path: root/drivers/char
2006-04-11[PATCH] ipmi: fix event queue limitCorey Minyard
The event handler mechanism in the IPMI driver had a limit on the number of received events, but the counts were not being updated. Update the counts to impose a limit. This is not a critical fix, as this function (the sending of the events) has to be turned on by the user, anyway. This avoids problems if they forget to turn it back off. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] MPBL0010 driver sysfs permissions wide openMark Bellon
The MPBL0010 Telco clock driver (drivers/char/tlclk.c) uses 0222 (anyone can write) permissions on its writable sysfs entries. Alter the permissions to 0220 (owner and group can write). The use case for this driver is to configure the fail over behavior of the clock hardware. That should be done by the more privileged users. Signed-off-by: Mark Bellon <mbellon@mvista.com> Acked-by: "Gross, Mark" <mark.gross@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] tty release_dev(): remove dead codePaul Fulghum
Remove dead code from tty_io.c release_dev() Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] ptmx: fix duplicate idr_removePaul Fulghum
Remove duplicate call to idr_remove() in ptmx_open. Error during open can result in call to release_dev() followed by call to idr_remove(). release_dev already calls idr_remove so the second call can cause a stack dump in idr_remove()->sub_remove() flagging an attempt to release an already released entry. I reproduces this on a machine with a misconfigured X server (attempting to restart multiple times rapidly) getting the same error as the 1st link below. This also seems to be related to: http://marc.theaimsgroup.com/?l=selinux&m=110536513426735&w=2 http://marc.theaimsgroup.com/?l=selinux&m=110596994916785&w=2 The stack dump can occur on close (as well as open) as shown in the 1st instance above, possible from something like: process A - open (index=0), open fail to out1, release_dev calls idr_remove (index 0), down(sem) sleeps process B - open (index=0), open OK (idr allocated) process A - wake and call idr_remove on index 0 ... process B - close, release_dev, stack dump on idr_remove (index=0) because entry already removed Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Remove extraneous \n in doubletalk init printk.Dave Jones
Doubletalk printk's an extraneous \n Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] make tty_insert_flip_string_flags() a non gpl exportAndrew Morton
We changed the wrong symbol. It's tty_insert_flip_string_flags() which is called from the previously-non-GPL'ed now-inlined tty_insert_flip_char(). Fix that up, and uninline tty_schedule_flip() while we're there. Cc: Tobias Powalowski <t.powa@gmx.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[IPV6]: Unexport secure_ipv6_port_ephemeralAdrian Bunk
This patch removes the unused EXPORT_SYMBOL(secure_ipv6_port_ephemeral). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-07drm: deline a few large inlines in DRM codeDave Airlie
This patch moves a few large functions from drm_memory.h to drm_memory.c, with the following effect: text data bss dec hex filename 46305 1304 20 47629 ba0d new/drm.ko 46367 1304 20 47691 ba4b org/drm.ko 12969 1372 0 14341 3805 new/i810.ko 14712 1372 0 16084 3ed4 org/i810.ko 16447 1364 0 17811 4593 new/i830.ko 18198 1364 0 19562 4c6a org/i830.ko 11875 1324 0 13199 338f new/i915.ko 13025 1324 0 14349 380d org/i915.ko 23936 29288 0 53224 cfe8 new/mga.ko 27280 29288 0 56568 dcf8 org/mga.ko Please apply. Signed-off-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-05drm: remove master setting from add/remove contextDave Airlie
Clients can do this in the miniglx setups. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-05drm: drm_pci needs dma-mapping.hDave Airlie
On alpha: WARNING: "dma_free_coherent" [drivers/char/drm/drm.ko] undefined! WARNING: "dma_alloc_coherent" [drivers/char/drm/drm.ko] undefined! Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-05[PATCH] drm: Fix issue reported by Coverity in drivers/char/drm/via_irq.cDave Airlie
This patch tries to fix an issue reported in drivers/char/drm/via_irq.c by Coverity, please review and apply if correct. Error reported: CID: 3444 Checker: REVERSE_INULL (help) File: /export2/p4-coverity/mc2/linux26/drivers/char/drm/via_irq.c Function: via_driver_irq_wait Description: Pointer "dev_priv" dereferenced before NULL check Patch Description: Move de-referencing dev_priv to after the NULL check. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-02Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] at91_wdt.c - Atmel AT91RM9200 watchdog driver [WATCHDOG] pcwd_usb.c: fix a NULL pointer dereference [WATCHDOG] pcwd.c sprintf/strcpy fix [WATCHDOG] pcwd.c general clean-up after patches [WATCHDOG] pcwd.c add debug info [WATCHDOG] pcwd.c pcwd_cleanup_module patch [WATCHDOG] pcwd.c firmware-info patch [WATCHDOG] pcwd.c control status patch
2006-04-02Merge master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (33 commits) [PATCH] pcmcia: declare pccard_iodyn_ops (fix m8xx_pcmcia.c compilation error) [PATCH] pcmcia: fix pcmcia_device_remove oops [PATCH] pcmcia: Add support for Possio GCC AKA PCMCIA Siemens MC45 [PATCH] pcmcia: pseudo device handling update [PATCH] pcmcia: convert DEV_OK to pcmcia_dev_present [PATCH] pcmcia: use bitfield instead of p_state and state [PATCH] pcmcia: remove unused p_dev->state flags [PATCH] pcmcia: make pcmcia_release_{io,irq} static [PATCH] pcmcia: add return value to _config() functions [PATCH] pcmcia: remove dev_link_t and client_handle_t indirection [PATCH] pcmcia: embed dev_link_t into struct pcmcia_device [PATCH] pcmcia: rename pcmcia_device.state [PATCH] pcmcia: remove unneeded Vcc pseudo setting [PATCH] pcmcia: remove export of pcmcia_release_configuration [PATCH] pcmcia: default suspend and resume handling [PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irq [PATCH] pcmcia: add pcmcia_disable_device [PATCH] serial_cs: add Merlin U630 IDs [PATCH] pcmcia: AT91RM9200 Compact Flash driver [PATCH] pcmcia: socket.functions starts with 1 ...
2006-04-02Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (26 commits) Input: add support for Braille devices Input: synaptics - limit rate to 40pps on Toshiba Protege M300 Input: gamecon - add SNES mouse support Input: make modalias code respect allowed buffer size Input: convert /proc handling to seq_file Input: limit attributes' output to PAGE_SIZE Input: gameport - fix memory leak Input: serio - fix memory leak Input: zaurus keyboard driver updates Input: i8042 - fix logic around pnp_register_driver() Input: ns558 - fix logic around pnp_register_driver() Input: pcspkr - separate device and driver registration Input: atkbd - allow disabling on X86_PC (if EMBEDDED) Input: atkbd - disable softrepeat for dumb keyboards Input: atkbd - fix complaints about 'releasing unknown key 0x7f' Input: HID - fix duplicate key mapping for Logitech UltraX remote Input: use kzalloc() throughout the code Input: fix input_free_device() implementation Input: initialize serio and gameport at subsystem level Input: uinput - semaphore to mutex conversion ...
2006-04-02[WATCHDOG] at91_wdt.c - Atmel AT91RM9200 watchdog driverAndrew Victor
Watchdog driver for the Atmel AT91RM9200 processor. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-04-02[WATCHDOG] pcwd_usb.c: fix a NULL pointer dereferenceAdrian Bunk
The Coverity checker noted that this resulted in a NULL pointer reference if we were coming from if (usb_pcwd == NULL) { printk(KERN_ERR PFX "Out of memory\n"); goto error; } Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-04-02[WATCHDOG] pcwd.c sprintf/strcpy fixWim Van Sebroeck
change sprintf(pcwd_private.fw_ver_str, "ERROR"); to strcpy... as pointed out by Andrew Morton. Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-04-02[WATCHDOG] pcwd.c general clean-up after patchesWim Van Sebroeck
removal of includes (since we don't use kmalloc and TASK_INTERRUPTABLE anymore). Addition of missing commands. Printk that lets the user know when the module was unloaded. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-04-02[WATCHDOG] pcwd.c add debug infoWim Van Sebroeck
Add debugging info for the pcwd.c module. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-04-02[WATCHDOG] pcwd.c pcwd_cleanup_module patchWim Van Sebroeck
static void pcwd_cleanup_module doesn't need a return; Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-04-02[WATCHDOG] pcwd.c firmware-info patchWim Van Sebroeck
Get the firmware version into the private data struct of the ISA-PC watchdog card. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-04-02[WATCHDOG] pcwd.c control status patchWim Van Sebroeck
Clean-up the control status code (insert tabs where relevant), Add new Control Status defines, Make sure that the R2DS bit stays the same. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-04-02Input: add support for Braille devicesSamuel Thibault
- Add KEY_BRL_* input keys and K_BRL_* keycodes; - Add emulation of how braille keyboards usually combine braille dots to the console keyboard driver; - Add handling of unicode U+28xy diacritics. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-01[PATCH] powerpc/pseries: Change H_StudlyCaps to H_SHOUTING_CAPSSegher Boessenkool
Also cleans up some nearby whitespace problems. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-31[PATCH] vt: add TIOCL_GETKMSGREDIRECTRafael J. Wysocki
Add TIOCL_GETKMSGREDIRECT needed by the userland suspend tool to get the current value of kmsg_redirect from the kernel so that it can save it and restore it after resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] drivers/char/[i]stallion: Clean up kmalloc usageTobias Klauser
Delete two useless kmalloc wrappers and use kmalloc/kzalloc. Some weird NULL checks are also simplified. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] IPMI: convert from semaphores to mutexesCorey Minyard
Convert the remaining semaphores to mutexes in the IPMI driver. The watchdog was using a semaphore as a real semaphore (for IPC), so the conversion there required adding a completion. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] IPMI: tidy up various thingsCorey Minyard
Tidy up various coding standard things, mostly removing the space after !, but also break some long lines and fix a few other spacing inconsistencies. Also fixes some bad error reporting when deleting an IPMI user. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] IPMI: fix startup race conditionCorey Minyard
Matt Domsch noticed a startup race with the IPMI kernel thread, it was possible (though extraordinarly unlikely) that a message could come in before the upper layer was ready to handle it. This patch splits the startup processing of an IPMI interface into two parts, one to get ready and one to actually start the processes to receive messages from the interface. [akpm@osdl.org: cleanups] Signed-off-by: Corey Minyard <minyard@acm.org> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] make tty_insert_flip_string a non-GPL exportAndrew Morton
Alan sayeth "Based on Linus original comments about _GPL we should export tty_insert_flip_char as EXPORT_SYMBOL because it used to be EXPORT_SYMBOL equivalent (trivial inline). The other features are new extensions are were not available to drivers before so need not be provided except as _GPL functionality as far as I can see." Addresses http://bugzilla.kernel.org/show_bug.cgi?id=6294 Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Philippe Vouters <Philippe.Vouters@laposte.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_presentDominik Brodowski
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present(). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-30Merge branch 'drm-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: remove drm_{alloc,free}_pages drm: sis fix compile warning drm: add new radeon PCI ids.. drm: read breadcrumb in IRQ handler drm: fixup i915 breadcrumb read/write drm: remove pointless checks in radeon_state drm: fixup improper cast. drm: rationalise some pci ids drm: Add general-purpose packet for manipulating scratch registers (r300) drm: rework radeon memory map (radeon 1.23) drm: update r300 register names drm: fixup PCI DMA support
2006-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (67 commits) [PATCH] powerpc: Remove oprofile spinlock backtrace code [PATCH] powerpc: Add oprofile calltrace support to all powerpc cpus [PATCH] powerpc: Add oprofile calltrace support [PATCH] for_each_possible_cpu: ppc [PATCH] for_each_possible_cpu: powerpc [PATCH] lock PTE before updating it in 440/BookE page fault handler [PATCH] powerpc: Kill _machine and hard-coded platform numbers ppc: Fix compile error in arch/ppc/lib/strcase.c [PATCH] git-powerpc: WARN was a dumb idea [PATCH] powerpc: a couple of trivial compile warning fixes powerpc: remove OCP references powerpc: Make uImage default build output for MPC8540 ADS powerpc: move math-emu over to arch/powerpc powerpc: use memparse() for mem= command line parsing ppc: fix strncasecmp prototype [PATCH] powerpc: make ISA floppies work again [PATCH] powerpc: Fix some initcall return values [PATCH] powerpc: Workaround for pSeries RTAS bug [PATCH] spufs: fix __init/__exit annotations [PATCH] powerpc: add hvc backend for rtas ...
2006-03-28[PATCH] do_SAK: don't depend on session ID 0Eric W. Biederman
I'm not really certain what the thinking was but the code obviously wanted to walk processes other than just those in it's session, for purposes of do_SAK. Just walking those tasks that don't have a session assigned sounds at the very least incomplete. So modify the code to kill everything in the session and anything else that might have the tty open. Hopefully this helps if the do_SAK functionality is ever finished. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] do_tty_hangup: use group_send_sig_info not send_group_sig_infoEric W. Biederman
We already have the tasklist_lock so there is no need for us to reacquire it with send_group_sig_info. reader/writer locks allow multiple readers and thus recursion so the old code was ok just wastful. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-29drm: remove drm_{alloc,free}_pagesDave Airlie
drm_alloc_pages and drm_free_pages can now be removed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-03-29drm: sis fix compile warningDave Airlie
Prevent a gcc warning in the SIS DRM driver. offset is a unsigned int and the printk wants a long. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] nvidia-agp: use time_before_eq()Marcelo Feitoza Parisi
It deals with wrapping correctly and is nicer to read. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] synclink_gt: remove uneeded async codePaul Fulghum
Remove code in async receive handling that serves no purpose with new tty receive buffering. Previously this code tried to free up receive buffer space, but now does nothing useful while making expensive calls. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] synclink_gt add gpio featurePaul Fulghum
Add driver support for general purpose I/O feature of the Synclink GT adapters. Signed-off-by: Paul Fulghum <paulkf@micrgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
