path: root/drivers/char/watchdog/mv64x60_wdt.c
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Rework the timeout register manipulationDale Farnsworth
Consolidate the timeout config register modification into a single function. Also, use the enabled flag in the config register to determine whether the timer is enabled instead of a separately maintained flag, MV64x60_WDOG_FLAG_ENABLED. Add spinlock protection around enabling/disabling the watchdog timer. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: disable watchdog timer when driver is probedDale Farnsworth
Make sure that we disable the watchdog at start-up. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Support the WDIOF_MAGICCLOSE featureDale Farnsworth
Disallow disabling of the watchdog timer unless a particular character ('V') was recently written to the watchdog device. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Add a module parameter to change nowayout settingDale Farnsworth
Also, use the WATCHDOG_NOWAYOUT macro, rather than #ifdefs, and use __module_get to prevent module unloading if WATCHDOG_NOWAYOUT is set. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Add WDIOC_SETOPTIONS ioctl supportDale Farnsworth
Allow the watchdog timer to be enabled or disabled via the WDIOC_SETOPTIONS ioctl. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Support for WDIOC_SETTIMEOUT ioctlDale Farnsworth
Add the ability to modify the watchdog timer timeout interval. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Fix WDIOC_GETTIMEOUT return valueDale Farnsworth
WDIOC_GETTIMEOUT returns seconds, not jiffies. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Check return value of nonseekable_openDale Farnsworth
Return the value of the nonseekable_open function and not 0. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Add arch/powerpc platform supportDale Farnsworth
Add support for arch/powerpc, specifically for the prpmc2800 platform. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: Get register address from platform dataDale Farnsworth
Previously, the address of the watchdog timer registers was retrieved by calling a global function, mv64x60_get_bridge_vbase(). That function doesn't exist in arch/powerpc. Instead, we now get the register address from a platform data resource and ioremap the registers within the driver. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[WATCHDOG] mv64x60_wdt: set up platform_device in platform codeDale Farnsworth
The driver previously registered its platform device data in its own init function--that's bogus. Move that code to platform-specific code in arch/ppc. This is being done so that the platform code can decide at runtime whether to initialize this driver or not. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-10-02[WATCHDOG] use ENOTTY instead of ENOIOCTLCMD in ioctl()Samuel Tardieu
Return ENOTTY instead of ENOIOCTLCMD in user-visible ioctl() results The watchdog drivers used to return ENOIOCTLCMD for bad ioctl() commands. ENOIOCTLCMD should not be visible by the user, so use ENOTTY instead. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mv64x600_wdt: convert to the new platform device interfaceDmitry Torokhov
mv64x600_wdt: convert to the new platform device interface Do not use platform_device_register_simple() as it is going away. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-01[WATCHDOG] adds device_driver .owner fieldWim Van Sebroeck
Initialise the .owner field of the device driver with the module that owns it, for easier tracking of device driver ownership. (probably also better for sysfs...) Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-29[PATCH] mv64x60_wdt __user annotations and cleanupsAl Viro
- use nonseekable_open() instead of messing with if (*ppos != file->f_pos) return -EISPIPE in ->write() (->read is NULL). - trivial __user annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[WATCHDOG] mv64x60_wdt.patchJames Chapman
Add mv64x60 (Marvell Discovery) watchdog support. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
