path: root/drivers/char/tty_ioctl.c
2008-04-30tty: add throttle/unthrottle helpersAlan Cox
Something Arjan suggested which allows us to clean up the code nicely Signed-off-by: Alan Cox <alan@redhat.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty_ioctl: soft carrier handlingAlan Cox
First cut at moving the soft carrier handling knowledge entirely into the core code. One or two drivers still needed to snoop these functions to track CLOCAL internally. Instead make TIOCSSOFTCAR generate the same driver calls as other termios ioctls changing the clocal flag. This allows us to remove any driver knowledge and special casing. Also while we are at it we can fix the error handling. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty_ioctl: locking for tty_wait_until_sentAlan Cox
This function still depends on the big kernel lock in some cases. Push locking into the function ready for removal of the BKL from ioctl call paths. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: BKL pushdownAlan Cox
- Push the BKL down into the line disciplines - Switch the tty layer to unlocked_ioctl - Introduce a new ctrl_lock spin lock for the control bits - Eliminate much of the lock_kernel use in n_tty - Prepare to (but don't yet) call the drivers with the lock dropped on the paths that historically held the lock BKL now primarily protects open/close/ldisc change in the tty layer [jirislaby@gmail.com: a couple of fixes] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08tty_ioctl: drag screaming into compliance with the coding styleAlan Cox
2008-01-08pl2303: Fix mode switching regressionAlan Cox
Cleaning out all the incorrect 'no change made' checks for termios settings showed up a problem with the PL2303. The hardware here seems to lose sync and bits if you tell it to make no changes. This shows up with a real world application. To fix this the driver check for meaningful hardware changes is restored but doing the tests correctly and as a tty layer function so it doesn't get duplicated wrongly everywhere if other drivers turn out to need it. Signed-off-by: Alan Cox <alan@redhat.com> Tested-by: Mirko Parthey <mirko.parthey@informatik.tu-chemnitz.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23tty: fix logic change introduced by wait_event_interruptible_timeout()Cory T. Tusar
Commit 5a52bd4a2dcb570333ce6fe2e16cd311650dbdc8 introduced a subtle logic change in tty_wait_until_sent(). The original version would only error out of the 'do { ... } while (timeout)' loop if signal_pending() evaluated to true; a timeout or break due to an empty buffer would fall out of the loop and into the tty->driver->wait_until_sent handling. The current implementation will error out on either a pending signal or an empty buffer, falling through to the tty->driver->wait_until_sent handling only on a timeout. The ->wait_until_sent() will not be reached if the buffer empties before timeout jiffies have elapsed. This behavior differs from that prior to commit 5a52bd4a2dcb570333ce6fe2e16cd311650dbdc8. I turned this up while using a little serial download utility to bootstrap an ARM-based eval board. The util worked fine on 2.6.22.x, but consistently failed on 2.6.23.x. Once I'd determined that, I narrowed things down with git bisect, and found the above difference in logic in tty_wait_until_sent() by inspection. This change reverts the logic flow in tty_wait_until_sent() to match that prior to the aforementioned commit. Signed-off-by: Cory T. Tusar <ctusar@videon-central.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-07[TTY]: Fix network driver interactions with TCGET/SET calls.Alan Cox
Dave Miller noted various cases where line disciplines for things like ppp go poking around in termios themselves in ways that broke with the new termios code. Rather than have them all learning about termios internals provide proper methods for this - tty_mode_ioctl() This handles all the terminal mode handling for speed/carrier etc and none of the methods are ldisc dependant so they can be called by any user - tty_perform_flush() This extracts the flush functionality and enables pppd the ppp layer to share it cleanly. The existing n_tty_ioctl code is refactored in this patch to provide the new functions and to call them itself appropriately. This patch has no (intended) behaviour changes and simply prepares for the other fixes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18tty_ioctl: fix the baud_table check in encode_baud_rateMaciej W. Rozycki
The tty_termios_encode_baud_rate() function as defined by tty_ioctl.c has a problem with the baud_table within. The comparison operators are reversed and as a result this table's entries never match and BOTHER is always used. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17tty: expose new methods needed for drivers to get termios rightAlan Cox
This adds three new functions (or in one case to be more exact makes it always available) tty_termios_copy_hw Copies all the hardware settings from one termios structure to the other. This is intended for drivers that support little or no hardware setting tty_termios_encode_baud_rate Allows you to set the input and output baud rate in a termios structure. A driver is supposed to set the resulting baud rate from a request so most will want to use this function to set the resulting input and output rates to match the hardware values. Internally it knows about keeping Bxxx encoding when possible to maximise compatibility. tty_encode_baud_rate As above but for the tty's own current termios structure I suspect this will initially need some tweaking as it gets enabled by driver patches over the next few mm cycles so consider this lot -mm only for the moment so it can stabilize and end up neat before it goes to base. I've tried not to break any obscure architectures - if you get a speed you can't represent the code will print warnings on non updated termios systems but not break. Once this is merged and seems sane I've got a growing pile of driver updates to use it - notably for USB serial drivers. [akpm@linux-foundation.org: cleanups] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-15sparc64 (and others): fix tty_ioctl.c buildTony Breeds
Add Guards around TIOCSLCKTRMIOS and TIOCGLCKTRMIOS. Several architectures are still broken. Put temporary-for-2.6.23 ifdef guards around the offending code. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by:: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11tty: termios locking functions break with new termios typeDavid Miller
I ran into a few problems. n_tty_ioctl() for instance: drivers/char/tty_ioctl.c:799: error: $,1rxstruct termios$,1ry has no member named $,1rxc_ispeed$,1ry This is calling the copy interface that is supposed to be using a termios2 when the new interfaces are defined, however: case TIOCGLCKTRMIOS: if (kernel_termios_to_user_termios((struct termios __user *)arg, real_tty->termios_locked)) return -EFAULT; return 0; This is going to write over the end of the userspace structure by a few bytes, and wasn't caught by you yet because the i386 implementation is simply copy_to_user() which does zero type checking. Signed-off-by: Alan Cox <alan@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Char: tty_ioctl, little whitespace cleanupJiri Slaby
tty_ioctl, little whitespace cleanup the point is to make while (++i < n_baud_table); clear and assign it to the do { } loop Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Char: tty_ioctl, use wait_event_interruptible_timeoutJiri Slaby
tty_ioctl, use wait_event_interruptible_timeout Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Prevent an O_NDELAY writer from blocking when a tty write is blocked by the ↵Alan Cox
tty atomic writer mutex Without this a tty write could block if a previous blocking tty write was in progress on the same tty and blocked by a line discipline or hardware event. Originally found and reported by Dave Johnson. Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] tty: improve encode_baud_rate logicAlan Cox
Mostly so people can see the work in progress. This enhances the encode function which isn't currently used in the base tree but is when using some of the testing tty patches. This resolves a problem with some hardware where applications got confusing information from the tty ioctls. Correct but confusing. In some situations asking for, say, 9600 baud actually gets you 9595 baud or similar near-miss values. With the old code this meant that a request for B9600 got a return of BOTHER, 9595 which programs interpreted as a failure. The new code now works on the following basis - If you ask for specific rate via BOTHER, you get a precise return - If you ask for a standard Bfoo rate and the result is close you get a Bfoo return - If you ask for a standard Bfoo rate and get something way off you get a BOTHER/rate return This seems to fix up the cases I've found where this broke compatibility. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty_ioctl: use termios for the old structure and termios2 for the newAlan Cox
Having split out the user and kernel structures it turns out that some non glibc C libraries pull their termios struct from the kernel headers directly or indirectly. This means we must keep "struct termios" as the library sees it correct for the old ioctls. Not a big problem just shuffle the names and ifdef around a bit [akpm@osdl.org: build fix] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermios and new frameworkAlan Cox
This is the core of the switch to the new framework. I've split it from the driver patches which are mostly search/replace and would encourage people to give this one a good hard stare. The references to BOTHER and ISHIFT are the termios values that must be defined by a platform once it wants to turn on "new style" ioctl support. The code patches here ensure that providing 1. The termios overlays the ktermios in memory 2. The only new kernel only fields are c_ispeed/c_ospeed (or none) the existing behaviour is retained. This is true for the patches at this point in time. Future patches will define BOTHER, ISHIFT and enable newer termios structures for each architecture, and once they are all done some of the ifdefs also vanish. [akpm@osdl.org: warning fix] [akpm@osdl.org: IRDA fix] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix locking for tty drivers when doing urgent charactersAlan Cox
If you send a priority character (as is done for flow control) then the tty driver can either have its own method for "jumping the queue" or the characrer can be queued normally. In the latter case we call the write method but without the atomic_write_lock taken elsewhere. Make this consistent. Note that the send_xchar method if implemented remains outside of the lock as it can jump ahead of a current write so must not be locked out by it. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] tty: make termios_sem a mutexArjan van de Ven
[akpm@osdl.org: fix] Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] tty layer comment the locking assumptions and functions somewhatAlan Cox
Doesn't fix them but does show up some interesting areas that need review and fixing. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] coverity: tty_ldisc_ref return null checkKAMBAROV, ZAUR
We add a check of the return value of tty_ldisc_ref(), which is checked 7 out of 8 times, e.g.: 149 ld = tty_ldisc_ref(tty); 150 if (ld != NULL) { 151 if (ld->set_termios) 152 (ld->set_termios)(tty, &old_termios); 153 tty_ldisc_deref(ld); 154 } This defect was found automatically by Coverity Prevent, a static analysis tool. (akpm: presumably `ld' is never NULL. Oh well) Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
