squash build warning for print of resource_size_t in fsl_soc.c
[RAPIDIO] fix current kernel-doc notation
[POWERPC] 86xx: mpc8610_hpcd: add support for PCI Express x8 slot
Fix a potential issue in mpc52xx uart driver
[POWERPC] mpc5200: Allow for fixed speed MII configurations
[POWERPC] 86xx: Fix the wrong serial1 interrupt for 8610 board
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
[PATCH] fix sysctl_nr_open bugs
[PATCH] sanitize anon_inode_getfd()
[PATCH] split linux/file.h
[PATCH] make osf_select() use core_sys_select()
[PATCH] remove horrors with irix tty ioctls handling
[PATCH] fix file and descriptor handling in perfmon
arch/powerpc/sysdev/xilinx_intc.c: In function 'xilinx_intc_init':
arch/powerpc/sysdev/xilinx_intc.c:111: warning: format '%08X' expects type 'unsigned int', but argument 2 has type 'resource_size_t'
drivers/char/xilinx_hwicap/xilinx_hwicap.c: In function 'hwicap_setup':
drivers/char/xilinx_hwicap/xilinx_hwicap.c:626: warning: cast to pointer from integer of different size
drivers/char/xilinx_hwicap/xilinx_hwicap.c:646: warning: format '%x' expects type 'unsigned int', but argument 6 has type 'resource_size_t'
Initial splitoff of the low-level stuff; taken to fdtable.h
Repair the effects of
commit 55da77899c1472d83452c914fa179d00ea96df65
Date: Wed Apr 30 00:54:07 2008 -0700
synclink series: switch to int put_char method
and do some whitespace repair and unneeded-cast-removal in there as well.
The i8k driver multiplies the fan speed reported by the BIOS with a factor of
30. On my Dell Latitude D800, this factor is not required.
I'd suggest to make this configurable.
x86 is the only arch right now, which provides an optimized for
div_long_long_rem and it has the downside that one has to be very careful that
the divide doesn't overflow.
The API is a little akward, as the arguments for the unsigned divide are
signed. The signed version also doesn't handle a negative divisor and
produces worse code on 64bit archs.
There is little incentive to keep this API alive, so this converts the few
users to the new API.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Christoph Lameter <clameter@sgi.com>
The switch of ioremap to default to uncached doesn't break this driver
but it does needlessly slow it down as BIOS space is cachable and this
driver is quite happy scanning cached ROM space.
__FUNCTION__ is gcc-specific, use __func__
This adds a minimalistic braille screen reader support. This is meant to
be used by blind people e.g. on boot failures or when / cannot be mounted
etc and thus the userland screen readers can not work.
[akpm@linux-foundation.org: fix exports]
Cc: Jiri Kosina <jikos@jikos.cz>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Factor out the code used to allocate/free a pts index into new interfaces,
devpts_new_index() and devpts_kill_index(). This localizes the external data
structures used in managing the pts indices.
[akpm@linux-foundation.org: undo accidental mutex2sem conversion]
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Have ptmx_open() propagate any error code returned by devpts_pty_new()
(which returns either 0 or -ENOMEM anyway).
Acked-by: Serge Hallyn <serue@us.ibm.com>
At ptmx_open(), the 2nd parameter for check_tty_count() should
be "ptmx_open".
Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Simple search/replace except for synclink.c where I noticed a real bug and
fixed it too. It was doing NULL + offset, then checking for NULL if the remap
failed.
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Something Arjan suggested which allows us to clean up the code nicely
Cc: Arjan van de Ven <arjan@infradead.org>
Fix the rather strange buffer management on open that turned up while auditing
for BKL dependencies.
Clean up the epca driver
- Operations are now a shared const function block as with most other Linux
objects
- Introduce wrappers for some optional functions to get consistent behaviour
- Wrap put_char which used to be patched by the tty layer
- Document which functions are needed/optional
- Make put_char report success/fail
- Cache the driver->ops pointer in the tty as tty->ops
- Remove various surplus lock calls we no longer need
- Remove proc_write method as noted by Alexey Dobriyan
- Introduce some missing sanity checks where certain driver/ldisc
combinations would oops as they didn't check needed methods were present
[akpm@linux-foundation.org: fix fs/compat_ioctl.c build]
[akpm@linux-foundation.org: fix isicom]
[akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build]
[akpm@linux-foundation.org: fix kgdb]
Cc: Jason Wessel <jason.wessel@windriver.com>
[akpm@linux-foundation.org: fix arm, cleanups]
We are about to change the tty layer to avoid keeping private copies of all
the methods in each tty. We have to update the pty layer first as it
currently patches the ioctl method according to the tty type. Use multiple
tty operations sets instead.
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Cc: Antonino Daplas <adaplas@pol.net>
Cc: Kelly Daly <kelly@au.ibm.com>
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
