path: root/drivers/char/vc_screen.c
2009-03-24vcs: hook sysfs devices into object lifetime instead of "binding"Kay Sievers
During bootup performance tracing I noticed many occurrences of vca* device creation and removal, leading to the usual userspace uevent processing, which are, in this case, rather pointless. A simple test showing the kernel timing (not including all the work userspace has to do), gives us these numbers: $ time for i in `seq 1000`; do echo a > /dev/tty2; done real 0m1.142s user 0m0.015s sys 0m0.540s If we move the hook for the vcs* driver core devices from the tty "binding" to the vc allocation/deallocation, which is what the vcs* devices represent, we get the following numbers: $ time for i in `seq 1000`; do echo a > /dev/tty2; done real 0m0.152s user 0m0.030s sys 0m0.072s Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: char: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-20vcs: BKL pushdownJonathan Corbet
Add explicit BKL to vcs_open(). Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2007-05-08use mutex instead of semaphore in virtual console driverMatthias Kaehlcke
The virtual console driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert char-driversJosef Sipek
2006-12-01Driver core: convert vc code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-29[PATCH] There is no devfs, there has never been a devfs, we have always been ↵Alan Cox
at war with... Jon Smirl noted a couple of tty driver functions now are quite misleadingly named with the death of devfs. A quick grep found another case in the lp driver. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-29[PATCH] fix ia64 compile failure with gcc4.1Dave Jones
__get_unaligned creates a typeof the var its passed, and writes to it, which on gcc4.1, spits out the following error: drivers/char/vc_screen.c: In function 'vcs_write': drivers/char/vc_screen.c:422: error: assignment of read-only variable 'val' Signed-off-by: Dave Jones <davej@redhat.com> [ The "right" fix would be to try to fix <asm-generic/unaligned.h> but that's hard to do with the tools gcc gives us. So this simpler patch is preferable -- Linus ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] class: convert drivers/char/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
